[GRASS-SVN] r71849 - grass/trunk/tools
Sun Nov 26 13:39:25 PST 2017
Author: wenzeslaus
Date: 2017-11-26 13:39:24 -0800 (Sun, 26 Nov 2017)
New Revision: 71849
   grass/trunk/tools/mkhtml.py
doc: Python 3 compatibility (see #2708)
Decode file content on input in 3, leave as in in 2.
Call constructor of parent class (Python 3 version needs to init a var).
Call less efficient items() in Python 2 (same code in both, although slower in 2, ok here).
This avoids compile (mkhtml) errors in most of the directories with Python 3.5.2 as python.
Modified: grass/trunk/tools/mkhtml.py
--- grass/trunk/tools/mkhtml.py	2017-11-26 20:24:08 UTC (rev 71848)
+++ grass/trunk/tools/mkhtml.py	2017-11-26 21:39:24 UTC (rev 71849)
@@ -21,6 +21,7 @@
 import string
 import re
 from datetime import datetime
+import locale
 try:
     # Python 2 import
@@ -34,6 +35,38 @@
     import urllib.parse as urlparse
+if sys.version_info.major == 2:
+    PY2 = True
+else:
+    PY2 = False
+if not PY2:
+    unicode = str
+def _get_encoding():
+    encoding = locale.getdefaultlocale()[1]
+    if not encoding:
+        encoding = 'UTF-8'
+    return encoding
+def decode(bytes_):
+    """Decode bytes with default locale and return (unicode) string
+    No-op if parameter is not bytes (assumed unicode string).
+    :param bytes bytes_: the bytes to decode
+    if isinstance(bytes_, unicode):
+        return bytes_
+    if isinstance(bytes_, bytes):
+        enc = _get_encoding()
+        return bytes_.decode(enc)
+    return unicode(bytes_)
 pgm = sys.argv[1]
 src_file = "%s.html" % pgm
@@ -119,7 +152,10 @@
         f = open(name, 'rb')
         s = f.read()
         f.close()
-        return s
+        if PY2:
+            return s
+        else:
+            return decode(s)
     except IOError:
         return ""
@@ -127,6 +163,7 @@
 def create_toc(src_data):
     class MyHTMLParser(HTMLParser):
         def __init__(self):
+            HTMLParser.__init__(self)
             self.reset()
             self.idx = 1
             self.tag_curr = ''
@@ -291,7 +328,7 @@
 index_titles = {}
-for key, name in index_names.iteritems():
+for key, name in index_names.items():
     index_titles[key] = to_title(name)
 # process footer
