[GRASS-SVN] r71726 - grass/trunk/lib/init
Sun Nov 12 14:57:22 PST 2017
Author: veroandreo
Date: 2017-11-12 14:57:22 -0800 (Sun, 12 Nov 2017)
New Revision: 71726
Added:
   grass/trunk/lib/init/circle_6.png
   grass/trunk/lib/init/circle_1.png
   grass/trunk/lib/init/circle_2.png
   grass/trunk/lib/init/circle_3.png
   grass/trunk/lib/init/circle_4.png
   grass/trunk/lib/init/circle_5.png
   grass/trunk/lib/init/grass_start.png
   grass/trunk/lib/init/helptext.html
lib/init/helptext: start-up screen fig updated and Download button explained
Modified: grass/trunk/lib/init/circle_1.png
(Binary files differ)
Modified: grass/trunk/lib/init/circle_2.png
Modified: grass/trunk/lib/init/circle_3.png
Modified: grass/trunk/lib/init/circle_4.png
Modified: grass/trunk/lib/init/circle_5.png
Added: grass/trunk/lib/init/circle_6.png
Property changes on: grass/trunk/lib/init/circle_6.png
___________________________________________________________________
Added: svn:mime-type
   + image/png
Modified: grass/trunk/lib/init/grass_start.png
Modified: grass/trunk/lib/init/helptext.html
--- grass/trunk/lib/init/helptext.html	2017-11-12 22:40:40 UTC (rev 71725)
+++ grass/trunk/lib/init/helptext.html	2017-11-12 22:57:22 UTC (rev 71726)
@@ -42,6 +42,9 @@
 easily create a new LOCATION from scratch from a geocoded file, by
 defining the parameters or by selecting the corresponding EPSG projection
 code.
+<p>
+See <img src="circle_5.png" alt="[(5)]"> to directly download a
+sample LOCATION into the DATABASE.
 <h3><img src="circle_3.png" alt="[(3)]"> Selecting the MAPSET (a subproject)</h3>
@@ -58,8 +61,16 @@
 data file (e.g., SHAPE file or GeoTIFF, see below).  Find below also some
 rules to define the default raster resolution for a new LOCATION.
-<h3><img src="circle_5.png" alt="[(5)]"> Start GRASS</h3>
+<h3><img src="circle_5.png" alt="[(5)]"> Download a sample LOCATION</h3>
+In the "Location Wizard" there is also a Download button that allows you to
+directly download a ready-to-use LOCATION into the DATABASE. You can
+choose among different sample LOCATIONS that are currently available at the
+<a href="https://grass.osgeo.org/download/sample-data/">Download</a>
+section in the GRASS GIS website.
+<h3><img src="circle_6.png" alt="[(6)]"> Start GRASS</h3>
 Once you have selected an existing LOCATION/MAPSET or defined a new
 one, you can enter GRASS. The graphical user interface
 <a href="wxGUI.html">wxGUI</a> will open and provide you with a
