[GRASS-SVN] r71747 - grass/branches/releasebranch_7_4/general/g.mapset
svn_grass at osgeo.org
Thu Nov 16 13:13:51 PST 2017
Author: neteler
Date: 2017-11-16 13:13:51 -0800 (Thu, 16 Nov 2017)
New Revision: 71747
grass/branches/releasebranch_7_4/general/g.mapset/g.mapset.html
g.mapset manual: clarify where shell history is written
Modified: grass/branches/releasebranch_7_4/general/g.mapset/g.mapset.html
--- grass/branches/releasebranch_7_4/general/g.mapset/g.mapset.html 2017-11-16 21:13:05 UTC (rev 71746)
+++ grass/branches/releasebranch_7_4/general/g.mapset/g.mapset.html 2017-11-16 21:13:51 UTC (rev 71747)
@@ -3,14 +3,18 @@
<em>g.mapset</em> changes the current working MAPSET, LOCATION, or GISDBASE.
This is a fairly radical maneuver to run mid-session, take care when running
the GUI at the same time.
+<p>
+With <em>g.mapset</em>, the shell history (i.e. <tt>.bash_history</tt> file
+of the initial location will be used to record the command history.
<h2>NOTES</h2>
-The shell continues to use the history for the old mapset. To change this
-you can switch the history to the new settings by commands. For Bash:
+By default, the shell continues to use the history for the old mapset.
+To change this behaviour the history can be switched to record in the new
+mapset's history file as follows:
<div class="code"><pre>
+# bash example
history -w
history -r /"$GISDBASE/$LOCATION/$MAPSET"/.bash_history
HISTFILE=/"$GISDBASE/$LOCATION/$MAPSET"/.bash_history
