[GRASS-SVN] r71808 - grass-addons/grass7/raster/r.change.info
Thu Nov 23 13:53:57 PST 2017
Author: veroandreo
Date: 2017-11-23 13:53:56 -0800 (Thu, 23 Nov 2017)
New Revision: 71808
   grass-addons/grass7/raster/r.change.info/r.change.info.html
r.change.info addon manual: minor grammar fixes
Modified: grass-addons/grass7/raster/r.change.info/r.change.info.html
--- grass-addons/grass7/raster/r.change.info/r.change.info.html	2017-11-23 09:02:43 UTC (rev 71807)
+++ grass-addons/grass7/raster/r.change.info/r.change.info.html	2017-11-23 21:53:56 UTC (rev 71808)
@@ -68,10 +68,10 @@
 <p>
 A low change in category distributions and a high change in
 size distributions means that the frequency of categories did not
-change much whereas that the size of patches changed.
+change much whereas the size of patches did change.
 <h4>Information gain</h4>
-The methods <b>gain1,gain2,gain3</b> calculate the <em>information
+The methods <b>gain1, gain2 and gain3</b> calculate the <em>information
 gain</em> after Quinlan (1986). The information gain is the difference
 between the entropy of the combined distribution and the average
 entropy of the observed distributions (conditional entropy). A larger
@@ -84,38 +84,38 @@
 classes, information gain tends to over-estimate changes.
 <p>
 The information gain can be zero even if all cells changed, but the
-distributions (frequencies of occurence) remained identical. The square
+distributions (frequencies of occurrence) remained identical. The square
 root of the information gain is sometimes used as a distance measure
-and is closely related to Fisher's information metric.
+and it is closely related to Fisher's information metric.
 <h4>Information gain ratio</h4>
-The methods <b>ratio1,ratio2,ratio3</b> calculate the <em>information
-gain ratio</em> that changes occured, estimated with the ratio of the
+The methods <b>ratio1, ratio2 and ratio3</b> calculate the <em>information
+gain ratio</em> that changes occurred, estimated with the ratio of the
 average entropy of the observed distributions to the entropy of the
 combined distribution. In other words, the ratio is equivalent to the
 ratio of actual change to maximum possible change (in uncertainty). The
 gain ratio is better suited than absolute information gain when the
 cells are distributed over a large number of categories and a large number
-of size classes. The gain ratio here follows the same rationale like
+of size classes. The gain ratio here follows the same rationale as
 the gain ratio of Quinlan (1986), but is calculated differently.
 <p>
 The gain ratio is always in the range (0, 1). A larger value means
 larger differences between input maps.
 <h4>CHI-square</h4>
-The methods <b>chisq1,chisq2,chisq3</b> calculate <em>CHI square</em>
+The methods <b>chisq1, chisq2 and chisq3</b> calculate <em>CHI square</em>
 after Quinlan (1986) to estimate the relevance of the different input
 maps. If the input maps are identical, the relevance measured as
-CHI-square is zero, no change occured. If the input maps differ from
-each other substantially, major changes occured and the relevance
+CHI-square is zero, i.e. no change occurred. If the input maps differ from
+each other substantially, major changes occurred and the relevance
 measured as CHI-square is large.
 <h4>Gini impurity</h4>
-The methods <b>gini1,gini2,gini3</b> calculate the <em>Gini
+The methods <b>gini1, gini2 and gini3</b> calculate the <em>Gini
 impurity</em>, which is 1 - Simpson's index, or 1 - 1 / diversity, or 1
 - 1 / 2^entropy for alpha = 1. The Gini impurity can thus be regarded
 as a modified measure of the diversity of a distribution. Changes
-occured when the diversity of the combined distribution is larger than
+occurred when the diversity of the combined distribution is larger than
 the average diversity of the observed distributions, thus a larger
 value means larger differences between input maps.
 <p>
@@ -124,14 +124,13 @@
 <p>
 The methods <em>information gain</em> and <em>CHI square</em> are the
-most sensitive measures, but also most susceptible to noise. The
+most sensitive measures, but also the most susceptible to noise. The
 <em>information gain ratio</em> is less sensitive, but more robust
 against noise. The <em>Gini impurity</em> is the least sensitive and
 detects only drastic changes.
 <h4>Distance</h4>
-The methods <b>dist1,dist2,dist3</b> calculate the statistical
+The methods <b>dist1, dist2 and dist3</b> calculate the statistical
 <em>distance</em> from the absolute differences between the average
 distribution and the observed distributions. The distance is always in
 the range (0, 1). A larger value means larger differences between input
@@ -193,9 +192,9 @@
 </pre></div>
-then a change assement can be done with
+then a change assessment can be done with
 <div class="code"><pre>
-r.change.info in=`g.mlist type=rast pat=MCD12Q1.A*.Land_Cover_Type_1 sep=,` \
+r.change.info in=`g.list type=rast pat=MCD12Q1.A*.Land_Cover_Type_1 sep=,` \
 	      method=pc,gain1,gain2,ratio1,ratio2,dist1,dist2
 	      out=MCD12Q1.pc,MCD12Q1.gain1,MCD12Q1.gain2,MCD12Q1.ratio1,MCD12Q1.ratio2,MCD12Q1.dist1,MCD12Q1.dist2 \
 	      radius=20 step=40 alpha=2
