[GRASS-SVN] r71695 - grass/trunk/raster/r.stream.extract
svn_grass at osgeo.org
Sun Nov 12 05:07:56 PST 2017
Author: mmetz
Date: 2017-11-12 05:07:55 -0800 (Sun, 12 Nov 2017)
New Revision: 71695
grass/trunk/raster/r.stream.extract/load.c
grass/trunk/raster/r.stream.extract/r.stream.extract.html
r.stream.extract: allow modified accumulation map
Modified: grass/trunk/raster/r.stream.extract/load.c
--- grass/trunk/raster/r.stream.extract/load.c 2017-11-12 13:02:15 UTC (rev 71694)
+++ grass/trunk/raster/r.stream.extract/load.c 2017-11-12 13:07:55 UTC (rev 71695)
@@ -96,7 +96,20 @@
Rast_set_d_null_value(&acc_value, 1);
+ else if (acc_fd >= 0 && Rast_is_null_value(acc_ptr, acc_map_type)) {
+ /* elevation is not NULL, but provided accumulation is NULL
+ * this is ok after weighing or
+ * when analysing a selected upstream catchment area */
+ FLAG_SET(afbuf[c].flag, NULLFLAG);
+ FLAG_SET(afbuf[c].flag, INLISTFLAG);
+ FLAG_SET(afbuf[c].flag, WORKEDFLAG);
+ FLAG_SET(afbuf[c].flag, WORKED2FLAG);
+ Rast_set_c_null_value(&ele_value, 1);
+ Rast_set_d_null_value(&acc_value, 1);
else {
+ /* elevation is not NULL, and
+ * if accumulation is provided it is also not NULL */
switch (ele_map_type) {
case CELL_TYPE:
ele_value = *((CELL *) ptr);
@@ -115,11 +128,6 @@
if (acc_fd < 0)
acc_value = 1;
else {
- if (Rast_is_null_value(acc_ptr, acc_map_type)) {
- /* can this be ok after weighing ? */
- G_fatal_error(_("Accumulation raster map is NULL but elevation map is not NULL"));
switch (acc_map_type) {
case CELL_TYPE:
acc_value = *((CELL *) acc_ptr);
Modified: grass/trunk/raster/r.stream.extract/r.stream.extract.html
--- grass/trunk/raster/r.stream.extract/r.stream.extract.html 2017-11-12 13:02:15 UTC (rev 71694)
+++ grass/trunk/raster/r.stream.extract/r.stream.extract.html 2017-11-12 13:07:55 UTC (rev 71695)
@@ -220,14 +220,12 @@
stream_rast=elev_ned_30m.streams.noweight
# extract streams from weighed map
-# requires a priori no-data filtering
-r.mapcalc "MASK = if(isnull(elev_ned_30m.acc.weighed), null(), 1)"
+# note that the weighed map is a bit smaller than the original map
r.stream.extract elevation=elev_ned_30m at PERMANENT \
accumulation=elev_ned_30m.acc.weighed \
threshold=1000 \
-r.mask -r
</pre></div>
<p>
