[GRASS-SVN] r71786 - grass-addons/grass7/raster/r.neighborhoodmatrix
svn_grass at osgeo.org
Mon Nov 20 03:49:09 PST 2017
Author: mlennert
Date: 2017-11-20 03:49:09 -0800 (Mon, 20 Nov 2017)
New Revision: 71786
grass-addons/grass7/raster/r.neighborhoodmatrix/r.neighborhoodmatrix.html
grass-addons/grass7/raster/r.neighborhoodmatrix/r.neighborhoodmatrix.py
r.neighborhoodmatrix: rewrite to include neighborhood length, avoid all-in-memory processing, allow parallelization
Modified: grass-addons/grass7/raster/r.neighborhoodmatrix/r.neighborhoodmatrix.html
--- grass-addons/grass7/raster/r.neighborhoodmatrix/r.neighborhoodmatrix.html 2017-11-19 20:47:14 UTC (rev 71785)
+++ grass-addons/grass7/raster/r.neighborhoodmatrix/r.neighborhoodmatrix.html 2017-11-20 11:49:09 UTC (rev 71786)
@@ -1,30 +1,54 @@
<h2>DESCRIPTION</h2>
+<p>
<em>r.neighborhoodmatrix</em> identifies all adjacency relations between
-segments (or clumps) in a raster map and exports these as a 2xn matrix
+objects (aka segments or clumps) in a raster map and exports these as a 2xn matrix
where n is the number of neighborhood relations with each relation listed
in both directions (i.e. if a is neighbor of b, the list will contain
-a,b and b,a).
+a,b and b,a). If a path to an output file is specified, the matrix will be
+written to that file, otherwise it will be sent to standard output.
+<p>
Neighborhood relations are determined pixel by pixel, and by default only
pixels that share a common pixel boundary are considered neighbors. When
the <em>-d</em> flag is set pixels sharing a common corner (i.e. diagonal
neighbors) are also taken into account.
-If a path to an output file is specified, the matrix will be written to that
-file, otherwise it will be sent to standard output.
+<p>
+When the <em>-l</em> flag is set, the module additionally indicates the length
+of the common border between two neighbors in number of pixels. As this length
+is not clearly defined for diagonal neighbors, the <em>-l</em> flag cannot
+be used in combination with the <em>-d</em> flag.
+<p>
+In order to speed up calculations, the user can set the parameter
+<em>processes</em> to the number of desired processes to run in parallel. As
+the module parallelizes per direction, the maximum number of processes is 4
+without and 8 with the <em>-d</em> flag.
<h2>NOTES</h2>
+<p>
The module (without the <em>-d</em> flag) should give the same result as the equivalent call to
<a href="v.neighborhoodmatrix.html">v.neighborhoodmatrix</a> with the <em>-b</em>
flag. Currently it actually seems faster for some maps to transform the raster
to vector and then run the latter. More tests are needed, though, to confirm
this.
+<p>
+As neighborhood length is measured in pixels, this length is not in proportion
+to length in map units if the location is a lat-long location, or if the
+resolution is not the same in East-West and in North-South direction
+(rectangular pixels).
<h2>TODO</h2>
-Add flag to only output half matrix with each relation only shown once.
+<ul>
+ <li>Add flag to only output half matrix with each relation only shown
+ once.</li>
+ <li>Measure neighbordhood length in map units, not only pixels</li>
+</ul>
<h2>EXAMPLE</h2>
@@ -35,13 +59,15 @@
r.neighborhoodmatrix in=boundary_county_500m sep=comma
</pre></div>
-Idem, but sending the output to a file:
+Idem, but also calculating neighborhood length, sending the output to a file
+and using 4 parallel processes:
<div class="code"><pre>
-r.neighborhoodmatrix in=boundary_county_500m sep=comma output=county_neighbors.csv
+r.neighborhoodmatrix -l n=boundary_county_500m sep=comma \
+ output=county_neighbors.csv processes=4
</pre></div>
-Transforming the raster to vector (without attribute table or topology) and the using
+Transforming the raster to vector (without attribute table or topology) and using
<a href="v.neighborhoodmatrix.html">v.neighborhoodmatrix</a>:
Modified: grass-addons/grass7/raster/r.neighborhoodmatrix/r.neighborhoodmatrix.py
--- grass-addons/grass7/raster/r.neighborhoodmatrix/r.neighborhoodmatrix.py 2017-11-19 20:47:14 UTC (rev 71785)
+++ grass-addons/grass7/raster/r.neighborhoodmatrix/r.neighborhoodmatrix.py 2017-11-20 11:49:09 UTC (rev 71786)
@@ -35,102 +35,155 @@
#%option G_OPT_F_SEP
#%end
+#%option
+#% key: processes
+#% type: integer
+#% description: Number of processes to run in parallel (for multiple rasters)
+#% required: no
+#% answer: 1
+#%end
#%flag
#% key: d
#% description: Also take into account diagonal neighbors
#%end
+#%flag
+#% key: l
+#% description: Also output length of common border (in pixels)
+#%end
import grass.script as gscript
import sys
import os
import atexit
+import heapq
+from functools import partial
+from multiprocessing import Pool, Process, Queue
def cleanup():
- for nmap in n_mapnames.values():
+ for mapname in mapnames:
gscript.run_command('g.remove', flags='f', type='raster',
- pat=nmap, quiet=True)
- gscript.run_command('g.remove', flags='f', type='raster',
- pat=temp_map, quiet=True)
+ name=mapname, quiet=True)
- if diag:
- for nmap in n_diag_mapnames.values():
+ for filename in filenames:
+ os.remove(filename)
+ if outfile:
+ os.remove(outfile)
+ return 0
+def worker(input_queue, rinput, separator, result_queue):
+ for mapname, modifier in iter(input_queue.get, 'STOP'):
+ expression = "%s = if(%s%s!=%s, %s%s, null())" % (mapname, rinput, modifier, rinput, rinput, modifier)
+ gscript.run_command('r.mapcalc',
+ expression=expression,
+ quiet=True)
+ tf = gscript.tempfile()
+ rstats_results = gscript.read_command('r.stats',
+ input_=[rinput, mapname],
+ flags='nc',
+ output=tf,
+ separator=separator,
+ quiet=True)
+ result_queue.put(tf)
+# Sort by both cat values
+def keyfunc(s):
+ return [int(x) for x in s.split(separator)[:2]]
+def decorated_file(f, key):
+ for line in f:
+ yield (key(line), line)
def main():
+ global mapnames
+ mapnames = []
+ global filenames
+ filenames = []
+ global outfile
+ outfile = None
rinput = options['input']
output = options['output']
+ global separator
separator = gscript.separator(options['separator'])
+ processes = int(options['processes'])
- neighbors = []
- global pid, n_mapnames, diag, temp_map
- diag = False
pid = os.getpid()
- n_mapnames = {}
- n_mapnames['nl'] = "temp_nl_map_%d" % pid
- n_mapnames['nr'] = "temp_nr_map_%d" % pid
- n_mapnames['nu'] = "temp_nu_map_%d" % pid
- n_mapnames['nd'] = "temp_nd_map_%d" % pid
- temp_map = "temp_rneighborhoodmatrix_map_%d" % pid
+ nbnames = ['nl', 'nr', 'nu', 'nd', 'nul', 'nur', 'nll', 'nlr']
+ modifiers = ['[0,-1]', '[0,1]', '[1,0]', '[-1,0]', '[1,-1]', '[1,1]', '[-1,-1]', '[-1,1]']
- nbs = {'nl': '[0,-1]', 'nr': '[0,1]', 'nu': '[1,0]', 'nd': '[-1,0]'}
- nbs_diag = {'nul': '[1,-1]', 'nur': '[1,1]', 'nll': '[-1,-1]', 'nlr': '[-1,1]'}
- for n, modifier in nbs.items():
- expression = "%s = (%s%s)" % (temp_map, rinput, modifier)
- gscript.run_command('r.mapcalc',
- expression=expression,
- overwrite=True,
- quiet=True)
- expression = "%s = if(%s!=%s, %s, null())" % (n_mapnames[n], temp_map,
- rinput, temp_map)
- quiet=True)
- rstats_results = gscript.read_command('r.stats',
- input_=[rinput, n_mapnames[n]],
- flags='n1',
- separator=separator,
- quiet=True)
- results = rstats_results.splitlines()
- neighbors += results
+ # If the diagonal flag is not set, only keep direct neighbors
+ if not flags['d']:
+ nbnames = nbnames[:4]
+ modifiers = modifiers[:4]
+ mapnames = ["nb_temp_%s_map_%d" % (nbname, pid) for nbname in nbnames]
+ input_data = zip(mapnames, modifiers)
+ input_queue = Queue()
+ for input_datum in input_data:
+ input_queue.put(input_datum)
+ result_queue = Queue()
- if flags['d']:
- diag = True
- global n_diag_mapnames
- n_diag_mapnames = {}
- n_diag_mapnames['nul'] = "temp_nul_map_%d" % pid
- n_diag_mapnames['nur'] = "temp_nur_map_%d" % pid
- n_diag_mapnames['nll'] = "temp_nll_map_%d" % pid
- n_diag_mapnames['nlr'] = "temp_nlr_map_%d" % pid
+ # Launch processes for r.mapcalc and r.stats in as many processes as
+ # requested
+ processes_list = []
+ for p in xrange(processes):
+ proc = Process(target=worker, args=(input_queue, rinput, separator, result_queue))
+ proc.start()
+ processes_list.append(proc)
+ input_queue.put('STOP')
+ for p in processes_list:
+ p.join()
+ result_queue.put('STOP')
- for n, modifier in nbs_diag.items():
- expression = "%s = if(%s%s!=%s, %s%s, null())" % (n_diag_mapnames[n], rinput,
- modifier, rinput, rinput, modifier)
- quiet=True)
- input_=[rinput, n_diag_mapnames[n]],
- flags='n1',
- quiet=True)
- unique_neighbors = list(set(neighbors))
- unique_neighbors_sorted = gscript.natural_sort(unique_neighbors)
+ # Now merge all r.stats outputs (which are already sorted)
+ # into one file
+ for tf in iter(result_queue.get, 'STOP'):
+ filenames.append(tf)
+ files = map(open, filenames)
+ outfile = gscript.tempfile()
+ # This code comes from https://stackoverflow.com/a/1001625
+ with open(outfile, 'wb') as outf:
+ for line in heapq.merge(*[decorated_file(f, keyfunc) for f in files]):
+ outf.write(line[1])
+ # Define final output
if output == '-':
- for line in unique_neighbors_sorted:
- sys.stdout.write(line+"\n")
+ of = sys.stdout
else:
- of = open(output, 'w')
- of.write(line+"\n")
- of.close()
+ of = open(output, 'w')
+ # Read the merged output file and sum the results per neighborhood pair
+ OldAcat = None
+ OldBcat = None
+ Sum = 0
+ with open(outfile, 'r') as fin:
+ for line in fin:
+ Acat = line.split(separator)[0]
+ Bcat = line.split(separator)[1]
+ value = int(line.split(separator)[2])
+ if Acat == OldAcat and Bcat == OldBcat:
+ Sum += value
+ else:
+ if OldAcat and OldBcat:
+ if flags['l']:
+ woutput = separator.join([OldAcat, OldBcat, str(Sum)])
+ else:
+ woutput = separator.join([OldAcat, OldBcat])
+ of.write(woutput+"\n")
+ OldAcat = Acat
+ OldBcat = Bcat
+ Sum = value
+ if flags['l']:
+ else:
+ of.close()
if __name__ == "__main__":
options, flags = gscript.parser()
atexit.register(cleanup)
