[GRASS-SVN] r71757 - grass/trunk
Fri Nov 17 02:47:08 PST 2017
Author: martinl
Date: 2017-11-17 02:47:08 -0800 (Fri, 17 Nov 2017)
New Revision: 71757
   grass/trunk/configure
   grass/trunk/configure.in
configure: check for liblas/capi/liblas.h
Modified: grass/trunk/configure
--- grass/trunk/configure	2017-11-17 10:24:03 UTC (rev 71756)
+++ grass/trunk/configure	2017-11-17 10:47:08 UTC (rev 71757)
@@ -6450,15 +6450,52 @@
   LIBS="$LIBS $LIBLAS_LIBS"
   CFLAGS="$CFLAGS $LIBLAS_CFLAGS"
   CPPFLAGS="$CPPFLAGS $LIBLAS_INC"
+  for ac_hdr in liblas/capi/liblas.h
+do
+ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
+echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
+echo "configure:6458: checking for $ac_hdr" >&5
+cat > conftest.$ac_ext <<EOF
+#line 6461 "configure"
+#include "confdefs.h"
+#include <$ac_hdr>
+EOF
+ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
+{ (eval echo configure:6466: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
+if test -z "$ac_err"; then
+  rm -rf conftest*
+  eval "ac_cv_header_$ac_safe=yes"
+else
+  echo "$ac_err" >&5
+  echo "configure: failed program was:" >&5
+  cat conftest.$ac_ext >&5
+  rm -rf conftest*
+  eval "ac_cv_header_$ac_safe=no"
+fi
+rm -f conftest*
+if eval "test \"`echo '$ac_cv_header_'$ac_safe`\" = yes"; then
+  echo "$ac_t""yes" 1>&6
+    ac_tr_hdr=HAVE_`echo $ac_hdr | sed 'y%abcdefghijklmnopqrstuvwxyz./-%ABCDEFGHIJKLMNOPQRSTUVWXYZ___%'`
+  cat >> confdefs.h <<EOF
+#define $ac_tr_hdr 1
+EOF
+else
+  echo "$ac_t""no" 1>&6
+fi
+done
-#line 6455 "configure"
+#line 6492 "configure"
 #include <liblas/capi/liblas.h>
 int main() {
 LASReader_Create("foo");
 ; return 0; }
 EOF
-if { (eval echo configure:6462: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6499: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
 else
@@ -6466,14 +6503,14 @@
   rm -rf conftest*
-#line 6470 "configure"
+#line 6507 "configure"
 int main() {
 ; return 0; }
 EOF
-if { (eval echo configure:6477: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6514: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   LAS_LIBS="$LAS_LIBS"
 else
@@ -6506,7 +6543,7 @@
 # PDAL option
 echo $ac_n "checking whether to use PDAL""... $ac_c" 1>&6
-echo "configure:6510: checking whether to use PDAL" >&5
+echo "configure:6547: checking whether to use PDAL" >&5
 # new and currently used way to switch language to C++
 # AC_LANG_PUSH(C++)
@@ -6534,7 +6571,7 @@
   # Extract the first word of "pdal-config", so it can be a program name with args.
 set dummy pdal-config; ac_word=$2
 echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:6538: checking for $ac_word" >&5
+echo "configure:6575: checking for $ac_word" >&5
 case "$PDAL_CONFIG" in
@@ -6584,14 +6621,14 @@
   CFLAGS="$CFLAGS $PDAL_CFLAGS"
   CPPFLAGS="$CPPFLAGS $PDAL_CPPFLAGS $PDAL_INC"
-#line 6588 "configure"
+#line 6625 "configure"
 #include <pdal/PointTable.hpp>
 int main() {
 pdal::PointTable table;
 ; return 0; }
 EOF
-if { (eval echo configure:6595: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6632: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
 else
@@ -6599,14 +6636,14 @@
   rm -rf conftest*
-#line 6603 "configure"
+#line 6640 "configure"
 int main() {
 ; return 0; }
 EOF
-if { (eval echo configure:6610: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6647: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   PDAL_LIBS="$PDAL_LIBS"
 else
@@ -6656,7 +6693,7 @@
 # NetCDF option
 echo $ac_n "checking whether to use NetCDF""... $ac_c" 1>&6
-echo "configure:6660: checking whether to use NetCDF" >&5
+echo "configure:6697: checking whether to use NetCDF" >&5
 NETCDF_LIBS=
 NETCDF_CFLAGS=
@@ -6673,7 +6710,7 @@
   # Extract the first word of "nc-config", so it can be a program name with args.
 set dummy nc-config; ac_word=$2
-echo "configure:6677: checking for $ac_word" >&5
+echo "configure:6714: checking for $ac_word" >&5
 case "$NETCDF_CONFIG" in
@@ -6720,14 +6757,14 @@
   LIBS="$LIBS $NETCDF_LIBS"
   CFLAGS="$CFLAGS $NETCDF_CFLAGS"
-#line 6724 "configure"
+#line 6761 "configure"
 #include <netcdf.h>
 int main() {
 nc_create("foo", NC_CLOBBER, NULL);
 ; return 0; }
 EOF
-if { (eval echo configure:6731: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6768: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
 else
@@ -6735,14 +6772,14 @@
   rm -rf conftest*
-#line 6739 "configure"
+#line 6776 "configure"
 #include <netcdf.h>
 int main() {
 ; return 0; }
 EOF
-if { (eval echo configure:6746: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6783: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   NETCDF_LIBS="$NETCDF_LIBS"
 else
@@ -6773,7 +6810,7 @@
 # GEOS option
 echo $ac_n "checking whether to use GEOS""... $ac_c" 1>&6
-echo "configure:6777: checking whether to use GEOS" >&5
+echo "configure:6814: checking whether to use GEOS" >&5
 GEOS_LIBS=
 GEOS_CFLAGS=
@@ -6791,7 +6828,7 @@
   # Extract the first word of "geos-config", so it can be a program name with args.
 set dummy geos-config; ac_word=$2
-echo "configure:6795: checking for $ac_word" >&5
+echo "configure:6832: checking for $ac_word" >&5
 case "$GEOS_CONFIG" in
@@ -6839,15 +6876,15 @@
 do
-echo "configure:6843: checking for $ac_hdr" >&5
+echo "configure:6880: checking for $ac_hdr" >&5
-#line 6846 "configure"
+#line 6883 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:6851: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:6888: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -6886,13 +6923,13 @@
 echo $ac_n "checking for initGEOS in -lgeos_c""... $ac_c" 1>&6
-echo "configure:6890: checking for initGEOS in -lgeos_c" >&5
+echo "configure:6927: checking for initGEOS in -lgeos_c" >&5
 ac_lib_var=`echo geos_c'_'initGEOS | sed 'y%./+-%__p_%'`
 ac_save_LIBS="$LIBS"
 LIBS="-lgeos_c  $LIBS"
-#line 6896 "configure"
+#line 6933 "configure"
 /* Override any gcc2 internal prototype to avoid an error.  */
 /* We use char because int might match the return type of a gcc2
@@ -6903,7 +6940,7 @@
 initGEOS()
 ; return 0; }
 EOF
-if { (eval echo configure:6907: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6944: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_lib_$ac_lib_var=yes"
 else
@@ -6947,7 +6984,7 @@
 echo $ac_n "checking whether to use TIFF""... $ac_c" 1>&6
-echo "configure:6951: checking whether to use TIFF" >&5
+echo "configure:6988: checking whether to use TIFF" >&5
 echo "$ac_t"""$with_tiff"" 1>&6
 case "$with_tiff" in
 	"no")	USE_TIFF=	;;
@@ -6967,7 +7004,7 @@
 echo $ac_n "checking for location of TIFF includes""... $ac_c" 1>&6
-echo "configure:6971: checking for location of TIFF includes" >&5
+echo "configure:7008: checking for location of TIFF includes" >&5
 case "$with_tiff_includes" in
 y | ye | yes | n | no)
 	{ echo "configure: error: *** You must supply a directory to --with-tiff-includes." 1>&2; exit 1; }
@@ -6993,15 +7030,15 @@
 do
-echo "configure:6997: checking for $ac_hdr" >&5
+echo "configure:7034: checking for $ac_hdr" >&5
-#line 7000 "configure"
+#line 7037 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:7005: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7042: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -7035,7 +7072,7 @@
 echo $ac_n "checking for location of TIFF library""... $ac_c" 1>&6
-echo "configure:7039: checking for location of TIFF library" >&5
+echo "configure:7076: checking for location of TIFF library" >&5
 case "$with_tiff_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-tiff-libs." 1>&2; exit 1; }
@@ -7066,13 +7103,13 @@
 echo $ac_n "checking for TIFFOpen in -ltiff""... $ac_c" 1>&6
-echo "configure:7070: checking for TIFFOpen in -ltiff" >&5
+echo "configure:7107: checking for TIFFOpen in -ltiff" >&5
 ac_lib_var=`echo tiff'_'TIFFOpen | sed 'y%./+-%__p_%'`
 LIBS="-ltiff  $LIBS"
-#line 7076 "configure"
+#line 7113 "configure"
@@ -7083,7 +7120,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:7087: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7124: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7102,13 +7139,13 @@
-echo "configure:7106: checking for TIFFOpen in -ltiff" >&5
+echo "configure:7143: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff $MATHLIB $LIBS"
-#line 7112 "configure"
+#line 7149 "configure"
@@ -7119,7 +7156,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:7123: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7160: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7138,13 +7175,13 @@
-echo "configure:7142: checking for TIFFOpen in -ltiff" >&5
+echo "configure:7179: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff $ZLIB $LIBS"
-#line 7148 "configure"
+#line 7185 "configure"
@@ -7155,7 +7192,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:7159: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7196: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7174,13 +7211,13 @@
-echo "configure:7178: checking for TIFFOpen in -ltiff" >&5
+echo "configure:7215: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff $ZLIB $MATHLIB $LIBS"
-#line 7184 "configure"
+#line 7221 "configure"
@@ -7191,7 +7228,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:7195: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7232: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7210,13 +7247,13 @@
-echo "configure:7214: checking for TIFFOpen in -ltiff" >&5
+echo "configure:7251: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff -ljpeg $LIBS"
-#line 7220 "configure"
+#line 7257 "configure"
@@ -7227,7 +7264,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:7231: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7268: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7246,13 +7283,13 @@
-echo "configure:7250: checking for TIFFOpen in -ltiff" >&5
+echo "configure:7287: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff -ljpeg $MATHLIB $LIBS"
-#line 7256 "configure"
+#line 7293 "configure"
@@ -7263,7 +7300,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:7267: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7304: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7282,13 +7319,13 @@
-echo "configure:7286: checking for TIFFOpen in -ltiff" >&5
+echo "configure:7323: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff -ljpeg $ZLIB $LIBS"
-#line 7292 "configure"
+#line 7329 "configure"
@@ -7299,7 +7336,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:7303: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7340: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7318,13 +7355,13 @@
-echo "configure:7322: checking for TIFFOpen in -ltiff" >&5
+echo "configure:7359: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff -ljpeg $ZLIB $MATHLIB $LIBS"
-#line 7328 "configure"
+#line 7365 "configure"
@@ -7335,7 +7372,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:7339: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7376: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7433,7 +7470,7 @@
 echo $ac_n "checking whether to use PNG""... $ac_c" 1>&6
-echo "configure:7437: checking whether to use PNG" >&5
+echo "configure:7474: checking whether to use PNG" >&5
 echo "$ac_t"""$with_png"" 1>&6
 case "$with_png" in
 	"no")	USE_PNG=	;;
@@ -7452,7 +7489,7 @@
 echo $ac_n "checking for location of PNG includes""... $ac_c" 1>&6
-echo "configure:7456: checking for location of PNG includes" >&5
+echo "configure:7493: checking for location of PNG includes" >&5
 case "$with_png_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-png-includes." 1>&2; exit 1; }
@@ -7478,15 +7515,15 @@
 do
-echo "configure:7482: checking for $ac_hdr" >&5
+echo "configure:7519: checking for $ac_hdr" >&5
-#line 7485 "configure"
+#line 7522 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:7490: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7527: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -7520,7 +7557,7 @@
 echo $ac_n "checking for location of PNG library""... $ac_c" 1>&6
-echo "configure:7524: checking for location of PNG library" >&5
+echo "configure:7561: checking for location of PNG library" >&5
 case "$with_png_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-png-libs." 1>&2; exit 1; }
@@ -7545,13 +7582,13 @@
 echo $ac_n "checking for png_read_image in -lpng""... $ac_c" 1>&6
-echo "configure:7549: checking for png_read_image in -lpng" >&5
+echo "configure:7586: checking for png_read_image in -lpng" >&5
 ac_lib_var=`echo png'_'png_read_image | sed 'y%./+-%__p_%'`
 LIBS="-lpng $ZLIB $MATHLIB $LIBS"
-#line 7555 "configure"
+#line 7592 "configure"
@@ -7562,7 +7599,7 @@
 png_read_image()
 ; return 0; }
 EOF
-if { (eval echo configure:7566: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7603: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7604,7 +7641,7 @@
 echo $ac_n "checking whether to use PostgreSQL""... $ac_c" 1>&6
-echo "configure:7608: checking whether to use PostgreSQL" >&5
+echo "configure:7645: checking whether to use PostgreSQL" >&5
 echo "$ac_t"""$with_postgres"" 1>&6
 case "$with_postgres" in
 	"no")	USE_POSTGRES=	;;
@@ -7631,7 +7668,7 @@
 echo $ac_n "checking for location of PostgreSQL includes""... $ac_c" 1>&6
-echo "configure:7635: checking for location of PostgreSQL includes" >&5
+echo "configure:7672: checking for location of PostgreSQL includes" >&5
 case "$with_postgres_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-postgres-includes." 1>&2; exit 1; }
@@ -7657,15 +7694,15 @@
 do
-echo "configure:7661: checking for $ac_hdr" >&5
+echo "configure:7698: checking for $ac_hdr" >&5
-#line 7664 "configure"
+#line 7701 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:7669: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7706: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -7703,7 +7740,7 @@
 echo $ac_n "checking for location of PostgreSQL library""... $ac_c" 1>&6
-echo "configure:7707: checking for location of PostgreSQL library" >&5
+echo "configure:7744: checking for location of PostgreSQL library" >&5
 case "$with_postgres_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-postgres-libs." 1>&2; exit 1; }
@@ -7732,13 +7769,13 @@
 echo $ac_n "checking for PQsetdbLogin in -lpq""... $ac_c" 1>&6
-echo "configure:7736: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:7773: checking for PQsetdbLogin in -lpq" >&5
 ac_lib_var=`echo pq'_'PQsetdbLogin | sed 'y%./+-%__p_%'`
 LIBS="-lpq  $LIBS"
-#line 7742 "configure"
+#line 7779 "configure"
@@ -7749,7 +7786,7 @@
 PQsetdbLogin()
 ; return 0; }
 EOF
-if { (eval echo configure:7753: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7790: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7768,13 +7805,13 @@
-echo "configure:7772: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:7809: checking for PQsetdbLogin in -lpq" >&5
 LIBS="-lpq -lssl -lcrypto $LIBS"
-#line 7778 "configure"
+#line 7815 "configure"
@@ -7785,7 +7822,7 @@
 PQsetdbLogin()
 ; return 0; }
 EOF
-if { (eval echo configure:7789: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7826: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7804,13 +7841,13 @@
-echo "configure:7808: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:7845: checking for PQsetdbLogin in -lpq" >&5
 LIBS="-lpq -lcrypt $LIBS"
-#line 7814 "configure"
+#line 7851 "configure"
@@ -7821,7 +7858,7 @@
 PQsetdbLogin()
 ; return 0; }
 EOF
-if { (eval echo configure:7825: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7862: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7840,13 +7877,13 @@
-echo "configure:7844: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:7881: checking for PQsetdbLogin in -lpq" >&5
 LIBS="-lpq -lcrypt -lssl -lcrypto $LIBS"
-#line 7850 "configure"
+#line 7887 "configure"
@@ -7857,7 +7894,7 @@
 PQsetdbLogin()
 ; return 0; }
 EOF
-if { (eval echo configure:7861: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7898: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7914,13 +7951,13 @@
 ac_save_ldflags="$LDFLAGS"
 LDFLAGS="$LDFLAGS $PQLIBPATH"
 echo $ac_n "checking for PQcmdTuples in -lpq""... $ac_c" 1>&6
-echo "configure:7918: checking for PQcmdTuples in -lpq" >&5
+echo "configure:7955: checking for PQcmdTuples in -lpq" >&5
 ac_lib_var=`echo pq'_'PQcmdTuples | sed 'y%./+-%__p_%'`
 LIBS="-lpq  $LIBS"
-#line 7924 "configure"
+#line 7961 "configure"
@@ -7931,7 +7968,7 @@
 PQcmdTuples()
 ; return 0; }
 EOF
-if { (eval echo configure:7935: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7972: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7953,13 +7990,13 @@
-echo "configure:7957: checking for PQcmdTuples in -lpq" >&5
+echo "configure:7994: checking for PQcmdTuples in -lpq" >&5
-#line 7963 "configure"
+#line 8000 "configure"
@@ -7970,7 +8007,7 @@
 PQcmdTuples()
 ; return 0; }
 EOF
-if { (eval echo configure:7974: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8011: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8013,7 +8050,7 @@
 echo $ac_n "checking whether to use MySQL""... $ac_c" 1>&6
-echo "configure:8017: checking whether to use MySQL" >&5
+echo "configure:8054: checking whether to use MySQL" >&5
 echo "$ac_t"""$with_mysql"" 1>&6
 case "$with_mysql" in
 	"no")	USE_MYSQL=	;;
@@ -8033,7 +8070,7 @@
 echo $ac_n "checking for location of MySQL includes""... $ac_c" 1>&6
-echo "configure:8037: checking for location of MySQL includes" >&5
+echo "configure:8074: checking for location of MySQL includes" >&5
 case "$with_mysql_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-mysql-includes." 1>&2; exit 1; }
@@ -8059,15 +8096,15 @@
 do
-echo "configure:8063: checking for $ac_hdr" >&5
+echo "configure:8100: checking for $ac_hdr" >&5
-#line 8066 "configure"
+#line 8103 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:8071: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8108: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -8104,7 +8141,7 @@
 echo $ac_n "checking for location of MySQL library""... $ac_c" 1>&6
-echo "configure:8108: checking for location of MySQL library" >&5
+echo "configure:8145: checking for location of MySQL library" >&5
 case "$with_mysql_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-mysql-libs." 1>&2; exit 1; }
@@ -8135,13 +8172,13 @@
 echo $ac_n "checking for mysql_query in -lmysqlclient""... $ac_c" 1>&6
-echo "configure:8139: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:8176: checking for mysql_query in -lmysqlclient" >&5
 ac_lib_var=`echo mysqlclient'_'mysql_query | sed 'y%./+-%__p_%'`
 LIBS="-lmysqlclient  $LIBS"
-#line 8145 "configure"
+#line 8182 "configure"
@@ -8152,7 +8189,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:8156: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8193: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8171,13 +8208,13 @@
-echo "configure:8175: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:8212: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $MATHLIB $LIBS"
-#line 8181 "configure"
+#line 8218 "configure"
@@ -8188,7 +8225,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:8192: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8229: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8207,13 +8244,13 @@
-echo "configure:8211: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:8248: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $SOCKLIB $LIBS"
-#line 8217 "configure"
+#line 8254 "configure"
@@ -8224,7 +8261,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:8228: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8265: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8243,13 +8280,13 @@
-echo "configure:8247: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:8284: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $SOCKLIB $MATHLIB $LIBS"
-#line 8253 "configure"
+#line 8290 "configure"
@@ -8260,7 +8297,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:8264: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8301: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8279,13 +8316,13 @@
-echo "configure:8283: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:8320: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $ZLIB $LIBS"
-#line 8289 "configure"
+#line 8326 "configure"
@@ -8296,7 +8333,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:8300: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8337: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8315,13 +8352,13 @@
-echo "configure:8319: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:8356: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $ZLIB $MATHLIB $LIBS"
-#line 8325 "configure"
+#line 8362 "configure"
@@ -8332,7 +8369,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:8336: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8373: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8351,13 +8388,13 @@
-echo "configure:8355: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:8392: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $ZLIB $SOCKLIB $LIBS"
-#line 8361 "configure"
+#line 8398 "configure"
@@ -8368,7 +8405,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:8372: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8409: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8387,13 +8424,13 @@
-echo "configure:8391: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:8428: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $ZLIB $SOCKLIB $MATHLIB $LIBS"
-#line 8397 "configure"
+#line 8434 "configure"
@@ -8404,7 +8441,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:8408: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8445: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8494,7 +8531,7 @@
   # Extract the first word of "mysql_config", so it can be a program name with args.
 set dummy mysql_config; ac_word=$2
-echo "configure:8498: checking for $ac_word" >&5
+echo "configure:8535: checking for $ac_word" >&5
 case "$MYSQLD_CONFIG" in
@@ -8543,10 +8580,10 @@
     LIBS="$MYSQLDLIB $LIBS"
     echo $ac_n "checking for mysql_server_init""... $ac_c" 1>&6
-echo "configure:8547: checking for mysql_server_init" >&5
+echo "configure:8584: checking for mysql_server_init" >&5
-#line 8550 "configure"
+#line 8587 "configure"
 /* System header to define __stub macros and hopefully few prototypes,
     which can conflict with char mysql_server_init(); below.  */
@@ -8572,7 +8609,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:8576: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8613: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_mysql_server_init=yes"
 else
@@ -8624,7 +8661,7 @@
 echo $ac_n "checking whether to use SQLite""... $ac_c" 1>&6
-echo "configure:8628: checking whether to use SQLite" >&5
+echo "configure:8665: checking whether to use SQLite" >&5
 echo "$ac_t"""$with_sqlite"" 1>&6
 case "$with_sqlite" in
 	"no")	USE_SQLITE=	;;
@@ -8644,7 +8681,7 @@
 echo $ac_n "checking for location of SQLite includes""... $ac_c" 1>&6
-echo "configure:8648: checking for location of SQLite includes" >&5
+echo "configure:8685: checking for location of SQLite includes" >&5
 case "$with_sqlite_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-sqlite-includes." 1>&2; exit 1; }
@@ -8670,15 +8707,15 @@
 do
-echo "configure:8674: checking for $ac_hdr" >&5
+echo "configure:8711: checking for $ac_hdr" >&5
-#line 8677 "configure"
+#line 8714 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:8682: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8719: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -8721,7 +8758,7 @@
 echo $ac_n "checking for location of SQLite library""... $ac_c" 1>&6
-echo "configure:8725: checking for location of SQLite library" >&5
+echo "configure:8762: checking for location of SQLite library" >&5
 case "$with_sqlite_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-sqlite-libs." 1>&2; exit 1; }
@@ -8750,13 +8787,13 @@
 echo $ac_n "checking for sqlite3_open in -lsqlite3""... $ac_c" 1>&6
-echo "configure:8754: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:8791: checking for sqlite3_open in -lsqlite3" >&5
 ac_lib_var=`echo sqlite3'_'sqlite3_open | sed 'y%./+-%__p_%'`
 LIBS="-lsqlite3  $LIBS"
-#line 8760 "configure"
+#line 8797 "configure"
@@ -8767,7 +8804,7 @@
 sqlite3_open()
 ; return 0; }
 EOF
-if { (eval echo configure:8771: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8808: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8786,13 +8823,13 @@
-echo "configure:8790: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:8827: checking for sqlite3_open in -lsqlite3" >&5
 LIBS="-lsqlite3 $DLLIB $LIBS"
-#line 8796 "configure"
+#line 8833 "configure"
@@ -8803,7 +8840,7 @@
 sqlite3_open()
 ; return 0; }
 EOF
-if { (eval echo configure:8807: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8844: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8822,13 +8859,13 @@
-echo "configure:8826: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:8863: checking for sqlite3_open in -lsqlite3" >&5
 LIBS="-lsqlite3 $MATHLIB $LIBS"
-#line 8832 "configure"
+#line 8869 "configure"
@@ -8839,7 +8876,7 @@
 sqlite3_open()
 ; return 0; }
 EOF
-if { (eval echo configure:8843: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8880: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8858,13 +8895,13 @@
-echo "configure:8862: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:8899: checking for sqlite3_open in -lsqlite3" >&5
 LIBS="-lsqlite3 $MATHLIB $DLLIB $LIBS"
-#line 8868 "configure"
+#line 8905 "configure"
@@ -8875,7 +8912,7 @@
 sqlite3_open()
 ; return 0; }
 EOF
-if { (eval echo configure:8879: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8916: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8950,7 +8987,7 @@
 OPENGL_WINDOWS=
 echo $ac_n "checking whether to use OpenGL""... $ac_c" 1>&6
-echo "configure:8954: checking whether to use OpenGL" >&5
+echo "configure:8991: checking whether to use OpenGL" >&5
 echo "$ac_t"""$with_opengl"" 1>&6
 case "$with_opengl" in
 	n|no)
@@ -8984,7 +9021,7 @@
 echo $ac_n "checking for location of OpenGL includes""... $ac_c" 1>&6
-echo "configure:8988: checking for location of OpenGL includes" >&5
+echo "configure:9025: checking for location of OpenGL includes" >&5
 case "$with_opengl_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-opengl-includes." 1>&2; exit 1; }
@@ -9010,15 +9047,15 @@
 do
-echo "configure:9014: checking for $ac_hdr" >&5
+echo "configure:9051: checking for $ac_hdr" >&5
-#line 9017 "configure"
+#line 9054 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:9022: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:9059: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -9052,7 +9089,7 @@
 echo $ac_n "checking for location of OpenGL library""... $ac_c" 1>&6
-echo "configure:9056: checking for location of OpenGL library" >&5
+echo "configure:9093: checking for location of OpenGL library" >&5
 case "$with_opengl_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-opengl-libs." 1>&2; exit 1; }
@@ -9081,13 +9118,13 @@
 echo $ac_n "checking for glBegin in -lGL""... $ac_c" 1>&6
-echo "configure:9085: checking for glBegin in -lGL" >&5
+echo "configure:9122: checking for glBegin in -lGL" >&5
 ac_lib_var=`echo GL'_'glBegin | sed 'y%./+-%__p_%'`
 LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB  $LIBS"
-#line 9091 "configure"
+#line 9128 "configure"
@@ -9098,7 +9135,7 @@
 glBegin()
 ; return 0; }
 EOF
-if { (eval echo configure:9102: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9139: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9117,13 +9154,13 @@
-echo "configure:9121: checking for glBegin in -lGL" >&5
+echo "configure:9158: checking for glBegin in -lGL" >&5
 LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lXext $LIBS"
-#line 9127 "configure"
+#line 9164 "configure"
@@ -9134,7 +9171,7 @@
 glBegin()
 ; return 0; }
 EOF
-if { (eval echo configure:9138: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9175: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9153,13 +9190,13 @@
-echo "configure:9157: checking for glBegin in -lGL" >&5
+echo "configure:9194: checking for glBegin in -lGL" >&5
 LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lpthread $LIBS"
-#line 9163 "configure"
+#line 9200 "configure"
@@ -9170,7 +9207,7 @@
 glBegin()
 ; return 0; }
 EOF
-if { (eval echo configure:9174: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9211: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9189,13 +9226,13 @@
-echo "configure:9193: checking for glBegin in -lGL" >&5
+echo "configure:9230: checking for glBegin in -lGL" >&5
 LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lpthread -lXext $LIBS"
-#line 9199 "configure"
+#line 9236 "configure"
@@ -9206,7 +9243,7 @@
 glBegin()
 ; return 0; }
 EOF
-if { (eval echo configure:9210: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9247: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9268,13 +9305,13 @@
 echo $ac_n "checking for gluBeginCurve in -lGLU""... $ac_c" 1>&6
-echo "configure:9272: checking for gluBeginCurve in -lGLU" >&5
+echo "configure:9309: checking for gluBeginCurve in -lGLU" >&5
 ac_lib_var=`echo GLU'_'gluBeginCurve | sed 'y%./+-%__p_%'`
 LIBS="-lGLU $OPENGLLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB  $LIBS"
-#line 9278 "configure"
+#line 9315 "configure"
@@ -9285,7 +9322,7 @@
 gluBeginCurve()
 ; return 0; }
 EOF
-if { (eval echo configure:9289: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9326: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9304,13 +9341,13 @@
-echo "configure:9308: checking for gluBeginCurve in -lGLU" >&5
+echo "configure:9345: checking for gluBeginCurve in -lGLU" >&5
 LIBS="-lGLU $OPENGLLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lstdc++ $LIBS"
-#line 9314 "configure"
+#line 9351 "configure"
@@ -9321,7 +9358,7 @@
 gluBeginCurve()
 ; return 0; }
 EOF
-if { (eval echo configure:9325: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9362: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9368,10 +9405,10 @@
 LIBS=" $OPENGLLIB $LIBS"
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for glXCreatePbuffer""... $ac_c" 1>&6
-echo "configure:9372: checking for glXCreatePbuffer" >&5
+echo "configure:9409: checking for glXCreatePbuffer" >&5
-#line 9375 "configure"
+#line 9412 "configure"
     which can conflict with char glXCreatePbuffer(); below.  */
@@ -9394,7 +9431,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:9398: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9435: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_glXCreatePbuffer=yes"
 else
@@ -9431,10 +9468,10 @@
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for glXCreateGLXPixmap""... $ac_c" 1>&6
-echo "configure:9435: checking for glXCreateGLXPixmap" >&5
+echo "configure:9472: checking for glXCreateGLXPixmap" >&5
-#line 9438 "configure"
+#line 9475 "configure"
     which can conflict with char glXCreateGLXPixmap(); below.  */
@@ -9457,7 +9494,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:9461: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9498: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_glXCreateGLXPixmap=yes"
 else
@@ -9500,7 +9537,7 @@
 echo $ac_n "checking for location of OpenGL framework""... $ac_c" 1>&6
-echo "configure:9504: checking for location of OpenGL framework" >&5
+echo "configure:9541: checking for location of OpenGL framework" >&5
 case "$with_opengl_framework" in
 	{ echo "configure: error: *** You must supply a directory to --with-opengl-framework." 1>&2; exit 1; }
@@ -9524,15 +9561,15 @@
 do
-echo "configure:9528: checking for $ac_hdr" >&5
+echo "configure:9565: checking for $ac_hdr" >&5
-#line 9531 "configure"
+#line 9568 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:9536: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:9573: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -9568,10 +9605,10 @@
 LIBS="-framework OpenGL -framework AGL -framework ApplicationServices  $LIBS"
 LDFLAGS="$OPENGLPATH $LDFLAGS"
 echo $ac_n "checking for glBegin""... $ac_c" 1>&6
-echo "configure:9572: checking for glBegin" >&5
+echo "configure:9609: checking for glBegin" >&5
-#line 9575 "configure"
+#line 9612 "configure"
     which can conflict with char glBegin(); below.  */
@@ -9594,7 +9631,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:9598: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9635: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_glBegin=yes"
 else
@@ -9631,10 +9668,10 @@
 echo $ac_n "checking for gluBeginCurve""... $ac_c" 1>&6
-echo "configure:9635: checking for gluBeginCurve" >&5
+echo "configure:9672: checking for gluBeginCurve" >&5
-#line 9638 "configure"
+#line 9675 "configure"
     which can conflict with char gluBeginCurve(); below.  */
@@ -9657,7 +9694,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:9661: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9698: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_gluBeginCurve=yes"
 else
@@ -9705,7 +9742,7 @@
-echo "configure:9709: checking for location of OpenGL includes" >&5
+echo "configure:9746: checking for location of OpenGL includes" >&5
@@ -9731,15 +9768,15 @@
 do
-echo "configure:9735: checking for $ac_hdr" >&5
+echo "configure:9772: checking for $ac_hdr" >&5
-#line 9738 "configure"
+#line 9775 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:9743: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:9780: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -9773,7 +9810,7 @@
-echo "configure:9777: checking for location of OpenGL library" >&5
+echo "configure:9814: checking for location of OpenGL library" >&5
@@ -9798,18 +9835,18 @@
 ac_save_libs="$LIBS"
 echo $ac_n "checking for OpenGL library""... $ac_c" 1>&6
-echo "configure:9802: checking for OpenGL library" >&5
+echo "configure:9839: checking for OpenGL library" >&5
 LDFLAGS="$OPENGL_LIB_PATH $LDFLAGS"
 LIBS="-lopengl32  "
-#line 9806 "configure"
+#line 9843 "configure"
 #include <GL/gl.h>
 int main() {
 glEnd();
 ; return 0; }
 EOF
-if { (eval echo configure:9813: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9850: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 echo "$ac_t""found" 1>&6
@@ -9833,18 +9870,18 @@
 echo $ac_n "checking for GLU library""... $ac_c" 1>&6
-echo "configure:9837: checking for GLU library" >&5
+echo "configure:9874: checking for GLU library" >&5
 LIBS="-lglu32 $OPENGLLIB "
-#line 9841 "configure"
+#line 9878 "configure"
 #include <GL/glu.h>
 int main() {
 gluNewQuadric();
 ; return 0; }
 EOF
-if { (eval echo configure:9848: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9885: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
@@ -9893,7 +9930,7 @@
 echo $ac_n "checking whether to use ODBC""... $ac_c" 1>&6
-echo "configure:9897: checking whether to use ODBC" >&5
+echo "configure:9934: checking whether to use ODBC" >&5
 echo "$ac_t"""$with_odbc"" 1>&6
 case "$with_odbc" in
 	"no")	USE_ODBC=	;;
@@ -9912,7 +9949,7 @@
 echo $ac_n "checking for location of ODBC includes""... $ac_c" 1>&6
-echo "configure:9916: checking for location of ODBC includes" >&5
+echo "configure:9953: checking for location of ODBC includes" >&5
 case "$with_odbc_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-odbc-includes." 1>&2; exit 1; }
@@ -9938,15 +9975,15 @@
 do
-echo "configure:9942: checking for $ac_hdr" >&5
+echo "configure:9979: checking for $ac_hdr" >&5
-#line 9945 "configure"
+#line 9982 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:9950: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:9987: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -9980,7 +10017,7 @@
 echo $ac_n "checking for location of ODBC library""... $ac_c" 1>&6
-echo "configure:9984: checking for location of ODBC library" >&5
+echo "configure:10021: checking for location of ODBC library" >&5
 case "$with_odbc_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-odbc-libs." 1>&2; exit 1; }
@@ -10005,13 +10042,13 @@
 echo $ac_n "checking for SQLConnect in -lodbc""... $ac_c" 1>&6
-echo "configure:10009: checking for SQLConnect in -lodbc" >&5
+echo "configure:10046: checking for SQLConnect in -lodbc" >&5
 ac_lib_var=`echo odbc'_'SQLConnect | sed 'y%./+-%__p_%'`
 LIBS="-lodbc $ICONVLIB  $LIBS"
-#line 10015 "configure"
+#line 10052 "configure"
@@ -10022,7 +10059,7 @@
 SQLConnect()
 ; return 0; }
 EOF
-if { (eval echo configure:10026: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10063: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10047,13 +10084,13 @@
 echo $ac_n "checking for SQLConnect in -liodbc""... $ac_c" 1>&6
-echo "configure:10051: checking for SQLConnect in -liodbc" >&5
+echo "configure:10088: checking for SQLConnect in -liodbc" >&5
 ac_lib_var=`echo iodbc'_'SQLConnect | sed 'y%./+-%__p_%'`
 LIBS="-liodbc  $LIBS"
-#line 10057 "configure"
+#line 10094 "configure"
@@ -10064,7 +10101,7 @@
 SQLConnect()
 ; return 0; }
 EOF
-if { (eval echo configure:10068: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10105: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10089,11 +10126,11 @@
 echo $ac_n "checking for ODBC library""... $ac_c" 1>&6
-echo "configure:10093: checking for ODBC library" >&5
+echo "configure:10130: checking for ODBC library" >&5
 LDFLAGS="$ODBCLIB $LDFLAGS"
 LIBS="-lodbc32  "
-#line 10097 "configure"
+#line 10134 "configure"
 #include <windows.h>
 #include <sql.h>
@@ -10101,7 +10138,7 @@
 SQLAllocEnv((SQLHENV *)0);
 ; return 0; }
 EOF
-if { (eval echo configure:10105: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10142: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
@@ -10150,7 +10187,7 @@
 echo $ac_n "checking whether to use FFTW""... $ac_c" 1>&6
-echo "configure:10154: checking whether to use FFTW" >&5
+echo "configure:10191: checking whether to use FFTW" >&5
 echo "$ac_t"""$with_fftw"" 1>&6
 case "$with_fftw" in
 	"no")	USE_FFTW=	;;
@@ -10169,7 +10206,7 @@
 echo $ac_n "checking for location of FFTW includes""... $ac_c" 1>&6
-echo "configure:10173: checking for location of FFTW includes" >&5
+echo "configure:10210: checking for location of FFTW includes" >&5
 case "$with_fftw_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-fftw-includes." 1>&2; exit 1; }
@@ -10195,15 +10232,15 @@
 do
-echo "configure:10199: checking for $ac_hdr" >&5
+echo "configure:10236: checking for $ac_hdr" >&5
-#line 10202 "configure"
+#line 10239 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:10207: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10244: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -10231,15 +10268,15 @@
 do
-echo "configure:10235: checking for $ac_hdr" >&5
+echo "configure:10272: checking for $ac_hdr" >&5
-#line 10238 "configure"
+#line 10275 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:10243: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10280: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -10267,15 +10304,15 @@
 do
-echo "configure:10271: checking for $ac_hdr" >&5
+echo "configure:10308: checking for $ac_hdr" >&5
-#line 10274 "configure"
+#line 10311 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:10279: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10316: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -10321,7 +10358,7 @@
 echo $ac_n "checking for location of FFTW library""... $ac_c" 1>&6
-echo "configure:10325: checking for location of FFTW library" >&5
+echo "configure:10362: checking for location of FFTW library" >&5
 case "$with_fftw_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-fftw-libs." 1>&2; exit 1; }
@@ -10346,13 +10383,13 @@
 echo $ac_n "checking for fftw_execute in -lfftw3""... $ac_c" 1>&6
-echo "configure:10350: checking for fftw_execute in -lfftw3" >&5
+echo "configure:10387: checking for fftw_execute in -lfftw3" >&5
 ac_lib_var=`echo fftw3'_'fftw_execute | sed 'y%./+-%__p_%'`
 LIBS="-lfftw3 $MATHLIB $LIBS"
-#line 10356 "configure"
+#line 10393 "configure"
@@ -10363,7 +10400,7 @@
 fftw_execute()
 ; return 0; }
 EOF
-if { (eval echo configure:10367: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10404: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10388,13 +10425,13 @@
 echo $ac_n "checking for fftwnd_one in -lfftw""... $ac_c" 1>&6
-echo "configure:10392: checking for fftwnd_one in -lfftw" >&5
+echo "configure:10429: checking for fftwnd_one in -lfftw" >&5
 ac_lib_var=`echo fftw'_'fftwnd_one | sed 'y%./+-%__p_%'`
 LIBS="-lfftw $MATHLIB $LIBS"
-#line 10398 "configure"
+#line 10435 "configure"
@@ -10405,7 +10442,7 @@
 fftwnd_one()
 ; return 0; }
 EOF
-if { (eval echo configure:10409: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10446: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10430,13 +10467,13 @@
 echo $ac_n "checking for fftwnd_one in -ldfftw""... $ac_c" 1>&6
-echo "configure:10434: checking for fftwnd_one in -ldfftw" >&5
+echo "configure:10471: checking for fftwnd_one in -ldfftw" >&5
 ac_lib_var=`echo dfftw'_'fftwnd_one | sed 'y%./+-%__p_%'`
 LIBS="-ldfftw $MATHLIB $LIBS"
-#line 10440 "configure"
+#line 10477 "configure"
@@ -10447,7 +10484,7 @@
 fftwnd_one()
 ; return 0; }
 EOF
-if { (eval echo configure:10451: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10488: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10504,7 +10541,7 @@
 echo $ac_n "checking whether to use BLAS""... $ac_c" 1>&6
-echo "configure:10508: checking whether to use BLAS" >&5
+echo "configure:10545: checking whether to use BLAS" >&5
 echo "$ac_t"""$with_blas"" 1>&6
 case "$with_blas" in
 	"no")	USE_BLAS=	;;
@@ -10525,7 +10562,7 @@
 echo $ac_n "checking for location of BLAS includes""... $ac_c" 1>&6
-echo "configure:10529: checking for location of BLAS includes" >&5
+echo "configure:10566: checking for location of BLAS includes" >&5
 case "$with_blas_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-blas-includes." 1>&2; exit 1; }
@@ -10545,7 +10582,7 @@
 echo $ac_n "checking for location of BLAS library""... $ac_c" 1>&6
-echo "configure:10549: checking for location of BLAS library" >&5
+echo "configure:10586: checking for location of BLAS library" >&5
 case "$with_blas_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-blas-libs." 1>&2; exit 1; }
@@ -10571,15 +10608,15 @@
 do
-echo "configure:10575: checking for $ac_hdr" >&5
+echo "configure:10612: checking for $ac_hdr" >&5
-#line 10578 "configure"
+#line 10615 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:10583: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10620: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -10614,13 +10651,13 @@
 echo $ac_n "checking for dnrm2_ in -lblas""... $ac_c" 1>&6
-echo "configure:10618: checking for dnrm2_ in -lblas" >&5
+echo "configure:10655: checking for dnrm2_ in -lblas" >&5
 ac_lib_var=`echo blas'_'dnrm2_ | sed 'y%./+-%__p_%'`
 LIBS="-lblas $MATHLIB  $LIBS"
-#line 10624 "configure"
+#line 10661 "configure"
@@ -10631,7 +10668,7 @@
 dnrm2_()
 ; return 0; }
 EOF
-if { (eval echo configure:10635: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10672: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10650,13 +10687,13 @@
-echo "configure:10654: checking for dnrm2_ in -lblas" >&5
+echo "configure:10691: checking for dnrm2_ in -lblas" >&5
 LIBS="-lblas $MATHLIB -lg2c $LIBS"
-#line 10660 "configure"
+#line 10697 "configure"
@@ -10667,7 +10704,7 @@
 dnrm2_()
 ; return 0; }
 EOF
-if { (eval echo configure:10671: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10708: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10711,13 +10748,13 @@
 save_LDFLAGS="$LDFLAGS"
 LDFLAGS="$BLASLIB $LDFLAGS"
 echo $ac_n "checking for ATL_xerbla in -latlas""... $ac_c" 1>&6
-echo "configure:10715: checking for ATL_xerbla in -latlas" >&5
+echo "configure:10752: checking for ATL_xerbla in -latlas" >&5
 ac_lib_var=`echo atlas'_'ATL_xerbla | sed 'y%./+-%__p_%'`
 LIBS="-latlas  $LIBS"
-#line 10721 "configure"
+#line 10758 "configure"
@@ -10728,7 +10765,7 @@
 ATL_xerbla()
 ; return 0; }
 EOF
-if { (eval echo configure:10732: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10769: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10743,13 +10780,13 @@
 if eval "test \"`echo '$ac_cv_lib_'$ac_lib_var`\" = yes"; then
   echo $ac_n "checking for sgemm_ in -lf77blas""... $ac_c" 1>&6
-echo "configure:10747: checking for sgemm_ in -lf77blas" >&5
+echo "configure:10784: checking for sgemm_ in -lf77blas" >&5
 ac_lib_var=`echo f77blas'_'sgemm_ | sed 'y%./+-%__p_%'`
 LIBS="-lf77blas -latlas $LIBS"
-#line 10753 "configure"
+#line 10790 "configure"
@@ -10760,7 +10797,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:10764: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10801: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10775,13 +10812,13 @@
   echo $ac_n "checking for cblas_dgemm in -lcblas""... $ac_c" 1>&6
-echo "configure:10779: checking for cblas_dgemm in -lcblas" >&5
+echo "configure:10816: checking for cblas_dgemm in -lcblas" >&5
 ac_lib_var=`echo cblas'_'cblas_dgemm | sed 'y%./+-%__p_%'`
 LIBS="-lcblas -lf77blas -latlas $LIBS"
-#line 10785 "configure"
+#line 10822 "configure"
@@ -10792,7 +10829,7 @@
 cblas_dgemm()
 ; return 0; }
 EOF
-if { (eval echo configure:10796: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10833: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10838,16 +10875,16 @@
 	save_LIBS="$LIBS"
 	LIBS="$vlib_flags $LIBS"
 	echo $ac_n "checking for sgemm in $vlib_flags""... $ac_c" 1>&6
-echo "configure:10842: checking for sgemm in $vlib_flags" >&5
+echo "configure:10879: checking for sgemm in $vlib_flags" >&5
-#line 10844 "configure"
+#line 10881 "configure"
 int main() {
 sgemm
 ; return 0; }
 EOF
-if { (eval echo configure:10851: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10888: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   blas_ok=yes; BLASLIB="$vlib_flags"
 else
@@ -10865,13 +10902,13 @@
 # BLAS in PhiPACK libraries? (requires generic BLAS, too)
 if test $blas_ok = no; then
 	echo $ac_n "checking for sgemm_ in -lblas""... $ac_c" 1>&6
-echo "configure:10869: checking for sgemm_ in -lblas" >&5
+echo "configure:10906: checking for sgemm_ in -lblas" >&5
 ac_lib_var=`echo blas'_'sgemm_ | sed 'y%./+-%__p_%'`
 LIBS="-lblas  $LIBS"
-#line 10875 "configure"
+#line 10912 "configure"
@@ -10882,7 +10919,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:10886: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10923: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10897,13 +10934,13 @@
   echo $ac_n "checking for dgemm_ in -ldgemm""... $ac_c" 1>&6
-echo "configure:10901: checking for dgemm_ in -ldgemm" >&5
+echo "configure:10938: checking for dgemm_ in -ldgemm" >&5
 ac_lib_var=`echo dgemm'_'dgemm_ | sed 'y%./+-%__p_%'`
 LIBS="-ldgemm -lblas $LIBS"
-#line 10907 "configure"
+#line 10944 "configure"
@@ -10914,7 +10951,7 @@
 dgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:10918: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10955: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10929,13 +10966,13 @@
   echo $ac_n "checking for sgemm_ in -lsgemm""... $ac_c" 1>&6
-echo "configure:10933: checking for sgemm_ in -lsgemm" >&5
+echo "configure:10970: checking for sgemm_ in -lsgemm" >&5
 ac_lib_var=`echo sgemm'_'sgemm_ | sed 'y%./+-%__p_%'`
 LIBS="-lsgemm -lblas $LIBS"
-#line 10939 "configure"
+#line 10976 "configure"
@@ -10946,7 +10983,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:10950: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10987: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10980,13 +11017,13 @@
 	if test "x$GCC" != xyes; then # only works with Sun CC
 		echo $ac_n "checking for acosp in -lsunmath""... $ac_c" 1>&6
-echo "configure:10984: checking for acosp in -lsunmath" >&5
+echo "configure:11021: checking for acosp in -lsunmath" >&5
 ac_lib_var=`echo sunmath'_'acosp | sed 'y%./+-%__p_%'`
 LIBS="-lsunmath  $LIBS"
-#line 10990 "configure"
+#line 11027 "configure"
@@ -10997,7 +11034,7 @@
 acosp()
 ; return 0; }
 EOF
-if { (eval echo configure:11001: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11038: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11012,13 +11049,13 @@
   echo $ac_n "checking for sgemm_ in -lsunperf""... $ac_c" 1>&6
-echo "configure:11016: checking for sgemm_ in -lsunperf" >&5
+echo "configure:11053: checking for sgemm_ in -lsunperf" >&5
 ac_lib_var=`echo sunperf'_'sgemm_ | sed 'y%./+-%__p_%'`
 LIBS="-lsunperf -lsunmath $LIBS"
-#line 11022 "configure"
+#line 11059 "configure"
@@ -11029,7 +11066,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:11033: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11070: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11059,13 +11096,13 @@
 # Generic BLAS library
-echo "configure:11063: checking for sgemm_ in -lblas" >&5
+echo "configure:11100: checking for sgemm_ in -lblas" >&5
 LIBS="-lblas  $LIBS"
-#line 11069 "configure"
+#line 11106 "configure"
@@ -11076,7 +11113,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:11080: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11117: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11115,7 +11152,7 @@
 echo $ac_n "checking whether to use LAPACK""... $ac_c" 1>&6
-echo "configure:11119: checking whether to use LAPACK" >&5
+echo "configure:11156: checking whether to use LAPACK" >&5
 echo "$ac_t"""$with_lapack"" 1>&6
 case "$with_lapack" in
 	"no")	USE_LAPACK=	;;
@@ -11140,7 +11177,7 @@
 echo $ac_n "checking for location of LAPACK includes""... $ac_c" 1>&6
-echo "configure:11144: checking for location of LAPACK includes" >&5
+echo "configure:11181: checking for location of LAPACK includes" >&5
 case "$with_lapack_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-lapack-includes." 1>&2; exit 1; }
@@ -11160,7 +11197,7 @@
 echo $ac_n "checking for location of LAPACK library""... $ac_c" 1>&6
-echo "configure:11164: checking for location of LAPACK library" >&5
+echo "configure:11201: checking for location of LAPACK library" >&5
 case "$with_lapack_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-lapack-libs." 1>&2; exit 1; }
@@ -11186,15 +11223,15 @@
 do
-echo "configure:11190: checking for $ac_hdr" >&5
+echo "configure:11227: checking for $ac_hdr" >&5
-#line 11193 "configure"
+#line 11230 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:11198: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11235: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -11226,10 +11263,10 @@
 	save_LIBS="$LIBS"; LIBS="$LIBS $BLASLIB $MATHLIB $FLIBS"
 	save_LDFLAGS="$LDFLAGS"; LDFLAGS="$LAPACKLIB $LDFLAGS"
 	echo $ac_n "checking for dsegv_""... $ac_c" 1>&6
-echo "configure:11230: checking for dsegv_" >&5
+echo "configure:11267: checking for dsegv_" >&5
-#line 11233 "configure"
+#line 11270 "configure"
     which can conflict with char dsegv_(); below.  */
@@ -11252,7 +11289,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:11256: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11293: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_dsegv_=yes"
 else
@@ -11279,13 +11316,13 @@
 	save_libs="$LIBS"; LIBS="$BLASLIB $MATHLIB $LIBS"
 	echo $ac_n "checking for desgv_ in -llapack""... $ac_c" 1>&6
-echo "configure:11283: checking for desgv_ in -llapack" >&5
+echo "configure:11320: checking for desgv_ in -llapack" >&5
 ac_lib_var=`echo lapack'_'desgv_ | sed 'y%./+-%__p_%'`
 LIBS="-llapack $FLIBS $LIBS"
-#line 11289 "configure"
+#line 11326 "configure"
@@ -11296,7 +11333,7 @@
 desgv_()
 ; return 0; }
 EOF
-if { (eval echo configure:11300: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11337: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11328,13 +11365,13 @@
 echo $ac_n "checking for dgesv_ in -llapack""... $ac_c" 1>&6
-echo "configure:11332: checking for dgesv_ in -llapack" >&5
+echo "configure:11369: checking for dgesv_ in -llapack" >&5
 ac_lib_var=`echo lapack'_'dgesv_ | sed 'y%./+-%__p_%'`
 LIBS="-llapack $BLASLIB $MATHLIB  $LIBS"
-#line 11338 "configure"
+#line 11375 "configure"
@@ -11345,7 +11382,7 @@
 dgesv_()
 ; return 0; }
 EOF
-if { (eval echo configure:11349: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11386: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11364,13 +11401,13 @@
-echo "configure:11368: checking for dgesv_ in -llapack" >&5
+echo "configure:11405: checking for dgesv_ in -llapack" >&5
 LIBS="-llapack $BLASLIB $MATHLIB -lg2c $LIBS"
-#line 11374 "configure"
+#line 11411 "configure"
@@ -11381,7 +11418,7 @@
 dgesv_()
 ; return 0; }
 EOF
-if { (eval echo configure:11385: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11422: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11437,7 +11474,7 @@
 echo $ac_n "checking whether to use Cairo""... $ac_c" 1>&6
-echo "configure:11441: checking whether to use Cairo" >&5
+echo "configure:11478: checking whether to use Cairo" >&5
 echo "$ac_t"""$with_cairo"" 1>&6
 case "$with_cairo" in
 	"no")	USE_CAIRO=	;;
@@ -11469,7 +11506,7 @@
 echo $ac_n "checking for location of cairo includes""... $ac_c" 1>&6
-echo "configure:11473: checking for location of cairo includes" >&5
+echo "configure:11510: checking for location of cairo includes" >&5
 case "$with_cairo_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-cairo-includes." 1>&2; exit 1; }
@@ -11495,15 +11532,15 @@
 do
 ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
 echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:11499: checking for $ac_hdr" >&5
+echo "configure:11536: checking for $ac_hdr" >&5
 cat > conftest.$ac_ext <<EOF
-#line 11502 "configure"
+#line 11539 "configure"
 #include "confdefs.h"
 #include <$ac_hdr>
 EOF
 ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:11507: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11544: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
 ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
 if test -z "$ac_err"; then
   rm -rf conftest*
@@ -11539,7 +11576,7 @@
 echo $ac_n "checking for location of cairo library""... $ac_c" 1>&6
-echo "configure:11543: checking for location of cairo library" >&5
+echo "configure:11580: checking for location of cairo library" >&5
 case "$with_cairo_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-cairo-libs." 1>&2; exit 1; }
@@ -11559,7 +11596,7 @@
 echo $ac_n "checking for cairo linking flags""... $ac_c" 1>&6
-echo "configure:11563: checking for cairo linking flags" >&5
+echo "configure:11600: checking for cairo linking flags" >&5
 case "$with_cairo_ldflags" in
 	{ echo "configure: error: *** You must supply a directory to --with-cairo-ldflags." 1>&2; exit 1; }
@@ -11575,10 +11612,10 @@
 LIBS=" $CAIROLIB $LIBS"
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for cairo_create""... $ac_c" 1>&6
-echo "configure:11579: checking for cairo_create" >&5
+echo "configure:11616: checking for cairo_create" >&5
-#line 11582 "configure"
+#line 11619 "configure"
     which can conflict with char cairo_create(); below.  */
@@ -11601,7 +11638,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:11605: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11642: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_cairo_create=yes"
 else
@@ -11635,10 +11672,10 @@
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for cairo_xlib_surface_create_with_xrender_format""... $ac_c" 1>&6
-echo "configure:11639: checking for cairo_xlib_surface_create_with_xrender_format" >&5
+echo "configure:11676: checking for cairo_xlib_surface_create_with_xrender_format" >&5
-#line 11642 "configure"
+#line 11679 "configure"
     which can conflict with char cairo_xlib_surface_create_with_xrender_format(); below.  */
@@ -11661,7 +11698,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:11665: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11702: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_cairo_xlib_surface_create_with_xrender_format=yes"
 else
@@ -11694,10 +11731,10 @@
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for cairo_xlib_surface_get_xrender_format""... $ac_c" 1>&6
-echo "configure:11698: checking for cairo_xlib_surface_get_xrender_format" >&5
+echo "configure:11735: checking for cairo_xlib_surface_get_xrender_format" >&5
-#line 11701 "configure"
+#line 11738 "configure"
     which can conflict with char cairo_xlib_surface_get_xrender_format(); below.  */
@@ -11720,7 +11757,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:11724: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11761: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_cairo_xlib_surface_get_xrender_format=yes"
 else
@@ -11762,7 +11799,7 @@
 echo $ac_n "checking whether to use FreeType""... $ac_c" 1>&6
-echo "configure:11766: checking whether to use FreeType" >&5
+echo "configure:11803: checking whether to use FreeType" >&5
 echo "$ac_t"""$with_freetype"" 1>&6
 case "$with_freetype" in
 	"no")	USE_FREETYPE=	;;
@@ -11781,7 +11818,7 @@
 echo $ac_n "checking for location of FreeType includes""... $ac_c" 1>&6
-echo "configure:11785: checking for location of FreeType includes" >&5
+echo "configure:11822: checking for location of FreeType includes" >&5
 case "$with_freetype_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-freetype-includes." 1>&2; exit 1; }
@@ -11807,15 +11844,15 @@
 do
-echo "configure:11811: checking for $ac_hdr" >&5
+echo "configure:11848: checking for $ac_hdr" >&5
-#line 11814 "configure"
+#line 11851 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:11819: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11856: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -11849,7 +11886,7 @@
 echo $ac_n "checking for location of FreeType library""... $ac_c" 1>&6
-echo "configure:11853: checking for location of FreeType library" >&5
+echo "configure:11890: checking for location of FreeType library" >&5
 case "$with_freetype_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-freetype-libs." 1>&2; exit 1; }
@@ -11874,13 +11911,13 @@
 echo $ac_n "checking for FT_Init_FreeType in -lfreetype""... $ac_c" 1>&6
-echo "configure:11878: checking for FT_Init_FreeType in -lfreetype" >&5
+echo "configure:11915: checking for FT_Init_FreeType in -lfreetype" >&5
 ac_lib_var=`echo freetype'_'FT_Init_FreeType | sed 'y%./+-%__p_%'`
 ac_save_LIBS="$LIBS"
 LIBS="-lfreetype  $LIBS"
-#line 11884 "configure"
+#line 11921 "configure"
 /* Override any gcc2 internal prototype to avoid an error.  */
 /* We use char because int might match the return type of a gcc2
@@ -11891,7 +11928,7 @@
 FT_Init_FreeType()
 ; return 0; }
 EOF
-if { (eval echo configure:11895: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11932: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_lib_$ac_lib_var=yes"
 else
@@ -11932,7 +11969,7 @@
 echo $ac_n "checking whether to use NLS""... $ac_c" 1>&6
-echo "configure:11936: checking whether to use NLS" >&5
+echo "configure:11973: checking whether to use NLS" >&5
 echo "$ac_t"""$with_nls"" 1>&6
 case "$with_nls" in
 	"no")	USE_NLS=	;;
@@ -11952,10 +11989,10 @@
 echo $ac_n "checking for gettext""... $ac_c" 1>&6
-echo "configure:11956: checking for gettext" >&5
+echo "configure:11993: checking for gettext" >&5
-#line 11959 "configure"
+#line 11996 "configure"
     which can conflict with char gettext(); below.  */
@@ -11978,7 +12015,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:11982: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12019: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_gettext=yes"
 else
@@ -11996,13 +12033,13 @@
   echo "$ac_t""no" 1>&6
 echo $ac_n "checking for gettext in -lintl""... $ac_c" 1>&6
-echo "configure:12000: checking for gettext in -lintl" >&5
+echo "configure:12037: checking for gettext in -lintl" >&5
 ac_lib_var=`echo intl'_'gettext | sed 'y%./+-%__p_%'`
 LIBS="-lintl  $LIBS"
-#line 12006 "configure"
+#line 12043 "configure"
@@ -12013,7 +12050,7 @@
 gettext()
 ; return 0; }
 EOF
-if { (eval echo configure:12017: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12054: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12048,7 +12085,7 @@
 echo $ac_n "checking whether to use C++""... $ac_c" 1>&6
-echo "configure:12052: checking whether to use C++" >&5
+echo "configure:12089: checking whether to use C++" >&5
 echo "$ac_t"""$with_cxx"" 1>&6
 case "$with_cxx" in
 	"no")	USE_CXX=	;;
@@ -12064,7 +12101,7 @@
 # Extract the first word of "$ac_prog", so it can be a program name with args.
 set dummy $ac_prog; ac_word=$2
 echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:12068: checking for $ac_word" >&5
+echo "configure:12105: checking for $ac_word" >&5
 if test -n "$CXX"; then
   ac_cv_prog_CXX="$CXX" # Let the user override the test.
@@ -12093,7 +12130,7 @@
 echo $ac_n "checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works""... $ac_c" 1>&6
-echo "configure:12097: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works" >&5
+echo "configure:12134: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works" >&5
 ac_ext=C
 # CXXFLAGS is not in ac_cpp because -g, -O, etc. are not valid cpp options.
@@ -12104,12 +12141,12 @@
 cat > conftest.$ac_ext << EOF
-#line 12108 "configure"
+#line 12145 "configure"
 int main(){return(0);}
 EOF
-if { (eval echo configure:12113: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12150: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   ac_cv_prog_cxx_works=yes
   # If we can't run a trivial program, we are probably using a cross compiler.
   if (./conftest; exit) 2>/dev/null; then
@@ -12135,19 +12172,19 @@
   { echo "configure: error: installation or configuration problem: C++ compiler cannot create executables." 1>&2; exit 1; }
 fi
 echo $ac_n "checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler""... $ac_c" 1>&6
-echo "configure:12139: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler" >&5
+echo "configure:12176: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler" >&5
 echo "$ac_t""$ac_cv_prog_cxx_cross" 1>&6
 cross_compiling=$ac_cv_prog_cxx_cross
 echo $ac_n "checking whether we are using GNU C++""... $ac_c" 1>&6
-echo "configure:12144: checking whether we are using GNU C++" >&5
+echo "configure:12181: checking whether we are using GNU C++" >&5
 cat > conftest.C <<EOF
 #ifdef __GNUC__
   yes;
 #endif
 EOF
-if { ac_try='${CXX-g++} -E conftest.C'; { (eval echo configure:12151: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
+if { ac_try='${CXX-g++} -E conftest.C'; { (eval echo configure:12188: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
   ac_cv_prog_gxx=yes
 else
   ac_cv_prog_gxx=no
@@ -12165,7 +12202,7 @@
 ac_save_CXXFLAGS="$CXXFLAGS"
 CXXFLAGS=
 echo $ac_n "checking whether ${CXX-g++} accepts -g""... $ac_c" 1>&6
-echo "configure:12169: checking whether ${CXX-g++} accepts -g" >&5
+echo "configure:12206: checking whether ${CXX-g++} accepts -g" >&5
 echo 'void f(){}' > conftest.cc
 if test -z "`${CXX-g++} -g -c conftest.cc 2>&1`"; then
@@ -12193,58 +12230,7 @@
   fi
 fi
-for ac_declaration in \
-   '#include <stdlib.h>' \
-   'extern "C" void std::exit (int) throw (); using std::exit;' \
-   'extern "C" void std::exit (int); using std::exit;' \
-   'extern "C" void exit (int) throw ();' \
-   'extern "C" void exit (int);' \
-   'void exit (int);'
-do
-  cat > conftest.$ac_ext <<EOF
-#line 12207 "configure"
-#include "confdefs.h"
-#include <stdlib.h>
-$ac_declaration
-int main() {
-exit (42);
-; return 0; }
-EOF
-if { (eval echo configure:12215: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
-  echo "configure: failed program was:" >&5
-  cat conftest.$ac_ext >&5
-  rm -rf conftest*
-  continue
-fi
-rm -f conftest*
-#line 12225 "configure"
-$ac_declaration
-int main() {
-exit (42);
-; return 0; }
-EOF
-if { (eval echo configure:12232: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
-  rm -rf conftest*
-  break
-else
-fi
-rm -f conftest*
-done
-if test -n "$ac_declaration"; then
-  echo '#ifdef __cplusplus' >>confdefs.h
-  echo $ac_declaration      >>confdefs.h
-  echo '#endif'             >>confdefs.h
-fi
-else
 	CXX=
 	CXXFLAGS=
@@ -12257,7 +12243,7 @@
 echo $ac_n "checking whether to use openDWG""... $ac_c" 1>&6
-echo "configure:12261: checking whether to use openDWG" >&5
+echo "configure:12247: checking whether to use openDWG" >&5
 echo "$ac_t"""$with_opendwg"" 1>&6
 case "$with_opendwg" in
 	"no")	USE_OPENDWG=	;;
@@ -12277,7 +12263,7 @@
 echo $ac_n "checking for location of openDGW includes""... $ac_c" 1>&6
-echo "configure:12281: checking for location of openDGW includes" >&5
+echo "configure:12267: checking for location of openDGW includes" >&5
 case "$with_opendwg_includes" in
 y | ye | yes | n | no)
 	{ echo "configure: error: *** You must supply a directory to --with-opendwg-includes." 1>&2; exit 1; }
@@ -12303,15 +12289,15 @@
 do
-echo "configure:12307: checking for $ac_hdr" >&5
+echo "configure:12293: checking for $ac_hdr" >&5
-#line 12310 "configure"
+#line 12296 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:12315: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12301: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -12345,7 +12331,7 @@
 echo $ac_n "checking for location of openDWG library""... $ac_c" 1>&6
-echo "configure:12349: checking for location of openDWG library" >&5
+echo "configure:12335: checking for location of openDWG library" >&5
 case "$with_opendwg_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-opendwg-libs." 1>&2; exit 1; }
@@ -12386,7 +12372,7 @@
 echo $ac_n "checking whether to use POSIX threads""... $ac_c" 1>&6
-echo "configure:12390: checking whether to use POSIX threads" >&5
+echo "configure:12376: checking whether to use POSIX threads" >&5
 echo "$ac_t"""$with_pthread"" 1>&6
 case "$with_pthread" in
 	"no")	USE_PTHREAD=	;;
@@ -12406,7 +12392,7 @@
 echo $ac_n "checking for location of POSIX threads includes""... $ac_c" 1>&6
-echo "configure:12410: checking for location of POSIX threads includes" >&5
+echo "configure:12396: checking for location of POSIX threads includes" >&5
 case "$with_pthread_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-pthread-includes." 1>&2; exit 1; }
@@ -12432,15 +12418,15 @@
 do
-echo "configure:12436: checking for $ac_hdr" >&5
+echo "configure:12422: checking for $ac_hdr" >&5
-#line 12439 "configure"
+#line 12425 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:12444: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12430: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -12474,7 +12460,7 @@
 echo $ac_n "checking for location of POSIX threads library""... $ac_c" 1>&6
-echo "configure:12478: checking for location of POSIX threads library" >&5
+echo "configure:12464: checking for location of POSIX threads library" >&5
 case "$with_pthread_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-pthread-libs." 1>&2; exit 1; }
@@ -12499,10 +12485,10 @@
 LIBS="  $LIBS"
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for pthread_create""... $ac_c" 1>&6
-echo "configure:12503: checking for pthread_create" >&5
+echo "configure:12489: checking for pthread_create" >&5
-#line 12506 "configure"
+#line 12492 "configure"
     which can conflict with char pthread_create(); below.  */
@@ -12525,7 +12511,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:12529: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12515: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_pthread_create=yes"
 else
@@ -12552,13 +12538,13 @@
 echo $ac_n "checking for pthread_create in -lpthread""... $ac_c" 1>&6
-echo "configure:12556: checking for pthread_create in -lpthread" >&5
+echo "configure:12542: checking for pthread_create in -lpthread" >&5
 ac_lib_var=`echo pthread'_'pthread_create | sed 'y%./+-%__p_%'`
 LIBS="-lpthread  $LIBS"
-#line 12562 "configure"
+#line 12548 "configure"
@@ -12569,7 +12555,7 @@
 pthread_create()
 ; return 0; }
 EOF
-if { (eval echo configure:12573: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12559: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12619,7 +12605,7 @@
 echo $ac_n "checking whether to use OpenMP""... $ac_c" 1>&6
-echo "configure:12623: checking whether to use OpenMP" >&5
+echo "configure:12609: checking whether to use OpenMP" >&5
 echo "$ac_t"""$with_openmp"" 1>&6
 case "$with_openmp" in
 	"no")	USE_OPENMP=	;;
@@ -12640,7 +12626,7 @@
 echo $ac_n "checking for location of OpenMP includes""... $ac_c" 1>&6
-echo "configure:12644: checking for location of OpenMP includes" >&5
+echo "configure:12630: checking for location of OpenMP includes" >&5
 case "$with_openmp_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-openmp-includes." 1>&2; exit 1; }
@@ -12666,15 +12652,15 @@
 do
-echo "configure:12670: checking for $ac_hdr" >&5
+echo "configure:12656: checking for $ac_hdr" >&5
-#line 12673 "configure"
+#line 12659 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:12678: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12664: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -12712,7 +12698,7 @@
 echo $ac_n "checking for location of OpenMP library""... $ac_c" 1>&6
-echo "configure:12716: checking for location of OpenMP library" >&5
+echo "configure:12702: checking for location of OpenMP library" >&5
 case "$with_openmp_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-openmp-libs." 1>&2; exit 1; }
@@ -12737,10 +12723,10 @@
 LIBS="  $LIBS"
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for GOMP_parallel_start""... $ac_c" 1>&6
-echo "configure:12741: checking for GOMP_parallel_start" >&5
+echo "configure:12727: checking for GOMP_parallel_start" >&5
-#line 12744 "configure"
+#line 12730 "configure"
     which can conflict with char GOMP_parallel_start(); below.  */
@@ -12763,7 +12749,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:12767: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12753: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_GOMP_parallel_start=yes"
 else
@@ -12790,13 +12776,13 @@
 echo $ac_n "checking for GOMP_parallel_start in -lgomp""... $ac_c" 1>&6
-echo "configure:12794: checking for GOMP_parallel_start in -lgomp" >&5
+echo "configure:12780: checking for GOMP_parallel_start in -lgomp" >&5
 ac_lib_var=`echo gomp'_'GOMP_parallel_start | sed 'y%./+-%__p_%'`
 LIBS="-lgomp  $LIBS"
-#line 12800 "configure"
+#line 12786 "configure"
@@ -12807,7 +12793,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:12811: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12797: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12880,7 +12866,7 @@
 echo $ac_n "checking whether to use OpenCL""... $ac_c" 1>&6
-echo "configure:12884: checking whether to use OpenCL" >&5
+echo "configure:12870: checking whether to use OpenCL" >&5
 echo "$ac_t"""$with_opencl"" 1>&6
 case "$with_opencl" in
 	"no")	USE_OPENCL=	;;
@@ -12900,7 +12886,7 @@
 echo $ac_n "checking for location of OpenCL includes""... $ac_c" 1>&6
-echo "configure:12904: checking for location of OpenCL includes" >&5
+echo "configure:12890: checking for location of OpenCL includes" >&5
 case "$with_opencl_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-opencl-includes." 1>&2; exit 1; }
@@ -12927,15 +12913,15 @@
 do
-echo "configure:12931: checking for $ac_hdr" >&5
+echo "configure:12917: checking for $ac_hdr" >&5
-#line 12934 "configure"
+#line 12920 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:12939: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12925: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -12975,10 +12961,10 @@
 LIBS="-framework OpenCL  $LIBS"
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for clGetPlatformInfo""... $ac_c" 1>&6
-echo "configure:12979: checking for clGetPlatformInfo" >&5
+echo "configure:12965: checking for clGetPlatformInfo" >&5
-#line 12982 "configure"
+#line 12968 "configure"
     which can conflict with char clGetPlatformInfo(); below.  */
@@ -13001,7 +12987,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:13005: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12991: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_clGetPlatformInfo=yes"
 else
@@ -13040,15 +13026,15 @@
 do
-echo "configure:13044: checking for $ac_hdr" >&5
+echo "configure:13030: checking for $ac_hdr" >&5
-#line 13047 "configure"
+#line 13033 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:13052: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13038: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -13081,7 +13067,7 @@
     # With OpenCL library directory
 echo $ac_n "checking for location of OpenCL library""... $ac_c" 1>&6
-echo "configure:13085: checking for location of OpenCL library" >&5
+echo "configure:13071: checking for location of OpenCL library" >&5
 case "$with_opencl_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-opencl-libs." 1>&2; exit 1; }
@@ -13105,13 +13091,13 @@
 echo $ac_n "checking for clGetPlatformInfo in -lOpenCL""... $ac_c" 1>&6
-echo "configure:13109: checking for clGetPlatformInfo in -lOpenCL" >&5
+echo "configure:13095: checking for clGetPlatformInfo in -lOpenCL" >&5
 ac_lib_var=`echo OpenCL'_'clGetPlatformInfo | sed 'y%./+-%__p_%'`
 LIBS="-lOpenCL  $LIBS"
-#line 13115 "configure"
+#line 13101 "configure"
@@ -13122,7 +13108,7 @@
 clGetPlatformInfo()
 ; return 0; }
 EOF
-if { (eval echo configure:13126: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13112: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13182,7 +13168,7 @@
      fi
      echo $ac_n "checking for special C compiler options needed for large files""... $ac_c" 1>&6
-echo "configure:13186: checking for special C compiler options needed for large files" >&5
+echo "configure:13172: checking for special C compiler options needed for large files" >&5
 ac_cv_sys_largefile_CC=no
         largefile_cc_opt=""
@@ -13190,7 +13176,7 @@
 	  # IRIX 6.2 and later do not support large files by default,
 	  # so use the C compiler's -n32 option if that helps.
-#line 13194 "configure"
+#line 13180 "configure"
 #include <sys/types.h>
     /* Check that off_t can represent 2**63 - 1 correctly.
@@ -13206,7 +13192,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:13210: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13196: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
@@ -13215,7 +13201,7 @@
   ac_save_CC="${CC-cc}"
 	     CC="$CC -n32"
-#line 13219 "configure"
+#line 13205 "configure"
@@ -13231,7 +13217,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:13235: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13221: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_sys_largefile_CC=' -n32'
 else
@@ -13258,11 +13244,11 @@
      fi
      echo $ac_n "checking for _FILE_OFFSET_BITS value needed for large files""... $ac_c" 1>&6
-echo "configure:13262: checking for _FILE_OFFSET_BITS value needed for large files" >&5
+echo "configure:13248: checking for _FILE_OFFSET_BITS value needed for large files" >&5
 ac_cv_sys_file_offset_bits=no
-#line 13266 "configure"
+#line 13252 "configure"
@@ -13278,14 +13264,14 @@
 ; return 0; }
 EOF
-if { (eval echo configure:13282: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13268: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
   rm -rf conftest*
-#line 13289 "configure"
+#line 13275 "configure"
 #define _FILE_OFFSET_BITS 64
@@ -13303,7 +13289,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:13307: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13293: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_sys_file_offset_bits=64
 else
@@ -13329,11 +13315,11 @@
    fi
      echo $ac_n "checking for _LARGE_FILES value needed for large files""... $ac_c" 1>&6
-echo "configure:13333: checking for _LARGE_FILES value needed for large files" >&5
+echo "configure:13319: checking for _LARGE_FILES value needed for large files" >&5
 ac_cv_sys_large_files=no
-#line 13337 "configure"
+#line 13323 "configure"
@@ -13349,14 +13335,14 @@
 ; return 0; }
 EOF
-if { (eval echo configure:13353: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13339: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
   rm -rf conftest*
-#line 13360 "configure"
+#line 13346 "configure"
 #define _LARGE_FILES 1
@@ -13374,7 +13360,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:13378: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13364: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_sys_large_files=1
 else
@@ -13400,25 +13386,25 @@
    fi
      echo $ac_n "checking for _LARGEFILE_SOURCE value needed for large files""... $ac_c" 1>&6
-echo "configure:13404: checking for _LARGEFILE_SOURCE value needed for large files" >&5
+echo "configure:13390: checking for _LARGEFILE_SOURCE value needed for large files" >&5
 ac_cv_sys_largefile_source=no
-#line 13408 "configure"
+#line 13394 "configure"
 #include <stdio.h>
 int main() {
 return !fseeko;
 ; return 0; }
 EOF
-if { (eval echo configure:13415: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13401: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
   rm -rf conftest*
-#line 13422 "configure"
+#line 13408 "configure"
 #define _LARGEFILE_SOURCE 1
 #include <stdio.h>
@@ -13427,7 +13413,7 @@
 return !fseeko;
 ; return 0; }
 EOF
-if { (eval echo configure:13431: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13417: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_sys_largefile_source=1
 else
@@ -13459,25 +13445,25 @@
 ac_save_cflags=${CFLAGS}
 CFLAGS="$LFS_CFLAGS ${ac_save_cflags}"
-echo "configure:13463: checking for _LARGEFILE_SOURCE value needed for large files" >&5
+echo "configure:13449: checking for _LARGEFILE_SOURCE value needed for large files" >&5
-#line 13467 "configure"
+#line 13453 "configure"
 #include <stdio.h>
 int main() {
 return !fseeko;
 ; return 0; }
 EOF
-if { (eval echo configure:13474: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13460: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
   rm -rf conftest*
-#line 13481 "configure"
+#line 13467 "configure"
 #include <stdio.h>
@@ -13486,7 +13472,7 @@
 return !fseeko;
 ; return 0; }
 EOF
-if { (eval echo configure:13490: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13476: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
 else
@@ -13516,18 +13502,18 @@
    # If you want fseeko and ftello with glibc, upgrade to a fixed glibc.
    echo $ac_n "checking for fseeko""... $ac_c" 1>&6
-echo "configure:13520: checking for fseeko" >&5
+echo "configure:13506: checking for fseeko" >&5
 ac_cv_func_fseeko=no
-#line 13524 "configure"
+#line 13510 "configure"
 #include <stdio.h>
 int main() {
 return fseeko && fseeko (stdin, 0, 0);
 ; return 0; }
 EOF
-if { (eval echo configure:13531: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13517: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   ac_cv_func_fseeko=yes
 else
@@ -13544,10 +13530,10 @@
    fi
 echo $ac_n "checking if system supports Large Files at all""... $ac_c" 1>&6
-echo "configure:13548: checking if system supports Large Files at all" >&5
+echo "configure:13534: checking if system supports Large Files at all" >&5
-#line 13551 "configure"
+#line 13537 "configure"
 #include <stdio.h>
@@ -13579,7 +13565,7 @@
 #endif
 ; return 0; }
 EOF
-if { (eval echo configure:13583: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13569: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_largefiles=yes
 else
Modified: grass/trunk/configure.in
--- grass/trunk/configure.in	2017-11-17 10:24:03 UTC (rev 71756)
+++ grass/trunk/configure.in	2017-11-17 10:47:08 UTC (rev 71757)
@@ -850,6 +850,7 @@
   LIBS="$LIBS $LIBLAS_LIBS"
   CFLAGS="$CFLAGS $LIBLAS_CFLAGS"
   CPPFLAGS="$CPPFLAGS $LIBLAS_INC"
+  AC_CHECK_HEADERS(liblas/capi/liblas.h)
   AC_TRY_LINK([#include <liblas/capi/liblas.h>],[LASReader_Create("foo");],,[
   AC_TRY_LINK([#include <liblas/capi/liblas.h>],[LASReader_Create("foo");],LAS_LIBS="$LAS_LIBS",[
   AC_MSG_ERROR([*** Unable to locate libLAS library.])
