[GRASS-SVN] r71647 - grass-addons/grass7/vector/v.stream.inbasin
Wed Nov 8 06:57:59 PST 2017
Author: awickert
Date: 2017-11-08 06:57:59 -0800 (Wed, 08 Nov 2017)
New Revision: 71647
   grass-addons/grass7/vector/v.stream.inbasin/v.stream.inbasin.py
v.stream.inbasin: generation of outlet pour point; selection of downstream-most
segment by user-defined approximate x,y position of pour point so all values
can be defined before running the code (i.e. instead of needing to look up
the stream segment cat at the downstream-most site)
Modified: grass-addons/grass7/vector/v.stream.inbasin/v.stream.inbasin.py
--- grass-addons/grass7/vector/v.stream.inbasin/v.stream.inbasin.py	2017-11-08 14:54:44 UTC (rev 71646)
+++ grass-addons/grass7/vector/v.stream.inbasin/v.stream.inbasin.py	2017-11-08 14:57:59 UTC (rev 71647)
@@ -46,10 +46,24 @@
 #%option
 #%  key: cat
 #%  label: Farthest downstream segment category
-#%  required: yes
+#%  required: no
 #%  guidependency: layer,column
 #%end
+#%option
+#%  key: x_outlet
+#%  label: Approx. pour point x/Easting: will find closest segment
+#%  required: no
+#%  guidependency: layer,column
+#%end
+#%option
+#%  key: y_outlet
+#%  label: Approx. pour point y/Northing: will find closest segment
+#%  required: no
+#%end
 #%option G_OPT_V_OUTPUT
 #%  key: output_basin
 #%  label: Vector output drainage basin
@@ -105,19 +119,52 @@
     network by referencing its category (cat) number in a new column. "0"
     means that the river exits the map.
     options, flags = gscript.parser()
     streams = options['input_streams']
     basins = options['input_basins']
-    cat = options['cat']
+    downstream_cat = options['cat']
+    x_outlet = float(options['x_outlet'])
+    y_outlet = float(options['y_outlet'])
     output_basins = options['output_basin']
     output_streams = options['output_streams']
     output_pour_point = options['output_pour_point']
     #print options
     #print flags
+    # Check that either x,y or cat are set
+    if (downstream_cat != '') or ((x_outlet != '') and (y_outlet != '')):
+        pass
+    else:
+        gscript.fatal('You must set either "cat" or "x_outlet" and "y_outlet".')
+    # NEED TO ADD IF-STATEMENT HERE TO AVOID AUTOMATIC OVERWRITING!!!!!!!!!!!
+    if downstream_cat == '':
+        # Need to find outlet pour point -- start by creating a point at this
+        # location to use with v.distance
+        try:
+            v.db_droptable(table='tmp', flags='f')
+        except:
+            pass
+        tmp = vector.Vector('tmp')
+        _cols = [(u'cat',       'INTEGER PRIMARY KEY'),
+                 (u'x',         'DOUBLE PRECISION'),
+                 (u'y',         'DOUBLE PRECISION'),
+                 (u'strcat',    'DOUBLE PRECISION')]
+        tmp.open('w', tab_name='tmp', tab_cols=_cols)
+        point0 = Point(x_outlet,y_outlet)
+        tmp.write(point0, cat=1, attrs=(str(x_outlet), str(y_outlet), 0), )
+        tmp.table.conn.commit()
+        tmp.build()
+        tmp.close()
+        # Now v.distance
+        gscript.run_command('v.distance', from_='tmp', to=streams, upload='cat', column='strcat')
+        #v.distance(_from_='tmp', to=streams, upload='cat', column='strcat')
+        downstream_cat = gscript.vector_db_select(map='tmp', columns='strcat')
+        downstream_cat = int(downstream_cat['values'].values()[0][0])
     # Attributes of streams
     colNames = np.array(vector_db_select(streams)['columns'])
     colValues = np.array(vector_db_select(streams)['values'].values())
@@ -125,8 +172,8 @@
     cats = colValues[:,colNames == 'cat'].astype(int).squeeze() # = "fromstream"
     # Find network
-    basincats = [cat] # start here
-    most_upstream_cats = [cat] # all of those for which new cats must be sought
+    basincats = [downstream_cat] # start here
+    most_upstream_cats = [downstream_cat] # all of those for which new cats must be sought
     while True:
         if len(most_upstream_cats) == 0:
             break
@@ -147,8 +194,10 @@
         v.extract(input=basins, output=output_basins, where=SQL_OR, overwrite=gscript.overwrite(), quiet=True)
     if len(streams) > 0:
         v.extract(input=streams, output=output_streams, cats=basincats_str, overwrite=gscript.overwrite(), quiet=True)
+    # If we want to output the pour point location
     if len(output_pour_point) > 0:
-        _pp = gscript.vector_db_select(map=streams, columns='x2,y2', where='cat='+str(cat))
+        _pp = gscript.vector_db_select(map=streams, columns='x2,y2', where='cat='+str(downstream_cat))
         _xy = np.squeeze(_pp['values'].values())
         _x = float(_xy[0])
         _y = float(_xy[1])
