[GRASS-SVN] r71142 - grass-addons/grass7/temporal/t.rast.what.aggr
svn_grass at osgeo.org
Fri May 26 02:05:58 PDT 2017
Author: lucadelu
Date: 2017-05-26 02:05:58 -0700 (Fri, 26 May 2017)
New Revision: 71142
grass-addons/grass7/temporal/t.rast.what.aggr/t.rast.what.aggr.py
t.rast.what.aggr: improvement
Modified: grass-addons/grass7/temporal/t.rast.what.aggr/t.rast.what.aggr.py
--- grass-addons/grass7/temporal/t.rast.what.aggr/t.rast.what.aggr.py 2017-05-25 14:10:03 UTC (rev 71141)
+++ grass-addons/grass7/temporal/t.rast.what.aggr/t.rast.what.aggr.py 2017-05-26 09:05:58 UTC (rev 71142)
@@ -142,6 +142,8 @@
from grass.pygrass.vector import VectorTopo
invect = options["input"]
+ if invect.find('@') != -1:
+ invect = invect.split('@')[0]
incol = options["date_column"]
indate = options["date"]
strds = options["strds"]
@@ -211,7 +213,8 @@
pymod.Module("v.db.addtable", map=invect)
except CalledModuleError:
dbif.close()
- gscript.fatal(_("Unable to add table <%s> to vector map <%s>" % invect))
+ gscript.fatal(_("Unable to add table <%s> to vector map "
+ "<%s>" % invect))
if pymap.is_open():
pymap.close()
qfeat = pymod.Module("v.category", stdout_=PI, stderr_=PI,
@@ -229,6 +232,7 @@
mwhere="start_time >= '{inn}' and end_time < '{out}'".format(inn=sdata,
out=fdata)
+ lines = None
try:
r_what = pymod.Module("t.rast.what", points=invect, strds=strds,
layout='timerow', separator=separator,
@@ -236,8 +240,7 @@
stdout_=PI, stderr_=PI)
lines = r_what.outputs["stdout"].value.splitlines()
- gscript.fatal(_("Problem running 't.rast.what', probably it "
- "returned an empty dataset"))
+ pass
if incol:
try:
qfeat = pymod.Module("db.select", flags='c', stdout_=PI,
@@ -249,6 +252,15 @@
gscript.fatal(_("db.select returned an error for date "
"{da}".format(da=data)))
+ if not lines and stdout:
+ for feat in myfeats:
+ outtxt += "{di}{sep}{da}".format(di=feat, da=data,
+ sep=separator)
+ for n in range(len(mets)):
+ outtxt += "{sep}{val}".format(val='*', sep=separator)
+ outtxt += "\n"
+ if not lines:
+ continue
x=0
for line in lines:
vals = line.split(separator)
@@ -256,14 +268,23 @@
try:
nvals = np.array(vals[4:]).astype(np.float)
except ValueError:
+ if stdout:
+ outtxt += "{di}{sep}{da}".format(di=vals[0],
+ da=data,
+ sep=separator)
+ sep=separator)
+ outtxt += "\n"
continue
+ if stdout:
+ outtxt += "{di}{sep}{da}".format(di=vals[0], da=data,
+ sep=separator)
result = return_value(nvals, mets[n])
if stdout:
- outtxt += "{di}{sep}{da}{sep}{val}\n".format(di=vals[0],
- da=data,
- val=result,
- sep=separator)
+ outtxt += "{sep}{val}".format(val=result,
+ sep=separator)
else:
try:
if incol:
@@ -278,6 +299,8 @@
where="cat={ca}".format(ca=vals[0]))
gscript.fatal(_("v.db.update return an error"))
+ if stdout:
+ outtxt += "\n"
if x == len(myfeats):
break
else:
