[GRASS-SVN] r71140 - in grass-addons/grass7/temporal: . t.rast.what.aggr
svn_grass at osgeo.org
Thu May 25 04:06:14 PDT 2017
Author: lucadelu
Date: 2017-05-25 04:06:13 -0700 (Thu, 25 May 2017)
New Revision: 71140
Added:
grass-addons/grass7/temporal/t.rast.what.aggr/
grass-addons/grass7/temporal/t.rast.what.aggr/t.rast.what.aggr.py
t.rast.what.aggr.py: added to addons, testsuite and html doc needed
Added: grass-addons/grass7/temporal/t.rast.what.aggr/t.rast.what.aggr.py
--- grass-addons/grass7/temporal/t.rast.what.aggr/t.rast.what.aggr.py (rev 0)
+++ grass-addons/grass7/temporal/t.rast.what.aggr/t.rast.what.aggr.py 2017-05-25 11:06:13 UTC (rev 71140)
@@ -0,0 +1,290 @@
+#!/usr/bin/env python
+# -*- coding: utf-8 -*-
+# MODULE: t.rast.what.aggr
+# AUTHOR(S): Luca Delucchi
+# PURPOSE: Sample a space time raster dataset at specific vector point
+# map returning aggregate values and write the output to stdout
+# or to attribute table
+# COPYRIGHT: (C) 2017 by the GRASS Development Team
+# This program is free software under the GNU General Public
+# License (version 2). Read the file COPYING that comes with GRASS
+# for details.
+#%module
+#% description: Sample a space time raster dataset at specific vector point map returning aggregate values and write the output to stdout or to attribute table
+#% keyword: temporal
+#% keyword: sampling
+#% keyword: raster
+#% keyword: time
+#%end
+#%option G_OPT_V_INPUT
+#%end
+#%option G_OPT_STRDS_INPUT
+#% key: strds
+#%end
+#%option G_OPT_DB_COLUMN
+#% key: date_column
+#% description: Name of the input column containing dates for aggregates
+#% required: no
+#%end
+#%option
+#% key: date
+#% type: string
+#% description: The date for aggregates
+#% required: no
+#% multiple: no
+#%end
+#%option G_OPT_F_OUTPUT
+#% required: no
+#% description: Name for the output file or "-" in case stdout should be used
+#% answer: -
+#%end
+#%option G_OPT_DB_COLUMNS
+#%end
+#%option
+#% key: granularity
+#% type: string
+#% description: Aggregation granularity, format absolute time "x years, x months, x weeks, x days, x hours, x minutes, x seconds" or an integer value for relative time
+#% required: yes
+#% multiple: no
+#%end
+#%option
+#% key: method
+#% type: string
+#% description: Aggregate operation to be performed on the raster maps
+#% required: yes
+#% multiple: yes
+#% options: average,median,mode,minimum,maximum,stddev,sum,variance,quart1,quart3,perc90,quantile
+#% answer: average
+#%end
+#%option G_OPT_F_SEP
+#%end
+#%option
+#% key: nprocs
+#% type: integer
+#% description: Number of processes to run in parallel
+#% required: no
+#% multiple: no
+#% answer: 1
+#%end
+#%option
+#% key: date_format
+#% type: string
+#% description: Tha date format
+#% required: no
+#% answer: %Y-%m-%d
+#%end
+#%flag
+#% key: u
+#% label: Update attribute table of input vector map
+#% description: Instead of creating a new vector map update the attribute table with value(s)
+#%end
+from datetime import datetime
+from datetime import timedelta
+from subprocess import PIPE as PI
+import numpy as np
+from scipy import stats
+import grass.script as gscript
+from grass.exceptions import CalledModuleError
+def return_value(vals, met):
+ """Return the value according the choosen method"""
+ if met == 'average':
+ return vals.mean()
+ elif met == 'median':
+ return np.median(vals)
+ elif met == 'mode':
+ m = stats.mode(vals)
+ return m.mode[0]
+ elif met == 'minimum':
+ return vals.min()
+ elif met == 'maximum':
+ return vals.max()
+ elif met == 'stddev':
+ return vals.std()
+ elif met == 'sum':
+ return vals.sum()
+ elif met == 'variance':
+ return vals.var()
+ elif met == 'quart1':
+ return np.percentile(vals, 25)
+ elif met == 'quart3':
+ return np.percentile(vals, 75)
+ elif met == 'perc90':
+ return np.percentile(vals, 90)
+ elif met == 'quantile':
+ return
+def main(options, flags):
+ import grass.pygrass.modules as pymod
+ import grass.temporal as tgis
+ from grass.pygrass.vector import VectorTopo
+ invect = options["input"]
+ incol = options["date_column"]
+ indate = options["date"]
+ strds = options["strds"]
+ output = options["output"]
+ cols = options["columns"].split(',')
+ mets = options["method"].split(',')
+ gran = options["granularity"]
+ dateformat = options["date_format"]
+ separator = gscript.separator(options["separator"])
+ stdout = False
+ if output != '-' and flags['u']:
+ gscript.fatal(_("Cannot combine 'output' option and 'u' flag"))
+ elif output == '-' and flags['u']:
+ output = invect
+ gscript.warning(_("Attribute table of vector {name} will be updated"
+ "...").format(name=invect))
+ else:
+ stdout = True
+ if output != '-' and len(cols) != len(mets):
+ gscript.fatal(_("'columns' and 'method' options must have the same "
+ "number of elements"))
+ tgis.init()
+ dbif = tgis.SQLDatabaseInterfaceConnection()
+ dbif.connect()
+ sp = tgis.open_old_stds(strds, "strds", dbif)
+ if sp.get_temporal_type() == 'absolute':
+ delta = int(tgis.gran_to_gran(gran, sp.get_granularity(), True))
+ if tgis.gran_singular_unit(gran) in ['year', 'month']:
+ delta = int(tgis.gran_to_gran(gran, '1 day', True))
+ td = timedelta(delta)
+ elif tgis.gran_singular_unit(gran) == 'day':
+ delta = tgis.gran_to_gran(gran, sp.get_granularity(), True)
+ elif tgis.gran_singular_unit(gran) == 'hour':
+ td = timedelta(hours=delta)
+ elif tgis.gran_singular_unit(gran) == 'minute':
+ td = timedelta(minutes=delta)
+ elif tgis.gran_singular_unit(gran) == 'second':
+ td = timedelta(seconds=delta)
+ else:
+ if sp.get_granularity() >= int(gran):
+ gscript.fatal(_("Input granularity is smaller or equal to the {iv}"
+ " STRDS granularity".format(iv=strds)))
+ td = int(gran)
+ if incol and indate:
+ gscript.fatal(_("Cannot combine 'date_column' and 'date' options"))
+ elif not incol and not indate:
+ gscript.fatal(_("You have to fill 'date_column' or 'date' option"))
+ elif incol:
+ try:
+ dates = pymod.Module("db.select", flags='c', stdout_=PI,
+ stderr_=PI, sql="SELECT DISTINCT {dc} from " \
+ "{vmap} order by {dc}".format(vmap=invect,
+ dc=incol))
+ mydates = dates.outputs["stdout"].value.splitlines()
+ except CalledModuleError:
+ gscript.fatal(_("db.select return an error"))
+ elif indate:
+ mydates = [indate]
+ pymap = VectorTopo(invect)
+ pymap.open('r')
+ if len(pymap.dblinks) == 0:
+ try:
+ pymap.close()
+ pymod.Module("v.db.addtable", map=invect)
+ dbif.close()
+ gscript.fatal(_("Unable to add table <%s> to vector map <%s>" % invect))
+ if pymap.is_open():
+ pymap.close()
+ qfeat = pymod.Module("v.category", stdout_=PI, stderr_=PI,
+ input=invect, option='print')
+ myfeats = qfeat.outputs["stdout"].value.splitlines()
+ if stdout:
+ outtxt = ''
+ for data in mydates:
+ fdata = datetime.strptime(data, dateformat)
+ else:
+ fdata = int(data)
+ sdata = fdata - td
+ mwhere="start_time >= '{inn}' and end_time < '{out}'".format(inn=sdata,
+ out=fdata)
+ try:
+ r_what = pymod.Module("t.rast.what", points=invect, strds=strds,
+ layout='timerow', separator=separator,
+ flags="v", where=mwhere, quiet=True,
+ stdout_=PI, stderr_=PI)
+ lines = r_what.outputs["stdout"].value.splitlines()
+ gscript.fatal(_("Problem running 't.rast.what', probably it "
+ "returned an empty dataset"))
+ if incol:
+ try:
+ qfeat = pymod.Module("db.select", flags='c', stdout_=PI,
+ stderr_=PI, sql="SELECT DISTINCT cat from"
+ " {vmap} where {dc}='{da}' order by "
+ "cat".format(vmap=invect, da=data,
+ dc=incol))
+ gscript.fatal(_("db.select returned an error for date "
+ "{da}".format(da=data)))
+ x=0
+ for line in lines:
+ vals = line.split(separator)
+ if vals[0] in myfeats:
+ try:
+ nvals = np.array(vals[4:]).astype(np.float)
+ except ValueError:
+ continue
+ for n in range(len(mets)):
+ result = return_value(nvals, mets[n])
+ if stdout:
+ outtxt += "{di}{sep}{da}{sep}{val}\n".format(di=vals[0],
+ da=data,
+ val=result,
+ sep=separator)
+ else:
+ try:
+ if incol:
+ pymod.Module("v.db.update", map=output,
+ column=cols[n], value=str(result),
+ where="{dc}='{da}' AND cat="
+ "{ca}".format(da=data, ca=vals[0],
+ dc=incol))
+ else:
+ where="cat={ca}".format(ca=vals[0]))
+ gscript.fatal(_("v.db.update return an error"))
+ if x == len(myfeats):
+ break
+ else:
+ x += 1
+ if stdout:
+ print(outtxt)
+if __name__ == "__main__":
+ options, flags = gscript.parser()
+ main(options, flags)
Property changes on: grass-addons/grass7/temporal/t.rast.what.aggr/t.rast.what.aggr.py
___________________________________________________________________
Added: svn:mime-type
+ text/x-python
Added: svn:eol-style
+ native
