[GRASS-SVN] r71740 - grass-addons/grass7/vector/v.gsflow.grid
svn_grass at osgeo.org
Wed Nov 15 22:34:49 PST 2017
Author: awickert
Date: 2017-11-15 22:34:48 -0800 (Wed, 15 Nov 2017)
New Revision: 71740
grass-addons/grass7/vector/v.gsflow.grid/v.gsflow.grid.py
v.gsflow.grid: 2-part r.mapcalc overwrite for Windows
Modified: grass-addons/grass7/vector/v.gsflow.grid/v.gsflow.grid.py
--- grass-addons/grass7/vector/v.gsflow.grid/v.gsflow.grid.py 2017-11-16 06:34:20 UTC (rev 71739)
+++ grass-addons/grass7/vector/v.gsflow.grid/v.gsflow.grid.py 2017-11-16 06:34:48 UTC (rev 71740)
@@ -195,7 +195,8 @@
# Coarse resolution region:
g.region(w=str(_w), e=str(_e), s=str(_s), n=str(_n), nsres=str(grid_ratio_ns*reg['nsres']), ewres=str(grid_ratio_ew*reg['ewres']))
r.resamp_stats(input=mask, output=mask, method='sum', overwrite=True, quiet=True)
- r.mapcalc(mask+' = '+mask+' > 0', overwrite=True, quiet=True)
+ r.mapcalc('tmp'+' = '+mask+' > 0', overwrite=True, quiet=True)
+ g.rename(raster=('tmp',mask), overwrite=True, quiet=True)
r.null(map=mask, null=0, quiet=True)
# Add mask location (1 vs 0) in the MODFLOW grid
v.db_addcolumn(map=grid, columns='basinmask double precision', quiet=True)
@@ -222,12 +223,14 @@
# May not work with dx != dy!
v.to_rast(input=pp, output='tmp', use='val', value=1, overwrite=True)
r.buffer(input='tmp', output='tmp', distances=float(dx)*1.5, overwrite=True)
- r.mapcalc('tmp = (tmp == 2) * '+raster_input, overwrite=True)
+ r.mapcalc('tmp2 = (tmp == 2) * '+raster_input, overwrite=True)
+ g.rename(raster=('tmp2','tmp'), overwrite=True, quiet=True)
#r.mapcalc('tmp = if(isnull('+raster_input+',0,(tmp == 2)))', overwrite=True)
#g.region(rast='tmp')
#r.null(map=raster_input,
r.drain(input=raster_input, start_points=pp, output='tmp2', overwrite=True)
- r.mapcalc('tmp = tmp2 * tmp', overwrite=True)
+ r.mapcalc('tmp3 = tmp2 * tmp', overwrite=True, quiet=True)
+ g.rename(raster=('tmp3','tmp'), overwrite=True, quiet=True)
r.null(map='tmp', setnull=0)
r.to_vect(input='tmp', output=bc_cell, type='point', column='z',
overwrite=gscript.overwrite(), quiet=True)
