[GRASS-SVN] r71655 - grass-addons/grass7/raster/r.object.geometry
Fri Nov 10 07:23:51 PST 2017
Author: mlennert
Date: 2017-11-10 07:23:51 -0800 (Fri, 10 Nov 2017)
New Revision: 71655
   grass-addons/grass7/raster/r.object.geometry/r.object.geometry.html
r.object.geometry: add hint about when to use -m flag
Modified: grass-addons/grass7/raster/r.object.geometry/r.object.geometry.html
--- grass-addons/grass7/raster/r.object.geometry/r.object.geometry.html	2017-11-10 15:19:57 UTC (rev 71654)
+++ grass-addons/grass7/raster/r.object.geometry/r.object.geometry.html	2017-11-10 15:23:51 UTC (rev 71655)
@@ -10,7 +10,8 @@
 <p>
 By default, values are in pixels. If values in meters is desired, the user
-can set the <b>-m</b> flag.
+can set the <b>-m</b> flag. If the current working region is in lat-long or
+has non-square pixels, using meters is recommended.
 <p>
 Statistics currently calculated are exactly the same as in
