[GRASS-SVN] r71779 - in grass/branches/releasebranch_7_2: include/iostream lib/iostream
svn_grass at osgeo.org
Sun Nov 19 12:04:29 PST 2017
Author: mmetz
Date: 2017-11-19 12:04:29 -0800 (Sun, 19 Nov 2017)
New Revision: 71779
grass/branches/releasebranch_7_2/include/iostream/empq_adaptive.h
grass/branches/releasebranch_7_2/include/iostream/mm.h
grass/branches/releasebranch_7_2/lib/iostream/mm.cpp
iostreamlib: fix memory manager (backport trunk r71625)
Modified: grass/branches/releasebranch_7_2/include/iostream/empq_adaptive.h
--- grass/branches/releasebranch_7_2/include/iostream/empq_adaptive.h 2017-11-19 20:03:10 UTC (rev 71778)
+++ grass/branches/releasebranch_7_2/include/iostream/empq_adaptive.h 2017-11-19 20:04:29 UTC (rev 71779)
@@ -44,10 +44,9 @@
#include "empq_impl.h"
+#define EMPQAD_DEBUG if(G_verbose() > G_verbose_std())
-#define EMPQAD_DEBUG if(1)
enum regim_type {
INMEM = 0,
EXTMEM,
Modified: grass/branches/releasebranch_7_2/include/iostream/mm.h
--- grass/branches/releasebranch_7_2/include/iostream/mm.h 2017-11-19 20:03:10 UTC (rev 71778)
+++ grass/branches/releasebranch_7_2/include/iostream/mm.h 2017-11-19 20:04:29 UTC (rev 71779)
@@ -132,18 +132,20 @@
void print();
- friend class mm_register_init;
+ // make these members of MM_register
#ifdef GRASS_MM_USE_EXCEPTION_SPECIFIER
- friend void * operator new(size_t) throw (std::bad_alloc);
- friend void * operator new[] (size_t) throw (std::bad_alloc);
- friend void operator delete(void *) throw();
- friend void operator delete[](void *) throw();
+ void * operator new(size_t) throw (std::bad_alloc);
+ void * operator new[] (size_t) throw (std::bad_alloc);
+ void operator delete(void *) throw();
+ void operator delete[](void *) throw();
#else
- friend void * operator new(size_t);
- friend void * operator new[] (size_t);
- friend void operator delete(void *) noexcept;
- friend void operator delete[](void *) noexcept;
+ void * operator new(size_t);
+ void * operator new[] (size_t);
+ void operator delete(void *) noexcept;
+ void operator delete[](void *) noexcept;
#endif /* GRASS_MM_USE_EXCEPTION_SPECIFIER */
+ friend class mm_register_init;
Modified: grass/branches/releasebranch_7_2/lib/iostream/mm.cpp
--- grass/branches/releasebranch_7_2/lib/iostream/mm.cpp 2017-11-19 20:03:10 UTC (rev 71778)
+++ grass/branches/releasebranch_7_2/lib/iostream/mm.cpp 2017-11-19 20:04:29 UTC (rev 71779)
@@ -276,13 +276,18 @@
+/* these overloaded operators must only be used by this memory manager
+ * risk of invalid free if these operators are defined outside the MM_register class
+ * e.g. GDAL allocating memory with something else than new as defined here
+ * but then using delete as defined here
-void* operator new[] (size_t sz) throw (std::bad_alloc) {
+void* MM_register::operator new[] (size_t sz) throw (std::bad_alloc) {
#else
-void* operator new[] (size_t sz) {
+void* MM_register::operator new[] (size_t sz) {
void *p;
MM_DEBUG cout << "new: sz=" << sz << ", register "
<< sz+SIZE_SPACE << "B ,";
@@ -320,7 +325,7 @@
assert(0);
exit (1);
*((size_t *) p) = sz;
MM_DEBUG cout << "ptr=" << (void*) (((char *) p) + SIZE_SPACE) << endl;
@@ -332,12 +337,12 @@
-void* operator new (size_t sz) throw (std::bad_alloc) {
+void* MM_register::operator new (size_t sz) throw (std::bad_alloc) {
#else
-void* operator new (size_t sz) {
+void* MM_register::operator new (size_t sz) {
void *p;
@@ -375,7 +380,7 @@
assert(0);
exit (1);
@@ -388,13 +393,13 @@
-void operator delete (void *ptr) throw() {
+void MM_register::operator delete (void *ptr) throw() {
#else
-void operator delete (void *ptr) noexcept {
+void MM_register::operator delete (void *ptr) noexcept {
size_t sz;
void *p;
MM_DEBUG cout << "delete: ptr=" << ptr << ",";
if (!ptr) {
@@ -411,6 +416,9 @@
assert(ptr);
+ /* causes invalid free if ptr has not been allocated with new as
+ * defined above */
p = ((char *)ptr) - SIZE_SPACE; // the base of memory
sz = *((size_t *)p);
@@ -432,9 +440,9 @@
-void operator delete[] (void *ptr) throw() {
+void MM_register::operator delete[] (void *ptr) throw() {
#else
-void operator delete[] (void *ptr) noexcept {
+void MM_register::operator delete[] (void *ptr) noexcept {
size_t sz;
void *p;
@@ -450,6 +458,9 @@
return;
assert(ptr);
