[GRASS-SVN] r71825 - in grass-addons/grass7/general: . g.download.location
svn_grass at osgeo.org
Sat Nov 25 13:07:03 PST 2017
Author: wenzeslaus
Date: 2017-11-25 13:07:03 -0800 (Sat, 25 Nov 2017)
New Revision: 71825
Added:
grass-addons/grass7/general/g.download.location/
grass-addons/grass7/general/g.download.location/Makefile
grass-addons/grass7/general/g.download.location/g.download.location.html
grass-addons/grass7/general/g.download.location/g.download.location.py
grass-addons/grass7/general/Makefile
g.download.location: get, extract and place location from any URL (see also trunk/core r71310)
Modified: grass-addons/grass7/general/Makefile
--- grass-addons/grass7/general/Makefile 2017-11-25 20:45:16 UTC (rev 71824)
+++ grass-addons/grass7/general/Makefile 2017-11-25 21:07:03 UTC (rev 71825)
@@ -4,6 +4,7 @@
g.cloud \
g.compare.md5 \
g.copyall \
+ g.download.location \
g.isis3mt \
g.proj.all \
g.rename.many
Added: grass-addons/grass7/general/g.download.location/Makefile
--- grass-addons/grass7/general/g.download.location/Makefile (rev 0)
+++ grass-addons/grass7/general/g.download.location/Makefile 2017-11-25 21:07:03 UTC (rev 71825)
@@ -0,0 +1,7 @@
+MODULE_TOPDIR = ../..
+PGM = g.download.location
+include $(MODULE_TOPDIR)/include/Make/Script.make
+default: script
Added: grass-addons/grass7/general/g.download.location/g.download.location.html
--- grass-addons/grass7/general/g.download.location/g.download.location.html (rev 0)
+++ grass-addons/grass7/general/g.download.location/g.download.location.html 2017-11-25 21:07:03 UTC (rev 71825)
@@ -0,0 +1,22 @@
+<h2>DESCRIPTION</h2>
+<em>g.download.location</em> downloads a location from a given URL
+and unpacks it to a specified or current GRASS GIS Spatial Database.
+URL can be also a local file on the disk.
+<h2>SEE ALSO</h2>
+<em>
+ <a href="g.mapset.html">g.mapset</a>,
+ <a href="g.mapsets.html">g.mapsets</a>,
+ <a href="r.proj.html">r.proj</a>,
+ <a href="v.proj.html">v.proj</a>,
+ <a href="g.proj.all.html">g.proj.all</a>,
+</em>
+<h2>AUTHORS</h2>
+Vaclav Petras, <a href="http://geospatial.ncsu.edu/osgeorel/">NCSU GeoForAll Lab</a>
+<p>
+<i>Last changed: $Date: 2016-04-21 10:33:08 -0400 (Thu, 21 Apr 2016) $</i>
Added: grass-addons/grass7/general/g.download.location/g.download.location.py
--- grass-addons/grass7/general/g.download.location/g.download.location.py (rev 0)
+++ grass-addons/grass7/general/g.download.location/g.download.location.py 2017-11-25 21:07:03 UTC (rev 71825)
@@ -0,0 +1,213 @@
+#!/usr/bin/env python
+# MODULE: g.download.location
+# AUTHOR(S): Vaclav Petras <wenzeslaus gmail com>
+# PURPOSE: Download and extract location from web
+# COPYRIGHT: (C) 2017 by the GRASS Development Team
+# This program is free software under the GNU General
+# Public License (>=v2). Read the file COPYING that
+# comes with GRASS for details.
+#%module
+#% label: Download GRASS Location from the web
+#% description: Get GRASS Location from an URL or file path
+#% keyword: general
+#% keyword: data
+#% keyword: download
+#% keyword: import
+#%end
+#%option
+#% key: url
+#% multiple: no
+#% type: string
+#% label: URL of the archive with a location to be downloaded
+#% description: URL of ZIP, TAR.GZ, or other similar archive
+#% required: yes
+#%end
+#%option G_OPT_M_LOCATION
+#% key: name
+#% required: no
+#% multiple: no
+#% key_desc: name
+#%end
+#%option G_OPT_M_DBASE
+#% required: no
+#% multiple: no
+#%end
+import os
+import shutil
+import tempfile
+try:
+ from urllib2 import HTTPError, URLError
+ from urllib import urlopen, urlretrieve
+except ImportError:
+ # there is also HTTPException, perhaps change to list
+ from urllib.error import HTTPError, URLError
+ from urllib.request import urlopen, urlretrieve
+import grass.script as gs
+from grass.script.utils import try_rmdir
+class DownloadError(Exception):
+ pass
+# TODO: multiple functions copied or modified from g.extension and
+# startup screen Download button
+# all should go to "grass.scripts.tools"
+# copy from g.extension
+def move_extracted_files(extract_dir, target_dir, files):
+ """Fix state of extracted file by moving them to different diretcory
+ When extracting, it is not clear what will be the root directory
+ or if there will be one at all. So this function moves the files to
+ a different directory in the way that if there was one directory extracted,
+ the contained files are moved.
+ gs.debug("move_extracted_files({0})".format(locals()))
+ if len(files) == 1:
+ shutil.copytree(os.path.join(extract_dir, files[0]), target_dir)
+ else:
+ if not os.path.exists(target_dir):
+ os.mkdir(target_dir)
+ for file_name in files:
+ actual_file = os.path.join(extract_dir, file_name)
+ if os.path.isdir(actual_file):
+ # shutil.copytree() replaced by copy_tree() because
+ # shutil's copytree() fails when subdirectory exists
+ shutil.copytree(actual_file,
+ os.path.join(target_dir, file_name))
+ else:
+ shutil.copy(actual_file, os.path.join(target_dir, file_name))
+def extract_zip(name, directory, tmpdir):
+ """Extract a ZIP file into a directory"""
+ gs.debug("extract_zip(name={name}, directory={directory},"
+ " tmpdir={tmpdir})".format(name=name, directory=directory,
+ tmpdir=tmpdir), 3)
+ try:
+ import zipfile
+ zip_file = zipfile.ZipFile(name, mode='r')
+ file_list = zip_file.namelist()
+ # we suppose we can write to parent of the given dir
+ # (supposing a tmp dir)
+ extract_dir = os.path.join(tmpdir, 'extract_dir')
+ os.mkdir(extract_dir)
+ for subfile in file_list:
+ # this should be safe in Python 2.7.4
+ zip_file.extract(subfile, extract_dir)
+ files = os.listdir(extract_dir)
+ move_extracted_files(extract_dir=extract_dir,
+ target_dir=directory, files=files)
+ except zipfile.BadZipfile as error:
+ raise DownloadError(_("ZIP file is unreadable: {0}").format(error))
+def extract_tar(name, directory, tmpdir):
+ """Extract a TAR or a similar file into a directory"""
+ gs.debug("extract_tar(name={name}, directory={directory},"
+ try:
+ import tarfile # we don't need it anywhere else
+ tar = tarfile.open(name)
+ tar.extractall(path=extract_dir)
+ except tarfile.TarError as error:
+ raise DownloadError(_("Archive file is unreadable: {0}").format(error))
+extract_tar.supported_formats = ['tar.gz', 'gz', 'bz2', 'tar', 'gzip', 'targz']
+def download_end_extract(source):
+ tmpdir = tempfile.mkdtemp()
+ directory = os.path.join(tmpdir, 'location')
+ if source.endswith('.zip'):
+ archive_name = os.path.join(tmpdir, 'location.zip')
+ # TODO: except IOError from urlretrieve
+ f, h = urlretrieve(source, archive_name)
+ if h.get('content-type', '') != 'application/zip':
+ raise DownloadError(_("Download of <%s> failed "
+ "or file is not a ZIP file") % source)
+ extract_zip(name=archive_name, directory=directory, tmpdir=tmpdir)
+ elif (source.endswith(".tar.gz") or
+ source.rsplit('.', 1)[1] in extract_tar.supported_formats):
+ if source.endswith(".tar.gz"):
+ ext = "tar.gz"
+ else:
+ ext = source.rsplit('.', 1)[1]
+ archive_name = os.path.join(tmpdir, 'extension.' + ext)
+ urlretrieve(source, archive_name)
+ # TODO: error handling for urlretrieve
+ extract_tar(name=archive_name, directory=directory, tmpdir=tmpdir)
+ else:
+ # probably programmer error
+ # TODO: use GUI way
+ raise DownloadError(_("Unknown format '{0}'.").format(source))
+ assert os.path.isdir(directory)
+ return directory
+# based on grass.py
+def is_location_valid(location):
+ """Return True if GRASS Location is valid
+ :param location: path of a Location
+ # DEFAULT_WIND file should not be required until you do something
+ # that actually uses them. The check is just a heuristic; a directory
+ # containing a PERMANENT/DEFAULT_WIND file is probably a GRASS
+ # location, while a directory lacking it probably isn't.
+ # TODO: perhaps we can relax this and require only permanent
+ return os.access(os.path.join(location,
+ "PERMANENT", "DEFAULT_WIND"), os.F_OK)
+def location_name_from_url(url):
+ return (url.rsplit('/', 1)[1].split('.', 1)[0]
+ .replace("-", "_").replace(" ", "_"))
+def main(options, flags):
+ url = options['url']
+ name = options['name']
+ database = options['dbase']
+ if not database:
+ # use current
+ database = gs.gisenv()['GISDBASE']
+ if not name:
+ name = location_name_from_url(url)
+ destination = os.path.join(database, name)
+ if os.path.exists(destination):
+ gs.fatal(_("Location named <%s> already exists,"
+ " download canceled") % name)
+ return
+ gs.message(_("Downloading and extracting..."))
+ directory = download_end_extract(url)
+ if not is_location_valid(directory):
+ try_rmdir(directory)
+ gs.message(_("Finalizing..."))
+ shutil.copytree(src=directory, dst=destination)
+ gs.message(_("Location is now in %s") % destination)
+if __name__ == '__main__':
+ main(*gs.parser())
