[GRASS-SVN] r71734 - in grass/trunk/db/db.describe: . testsuite
svn_grass at osgeo.org
Tue Nov 14 05:12:42 PST 2017
Author: lucadelu
Date: 2017-11-14 05:12:42 -0800 (Tue, 14 Nov 2017)
New Revision: 71734
Added:
grass/trunk/db/db.describe/testsuite/
grass/trunk/db/db.describe/testsuite/test_dbdescribe.py
db.describe: added tests
Added: grass/trunk/db/db.describe/testsuite/test_dbdescribe.py
--- grass/trunk/db/db.describe/testsuite/test_dbdescribe.py (rev 0)
+++ grass/trunk/db/db.describe/testsuite/test_dbdescribe.py 2017-11-14 13:12:42 UTC (rev 71734)
@@ -0,0 +1,186 @@
+#!/usr/bin/env python2
+# -*- coding: utf-8 -*-
+Created on Tue Nov 14 09:43:55 2017
+ at author: lucadelu
+from grass.gunittest.case import TestCase
+from grass.gunittest.main import test
+from grass.script.core import read_command
+output="""table:zipcodes
+description:
+insert:?
+delete:?
+ncols:12
+nrows:44
+column:cat
+description:
+type:INTEGER
+len:20
+scale:0
+precision:0
+default:
+nullok:yes
+select:?
+update:?
+column:OBJECTID
+description:
+type:INTEGER
+len:20
+scale:0
+precision:0
+default:
+nullok:yes
+select:?
+update:?
+column:WAKE_ZIPCO
+description:
+type:DOUBLE PRECISION
+len:20
+scale:0
+precision:0
+default:
+nullok:yes
+select:?
+update:?
+column:PERIMETER
+description:
+len:20
+scale:0
+precision:0
+default:
+nullok:yes
+select:?
+update:?
+column:ZIPCODE_
+description:
+len:20
+scale:0
+precision:0
+default:
+nullok:yes
+select:?
+update:?
+column:ZIPCODE_ID
+description:
+len:20
+scale:0
+precision:0
+default:
+nullok:yes
+select:?
+update:?
+column:ZIPNAME
+description:
+type:CHARACTER
+len:15
+scale:0
+precision:0
+default:
+nullok:yes
+select:?
+update:?
+column:ZIPNUM
+description:
+len:20
+scale:0
+precision:0
+default:
+nullok:yes
+select:?
+update:?
+column:ZIPCODE
+description:
+type:CHARACTER
+len:30
+scale:0
+precision:0
+default:
+nullok:yes
+select:?
+update:?
+column:NAME
+description:
+type:CHARACTER
+len:30
+scale:0
+precision:0
+default:
+nullok:yes
+select:?
+update:?
+column:SHAPE_Leng
+description:
+len:20
+scale:0
+precision:0
+default:
+nullok:yes
+select:?
+update:?
+column:SHAPE_Area
+description:
+len:20
+scale:0
+precision:0
+default:
+nullok:yes
+select:?
+update:?
+outcol="""ncols: 12
+nrows: 44
+Column 1: cat:INTEGER:20
+Column 2: OBJECTID:INTEGER:20
+Column 3: WAKE_ZIPCO:DOUBLE PRECISION:20
+Column 4: PERIMETER:DOUBLE PRECISION:20
+Column 5: ZIPCODE_:DOUBLE PRECISION:20
+Column 6: ZIPCODE_ID:DOUBLE PRECISION:20
+Column 7: ZIPNAME:CHARACTER:15
+Column 8: ZIPNUM:DOUBLE PRECISION:20
+Column 9: ZIPCODE:CHARACTER:30
+Column 10: NAME:CHARACTER:30
+Column 11: SHAPE_Leng:DOUBLE PRECISION:20
+Column 12: SHAPE_Area:DOUBLE PRECISION:20
+class TestDbCopy(TestCase):
+ invect = 'zipcodes'
+ mapset = '$GISDBASE/$LOCATION_NAME/PERMANENT/sqlite/sqlite.db'
+ def test_describe(self):
+ cols = read_command('db.describe', table=self.invect,
+ database=self.mapset)
+ self.assertEqual(first=cols, second=output)
+ def test_columns(self):
+ cols = read_command('db.describe', table=self.invect, flags='c',
+ self.assertEqual(first=cols, second=outcol)
+if __name__ == '__main__':
+ test()
Property changes on: grass/trunk/db/db.describe/testsuite/test_dbdescribe.py
___________________________________________________________________
Added: svn:mime-type
+ text/x-python
Added: svn:eol-style
+ native
