[GRASS-SVN] r71724 - grass/trunk/vector/v.buffer
svn_grass at osgeo.org
Sun Nov 12 14:04:17 PST 2017
Author: mmetz
Date: 2017-11-12 14:04:17 -0800 (Sun, 12 Nov 2017)
New Revision: 71724
grass/trunk/vector/v.buffer/main.c
grass/trunk/vector/v.buffer/v.buffer.html
v.buffer: warn if old options are used with GEOS buffering, update manual
Modified: grass/trunk/vector/v.buffer/main.c
--- grass/trunk/vector/v.buffer/main.c 2017-11-12 21:32:53 UTC (rev 71723)
+++ grass/trunk/vector/v.buffer/main.c 2017-11-12 22:04:17 UTC (rev 71724)
@@ -288,9 +288,8 @@
tol_opt->key = "tolerance";
tol_opt->type = TYPE_DOUBLE;
tol_opt->required = NO;
- tol_opt->answer = "0.01";
tol_opt->description =
- _("Maximum distance between theoretical arc and polygon segments as multiple of buffer");
+ _("Maximum distance between theoretical arc and polygon segments as multiple of buffer (default 0.01)");
tol_opt->guisection = _("Distance");
straight_flag = G_define_flag();
@@ -358,9 +357,12 @@
if (bufcol_opt->answer && field == -1)
G_fatal_error(_("The bufcol option requires a valid layer."));
- tolerance = atof(tol_opt->answer);
- if (tolerance <= 0)
- G_fatal_error(_("The tolerance must be > 0."));
+ tolerance = 0.01;
+ if (tol_opt->answer) {
+ tolerance = atof(tol_opt->answer);
+ if (tolerance <= 0)
+ G_fatal_error(_("The tolerance must be > 0."));
if (adjust_tolerance(&tolerance))
G_warning(_("The tolerance was reset to %g"), tolerance);
@@ -385,6 +387,18 @@
unit_tolerance = fabs(tolerance * MIN(da, db));
G_verbose_message(_("The tolerance in map units = %g"), unit_tolerance);
+ if (use_geos) {
+ if (distb_opt->answer)
+ G_warning(_("Option '%s' is not available with GEOS buffering"),
+ distb_opt->key);
+ if (dalpha != 0)
+ angle_opt->key);
+ tol_opt->key);
if (Vect_open_new(&Out, out_opt->answer, WITHOUT_Z) < 0)
Modified: grass/trunk/vector/v.buffer/v.buffer.html
--- grass/trunk/vector/v.buffer/v.buffer.html 2017-11-12 21:32:53 UTC (rev 71723)
+++ grass/trunk/vector/v.buffer/v.buffer.html 2017-11-12 22:04:17 UTC (rev 71724)
@@ -36,6 +36,10 @@
generates buffers using built-in buffering algorithm (which is still
buggy for some input data).
+<p>
+The options <b>minordistance</b>, <b>angle</b>, <b>tolerance</b> are
+kept for backward compatibility and have no effect with GEOS buffering.
<h3>Corner settings</h3>
The following vector line related corners (also called "cap") exist:
