[GRASS-SVN] r71138 - grass/trunk/lib/python/temporal
svn_grass at osgeo.org
Thu May 25 03:03:37 PDT 2017
Author: lucadelu
Date: 2017-05-25 03:03:37 -0700 (Thu, 25 May 2017)
New Revision: 71138
grass/trunk/lib/python/temporal/temporal_granularity.py
temporal library: improved gran_to_gran function to return correctly years and second values
Modified: grass/trunk/lib/python/temporal/temporal_granularity.py
--- grass/trunk/lib/python/temporal/temporal_granularity.py 2017-05-25 08:11:50 UTC (rev 71137)
+++ grass/trunk/lib/python/temporal/temporal_granularity.py 2017-05-25 10:03:37 UTC (rev 71138)
@@ -1115,29 +1115,41 @@
>>> import grass.temporal as tgis
>>> tgis.init()
- >>> tgis.gran_to_gran('1 month', 'days')
+ >>> tgis.gran_to_gran('1 month', '1 day')
'30.436875 days'
- >>> tgis.gran_to_gran('1 month', 'days', True)
+ >>> tgis.gran_to_gran('1 month', '1 day', True)
30.436875
- >>> tgis.gran_to_gran('10 year', 'hour')
- '87658.20000000001 hours'
+ >>> tgis.gran_to_gran('10 year', '1 hour')
+ '87658.2 hours'
- >>> tgis.gran_to_gran('10 year', 'minutes')
- '5259492.000000001 minutes'
+ >>> tgis.gran_to_gran('10 year', '1 minute')
+ '5259492.0 minutes'
- >>> tgis.gran_to_gran('6 months', 'days')
+ >>> tgis.gran_to_gran('6 months', '1 day')
'182.62125 days'
- >>> tgis.gran_to_gran('1 months', 'second')
+ >>> tgis.gran_to_gran('1 months', '1 second')
'2629746.0 seconds'
- >>> tgis.gran_to_gran('1 month', 'seconds', True)
+ >>> tgis.gran_to_gran('1 month', '1 second', True)
2629746.0
+ >>> tgis.gran_to_gran('30 month', '1 month', True)
+ 30
+ def _return(output, tounit, shell):
+ """Fuction to return the output"""
+ if shell:
+ return output
+ else:
+ if output == 1:
+ return "{val} {unit}".format(val=output, unit=tounit)
+ else:
+ return "{val} {unit}s".format(val=output, unit=tounit)
#TODO check the leap second
- msgr = get_tgis_message_interface()
if check_granularity_string(from_gran, 'absolute'):
output, unit = from_gran.split(" ")
if unit in PLURAL_GRAN:
@@ -1147,18 +1159,14 @@
output = ast.literal_eval(output)
for k, v in CONVERT_GRAN.items():
+ if myunit == tounit:
+ return _return(output, tounit, shell)
if k == myunit:
num, myunit = v.split(" ")
output = output * ast.literal_eval(num)
- if myunit == tounit:
- if shell:
- return output
- else:
- if output == 1:
- return "{val} {unit}".format(val=output, unit=tounit)
- else:
- return "{val} {unit}s".format(val=output, unit=tounit)
- msgr.warning(_("Probably you need to invert 'from_gran' and 'to_gran'"))
+ if tounit == 'second' and myunit == tounit:
+ print(_("Probably you need to invert 'from_gran' and 'to_gran'"))
return False
else:
print(_("Invalid absolute granularity"))
