[GRASS-SVN] r71645 - grass-addons/grass7/vector/v.gsflow.grid
    svn_grass at osgeo.org
    Wed Nov  8 06:53:21 PST 2017
Author: awickert
Date: 2017-11-08 06:53:21 -0800 (Wed, 08 Nov 2017)
New Revision: 71645
   grass-addons/grass7/vector/v.gsflow.grid/v.gsflow.grid.html
   grass-addons/grass7/vector/v.gsflow.grid/v.gsflow.grid.py
v.gsflow.grid: + boundary condition cell, - topography (r.gsflow.hydrodem)
Modified: grass-addons/grass7/vector/v.gsflow.grid/v.gsflow.grid.html
--- grass-addons/grass7/vector/v.gsflow.grid/v.gsflow.grid.html	2017-11-08 14:51:49 UTC (rev 71644)
+++ grass-addons/grass7/vector/v.gsflow.grid/v.gsflow.grid.html	2017-11-08 14:53:21 UTC (rev 71645)
@@ -1,6 +1,6 @@
 <h2>DESCRIPTION</h2>
-<em>v.gsflow.grid</em> generates the MODFLOW grid and associated supporting basin mask and topography files that are used for the USGS combined groundwater (MODFLOW) and surface-water (PRMS) model GSFLOW.
+<em>v.gsflow.grid</em> generates the MODFLOW grid and associated basin mask that are used for the USGS combined groundwater (MODFLOW) and surface-water (PRMS) model GSFLOW.
 <h2>REFERENCES</h2>
@@ -17,6 +17,7 @@
 <a href="v.gsflow.hruparams">v.gsflow.hruparams</a>
 <a href="v.gsflow.reaches">v.gsflow.reaches</a>
 <a href="v.gsflow.segments">v.gsflow.segments</a>
+<a href="r.gsflow.hydrodem">r.gsflow.hydrodem</a>
 <a href="v.stream.inbasin">v.stream.inbasin</a>
 <a href="v.stream.network">v.stream.network</a>
Modified: grass-addons/grass7/vector/v.gsflow.grid/v.gsflow.grid.py
--- grass-addons/grass7/vector/v.gsflow.grid/v.gsflow.grid.py	2017-11-08 14:51:49 UTC (rev 71644)
+++ grass-addons/grass7/vector/v.gsflow.grid/v.gsflow.grid.py	2017-11-08 14:53:21 UTC (rev 71645)
@@ -1,7 +1,7 @@
 #!/usr/bin/env python
-# MODULE:       v.gsflow.reaches
+# MODULE:       v.gsflow.grid
 # AUTHOR(S):    Andrew Wickert
@@ -41,6 +41,12 @@
 #%  required: yes
 #%end
+#%option G_OPT_R_INPUT
+#%  key: raster_input
+#%  label: Raster to be resampled to grid resolution
+#%  required: no
+#%end
 #%option
 #%  key: dx
 #%  label: Cell size suggestion (x / E / zonal), map units: rounds to DEM
@@ -61,10 +67,16 @@
 #%option G_OPT_R_OUTPUT
 #%  key: mask_output
-#%  label: Basin mask: inside (1) or outside (0) the watershed?
+#%  label: Raster basin mask: inside (1) or outside (0) the watershed?
 #%  required: no
 #%end
+#%option G_OPT_V_OUTPUT
+#%  key: bc_cell
+#%  label: Constant-head boundary condition cell
+#%  required: yes
+#%end
 # IMPORT MODULES #
@@ -95,14 +107,25 @@
     Builds a grid for the MODFLOW component of the USGS hydrologic model,
     GSFLOW.
     options, flags = gscript.parser()
     basin = options['basin']
+    pp = options['pour_point']
+    raster_input = options['raster_input']
     dx = options['dx']
     dy = options['dy']
     grid = options['output']
     mask = options['mask_output']
-    pp = options['pour_point']
+    bc_cell = options['bc_cell']
+    # basin='basins_tmp_onebasin'; pp='pp_tmp'; raster_input='DEM'; raster_output='DEM_coarse'; dx=dy='500'; grid='grid_tmp'; mask='mask_tmp'
+    # Fatal if raster input and output are not both set
+    _lena0 = (len(raster_input) == 0)
+    _lenb0 = (len(raster_output) == 0)
+    if _lena0 + _lenb0 == 1:
+        grass.fatal("You must set both raster input and output, or neither.")
     # Create grid -- overlaps DEM, one cell of padding
     gscript.use_temp_region()
@@ -115,19 +138,19 @@
     grid_ratio_ns = np.round(regnew['nsres']/reg['nsres'])
     grid_ratio_ew = np.round(regnew['ewres']/reg['ewres'])
     # Get S, W, and then move the unit number of grid cells over to get N and E
-    # and include 1 (new) cell of padding around the whole watershed
-    _s_dist = np.abs(reg_grid_edges_sn - (regnew['s'] - 2.*regnew['nsres']) )
+    # and include 3 cells of padding around the whole watershed
+    _s_dist = np.abs(reg_grid_edges_sn - (regnew['s'] - 3.*regnew['nsres']) )
     _s_idx = np.where(_s_dist == np.min(_s_dist))[0][0]
     _s = float(reg_grid_edges_sn[_s_idx])
-    _n_grid = np.arange(_s, reg['n'] + 2*grid_ratio_ns*reg['nsres'], grid_ratio_ns*reg['nsres'])
-    _n_dist = np.abs(_n_grid - (regnew['n'] + 2.*regnew['nsres']))
+    _n_grid = np.arange(_s, reg['n'] + 3*grid_ratio_ns*reg['nsres'], grid_ratio_ns*reg['nsres'])
+    _n_dist = np.abs(_n_grid - (regnew['n'] + 3.*regnew['nsres']))
     _n_idx = np.where(_n_dist == np.min(_n_dist))[0][0]
     _n = float(_n_grid[_n_idx])
-    _w_dist = np.abs(reg_grid_edges_we - (regnew['w'] - 2.*regnew['ewres']))
+    _w_dist = np.abs(reg_grid_edges_we - (regnew['w'] - 3.*regnew['ewres']))
     _w_idx = np.where(_w_dist == np.min(_w_dist))[0][0]
     _w = float(reg_grid_edges_we[_w_idx])
-    _e_grid = np.arange(_w, reg['e'] + 2*grid_ratio_ew*reg['ewres'], grid_ratio_ew*reg['ewres'])
-    _e_dist = np.abs(_e_grid - (regnew['e'] + 2.*regnew['ewres']))
+    _e_grid = np.arange(_w, reg['e'] + 3*grid_ratio_ew*reg['ewres'], grid_ratio_ew*reg['ewres'])
+    _e_dist = np.abs(_e_grid - (regnew['e'] + 3.*regnew['ewres']))
     _e_idx = np.where(_e_dist == np.min(_e_dist))[0][0]
     _e = float(_e_grid[_e_idx])
     # Finally make the region
@@ -162,8 +185,21 @@
     # Basin mask
     if len(mask) > 0:
-        v.to_rast(input=basin, output=mask, use='val', value=1, quiet=True)
+        # Fine resolution region:
+        g.region(n=reg['n'], s=reg['s'], w=reg['w'], e=reg['e'], nsres=reg['nsres'], ewres=reg['ewres'])
+        # Rasterize basin
+        v.to_rast(input=basin, output=mask, use='val', value=1, overwrite=gscript.overwrite(), quiet=True)
+        # Coarse resolution region:
+        g.region(w=str(_w), e=str(_e), s=str(_s), n=str(_n), nsres=str(grid_ratio_ns*reg['nsres']), ewres=str(grid_ratio_ew*reg['ewres']))
+        r.resamp_stats(input=mask, output=mask, method='sum', overwrite=True, quiet=True)
+        r.mapcalc(mask+' = '+mask+' > 0', overwrite=True, quiet=True)
+    # Resampled raster
+    if len(raster_output) > 0:
+        r.resamp_stats(input=raster_input, output=raster_output, method='average', overwrite=gscript.overwrite(), quiet=True)
     # Pour point
     if len(pp) > 0:
         v.db_addcolumn(map=pp, columns=('row integer','col integer'), quiet=True)
@@ -171,6 +207,28 @@
         v.what_vect(map=pp, query_map=grid, column='row', query_column='row', quiet=True)
         v.what_vect(map=pp, query_map=grid, column='col', query_column='col', quiet=True)
+    # Next point downstream of the pour point
+    if len(bc_cell) > 0:
+        ########## NEED TO USE TRUE TEMPORARY FILE ##########
+        # May not work with dx != dy!
+        v.to_rast(input=pp, output='tmp', use='val', value=1, overwrite=True)
+        r.buffer(input='tmp', output='tmp', distances=float(dx)*1.5, overwrite=True)
+        r.mapcalc('tmp = (tmp == 2) * '+raster_input, overwrite=True)
+        #r.mapcalc('tmp = if(isnull('+raster_input+',0,(tmp == 2)))', overwrite=True)
+        #g.region(rast='tmp')
+        #r.null(map=raster_input,
+        r.drain(input=raster_input, start_points=pp, output='tmp2', overwrite=True)
+        r.mapcalc('tmp = tmp2 * tmp', overwrite=True)
+        r.null(map='tmp', setnull=0)
+        r.to_vect(input='tmp', output=bc_cell, type='point', column='z',
+                  overwrite=gscript.overwrite(), quiet=True)
+        v.db_addcolumn(map=bc_cell, columns=('row integer','col integer'), quiet=True)
+        v.build(map=bc_cell, quiet=True)
+        v.what_vect(map=bc_cell, query_map=grid, column='row', \
+                    query_column='row', quiet=True)
+        v.what_vect(map=bc_cell, query_map=grid, column='col', \
+                    query_column='col', quiet=True)
