[GRASS-SVN] r71750 - grass/trunk
Thu Nov 16 22:38:41 PST 2017
Author: neteler
Date: 2017-11-16 22:38:41 -0800 (Thu, 16 Nov 2017)
New Revision: 71750
   grass/trunk/config.guess
   grass/trunk/config.sub
config.guess + config.sub: updated from http://git.savannah.gnu.org/cgit/config.git/plain/
Modified: grass/trunk/config.guess
--- grass/trunk/config.guess	2017-11-16 22:32:12 UTC (rev 71749)
+++ grass/trunk/config.guess	2017-11-17 06:38:41 UTC (rev 71750)
@@ -2,7 +2,7 @@
 # Attempt to guess a canonical system name.
 #   Copyright 1992-2017 Free Software Foundation, Inc.
-timestamp='2017-08-08'
+timestamp='2017-11-07'
 # This file is free software; you can redistribute it and/or modify it
 # under the terms of the GNU General Public License as published by
@@ -15,7 +15,7 @@
 # General Public License for more details.
 # You should have received a copy of the GNU General Public License
-# along with this program; if not, see <http://www.gnu.org/licenses/>.
+# along with this program; if not, see <https://www.gnu.org/licenses/>.
 # As a special exception to the GNU General Public License, if you
 # distribute this file as part of a program that contains a
@@ -27,7 +27,7 @@
 # Originally written by Per Bothner; maintained since 2000 by Ben Elliston.
 # You can get the latest version of this script from:
-# http://git.savannah.gnu.org/gitweb/?p=config.git;a=blob_plain;f=config.guess
+# https://git.savannah.gnu.org/gitweb/?p=config.git;a=blob_plain;f=config.guess
 # Please send patches to <config-patches at gnu.org>.
@@ -39,7 +39,7 @@
 Output the configuration name of the system \`$me' is run on.
-Operation modes:
+Options:
   -h, --help         print this help, then exit
   -t, --time-stamp   print date of last modification, then exit
   -v, --version      print version number, then exit
@@ -244,6 +244,9 @@
 	UNAME_MACHINE_ARCH=`arch | sed 's/^.*BSD\.//'`
 	echo ${UNAME_MACHINE_ARCH}-unknown-libertybsd${UNAME_RELEASE}
 	exit ;;
+    *:MidnightBSD:*:*)
+	echo ${UNAME_MACHINE}-unknown-midnightbsd${UNAME_RELEASE}
+	exit ;;
     *:ekkoBSD:*:*)
 	echo ${UNAME_MACHINE}-unknown-ekkobsd${UNAME_RELEASE}
 	exit ;;
@@ -318,15 +321,6 @@
 	exitcode=$?
 	trap '' 0
 	exit $exitcode ;;
-    Alpha\ *:Windows_NT*:*)
-	# How do we know it's Interix rather than the generic POSIX subsystem?
-	# Should we change UNAME_MACHINE based on the output of uname instead
-	# of the specific Alpha model?
-	echo alpha-pc-interix
-	exit ;;
-    21064:Windows_NT:50:3)
-	echo alpha-dec-winnt3.5
-	exit ;;
     Amiga*:UNIX_System_V:4.0:*)
 	echo m68k-unknown-sysv4
 	exit ;;
@@ -488,13 +482,13 @@
 #endif
 	#if defined (host_mips) && defined (MIPSEB)
 	#if defined (SYSTYPE_SYSV)
-	  printf ("mips-mips-riscos%ssysv\n", argv[1]); exit (0);
+	  printf ("mips-mips-riscos%ssysv\\n", argv[1]); exit (0);
 	#endif
 	#if defined (SYSTYPE_SVR4)
-	  printf ("mips-mips-riscos%ssvr4\n", argv[1]); exit (0);
+	  printf ("mips-mips-riscos%ssvr4\\n", argv[1]); exit (0);
 	#endif
 	#if defined (SYSTYPE_BSD43) || defined(SYSTYPE_BSD)
-	  printf ("mips-mips-riscos%sbsd\n", argv[1]); exit (0);
+	  printf ("mips-mips-riscos%sbsd\\n", argv[1]); exit (0);
 	#endif
 	#endif
 	  exit (-1);
@@ -617,7 +611,7 @@
     *:AIX:*:*)
 	echo rs6000-ibm-aix
 	exit ;;
-    ibmrt:4.4BSD:*|romp-ibm:BSD:*)
+    ibmrt:4.4BSD:*|romp-ibm:4.4BSD:*)
 	echo romp-ibm-bsd4.4
 	exit ;;
     ibmrt:*BSD:*|romp-ibm:BSD:*)            # covers RT/PC BSD and
@@ -638,8 +632,8 @@
     9000/[34678]??:HP-UX:*:*)
 	HPUX_REV=`echo ${UNAME_RELEASE}|sed -e 's/[^.]*.[0B]*//'`
 	case "${UNAME_MACHINE}" in
-	    9000/31? )            HP_ARCH=m68000 ;;
-	    9000/[34]?? )         HP_ARCH=m68k ;;
+	    9000/31?)            HP_ARCH=m68000 ;;
+	    9000/[34]??)         HP_ARCH=m68k ;;
 	    9000/[678][0-9][0-9])
 		if [ -x /usr/bin/getconf ]; then
 		    sc_cpu_version=`/usr/bin/getconf SC_CPU_VERSION 2>/dev/null`
@@ -752,7 +746,7 @@
 		{ echo "$SYSTEM_NAME"; exit; }
 	echo unknown-hitachi-hiuxwe2
 	exit ;;
-    9000/7??:4.3bsd:*:* | 9000/8?[79]:4.3bsd:*:* )
+    9000/7??:4.3bsd:*:* | 9000/8?[79]:4.3bsd:*:*)
 	echo hppa1.1-hp-bsd
 	exit ;;
     9000/8??:4.3bsd:*:*)
@@ -761,7 +755,7 @@
     *9??*:MPE/iX:*:* | *3000*:MPE/iX:*:*)
 	echo hppa1.0-hp-mpeix
 	exit ;;
-    hp7??:OSF1:*:* | hp8?[79]:OSF1:*:* )
+    hp7??:OSF1:*:* | hp8?[79]:OSF1:*:*)
 	echo hppa1.1-hp-osf
 	exit ;;
     hp8??:OSF1:*:*)
@@ -858,10 +852,6 @@
     *:MSYS*:*)
 	echo ${UNAME_MACHINE}-pc-msys
 	exit ;;
-    i*:windows32*:*)
-	# uname -m includes "-pc" on this system.
-	echo ${UNAME_MACHINE}-mingw32
-	exit ;;
     i*:PW*:*)
 	echo ${UNAME_MACHINE}-pc-pw32
 	exit ;;
@@ -877,27 +867,12 @@
 		echo ia64-unknown-interix${UNAME_RELEASE}
 		exit ;;
 	esac ;;
-    [345]86:Windows_95:* | [345]86:Windows_98:* | [345]86:Windows_NT:*)
-	echo i${UNAME_MACHINE}-pc-mks
-	exit ;;
-    8664:Windows_NT:*)
-	echo x86_64-pc-mks
-	exit ;;
-    i*:Windows_NT*:* | Pentium*:Windows_NT*:*)
-	# It also conflicts with pre-2.0 versions of AT&T UWIN. Should we
-	# UNAME_MACHINE based on the output of uname instead of i386?
-	echo i586-pc-interix
-	exit ;;
     i*:UWIN*:*)
 	echo ${UNAME_MACHINE}-pc-uwin
 	exit ;;
     amd64:CYGWIN*:*:* | x86_64:CYGWIN*:*:*)
 	echo x86_64-unknown-cygwin
 	exit ;;
-    p*:CYGWIN*:*)
-	echo powerpcle-unknown-cygwin
-	exit ;;
     prep*:SunOS:5.*:*)
 	echo powerpcle-unknown-solaris2`echo ${UNAME_RELEASE}|sed -e 's/[^.]*//'`
 	exit ;;
@@ -1100,7 +1075,7 @@
     i*86:*DOS:*:*)
 	echo ${UNAME_MACHINE}-pc-msdosdjgpp
 	exit ;;
-    i*86:*:4.*:* | i*86:SYSTEM_V:4.*:*)
+    i*86:*:4.*:*)
 	UNAME_REL=`echo ${UNAME_RELEASE} | sed 's/\/MP$//'`
 	if grep Novell /usr/include/link.h >/dev/null 2>/dev/null; then
 		echo ${UNAME_MACHINE}-univel-sysv${UNAME_REL}
@@ -1428,16 +1403,28 @@
 	exit ;;
 esac
+echo "$0: unable to guess system type" >&2
+case "${UNAME_MACHINE}:${UNAME_SYSTEM}" in
+    mips:Linux | mips64:Linux)
+	# If we got here on MIPS GNU/Linux, output extra information.
+	cat >&2 <<EOF
+NOTE: MIPS GNU/Linux systems require a C compiler to fully recognize
+the system type. Please install a C compiler and try again.
+EOF
+esac
 cat >&2 <<EOF
-$0: unable to guess system type
 This script (version $timestamp), has failed to recognize the
 operating system you are using. If your script is old, overwrite *all*
 copies of config.guess and config.sub with the latest versions from:
-  http://git.savannah.gnu.org/gitweb/?p=config.git;a=blob_plain;f=config.guess
+  https://git.savannah.gnu.org/gitweb/?p=config.git;a=blob_plain;f=config.guess
 and
-  http://git.savannah.gnu.org/gitweb/?p=config.git;a=blob_plain;f=config.sub
+  https://git.savannah.gnu.org/gitweb/?p=config.git;a=blob_plain;f=config.sub
 If $0 has already been updated, send the following data and any
 information you think might be pertinent to config-patches at gnu.org to
@@ -1469,7 +1456,7 @@
 exit 1
 # Local variables:
-# eval: (add-hook 'write-file-hooks 'time-stamp)
+# eval: (add-hook 'write-file-functions 'time-stamp)
 # time-stamp-start: "timestamp='"
 # time-stamp-format: "%:y-%02m-%02d"
 # time-stamp-end: "'"
Modified: grass/trunk/config.sub
--- grass/trunk/config.sub	2017-11-16 22:32:12 UTC (rev 71749)
+++ grass/trunk/config.sub	2017-11-17 06:38:41 UTC (rev 71750)
@@ -2,7 +2,7 @@
 # Configuration validation subroutine script.
-timestamp='2017-04-02'
+timestamp='2017-11-04'
@@ -15,7 +15,7 @@
@@ -33,7 +33,7 @@
 # Otherwise, we print the canonical config type on stdout and succeed.
-# http://git.savannah.gnu.org/gitweb/?p=config.git;a=blob_plain;f=config.sub
+# https://git.savannah.gnu.org/gitweb/?p=config.git;a=blob_plain;f=config.sub
 # This file is supposed to be the same for all GNU packages
 # and recognize all the CPU types, system types and aliases
@@ -57,7 +57,7 @@
 Canonicalize a configuration name.
-Operation modes:
+Options:
@@ -229,9 +229,6 @@
 	-ptx*)
 		basic_machine=`echo $1 | sed -e 's/86-.*/86-sequent/'`
-	-windowsnt*)
-		os=`echo $os | sed -e 's/windowsnt/winnt/'`
 	-psos*)
 		os=-psos
@@ -316,7 +313,6 @@
 	| v850 | v850e | v850e1 | v850e2 | v850es | v850e2v3 \
 	| visium \
 	| wasm32 \
-	| we32k \
 	| x86 | xc16x | xstormy16 | xtensa \
 	| z8k | z80)
 		basic_machine=$basic_machine-unknown
@@ -643,7 +639,7 @@
 		basic_machine=rs6000-bull
 		os=-bosx
-	dpx2* | dpx2*-bull)
+	dpx2*)
 		basic_machine=m68k-bull
 		os=-sysv3
@@ -905,7 +901,7 @@
 		basic_machine=v70-nec
 		os=-sysv
-	next | m*-next )
+	next | m*-next)
 		basic_machine=m68k-next
 		case $os in
 		    -nextstep* )
@@ -1259,6 +1255,9 @@
 		basic_machine=hppa1.1-winbond
 		os=-proelf
+	x64)
+		basic_machine=x86_64-pc
 	xbox)
 		basic_machine=i686-pc
 		os=-mingw32
@@ -1366,8 +1365,8 @@
 if [ x"$os" != x"" ]
 then
 case $os in
-	# First match some system type aliases
-	# that might get confused with valid system types.
+	# First match some system type aliases that might get confused
+	# with valid system types.
 	# -solaris* is a basic system type, with this one exception.
 	-auroraux)
 		os=-auroraux
@@ -1387,9 +1386,9 @@
 	-gnu/linux*)
 		os=`echo $os | sed -e 's|gnu/linux|linux-gnu|'`
-	# First accept the basic system types.
+	# Now accept the basic system types.
 	# The portable systems comes first.
-	# Each alternative MUST END IN A *, to match a version number.
+	# Each alternative MUST end in a * to match a version number.
 	# -sysv* is not here because it comes later, after sysvr4.
 	-gnu* | -bsd* | -mach* | -minix* | -genix* | -ultrix* | -irix* \
 	      | -*vms* | -sco* | -esix* | -isc* | -aix* | -cnk* | -sunos | -sunos[34]*\
@@ -1492,7 +1491,7 @@
 	-nova*)
 		os=-rtmk-nova
-	-ns2 )
+	-ns2)
 		os=-nextstep2
 	-nsk*)
@@ -1694,7 +1693,7 @@
 	m88k-omron*)
 		os=-luna
-	*-next )
+	*-next)
 		os=-nextstep
 	*-sequent)
@@ -1829,7 +1828,7 @@
 exit
 # Local variables:
