[GRASS-SVN] r71639 - in grass-addons/grass7/raster: . r.patch.smooth
svn_grass at osgeo.org
Sat Nov 4 19:33:11 PDT 2017
Author: annakrat
Date: 2017-11-04 19:33:10 -0700 (Sat, 04 Nov 2017)
New Revision: 71639
Added:
grass-addons/grass7/raster/r.patch.smooth/
grass-addons/grass7/raster/r.patch.smooth/Makefile
grass-addons/grass7/raster/r.patch.smooth/r.patch.smooth.html
grass-addons/grass7/raster/r.patch.smooth/r.patch.smooth.py
grass-addons/grass7/raster/r.patch.smooth/r_patch_smooth_overview.png
grass-addons/grass7/raster/r.patch.smooth/r_patch_smooth_parallel_smoothing.png
grass-addons/grass7/raster/Makefile
add r.patch.smooth to addons
Modified: grass-addons/grass7/raster/Makefile
--- grass-addons/grass7/raster/Makefile 2017-11-05 01:49:33 UTC (rev 71638)
+++ grass-addons/grass7/raster/Makefile 2017-11-05 02:33:10 UTC (rev 71639)
@@ -82,6 +82,7 @@
r.out.legend \
r.out.ntv2 \
r.out.tiff \
+ r.patch.smooth \
r.popgrowth \
r.quantile.ref \
r.random.weight \
Added: grass-addons/grass7/raster/r.patch.smooth/Makefile
--- grass-addons/grass7/raster/r.patch.smooth/Makefile (rev 0)
+++ grass-addons/grass7/raster/r.patch.smooth/Makefile 2017-11-05 02:33:10 UTC (rev 71639)
@@ -0,0 +1,7 @@
+MODULE_TOPDIR = ../..
+PGM = r.patch.smooth
+include $(MODULE_TOPDIR)/include/Make/Script.make
+default: script
Property changes on: grass-addons/grass7/raster/r.patch.smooth/Makefile
___________________________________________________________________
Added: svn:mime-type
+ text/x-makefile
Added: svn:eol-style
+ native
Added: grass-addons/grass7/raster/r.patch.smooth/r.patch.smooth.html
--- grass-addons/grass7/raster/r.patch.smooth/r.patch.smooth.html (rev 0)
+++ grass-addons/grass7/raster/r.patch.smooth/r.patch.smooth.html 2017-11-05 02:33:10 UTC (rev 71639)
@@ -0,0 +1,67 @@
+<h2>DESCRIPTION</h2>
+Module fuses rasters representing elevation together by patching them and smoothing
+values along edges using either fixed or spatially variable overlap width.
+Spatially variable overlap width is given by the difference
+along the edge between the two rasters. Higher difference results in larger overlap width
+to smooth the transition.
+<p>
+r.patch.smooth can be used, for example, for updating older, lower resolution
+DEM (<b>input_b</b>) with newer, higher resolution DEM (<b>input_a</b>).
+Note that both DEMs must be aligned and have the same resolution.
+Smoothing uses weighted averaging on the overlap of the rasters.
+r.patch.smooth supports 2 types of smoothing. The default one is
+simpler and uses fixed overlap width defined in <b>smooth_dist</b>.
+Since the differences along the seam line can vary,
+the second option uses spatially variable overlap width and can be activated with flag <b>-s</b>.
+The width is then computed based on the elevation differences along the edge and
+transition angle <b>transition_angle</b> controlling the steepness of the transition.
+If option <b>overlap</b> is specified, a map representing the spatially variable overlap
+is created and can be used for inspecting the fusion results.
+<center>
+<img src="r_patch_smooth_overview.png" width=600 border=0><br>
+Difference between fixed overlap width and spatially variable overlap.
+</center>
+<p>
+For spatially variable overlap, options <b>parallel_smoothing</b>
+and <b>difference_reach</b> can be specified.
+Option <b>parallel_smoothing</b> smoothes the overlap zone in direction
+parallel to the edge.
+Option <b>difference_reach</b> enables to increase the sensitivity to higher
+differences on the edges by taking maximum difference values in the cells
+close to edges.
+<center>
+<img src="r_patch_smooth_parallel_smoothing.png" border=0><br>
+Effect of <b>parallel_smoothing</b> option shown on overlap zone (created by specifying <b>overlap</b> option).
+Image A shows result with value 3 and B with value 9.
+</center>
+<p>
+Option <b>blend_mask</b> (experimental) can be used to specify which edges of
+the input_a DEM should be excluded from the blending. This is useful when
+DEMs A and B have identical edges (on the coast, for example) and we want
+to preserve only A (not blend it with B along the coast).
+The <b>blend_mask</b> raster can be created by digitizing area approximately around the excluded edges,
+so that the edge of DEM A is inside the areas and the rest are NULLs.
+This option requires more testing.
+<h2>SEE ALSO</h2>
+<a href="r.patch.html">r.patch</a>,
+<a href="r.mapcalc.html">r.mapcalc</a>,
+<a href="r.grow.distance.html">r.grow.distance</a>
+<h2>REFERENCES</h2>
+Anna Petrasova, Helena Mitasova, Vaclav Petras, Justyna Jeziorska.
+<a href="https://link.springer.com/article/10.1186/s40965-017-0019-2">
+Fusion of high-resolution DEMs for water flow modeling</a> (2017).
+Open Geospatial Data, Software and Standards.
+2: 6. <a href="https://doi.org/10.1186/s40965-017-0019-2">DOI: 10.1186/s40965-017-0019-2</a>
+<h2>AUTHOR</h2>
+Anna Petrasova, <a href="http://geospatial.ncsu.edu/osgeorel/">NCSU OSGeoREL</a><br>
+<p><i>Last changed: $Date$</i>
Property changes on: grass-addons/grass7/raster/r.patch.smooth/r.patch.smooth.html
+ text/html
Added: svn:keywords
+ Author Date Id
+ native
Added: grass-addons/grass7/raster/r.patch.smooth/r.patch.smooth.py
--- grass-addons/grass7/raster/r.patch.smooth/r.patch.smooth.py (rev 0)
+++ grass-addons/grass7/raster/r.patch.smooth/r.patch.smooth.py 2017-11-05 02:33:10 UTC (rev 71639)
@@ -0,0 +1,199 @@
+#!/usr/bin/env python
+# -*- coding: utf-8 -*-
+# MODULE: r.patch.smooth
+# AUTHOR(S): Anna Petrasova (kratochanna gmail.com)
+# PURPOSE: Patch raster and smooth along edges
+# COPYRIGHT: (C) 2015 by the GRASS Development Team
+# This program is free software under the GNU General Public
+# License (>=v2). Read the file COPYING that comes with GRASS
+# for details.
+#%module
+#% description: Module for patching rasters with smoothing along edges
+#% keyword: raster
+#% keyword: patch
+#%end
+#%option G_OPT_R_INPUT
+#% key: input_a
+#% label: Name for input raster map A
+#%end
+#% key: input_b
+#% label: Name for input raster map B
+#%end
+#%option G_OPT_R_OUTPUT
+#%end
+#% key: overlap
+#% label: Name for raster map of spatially variable overlap
+#% required: no
+#%end
+#%option
+#% type: string
+#% key: blend_mask
+#% label: Raster containing edge of raster A which is not to be blended
+#% description: Useful when raster A has common edge with raster B
+#% required: no
+#% guisection: Settings
+#%end
+#%option
+#% type: double
+#% key: smooth_dist
+#% description: Smoothing distance in map units
+#% required: no
+#%end
+#%option
+#% type: double
+#% key: transition_angle
+#% label: Angle of transition for spatially variable overlap
+#% description: Recommended values between 1 and 5 degrees
+#% required: no
+#%end
+#%option
+#% type: integer
+#% key: parallel_smoothing
+#% label: Size of smoothing window for smoothing edges of spatially variable overlap zone
+#% description: Small value results in more rugged shape of the overlap zone, large values result in spatially non-variable overlap zone. Requires odd values.
+#% answer: 9
+#% options: 3-99
+#% required: no
+#%end
+#%option
+#% type: integer
+#% key: difference_reach
+#% label: Look for maximum difference between surfaces in surrounding n cells from the edge
+#% description: Recommended values between 3 and 9
+#% answer: 3
+#% options: 2-100
+#% required: no
+#%end
+#%flag
+#% key: s
+#% description: Use spatially variable overlap
+#%end
+#%rules
+#% collective: -s,transition_angle
+#% exclusive: transition_angle,smooth_dist
+#% required: -s,smooth_dist
+#% excludes: smooth_dist,overlap
+#%end
+import os
+import sys
+import atexit
+import grass.script as gscript
+TMP = []
+def cleanup():
+ gscript.run_command('g.remove', flags='f', type=['raster', 'vector'], name=TMP, quiet=True)
+def main():
+ input_A = options['input_a']
+ input_B = options['input_b']
+ output = options['output']
+ overlap = options['overlap']
+ smooth_dist = options['smooth_dist']
+ angle = options['transition_angle']
+ blend_mask = options['blend_mask']
+ simple = not flags['s']
+ # smooth values of closest difference
+ smooth_closest_difference_size = int(options['parallel_smoothing'])
+ if smooth_closest_difference_size % 2 == 0:
+ gscript.fatal(_("Option 'parallel_smoothing' requires odd number"))
+ difference_reach = int(options['difference_reach'])
+ postfix = str(os.getpid())
+ tmp_absdiff = "tmp_absdiff_" + postfix
+ tmp_absdiff_smooth = "tmp_absdiff_smooth" + postfix
+ tmp_grow = "tmp_grow" + postfix
+ tmp_diff_overlap_1px = "tmp_diff_overlap_1px" + postfix
+ tmp_value = "tmp_value" + postfix
+ tmp_value_smooth = "tmp_value_smooth" + postfix
+ tmp_stretch_dist = "tmp_stretch_dist" + postfix
+ tmp_overlap = "tmp_overlap" + postfix
+ TMP.extend([tmp_absdiff, tmp_absdiff_smooth, tmp_grow, tmp_diff_overlap_1px, tmp_value, tmp_value_smooth, tmp_stretch_dist, tmp_overlap])
+ gscript.run_command('r.grow.distance', flags='n', input=input_A, distance=tmp_grow)
+ if simple and blend_mask:
+ tmp_mask1 = "tmp_mask1"
+ tmp_mask2 = "tmp_mask2"
+ tmp_mask3 = "tmp_mask3"
+ tmp_mask4 = "tmp_mask4"
+ TMP.extend([tmp_mask1, tmp_mask2, tmp_mask3, tmp_mask4])
+ # derive 1-pixel wide edge of A inside of the provided mask
+ gscript.mapcalc("{new} = if ({dist} > 0 && {dist} <= 1.5*nsres() && ! isnull({blend_mask}), 1, null())".format(new=tmp_mask1, dist=tmp_grow, blend_mask=blend_mask))
+ # create buffer around it
+ gscript.run_command('r.grow', input=tmp_mask1, output=tmp_mask2, flags='m', radius=smooth_dist, old=1, new=1)
+ # patch the buffer and A
+ gscript.mapcalc("{new} = if(! isnull({mask2}) || ! isnull({A}), 1, null())".format(A=input_A, mask2=tmp_mask2, new=tmp_mask3))
+ # inner grow
+ gscript.run_command('r.grow.distance', flags='n', input=tmp_mask3, distance=tmp_mask4)
+ # replace the distance inside the buffered area with 0
+ gscript.mapcalc('{new} = if(! isnull({A}), {m4}, 0)'.format(new=tmp_grow, A=input_A, m4=tmp_mask4), overwrite=True)
+ if simple:
+ gscript.mapcalc("{out} = if({grow} > {smooth}, {A}, if({grow} == 0, {B},"
+ "if (isnull({B}) && ! isnull({A}), {A},"
+ "(1 - {grow}/{smooth}) * {B} + ({grow}/{smooth} * {A}))))".format(out=output, grow=tmp_grow,
+ smooth=smooth_dist, A=input_A, B=input_B))
+ return
+ # difference
+ gscript.mapcalc("{new} = abs({A} - {B})".format(new=tmp_absdiff, A=input_A, B=input_B))
+ # take maximum difference from near cells
+ difference_reach = (difference_reach - 1) * 2 + 1
+ gscript.run_command('r.neighbors', flags='c', input=tmp_absdiff, output=tmp_absdiff_smooth, method='maximum', size=difference_reach)
+ # closest value of difference
+ if blend_mask:
+ # set the edge pixels to almost 0 where the mask is, results in no blending
+ gscript.mapcalc("{new} = if ({dist} > 0 && {dist} <= 1.5*nsres(), if(isnull({blend_mask}), {diff}, 0.00001), null())".format(new=tmp_diff_overlap_1px,
+ dist=tmp_grow, diff=tmp_absdiff_smooth, blend_mask=blend_mask))
+ else:
+ gscript.mapcalc("{new} = if ({dist} > 0 && {dist} <= 1.5*nsres(), {diff}, null())".format(new=tmp_diff_overlap_1px,
+ dist=tmp_grow, diff=tmp_absdiff_smooth))
+ gscript.run_command('r.grow.distance', input=tmp_diff_overlap_1px, value=tmp_value)
+ # smooth closest value
+ gscript.run_command('r.neighbors', flags='c', input=tmp_value, output=tmp_value_smooth, method='average',
+ size=smooth_closest_difference_size)
+ # stretch 10cm height difference per 5 meters
+ gscript.mapcalc("{stretch} = {value}/tan({alpha})".format(stretch=tmp_stretch_dist, value=tmp_value_smooth, alpha=angle))
+ # spatially variable overlap width s
+ gscript.mapcalc("{s} = if (isnull({B}) && ! isnull({A}), 1, {dist} / {stretch})".format(s=tmp_overlap, B=input_B,
+ A=input_A, dist=tmp_grow, stretch=tmp_stretch_dist))
+ # fusion
+ gscript.mapcalc("{fused} = if({s} >= 1, {A} , if({s} == 0, {B}, (1 - {s}) * {B} + {A} * {s}))".format(fused=output, s=tmp_overlap,
+ B=input_B, A=input_A))
+ # visualize overlap
+ if overlap:
+ gscript.mapcalc("{s_trim} = if ({s}>=1, null(), if({s}<=0, null(), {s}))".format(s_trim=overlap, s=tmp_overlap))
+if __name__ == "__main__":
+ options, flags = gscript.parser()
+ atexit.register(cleanup)
+ sys.exit(main())
Property changes on: grass-addons/grass7/raster/r.patch.smooth/r.patch.smooth.py
+ text/x-python
+ native
Added: grass-addons/grass7/raster/r.patch.smooth/r_patch_smooth_overview.png
(Binary files differ)
Property changes on: grass-addons/grass7/raster/r.patch.smooth/r_patch_smooth_overview.png
+ image/png
Added: grass-addons/grass7/raster/r.patch.smooth/r_patch_smooth_parallel_smoothing.png
Property changes on: grass-addons/grass7/raster/r.patch.smooth/r_patch_smooth_parallel_smoothing.png
+ image/png
