[GRASS-SVN] r71871 - grass/trunk/raster/r.info
svn_grass at osgeo.org
Wed Nov 29 11:32:24 PST 2017
Author: mmetz
Date: 2017-11-29 11:32:24 -0800 (Wed, 29 Nov 2017)
New Revision: 71871
grass/trunk/raster/r.info/main.c
r.info: add flag to print raster map statistics
Modified: grass/trunk/raster/r.info/main.c
--- grass/trunk/raster/r.info/main.c 2017-11-29 19:26:15 UTC (rev 71870)
+++ grass/trunk/raster/r.info/main.c 2017-11-29 19:32:24 UTC (rev 71871)
@@ -15,6 +15,8 @@
+#include <math.h>
+#include <sys/types.h>
#include <grass/config.h>
#include <stdlib.h>
#include <string.h>
@@ -31,7 +33,6 @@
fprintf(out,"-");\
fprintf (out,"%c\n",x)
/* local prototypes */
static void format_double(const double, char *);
static void compose_line(FILE *, const char *, ...);
@@ -50,6 +51,7 @@
FILE *out;
struct Range crange;
struct FPRange range;
+ struct R_stats rstats;
struct Cell_head cellhd;
struct Categories cats;
struct History hist;
@@ -61,7 +63,7 @@
struct Reclass reclass;
struct GModule *module;
struct Option *opt1;
- struct Flag *gflag, *rflag, *eflag, *hflag;
+ struct Flag *gflag, *rflag, *eflag, *hflag, *sflag;
/* Initialize GIS Engine */
G_gisinit(argv[0]);
@@ -84,6 +86,10 @@
rflag->key = 'r';
rflag->description = _("Print range in shell script style");
+ sflag = G_define_flag();
+ sflag->key = 's';
+ sflag->description = _("Print stats in shell script style");
eflag = G_define_flag();
eflag->key = 'e';
eflag->description = _("Print extended metadata information in shell script style");
@@ -95,7 +101,7 @@
if (G_parser(argc, argv))
exit(EXIT_FAILURE);
- if (hflag->answer && (gflag->answer || rflag->answer || eflag->answer))
+ if (hflag->answer && (gflag->answer || rflag->answer || sflag->answer || eflag->answer))
G_fatal_error(_("Flags -%c and -%c/%c/%c are mutually exclusive"),
hflag->key, gflag->key, rflag->key, eflag->key);
@@ -105,6 +111,7 @@
Rast_get_cellhd(name, "", &cellhd);
cats_ok = Rast_read_cats(name, "", &cats) >= 0;
+ title = Rast_get_cats_title(&cats);
hist_ok = Rast_read_history(name, "", &hist) >= 0;
is_reclass = Rast_get_reclass(name, "", &reclass);
data_type = Rast_map_type(name, "");
@@ -129,7 +136,7 @@
out = stdout;
- if (eflag->answer || (!gflag->answer && !rflag->answer && !hflag->answer)) {
+ if (eflag->answer || (!gflag->answer && !rflag->answer && !sflag->answer && !hflag->answer)) {
title = "";
/* empty title by default */
/* use title from category file as the primary (and only) title */
@@ -144,7 +151,7 @@
- if (!gflag->answer && !rflag->answer &&
+ if (!gflag->answer && !rflag->answer && !sflag->answer &&
!eflag->answer && !hflag->answer) {
divider('+');
@@ -232,13 +239,21 @@
" Range of data: min = %i max = %i",
(CELL) zmin, (CELL) zmax);
- else if (data_type == FCELL_TYPE) {
- compose_line(out, " Range of data: min = %.7g max = %.7g",
- zmin, zmax);
else {
- compose_line(out, " Range of data: min = %.15g max = %.15g",
- zmin, zmax);
+ if (Rast_is_d_null_value(&zmin)) {
+ compose_line(out,
+ " Range of data: min = NULL max = NULL");
+ else {
+ if (data_type == FCELL_TYPE) {
+ compose_line(out, " Range of data: min = %.7g max = %.7g",
+ zmin, zmax);
+ else {
+ compose_line(out, " Range of data: min = %.15g max = %.15g",
+ zmin, zmax);
@@ -316,7 +331,7 @@
fprintf(out, "\n");
- else { /* g,r,e, or h flags */
+ else { /* g,r,s, e, or h flags */
if (gflag->answer) {
G_format_northing(cellhd.north, tmp1, -1);
@@ -362,13 +377,94 @@
fprintf(out, "max=%i\n", (CELL) zmax);
- fprintf(out, "min=%.7g\n", zmin);
- fprintf(out, "max=%.7g\n", zmax);
+ else {
+ fprintf(out, "min=NULL\n");
+ fprintf(out, "max=NULL\n");
+ else {
+ fprintf(out, "min=%.7g\n", zmin);
+ fprintf(out, "max=%.7g\n", zmax);
+ else {
+ fprintf(out, "min=%.15g\n", zmin);
+ fprintf(out, "max=%.15g\n", zmax);
+ if (sflag->answer) {
+ if (Rast_read_rstats(name, mapset, &rstats) < 0) {
+ DCELL *dbuf, val;
+ int fd, r, c;
+ int first = 1;
+ Rast_set_input_window(&cellhd);
+ dbuf = Rast_allocate_d_input_buf();
+ fd = Rast_open_old(name, mapset);
+ for (r = 0; r < cellhd.rows; r++) {
+ Rast_get_d_row(fd, dbuf, r);
+ for (c = 0; c < cellhd.cols; c++) {
+ val = dbuf[c];
+ if (Rast_is_d_null_value(&val))
+ continue;
+ if (first) {
+ rstats.sum = val;
+ rstats.sumsq = (DCELL) val * val;
+ rstats.count = 1;
+ first = 0;
+ else {
+ rstats.sum += val;
+ rstats.sumsq += (DCELL) val * val;
+ rstats.count += 1;
+ Rast_close(fd);
+ G_free(dbuf);
+ if (rstats.count > 0) {
+ double mean, sd;
+ mean = (double)(rstats.sum / rstats.count);
+ sd = sqrt(rstats.sumsq / rstats.count - (mean * mean));
+#ifdef HAVE_LONG_LONG_INT
+ fprintf(out, "n=%lld\n", (long long int)rstats.count);
+#else
+ fprintf(out, "n=%.0f\n", (double)rstats.count);
+#endif
+ if (!rflag->answer) {
+ if (zmin == zmax) {
+ fprintf(out, "mean=%.15g\n", zmin);
+ fprintf(out, "stddev=0\n");
+ else {
+ fprintf(out, "mean=%.15g\n", mean);
+ fprintf(out, "stddev=%.15g\n", sd);
+ fprintf(out, "sum=%.15g\n", rstats.sum);
else {
- fprintf(out, "min=%.15g\n", zmin);
- fprintf(out, "max=%.15g\n", zmax);
+ fprintf(out, "n=0\n");
+ fprintf(out, "mean=NULL\n");
+ fprintf(out, "stddev=NULL\n");
+ fprintf(out, "sum=NULL\n");
