[GRASS-SVN] r71523 - grass/trunk/lib/proj
Sun Oct 1 13:44:08 PDT 2017
Author: mmetz
Date: 2017-10-01 13:44:08 -0700 (Sun, 01 Oct 2017)
New Revision: 71523
   grass/trunk/lib/proj/convert.c
   grass/trunk/lib/proj/get_proj.c
libproj: use PROJ4 EXTENSION in WKT (TODO: PROJ4_GRIDS)
Modified: grass/trunk/lib/proj/convert.c
--- grass/trunk/lib/proj/convert.c	2017-10-01 13:55:35 UTC (rev 71522)
+++ grass/trunk/lib/proj/convert.c	2017-10-01 20:44:08 UTC (rev 71523)
@@ -388,6 +388,7 @@
     const char *pszProjCS = NULL;
     char *datum = NULL;
     struct gpj_datum dstruct;
+    const char *ograttr;
     if (hSRS == NULL)
 	goto default_to_xy;
@@ -399,6 +400,66 @@
      * to start with... */
     OSRMorphFromESRI(hSRS);
+    *projinfo = G_create_key_value();
+    /* use proj4 definition from EXTENSION attribute if existing */
+    ograttr = OSRGetAttrValue(hSRS, "EXTENSION", 0);
+    if (ograttr && *ograttr && strcmp(ograttr, "PROJ4") == 0) {
+	ograttr = OSRGetAttrValue(hSRS, "EXTENSION", 1);
+	G_debug(3, "proj4 extension:");
+	G_debug(3, "%s", ograttr);
+	if (ograttr && *ograttr) {
+	    char *proj4ext;
+	    OGRSpatialReferenceH hSRS2;
+	    proj4ext = G_store(ograttr);
+	    hSRS2 = OSRNewSpatialReference(NULL);
+	    /* test */
+	    if (OSRImportFromProj4(hSRS2, proj4ext) != OGRERR_NONE) {
+		G_warning(_("Updating spatial reference with embedded proj4 definition failed. "
+		            "Proj4 definition: <%s>"), proj4ext);
+	    else {
+		OSRDestroySpatialReference(hSRS2);
+		/* update OGR spatial reference with proj4 string */
+		/* TODO: replace warning with important_message once confirmed working */
+		G_warning(_("Updating spatial reference with embedded proj4 definition"));
+		/*      Derive the user name for the coordinate system.                 */
+		pszProjCS = OSRGetAttrValue(hSRS, "PROJCS", 0);
+		if (!pszProjCS)
+		    pszProjCS = OSRGetAttrValue(hSRS, "GEOGCS", 0);
+		if (pszProjCS) {
+		    G_set_key_value("name", pszProjCS, *projinfo);
+		else if (pszProj) {
+		    char path[4095];
+		    char name[80];
+		    /* use name of the projection as name for the coordinate system */
+		    sprintf(path, "%s/etc/proj/projections", G_gisbase());
+		    if (G_lookup_key_value_from_file(path, pszProj, name, sizeof(name)) >
+			0)
+			G_set_key_value("name", name, *projinfo);
+		    else
+			G_set_key_value("name", pszProj, *projinfo);
+		OSRDestroySpatialReference(hSRS);
+		hSRS = OSRNewSpatialReference(NULL);
+		if (OSRImportFromProj4(hSRS, proj4ext) != OGRERR_NONE) {
+		    G_fatal_error(_("Can't parse PROJ.4-style parameter string"));
+	    G_free(proj4ext);
     /*      Set cellhd for well known coordinate systems.                   */
@@ -474,6 +535,11 @@
 	    pszProj = pszValue;
+	/* discard @null nadgrids */
+	if (G_strcasecmp(pszToken, "nadgrids") == 0 &&
+	    G_strcasecmp(pszValue, "@null") == 0)
+	    continue;
 	/* Ellipsoid and datum handled separately below */
 	if (G_strcasecmp(pszToken, "ellps") == 0
 	    || G_strcasecmp(pszToken, "a") == 0
@@ -493,33 +559,32 @@
     if (!pszProj)
 	G_warning(_("No projection name! Projection parameters likely to be meaningless."));
-    *projinfo = G_create_key_value();
-    pszProjCS = OSRGetAttrValue(hSRS, "PROJCS", 0);
-    if (!pszProjCS)
-	pszProjCS = OSRGetAttrValue(hSRS, "GEOGCS", 0);
+    if (!G_find_key_value("name", *projinfo)) {
+	if (!pszProjCS)
-    if (pszProjCS) {
-	G_set_key_value("name", pszProjCS, *projinfo);
-    else if (pszProj) {
-	char path[4095];
-	char name[80];
-	/* use name of the projection as name for the coordinate system */
+	if (pszProjCS) {
+	    char path[4095];
+	    char name[80];
-	sprintf(path, "%s/etc/proj/projections", G_gisbase());
-	if (G_lookup_key_value_from_file(path, pszProj, name, sizeof(name)) >
-	    0)
-	    G_set_key_value("name", name, *projinfo);
-	else
-	    G_set_key_value("name", pszProj, *projinfo);
+		0)
+	    else
     /*      Find the GRASS datum name and choose parameters either          */
     /*      interactively or not.                                           */
@@ -581,18 +646,18 @@
 		    if (paramsets > 0) {
-			struct gpj_datum_transform_list *list, *old;
+			struct gpj_datum_transform_list *tlist, *old;
-			list = GPJ_get_datum_transform_by_name(datum);
+			tlist = GPJ_get_datum_transform_by_name(datum);
-			if (list != NULL) {
+			if (tlist != NULL) {
 			    do {
-				if (list->count == datumtrans)
-				    chosenparams = G_store(list->params);
-				old = list;
-				list = list->next;
+				if (tlist->count == datumtrans)
+				    chosenparams = G_store(tlist->params);
+				old = tlist;
+				tlist = tlist->next;
 				GPJ_free_datum_transform(old);
-			    } while (list != NULL);
+			    } while (tlist != NULL);
@@ -653,8 +718,10 @@
 		 * accept first one that matches. These numbers were found
 		 * by trial and error and could be fine-tuned, or possibly
 		 * a direct comparison of IEEE floating point values used. */
-		if ((a == list->a || fabs(a - list->a) < 0.1 || fabs(1 - a / list->a) < 0.0000001) && ((es == 0 && list->es == 0) ||	/* Special case for sphere */
-												       (invflat == list->rf || fabs(invflat - list->rf) < 0.0000001))) {
+		if ((a == list->a || fabs(a - list->a) < 0.1 || fabs(1 - a / list->a) < 0.0000001) &&
+		    ((es == 0 && list->es == 0) ||
+		    /* Special case for sphere */
+		    (invflat == list->rf || fabs(invflat - list->rf) < 0.0000001))) {
 		    ellps = G_store(list->name);
 		    break;
Modified: grass/trunk/lib/proj/get_proj.c
--- grass/trunk/lib/proj/get_proj.c	2017-10-01 13:55:35 UTC (rev 71522)
+++ grass/trunk/lib/proj/get_proj.c	2017-10-01 20:44:08 UTC (rev 71523)
@@ -64,7 +64,7 @@
     double a, es, rf;
     int returnval = 1;
     char buffa[300], factbuff[50];
-    char proj_in[50], *datum, *params;
+    char proj_in[250], *datum, *params;
     projPJ *pj;
     proj_in[0] = '\0';
