[GRASS-SVN] r71641 - grass/trunk/vector/v.profile
svn_grass at osgeo.org
Mon Nov 6 03:59:34 PST 2017
Author: marisn
Date: 2017-11-06 03:59:34 -0800 (Mon, 06 Nov 2017)
New Revision: 71641
Removed:
grass/trunk/vector/v.profile/README
v.profile: Remove README file as it is useless now.
Deleted: grass/trunk/vector/v.profile/README
--- grass/trunk/vector/v.profile/README 2017-11-05 12:22:34 UTC (rev 71640)
+++ grass/trunk/vector/v.profile/README 2017-11-06 11:59:34 UTC (rev 71641)
@@ -1,13 +0,0 @@
-Vector point/line profiling tool. See v.profile.html file for full description.
-v.profile requires GRASS 7
-To install v.profile, one needs to provide MODULE_TOPDIR variable for make command (MODULE_TOPDIR=/path/to/GRASS) or change MODULE_TOPDIR in supplied MAKE file to point to GRASS source base. If GRASS source is located in /home/user/soft/grass-7.0, then set MODULE_TOPDIR to /home/user/soft/grass-7.0. Before compiling this module, it's required to configure GRASS (it must have include/Make/Module.make file).
-Short version:
-svn co https://svn.osgeo.org/grass/grass-addons/grass7/vector/v.profile v.profile
-cd v.profile
-#nano Makefile # alternative - edit MODULE_TOPDIR setting
-MODULE_TOPDIR='/path/to/grass-source' make
-make install
