[GRASS-SVN] r71705 - grass/trunk/imagery/i.segment
svn_grass at osgeo.org
Sun Nov 12 09:39:23 PST 2017
Author: mmetz
Date: 2017-11-12 09:39:23 -0800 (Sun, 12 Nov 2017)
New Revision: 71705
Added:
grass/trunk/imagery/i.segment/pavl.c
grass/trunk/imagery/i.segment/pavl.h
grass/trunk/imagery/i.segment/Makefile
grass/trunk/imagery/i.segment/mean_shift.c
grass/trunk/imagery/i.segment/region_growing.c
i.segment: use faster pavl tree
Modified: grass/trunk/imagery/i.segment/Makefile
--- grass/trunk/imagery/i.segment/Makefile 2017-11-12 17:09:04 UTC (rev 71704)
+++ grass/trunk/imagery/i.segment/Makefile 2017-11-12 17:39:23 UTC (rev 71705)
@@ -2,7 +2,7 @@
PGM = i.segment
-LIBES = $(IMAGERYLIB) $(RASTERLIB) $(SEGMENTLIB) $(GISLIB) $(BTREE2LIB)
+LIBES = $(IMAGERYLIB) $(RASTERLIB) $(SEGMENTLIB) $(GISLIB)
DEPENDENCIES = $(IMAGERYDEP) $(RASTERDEP) $(SEGMENTDEP) $(GISDEP)
include $(MODULE_TOPDIR)/include/Make/Module.make
Modified: grass/trunk/imagery/i.segment/mean_shift.c
--- grass/trunk/imagery/i.segment/mean_shift.c 2017-11-12 17:09:04 UTC (rev 71704)
+++ grass/trunk/imagery/i.segment/mean_shift.c 2017-11-12 17:39:23 UTC (rev 71705)
@@ -10,7 +10,7 @@
#include <grass/glocale.h>
#include <grass/raster.h>
#include <grass/segment.h> /* segmentation library */
-#include <grass/rbtree.h> /* Red Black Tree library functions */
+#include "pavl.h"
#include "iseg.h"
int remove_small_clumps(struct globals *globals);
@@ -418,6 +418,11 @@
return (a->row - b->row);
+static void free_item(void *p)
+ G_free(p);
static int find_best_neighbour(struct globals *globals, int row, int col,
int this_id, struct NB_TREE *nbtree,
int *reg_size, struct ngbr_stats **Rbest,
@@ -425,11 +430,11 @@
int rown, coln, n, count;
int neighbors[8][2];
- struct rc next, ngbr_rc;
+ struct rc next, ngbr_rc, *pngbr_rc;
struct rclist rilist;
int no_check;
int ngbr_id;
- struct RB_TREE *visited;
+ struct pavl_table *visited;
struct ngbr_stats Ri, Rk, *Rfound;
double sim, best_sim;
int best_n_id;
@@ -441,10 +446,13 @@
nbtree_clear(nbtree);
FLAG_UNSET(globals->candidate_flag, row, col);
- visited = rbtree_create(cmp_rc, sizeof(struct rc));
+ visited = pavl_create(cmp_rc, NULL);
ngbr_rc.row = row;
ngbr_rc.col = col;
- rbtree_insert(visited, &ngbr_rc);
+ pngbr_rc = G_malloc(sizeof(struct rc));
+ *pngbr_rc = ngbr_rc;
+ pavl_insert(visited, pngbr_rc);
+ pngbr_rc = NULL;
/* breadth-first search */
next.row = row;
@@ -470,9 +478,12 @@
ngbr_rc.row = rown;
ngbr_rc.col = coln;
+ if (pngbr_rc == NULL)
- if (!no_check && !rbtree_find(visited, &ngbr_rc)) {
+ if (!no_check && pavl_insert(visited, pngbr_rc) == NULL) {
+ pngbr_rc = NULL;
/* get neighbor ID */
Segment_get(&globals->rid_seg, (void *) &ngbr_id, rown, coln);
@@ -518,7 +529,9 @@
} while (rclist_drop(&rilist, &next)); /* while there are cells to check */
rclist_destroy(&rilist);
- rbtree_destroy(visited);
+ if (pngbr_rc)
+ G_free(pngbr_rc);
+ pavl_destroy(visited, free_item);
G_free(Ri.mean);
G_free(Rk.mean);
@@ -534,8 +547,8 @@
int this_id;
int ngbr_id;
LARGEINT reg_size;
int no_check;
@@ -544,10 +557,13 @@
ngbr_rc.row = row;
ngbr_rc.col = col;
+ pngbr_rc = NULL;
/* get this ID */
Segment_get(&globals->rid_seg, (void *) &this_id, row, col);
@@ -573,9 +589,12 @@
ngbr_rc.row = rown;
ngbr_rc.col = coln;
+ pngbr_rc = NULL;
/* get neighbour ID */
@@ -590,7 +609,9 @@
+ if (pngbr_rc)
+ G_free(pngbr_rc);
return reg_size;
Added: grass/trunk/imagery/i.segment/pavl.c
--- grass/trunk/imagery/i.segment/pavl.c (rev 0)
+++ grass/trunk/imagery/i.segment/pavl.c 2017-11-12 17:39:23 UTC (rev 71705)
@@ -0,0 +1,843 @@
+/* Produced by texiweb from libavl.w. */
+/* libavl - library for manipulation of binary trees.
+ Copyright (C) 1998, 1999, 2000, 2001, 2002, 2004 Free Software
+ Foundation, Inc.
+ This library is free software; you can redistribute it and/or
+ modify it under the terms of the GNU Lesser General Public
+ License as published by the Free Software Foundation; either
+ version 3 of the License, or (at your option) any later version.
+ This library is distributed in the hope that it will be useful,
+ but WITHOUT ANY WARRANTY; without even the implied warranty of
+ MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
+ Lesser General Public License for more details.
+ You should have received a copy of the GNU Lesser General Public
+ License along with this library; if not, write to the Free Software
+ Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, MA
+ 02110-1301 USA.
+/* Nov 2016, Markus Metz
+ * from libavl-2.0.3
+ * added safety checks and speed optimizations
+#include <assert.h>
+#include <stdio.h>
+#include <stdlib.h>
+#include "pavl.h"
+/* Creates and returns a new table
+ with comparison function |compare| using parameter |param|
+ and memory allocator |allocator|.
+ Returns |NULL| if memory allocation failed. */
+struct pavl_table *pavl_create(pavl_comparison_func * compare,
+ struct libavl_allocator *allocator)
+ struct pavl_table *tree;
+ assert(compare != NULL);
+ if (allocator == NULL)
+ allocator = &pavl_allocator_default;
+ tree = allocator->libavl_malloc(sizeof *tree);
+ if (tree == NULL)
+ return NULL;
+ tree->pavl_root = NULL;
+ tree->pavl_compare = compare;
+ tree->pavl_alloc = allocator;
+ tree->pavl_count = 0;
+ return tree;
+/* Search |tree| for an item matching |item|, and return it if found.
+ Otherwise return |NULL|. */
+void *pavl_find(const struct pavl_table *tree, const void *item)
+ const struct pavl_node *p;
+ assert(tree != NULL && item != NULL);
+ p = tree->pavl_root;
+ while (p != NULL) {
+ int cmp = tree->pavl_compare(item, p->pavl_data);
+ if (cmp == 0)
+ return p->pavl_data;
+ p = p->pavl_link[cmp > 0];
+ return NULL;
+/* Inserts |item| into |tree| and returns a pointer to |item|'s address.
+ If a duplicate item is found in the tree,
+ returns a pointer to the duplicate without inserting |item|.
+ Returns |NULL| in case of memory allocation failure. */
+void **pavl_probe(struct pavl_table *tree, void *item)
+ struct pavl_node *y; /* Top node to update balance factor, and parent. */
+ struct pavl_node *p, *q; /* Iterator, and parent. */
+ struct pavl_node *n; /* Newly inserted node. */
+ struct pavl_node *w; /* New root of rebalanced subtree. */
+ int dir; /* Direction to descend. */
+ y = p = tree->pavl_root;
+ q = NULL;
+ dir = 0;
+ if (cmp == 0)
+ return &p->pavl_data;
+ dir = cmp > 0;
+ if (p->pavl_balance != 0)
+ y = p;
+ q = p, p = p->pavl_link[dir];
+ n = tree->pavl_alloc->libavl_malloc(sizeof *p);
+ if (n == NULL)
+ return NULL;
+ tree->pavl_count++;
+ n->pavl_link[0] = n->pavl_link[1] = NULL;
+ n->pavl_parent = q;
+ n->pavl_data = item;
+ n->pavl_balance = 0;
+ if (q == NULL) {
+ tree->pavl_root = n;
+ return &n->pavl_data;
+ q->pavl_link[dir] = n;
+ p = n;
+ while (p != y) {
+ q = p->pavl_parent;
+ dir = q->pavl_link[0] != p;
+ if (dir == 0)
+ q->pavl_balance--;
+ else
+ q->pavl_balance++;
+ if (q->pavl_link[0] != p)
+ else
+ p = q;
+ if (y->pavl_balance == -2) {
+ struct pavl_node *x = y->pavl_link[0];
+ if (x->pavl_balance == -1) {
+ w = x;
+ y->pavl_link[0] = x->pavl_link[1];
+ x->pavl_link[1] = y;
+ x->pavl_balance = y->pavl_balance = 0;
+ x->pavl_parent = y->pavl_parent;
+ y->pavl_parent = x;
+ if (y->pavl_link[0] != NULL)
+ y->pavl_link[0]->pavl_parent = y;
+ else {
+ assert(x->pavl_balance == +1);
+ w = x->pavl_link[1];
+ x->pavl_link[1] = w->pavl_link[0];
+ w->pavl_link[0] = x;
+ y->pavl_link[0] = w->pavl_link[1];
+ w->pavl_link[1] = y;
+ if (w->pavl_balance == -1)
+ x->pavl_balance = 0, y->pavl_balance = +1;
+ else if (w->pavl_balance == 0)
+ else /* |w->pavl_balance == +1| */
+ x->pavl_balance = -1, y->pavl_balance = 0;
+ w->pavl_balance = 0;
+ w->pavl_parent = y->pavl_parent;
+ x->pavl_parent = y->pavl_parent = w;
+ if (x->pavl_link[1] != NULL)
+ x->pavl_link[1]->pavl_parent = x;
+ else if (y->pavl_balance == +2) {
+ struct pavl_node *x = y->pavl_link[1];
+ if (x->pavl_balance == +1) {
+ w = x;
+ y->pavl_link[1] = x->pavl_link[0];
+ x->pavl_link[0] = y;
+ if (y->pavl_link[1] != NULL)
+ y->pavl_link[1]->pavl_parent = y;
+ else {
+ assert(x->pavl_balance == -1);
+ w = x->pavl_link[0];
+ x->pavl_link[0] = w->pavl_link[1];
+ w->pavl_link[1] = x;
+ y->pavl_link[1] = w->pavl_link[0];
+ w->pavl_link[0] = y;
+ if (w->pavl_balance == +1)
+ x->pavl_balance = 0, y->pavl_balance = -1;
+ else /* |w->pavl_balance == -1| */
+ x->pavl_balance = +1, y->pavl_balance = 0;
+ if (x->pavl_link[0] != NULL)
+ x->pavl_link[0]->pavl_parent = x;
+ else
+ if (w->pavl_parent != NULL)
+ w->pavl_parent->pavl_link[y != w->pavl_parent->pavl_link[0]] = w;
+ else
+ tree->pavl_root = w;
+/* Inserts |item| into |table|.
+ Returns |NULL| if |item| was successfully inserted
+ or if a memory allocation error occurred.
+ Otherwise, returns the duplicate item. */
+void *pavl_insert(struct pavl_table *table, void *item)
+ void **p = pavl_probe(table, item);
+ return p == NULL || *p == item ? NULL : *p;
+/* Inserts |item| into |table|, replacing any duplicate item.
+ Returns |NULL| if |item| was inserted without replacing a duplicate,
+ Otherwise, returns the item that was replaced. */
+void *pavl_replace(struct pavl_table *table, void *item)
+ if (p == NULL || *p == item)
+ return NULL;
+ else {
+ void *r = *p;
+ *p = item;
+ return r;
+/* Deletes from |tree| and returns an item matching |item|.
+ Returns a null pointer if no matching item found. */
+void *pavl_delete(struct pavl_table *tree, const void *item)
+ struct pavl_node *p; /* Traverses tree to find node to delete. */
+ struct pavl_node *q; /* Parent of |p|. */
+ int dir; /* Side of |q| on which |p| is linked. */
+ int cmp; /* Result of comparison between |item| and |p|. */
+ dir = 0;
+ cmp = tree->pavl_compare(item, p->pavl_data);
+ if (cmp == 0)
+ break;
+ dir = cmp > 0;
+ p = p->pavl_link[dir];
+ if (p == NULL)
+ return NULL;
+ item = p->pavl_data;
+ if (q == NULL) {
+ q = (struct pavl_node *)&tree->pavl_root;
+ dir = 0;
+ if (p->pavl_link[1] == NULL) {
+ q->pavl_link[dir] = p->pavl_link[0];
+ if (q->pavl_link[dir] != NULL)
+ q->pavl_link[dir]->pavl_parent = p->pavl_parent;
+ else {
+ struct pavl_node *r = p->pavl_link[1];
+ if (r->pavl_link[0] == NULL) {
+ r->pavl_link[0] = p->pavl_link[0];
+ q->pavl_link[dir] = r;
+ r->pavl_parent = p->pavl_parent;
+ if (r->pavl_link[0] != NULL)
+ r->pavl_link[0]->pavl_parent = r;
+ r->pavl_balance = p->pavl_balance;
+ q = r;
+ dir = 1;
+ else {
+ struct pavl_node *s = r->pavl_link[0];
+ while (s->pavl_link[0] != NULL)
+ s = s->pavl_link[0];
+ r = s->pavl_parent;
+ r->pavl_link[0] = s->pavl_link[1];
+ s->pavl_link[0] = p->pavl_link[0];
+ s->pavl_link[1] = p->pavl_link[1];
+ q->pavl_link[dir] = s;
+ if (s->pavl_link[0] != NULL)
+ s->pavl_link[0]->pavl_parent = s;
+ s->pavl_link[1]->pavl_parent = s;
+ s->pavl_parent = p->pavl_parent;
+ s->pavl_balance = p->pavl_balance;
+ q = r;
+ dir = 0;
+ tree->pavl_alloc->libavl_free(p);
+ while (q != (struct pavl_node *)&tree->pavl_root) {
+ struct pavl_node *y = q;
+ if (y->pavl_parent != NULL)
+ q = y->pavl_parent;
+ else
+ if (dir == 0) {
+ dir = q->pavl_link[0] != y;
+ y->pavl_balance++;
+ if (y->pavl_balance == +1)
+ break;
+ q->pavl_link[dir] = w;
+ else {
+ q->pavl_link[dir] = x;
+ if (x->pavl_balance == 0) {
+ x->pavl_balance = -1;
+ y->pavl_balance = +1;
+ break;
+ else {
+ y = x;
+ else {
+ y->pavl_balance--;
+ if (y->pavl_balance == -1)
+ break;
+ else if (y->pavl_balance == -2) {
+ else {
+ x->pavl_balance = +1;
+ y->pavl_balance = -1;
+ break;
+ else {
+ y = x;
+ tree->pavl_count--;
+ return (void *)item;
+/* Initializes |trav| for use with |tree|
+ and selects the null node. */
+void pavl_t_init(struct pavl_traverser *trav, struct pavl_table *tree)
+ trav->pavl_table = tree;
+ trav->pavl_node = NULL;
+/* Initializes |trav| for |tree|.
+ Returns data item in |tree| with the least value,
+ or |NULL| if |tree| is empty. */
+void *pavl_t_first(struct pavl_traverser *trav, struct pavl_table *tree)
+ assert(tree != NULL && trav != NULL);
+ trav->pavl_node = tree->pavl_root;
+ if (trav->pavl_node != NULL) {
+ while (trav->pavl_node->pavl_link[0] != NULL)
+ trav->pavl_node = trav->pavl_node->pavl_link[0];
+ return trav->pavl_node->pavl_data;
+ else
+ return NULL;
+ Returns data item in |tree| with the greatest value,
+void *pavl_t_last(struct pavl_traverser *trav, struct pavl_table *tree)
+ while (trav->pavl_node->pavl_link[1] != NULL)
+ trav->pavl_node = trav->pavl_node->pavl_link[1];
+ else
+ return NULL;
+/* Searches for |item| in |tree|.
+ If found, initializes |trav| to the item found and returns the item
+ as well.
+ If there is no matching item, initializes |trav| to the null item
+ and returns |NULL|. */
+void *pavl_t_find(struct pavl_traverser *trav, struct pavl_table *tree,
+ void *item)
+ assert(trav != NULL && tree != NULL && item != NULL);
+ if (cmp == 0) {
+ trav->pavl_node = p;
+ return NULL;
+/* Attempts to insert |item| into |tree|.
+ If |item| is inserted successfully, it is returned and |trav| is
+ initialized to its location.
+ If a duplicate is found, it is returned and |trav| is initialized to
+ its location. No replacement of the item occurs.
+ If a memory allocation failure occurs, |NULL| is returned and |trav|
+ is initialized to the null item. */
+void *pavl_t_insert(struct pavl_traverser *trav,
+ struct pavl_table *tree, void *item)
+ void **p;
+ p = pavl_probe(tree, item);
+ if (p != NULL) {
+ trav->pavl_node = ((struct pavl_node *)((char *)p -
+ offsetof(struct pavl_node,
+ pavl_data)));
+ return *p;
+ else {
+ pavl_t_init(trav, tree);
+ return NULL;
+/* Initializes |trav| to have the same current node as |src|. */
+void *pavl_t_copy(struct pavl_traverser *trav,
+ const struct pavl_traverser *src)
+ assert(trav != NULL && src != NULL);
+ trav->pavl_table = src->pavl_table;
+ trav->pavl_node = src->pavl_node;
+ return trav->pavl_node != NULL ? trav->pavl_node->pavl_data : NULL;
+/* Returns the next data item in inorder
+ within the tree being traversed with |trav|,
+ or if there are no more data items returns |NULL|. */
+void *pavl_t_next(struct pavl_traverser *trav)
+ assert(trav != NULL);
+ if (trav->pavl_node == NULL)
+ return pavl_t_first(trav, trav->pavl_table);
+ else if (trav->pavl_node->pavl_link[1] == NULL) {
+ struct pavl_node *q, *p; /* Current node and its child. */
+ for (p = trav->pavl_node, q = p->pavl_parent;;
+ p = q, q = q->pavl_parent)
+ if (q == NULL || p == q->pavl_link[0]) {
+ trav->pavl_node = q;
+ trav->pavl_node->pavl_data : NULL;
+ else {
+/* Returns the previous data item in inorder
+void *pavl_t_prev(struct pavl_traverser *trav)
+ return pavl_t_last(trav, trav->pavl_table);
+ else if (trav->pavl_node->pavl_link[0] == NULL) {
+ if (q == NULL || p == q->pavl_link[1]) {
+ else {
+/* Returns |trav|'s current item. */
+void *pavl_t_cur(struct pavl_traverser *trav)
+/* Replaces the current item in |trav| by |new| and returns the item replaced.
+ |trav| must not have the null item selected.
+ The new item must not upset the ordering of the tree. */
+void *pavl_t_replace(struct pavl_traverser *trav, void *new)
+ void *old;
+ assert(trav != NULL && trav->pavl_node != NULL && new != NULL);
+ old = trav->pavl_node->pavl_data;
+ trav->pavl_node->pavl_data = new;
+ return old;
+/* Destroys |new| with |pavl_destroy (new, destroy)|,
+ first initializing right links in |new| that have
+ not yet been initialized at time of call. */
+static void
+copy_error_recovery(struct pavl_node *q,
+ struct pavl_table *new, pavl_item_func * destroy)
+ assert(q != NULL && new != NULL);
+ for (;;) {
+ struct pavl_node *p = q;
+ q = q->pavl_parent;
+ if (q == NULL)
+ break;
+ if (p == q->pavl_link[0])
+ q->pavl_link[1] = NULL;
+ pavl_destroy(new, destroy);
+/* Copies |org| to a newly created tree, which is returned.
+ If |copy != NULL|, each data item in |org| is first passed to |copy|,
+ and the return values are inserted into the tree;
+ |NULL| return values are taken as indications of failure.
+ On failure, destroys the partially created new tree,
+ applying |destroy|, if non-null, to each item in the new tree so far,
+ If |allocator != NULL|, it is used for allocation in the new tree.
+ Otherwise, the same allocator used for |org| is used. */
+struct pavl_table *pavl_copy(const struct pavl_table *org,
+ pavl_copy_func * copy, pavl_item_func * destroy,
+ struct pavl_table *new;
+ const struct pavl_node *x;
+ assert(org != NULL);
+ new = pavl_create(org->pavl_compare,
+ allocator != NULL ? allocator : org->pavl_alloc);
+ if (new == NULL)
+ return NULL;
+ new->pavl_count = org->pavl_count;
+ if (new->pavl_count == 0)
+ return new;
+ x = (const struct pavl_node *)&org->pavl_root;
+ y = (struct pavl_node *)&new->pavl_root;
+ while (x != NULL) {
+ while (x->pavl_link[0] != NULL) {
+ y->pavl_link[0] =
+ new->pavl_alloc->libavl_malloc(sizeof *y->pavl_link[0]);
+ if (y->pavl_link[0] == NULL) {
+ if (y != (struct pavl_node *)&new->pavl_root) {
+ y->pavl_data = NULL;
+ y->pavl_link[1] = NULL;
+ copy_error_recovery(y, new, destroy);
+ return NULL;
+ x = x->pavl_link[0];
+ y = y->pavl_link[0];
+ y->pavl_link[0] = NULL;
+ for (;;) {
+ y->pavl_balance = x->pavl_balance;
+ if (copy == NULL)
+ y->pavl_data = x->pavl_data;
+ else {
+ y->pavl_data = copy(x->pavl_data);
+ if (y->pavl_data == NULL) {
+ return NULL;
+ if (x->pavl_link[1] != NULL) {
+ y->pavl_link[1] =
+ new->pavl_alloc->libavl_malloc(sizeof *y->pavl_link[1]);
+ if (y->pavl_link[1] == NULL) {
+ return NULL;
+ x = x->pavl_link[1];
+ y = y->pavl_link[1];
+ break;
+ else
+ for (;;) {
+ const struct pavl_node *w = x;
+ x = x->pavl_parent;
+ if (x == NULL) {
+ new->pavl_root->pavl_parent = NULL;
+ return new;
+ y = y->pavl_parent;
+ if (w == x->pavl_link[0])
+ break;
+ return new;
+/* Frees storage allocated for |tree|.
+ If |destroy != NULL|, applies it to each data item in inorder. */
+void pavl_destroy(struct pavl_table *tree, pavl_item_func * destroy)
+ assert(tree != NULL);
+ if (p->pavl_link[0] == NULL) {
+ q = p->pavl_link[1];
+ if (destroy != NULL && p->pavl_data != NULL)
+ destroy(p->pavl_data);
+ else {
+ q = p->pavl_link[0];
+ p->pavl_link[0] = q->pavl_link[1];
+ q->pavl_link[1] = p;
+ p = q;
+ tree->pavl_alloc->libavl_free(tree);
+/* Allocates |size| bytes of space using |malloc()|.
+ Returns a null pointer if allocation fails. */
+void *pavl_malloc(size_t size)
+ if (size > 0)
+ return malloc(size);
+ return NULL;
+/* Frees |block|. */
+void pavl_free(void *block)
+ if (block)
+ free(block);
+/* Default memory allocator that uses |malloc()| and |free()|. */
+struct libavl_allocator pavl_allocator_default = {
+ pavl_malloc,
+ pavl_free
+#undef NDEBUG
+/* Asserts that |pavl_insert()| succeeds at inserting |item| into |table|. */
+void (pavl_assert_insert) (struct pavl_table * table, void *item)
+ assert(p != NULL && *p == item);
+/* Asserts that |pavl_delete()| really removes |item| from |table|,
+ and returns the removed item. */
+void *(pavl_assert_delete) (struct pavl_table * table, void *item)
+ void *p = pavl_delete(table, item);
+ assert(p != NULL);
+ return p;
Added: grass/trunk/imagery/i.segment/pavl.h
--- grass/trunk/imagery/i.segment/pavl.h (rev 0)
+++ grass/trunk/imagery/i.segment/pavl.h 2017-11-12 17:39:23 UTC (rev 71705)
@@ -0,0 +1,106 @@
+ Foundation, Inc.
+ 02110-1301 USA.
+#ifndef PAVL_H
+#define PAVL_H 1
+#include <stddef.h>
+/* Function types. */
+typedef int pavl_comparison_func(const void *pavl_a, const void *pavl_b);
+typedef void pavl_item_func(void *pavl_item);
+typedef void *pavl_copy_func(void *pavl_item);
+#ifndef LIBAVL_ALLOCATOR
+#define LIBAVL_ALLOCATOR
+/* Memory allocator. */
+ void *(*libavl_malloc) (size_t libavl_size);
+ void (*libavl_free) (void *libavl_block);
+#endif
+/* Default memory allocator. */
+extern struct libavl_allocator pavl_allocator_default;
+void *pavl_malloc(size_t);
+void pavl_free(void *);
+/* Maximum PAVL height, unused. */
+#ifndef PAVL_MAX_HEIGHT
+#define PAVL_MAX_HEIGHT 32
+#endif
+/* Tree data structure. */
+struct pavl_table
+ struct pavl_node *pavl_root; /* Tree's root. */
+ pavl_comparison_func *pavl_compare; /* Comparison function. */
+ struct libavl_allocator *pavl_alloc; /* Memory allocator. */
+ size_t pavl_count; /* Number of items in tree. */
+/* An PAVL tree node. */
+struct pavl_node
+ struct pavl_node *pavl_link[2]; /* Subtrees. */
+ struct pavl_node *pavl_parent; /* Parent node. */
+ void *pavl_data; /* Pointer to data. */
+ signed char pavl_balance; /* Balance factor. */
+/* PAVL traverser structure. */
+struct pavl_traverser
+ struct pavl_table *pavl_table; /* Tree being traversed. */
+ struct pavl_node *pavl_node; /* Current node in tree. */
+/* Table functions. */
+struct pavl_table *pavl_create(pavl_comparison_func *,
+ struct libavl_allocator *);
+struct pavl_table *pavl_copy(const struct pavl_table *, pavl_copy_func *,
+ pavl_item_func *, struct libavl_allocator *);
+void pavl_destroy(struct pavl_table *, pavl_item_func *);
+void **pavl_probe(struct pavl_table *, void *);
+void *pavl_insert(struct pavl_table *, void *);
+void *pavl_replace(struct pavl_table *, void *);
+void *pavl_delete(struct pavl_table *, const void *);
+void *pavl_find(const struct pavl_table *, const void *);
+void pavl_assert_insert(struct pavl_table *, void *);
+void *pavl_assert_delete(struct pavl_table *, void *);
+#define pavl_count(table) ((size_t) (table)->pavl_count)
+/* Table traverser functions. */
+void pavl_t_init(struct pavl_traverser *, struct pavl_table *);
+void *pavl_t_first(struct pavl_traverser *, struct pavl_table *);
+void *pavl_t_last(struct pavl_traverser *, struct pavl_table *);
+void *pavl_t_find(struct pavl_traverser *, struct pavl_table *, void *);
+void *pavl_t_insert(struct pavl_traverser *, struct pavl_table *, void *);
+void *pavl_t_copy(struct pavl_traverser *, const struct pavl_traverser *);
+void *pavl_t_next(struct pavl_traverser *);
+void *pavl_t_prev(struct pavl_traverser *);
+void *pavl_t_cur(struct pavl_traverser *);
+void *pavl_t_replace(struct pavl_traverser *, void *);
+#endif /* pavl.h */
Modified: grass/trunk/imagery/i.segment/region_growing.c
--- grass/trunk/imagery/i.segment/region_growing.c 2017-11-12 17:09:04 UTC (rev 71704)
+++ grass/trunk/imagery/i.segment/region_growing.c 2017-11-12 17:39:23 UTC (rev 71705)
@@ -11,7 +11,7 @@
+#include "pavl.h"
#include "iseg.h"
#define EPSILON 1.0e-8
@@ -114,6 +114,11 @@
struct rc *a = (struct rc *)first, *b = (struct rc *)second;
+ if (a->row == b->row)
+ return (a->col - b->col);
+ return (a->row - b->row);
if (a->row < b->row)
return -1;
if (a->row > b->row)
@@ -584,7 +589,7 @@
G_percent(row - globals->row_min,
globals->row_max - globals->row_min, 4);
for (col = globals->col_min; col < globals->col_max; col++) {
- int do_merge = 1;
+ do_merge = 1;
if (!(FLAG_GET(globals->candidate_flag, row, col)))
continue;
@@ -672,6 +677,10 @@
return TRUE;
+ G_free(p);
static int find_best_neighbor(struct ngbr_stats *Ri,
struct reg_stats *Ri_rs,
@@ -682,11 +691,11 @@
int n, n_ngbrs, no_check, cmp;
- struct rc ngbr_rc, next;
+ struct rc ngbr_rc, next, *pngbr_rc;
double tempsim;
- struct RB_TREE *no_check_tree; /* cells already checked */
+ struct pavl_table *no_check_tree; /* cells already checked */
struct reg_stats *rs_found;
int candk, candtmp;
@@ -703,10 +712,13 @@
/* *** initialize data *** */
- no_check_tree = rbtree_create(compare_rc, sizeof(struct rc));
ngbr_rc.row = Ri->row;
ngbr_rc.col = Ri->col;
- rbtree_insert(no_check_tree, &ngbr_rc);
+ no_check_tree = pavl_create(compare_rc, NULL);
+ pavl_insert(no_check_tree, pngbr_rc);
+ pngbr_rc = NULL;
nbtree_clear(Ri_ngbrs);
n_ngbrs = 0;
@@ -752,10 +764,12 @@
if (!no_check) {
- if (!rbtree_find(no_check_tree, &ngbr_rc)) {
- /* not yet checked, don't check it again */
+ if (pavl_insert(no_check_tree, pngbr_rc) == NULL) {
+ pngbr_rc = NULL;
@@ -822,7 +836,9 @@
/* clean up */
- rbtree_destroy(no_check_tree);
+ if (pngbr_rc)
+ G_free(pngbr_rc);
+ pavl_destroy(no_check_tree, free_item);
return n_ngbrs;
@@ -1031,17 +1047,21 @@
G_fatal_error(_("Region size is larger than 2: %d"), count);
else if (rs->count > 2) {
- struct RB_TREE *rc_check_tree; /* cells already checked */
+ struct pavl_table *rc_check_tree; /* cells already checked */
struct rclist rlist;
+ struct rc *pngbr_rc;
int no_check;
/* go through region, spreading outwards from head */
rclist_init(&rlist);
- rc_check_tree = rbtree_create(compare_rc, sizeof(struct rc));
ngbr_rc.row = row;
ngbr_rc.col = col;
- rbtree_insert(rc_check_tree, &ngbr_rc);
+ rc_check_tree = pavl_create(compare_rc, NULL);
+ pavl_insert(rc_check_tree, pngbr_rc);
+ pngbr_rc = NULL;
next.row = row;
next.col = col;
@@ -1062,13 +1082,15 @@
if (!no_check) {
if ((FLAG_GET(globals->null_flag, ngbr_rc.row, ngbr_rc.col)) == 0) {
/* already checked ? */
- if (!rbtree_find(rc_check_tree, &ngbr_rc)) {
+ if (pavl_insert(rc_check_tree, pngbr_rc) == NULL) {
+ pngbr_rc = NULL;
Segment_get(&globals->rid_seg, (void *) &rid,
ngbr_rc.row, ngbr_rc.col);
@@ -1090,7 +1112,9 @@
} while (rclist_drop(&rlist, &next));
/* clean up */
- rbtree_destroy(rc_check_tree);
+ if (pngbr_rc)
+ G_free(pngbr_rc);
+ pavl_destroy(rc_check_tree, free_item);
rclist_destroy(&rlist);
@@ -1488,9 +1512,9 @@
else if (globals->min_reg_size > 3) {
/* rs->id must be set */
int n, rid;
+ struct rc ngbr_rc, *pngbr_rc, next;
int no_check;
@@ -1498,10 +1522,13 @@
rclist_init(&rilist);
ngbr_rc.row = row;
ngbr_rc.col = col;
+ pngbr_rc = NULL;
next.row = row;
next.col = col;
@@ -1525,12 +1552,14 @@
if (!no_check) {
+ pngbr_rc = NULL;
@@ -1549,7 +1578,9 @@
/* clean up */
+ if (pngbr_rc)
+ G_free(pngbr_rc);
ret = 3;
