[GRASS-SVN] r71681 - grass/trunk/raster/r.viewshed
Sun Nov 12 03:02:39 PST 2017
Author: mmetz
Date: 2017-11-12 03:02:39 -0800 (Sun, 12 Nov 2017)
New Revision: 71681
   grass/trunk/raster/r.viewshed/grass.cpp
   grass/trunk/raster/r.viewshed/grass.h
   grass/trunk/raster/r.viewshed/visibility.cpp
r.viewshed: fix binary output for external memory mode (#1788)
Modified: grass/trunk/raster/r.viewshed/grass.cpp
--- grass/trunk/raster/r.viewshed/grass.cpp	2017-11-11 19:02:07 UTC (rev 71680)
+++ grass/trunk/raster/r.viewshed/grass.cpp	2017-11-12 11:02:39 UTC (rev 71681)
@@ -782,7 +782,6 @@
 /* helper function to deal with GRASS writing to a row buffer */
 void writeValue(void *bufrast, int j, double x, RASTER_MAP_TYPE data_type)
     switch (data_type) {
     case CELL_TYPE:
 	((CELL *) bufrast)[j] = (CELL) x;
@@ -824,7 +823,8 @@
 void
 save_io_visibilitygrid_to_GRASS(IOVisibilityGrid * visgrid,
 				char *fname, RASTER_MAP_TYPE type,
-				float (*fun) (float))
+				float (*fun) (float),
+				OutputMode mode)
     G_message(_("Saving grid to <%s>"), fname);
@@ -878,7 +878,10 @@
 	    else {
 		/*  this cell is not in stream, so it is invisible */
-		writeNodataValue(visrast, j, type);
+		if (mode == OUTPUT_BOOL)
+		    writeValue(visrast, j, BOOL_INVISIBLE, type);
+		else if (mode == OUTPUT_ANGLE)
+		    writeNodataValue(visrast, j, type);
 	}			/* for j */
Modified: grass/trunk/raster/r.viewshed/grass.h
--- grass/trunk/raster/r.viewshed/grass.h	2017-11-11 19:02:07 UTC (rev 71680)
+++ grass/trunk/raster/r.viewshed/grass.h	2017-11-12 11:02:39 UTC (rev 71681)
@@ -136,7 +136,8 @@
 void
 				char *outfname, RASTER_MAP_TYPE type,
-				float (*fun) (float));
+				OutputMode mode);
Modified: grass/trunk/raster/r.viewshed/visibility.cpp
--- grass/trunk/raster/r.viewshed/visibility.cpp	2017-11-11 19:02:07 UTC (rev 71680)
+++ grass/trunk/raster/r.viewshed/visibility.cpp	2017-11-12 11:02:39 UTC (rev 71681)
@@ -401,11 +401,13 @@
     if (viewOptions.outputMode == OUTPUT_BOOL)
 	save_io_visibilitygrid_to_GRASS(visgrid, viewOptions.outputfname,
-					CELL_TYPE, booleanVisibilityOutput);
+					CELL_TYPE, booleanVisibilityOutput,
+					OUTPUT_BOOL);
     else if (viewOptions.outputMode == OUTPUT_ANGLE)
-					FCELL_TYPE, angleVisibilityOutput);
+					FCELL_TYPE, angleVisibilityOutput,
+					OUTPUT_ANGLE);
     else
 	/* elevation  output */
 	save_io_vis_and_elev_to_GRASS(visgrid, viewOptions.inputfname,
