[GRASS-SVN] r71627 - in grass-addons/grass7/vector/v.clip: . testsuite
Thu Nov 2 08:17:41 PDT 2017
Author: lucadelu
Date: 2017-11-02 08:17:41 -0700 (Thu, 02 Nov 2017)
New Revision: 71627
Added:
   grass-addons/grass7/vector/v.clip/testsuite/
   grass-addons/grass7/vector/v.clip/testsuite/test_v_clip.py
v.clip: added tests
Added: grass-addons/grass7/vector/v.clip/testsuite/test_v_clip.py
--- grass-addons/grass7/vector/v.clip/testsuite/test_v_clip.py	                        (rev 0)
+++ grass-addons/grass7/vector/v.clip/testsuite/test_v_clip.py	2017-11-02 15:17:41 UTC (rev 71627)
@@ -0,0 +1,87 @@
+Name:       v.clip test
+Purpose:    Tests v.clip input parsing.
+            Uses NC Basic data set.
+Author:     Luca Delucchi
+Copyright:  (C) 2017 by Luca Delucchi and the GRASS Development Team
+Licence:    This program is free software under the GNU General Public
+            License (>=v2). Read the file COPYING that comes with GRASS
+            for details.
+import os
+from grass.gunittest.case import TestCase
+from grass.gunittest.main import test
+class TestClipling(TestCase):
+    inpclip = 'zipcodes'
+    inpoint = 'hospitals'
+    inlines = 'roadsmajor'
+    inpoly = 'geology'
+    outreg = 'hospreg'
+    outclip = 'hospzip'
+    outline = 'roadsgarner'
+    outpoly = 'geogarner'
+    outdiss = 'geodiss'
+    garner = 'garner'
+    @classmethod
+    def setUpClass(cls):
+        """Ensures expected computational region and generated data"""
+        cls.use_temp_region()
+        cls.runModule('g.region', vector=cls.inpclip)
+        cls.runModule('v.extract', input=cls.inpclip, output=cls.garner,
+                      where="ZIPNAME = '{na}'".format(na=cls.garner.upper()))
+    @classmethod
+    def tearDownClass(cls):
+        """Remove the temporary region and generated data"""
+        cls.runModule('g.remove', flags='f', type='vector',
+                      name=(cls.outclip, cls.outreg, cls.garner, cls.outline,
+                            cls.outpoly, cls.outdiss))
+        cls.del_temp_region()
+    def test_points(self):
+        """Test clipping points"""
+        self.assertModule('v.clip', input=self.inpoint, clip=self.inpclip,
+                          output=self.outclip)
+        self.assertVectorExists(self.outclip)
+        topology = dict(points=8)
+        self.assertVectorFitsTopoInfo(self.outclip, topology)
+    def test_region(self):
+        """Test clipping point by region"""
+                          output=self.outreg, flags='r')
+        self.assertVectorExists(self.outreg)
+        topology = dict(points=13)
+        self.assertVectorFitsTopoInfo(self.outreg, topology)
+    def test_lines(self):
+        """Test clipping lines"""
+        self.assertModule('v.clip', input=self.inlines, clip=self.garner,
+                          output=self.outline)
+        self.assertVectorExists(self.outline)
+        topology = dict(lines=13, nodes=16)
+        self.assertVectorFitsTopoInfo(self.outline, topology)
+    def test_poly(self):
+        """Test clipping polygon without dissolve"""
+        self.assertModule('v.clip', input=self.inpoly, clip=self.inpclip,
+                          output=self.outpoly)
+        self.assertVectorExists(self.outpoly)
+        topology = dict(areas=275)
+        self.assertVectorFitsTopoInfo(self.outpoly, topology)
+    def test_poly_diss(self):
+                          output=self.outdiss, flags='d')
+        self.assertVectorExists(self.outdiss)
+        topology = dict(areas=276)
+        self.assertVectorFitsTopoInfo(self.outdiss, topology)
+if __name__ == '__main__':
+    test()
Property changes on: grass-addons/grass7/vector/v.clip/testsuite/test_v_clip.py
___________________________________________________________________
Added: svn:mime-type
   + text/x-python
Added: svn:eol-style
   + native
