[GRASS-SVN] r71716 - grass/trunk/imagery/i.segment
svn_grass at osgeo.org
Sun Nov 12 12:07:19 PST 2017
Author: mmetz
Date: 2017-11-12 12:07:19 -0800 (Sun, 12 Nov 2017)
New Revision: 71716
grass/trunk/imagery/i.segment/open_files.c
grass/trunk/imagery/i.segment/parse_args.c
i.segment: input can be a group or a list of raster maps
Modified: grass/trunk/imagery/i.segment/open_files.c
--- grass/trunk/imagery/i.segment/open_files.c 2017-11-12 20:03:04 UTC (rev 71715)
+++ grass/trunk/imagery/i.segment/open_files.c 2017-11-12 20:07:19 UTC (rev 71716)
@@ -31,20 +31,6 @@
flag_clear_all(globals->null_flag);
flag_clear_all(globals->candidate_flag);
- G_debug(1, "Checking image group...");
- /* ****** open the input rasters ******* */
- if (!I_get_group_ref(globals->image_group, &globals->Ref))
- G_fatal_error(_("Group <%s> not found in the current mapset"),
- globals->image_group);
- if (globals->Ref.nfiles <= 0)
- G_fatal_error(_("Group <%s> contains no raster maps"),
- /* Read Imagery Group */
in_fd = G_malloc(globals->Ref.nfiles * sizeof(int));
inbuf = (DCELL **) G_malloc(globals->Ref.nfiles * sizeof(DCELL *));
fp_range = G_malloc(globals->Ref.nfiles * sizeof(struct FPRange));
Modified: grass/trunk/imagery/i.segment/parse_args.c
--- grass/trunk/imagery/i.segment/parse_args.c 2017-11-12 20:03:04 UTC (rev 71715)
+++ grass/trunk/imagery/i.segment/parse_args.c 2017-11-12 20:07:19 UTC (rev 71716)
@@ -18,9 +18,12 @@
*mem;
struct Flag *diagonal, *weighted, *ms_a, *ms_p;
struct Option *gof, *endt;
+ int bands;
/* required parameters */
- group = G_define_standard_option(G_OPT_I_GROUP);
+ group = G_define_standard_option(G_OPT_R_INPUTS);
+ group->key = "group";
+ group->description = _("Name of input imagery group or raster maps");
output = G_define_standard_option(G_OPT_R_OUTPUT);
@@ -180,8 +183,40 @@
/* Check and save parameters */
- globals->image_group = group->answer;
+ for (bands = 0; group->answers[bands] != NULL; bands++) ;
+ I_init_group_ref(&globals->Ref);
+ if (bands > 1 || !I_find_group(group->answers[0])) {
+ /* create group from input is raster map(s) */
+ char name[GNAME_MAX];
+ const char *mapset;
+ for (bands = 0; group->answers[bands] != NULL; bands++) {
+ /* strip @mapset, do not modify opt_in->answers */
+ strcpy(name, group->answers[bands]);
+ mapset = G_find_raster(name, "");
+ if (!mapset)
+ G_fatal_error(_("Raster map <%s> not found"),
+ group->answers[bands]);
+ /* Add input to group. */
+ I_add_file_to_group_ref(name, mapset, &globals->Ref);
+ globals->image_group = NULL;
+ else {
+ /* input is group. Try to read group file */
+ if (!I_get_group_ref(group->answers[0], &globals->Ref))
+ G_fatal_error(_("Group <%s> not found in the current mapset"),
+ group->answers[0]);
+ if (globals->Ref.nfiles <= 0)
+ G_fatal_error(_("Group <%s> contains no raster maps"),
+ globals->image_group);
+ globals->image_group = group->answers[0];
if (G_legal_filename(output->answer) == TRUE)
globals->out_name = output->answer;
else
