[GRASS-SVN] r71713 - grass/branches/releasebranch_7_4/lib/init
svn_grass at osgeo.org
Sun Nov 12 12:00:48 PST 2017
Author: neteler
Date: 2017-11-12 12:00:48 -0800 (Sun, 12 Nov 2017)
New Revision: 71713
grass/branches/releasebranch_7_4/lib/init/grass.py
grass startup script: added version output 'grass74 --config version'
Modified: grass/branches/releasebranch_7_4/lib/init/grass.py
--- grass/branches/releasebranch_7_4/lib/init/grass.py 2017-11-12 20:00:22 UTC (rev 71712)
+++ grass/branches/releasebranch_7_4/lib/init/grass.py 2017-11-12 20:00:48 UTC (rev 71713)
@@ -343,7 +343,7 @@
gui=_("use $DEFAULT_GUI graphical user interface"),
gui_detail=_("and set as default"),
config=_("print GRASS configuration parameters"),
- config_detail=_("options: arch,build,compiler,path,revision"),
+ config_detail=_("options: arch,build,compiler,path,revision,version"),
params=_("Parameters"),
gisdbase=_("initial GRASS GIS database directory"),
gisdbase_detail=_("directory containing Locations"),
@@ -1642,7 +1642,7 @@
params = sys.argv[2:]
if not params:
- params = ['arch', 'build', 'compiler', 'path', 'revision']
+ params = ['arch', 'build', 'compiler', 'path', 'revision', 'version']
for arg in params:
if arg == 'path':
@@ -1666,6 +1666,8 @@
val = grep('#define GIS_H_VERSION', linesrev)
filerev.close()
sys.stdout.write("%s\n" % val[0].split(':')[1].rstrip('$"\n').strip())
+ elif arg == 'version':
+ sys.stdout.write("%s\n" % grass_version)
else:
message(_("Parameter <%s> not supported") % arg)
