[GRASS-SVN] r71773 - in grass/branches/releasebranch_7_4: raster/r.in.gdal temporal/t.rast.import temporal/t.vect.import vector/v.in.ogr
svn_grass at osgeo.org
Sun Nov 19 09:44:41 PST 2017
Author: neteler
Date: 2017-11-19 09:44:41 -0800 (Sun, 19 Nov 2017)
New Revision: 71773
grass/branches/releasebranch_7_4/raster/r.in.gdal/main.c
grass/branches/releasebranch_7_4/temporal/t.rast.import/t.rast.import.py
grass/branches/releasebranch_7_4/temporal/t.vect.import/t.vect.import.py
grass/branches/releasebranch_7_4/vector/v.in.ogr/main.c
various commands: keywords added
Modified: grass/branches/releasebranch_7_4/raster/r.in.gdal/main.c
--- grass/branches/releasebranch_7_4/raster/r.in.gdal/main.c 2017-11-19 17:24:51 UTC (rev 71772)
+++ grass/branches/releasebranch_7_4/raster/r.in.gdal/main.c 2017-11-19 17:44:41 UTC (rev 71773)
@@ -91,6 +91,7 @@
module = G_define_module();
G_add_keyword(_("raster"));
G_add_keyword(_("import"));
+ G_add_keyword(_("create location"));
module->description =
_("Imports raster data into a GRASS raster map using GDAL library.");
Modified: grass/branches/releasebranch_7_4/temporal/t.rast.import/t.rast.import.py
--- grass/branches/releasebranch_7_4/temporal/t.rast.import/t.rast.import.py 2017-11-19 17:24:51 UTC (rev 71772)
+++ grass/branches/releasebranch_7_4/temporal/t.rast.import/t.rast.import.py 2017-11-19 17:44:41 UTC (rev 71773)
@@ -20,6 +20,7 @@
#% keyword: import
#% keyword: raster
#% keyword: time
+#% keyword: create location
#%end
#%option G_OPT_F_INPUT
Modified: grass/branches/releasebranch_7_4/temporal/t.vect.import/t.vect.import.py
--- grass/branches/releasebranch_7_4/temporal/t.vect.import/t.vect.import.py 2017-11-19 17:24:51 UTC (rev 71772)
+++ grass/branches/releasebranch_7_4/temporal/t.vect.import/t.vect.import.py 2017-11-19 17:44:41 UTC (rev 71773)
@@ -20,6 +20,7 @@
#% keyword: import
#% keyword: vector
#% keyword: time
#%end
Modified: grass/branches/releasebranch_7_4/vector/v.in.ogr/main.c
--- grass/branches/releasebranch_7_4/vector/v.in.ogr/main.c 2017-11-19 17:24:51 UTC (rev 71772)
+++ grass/branches/releasebranch_7_4/vector/v.in.ogr/main.c 2017-11-19 17:44:41 UTC (rev 71773)
@@ -169,6 +169,10 @@
G_add_keyword(_("vector"));
G_add_keyword("OGR");
+ G_add_keyword(_("topology"));
+ G_add_keyword(_("geometry"));
+ G_add_keyword(_("snapping"));
module->description = _("Imports vector data into a GRASS vector map using OGR library.");
param.dsn = G_define_option();
