[GRASS-SVN] r71550 - grass/trunk/vector/v.in.ogr
svn_grass at osgeo.org
Wed Oct 11 01:27:36 PDT 2017
Author: mmetz
Date: 2017-10-11 01:27:36 -0700 (Wed, 11 Oct 2017)
New Revision: 71550
grass/trunk/vector/v.in.ogr/main.c
v.in.ogr: stricter projection check, layer-specific settings, code restructuring
Modified: grass/trunk/vector/v.in.ogr/main.c
--- grass/trunk/vector/v.in.ogr/main.c 2017-10-11 08:04:48 UTC (rev 71549)
+++ grass/trunk/vector/v.in.ogr/main.c 2017-10-11 08:27:36 UTC (rev 71550)
@@ -6,8 +6,9 @@
* AUTHOR(S): Radim Blazek
* Markus Neteler (spatial parm, projection support)
* Paul Kelly (projection support)
+ * Markus Metz
- * PURPOSE: Import OGR vectors
+ * PURPOSE: Import vector data with OGR
* COPYRIGHT: (C) 2003-2016 by the GRASS Development Team
@@ -38,6 +39,19 @@
# define MAX(a,b) ((a>b) ? a : b)
#endif
+/* define type of input datasource
+ * as of GDAL 2.2, all functions having as argument a GDAL/OGR dataset
+ * must use the GDAL version, not the OGR version */
+#if GDAL_VERSION_NUM >= 2020000
+typedef GDALDatasetH ds_t;
+#define ds_getlayerbyindex(ds, i) GDALDatasetGetLayer((ds), (i))
+#define ds_close(ds) GDALClose(ds)
+#else
+typedef OGRDataSourceH ds_t;
+#define ds_getlayerbyindex(ds, i) OGR_DS_GetLayer((ds), (i))
+#define ds_close(ds) OGR_DS_Destroy(ds)
+#endif
int n_polygons;
int n_polygon_boundaries;
double split_distance;
@@ -50,13 +64,19 @@
char *get_datasource_name(const char *, int);
+int cmp_layer_srs(ds_t, int, int *, char **, char *);
+int get_layer_proj(OGRLayerH, struct Cell_head *,
+ struct Key_Value **, struct Key_Value **,
+ char *, int);
+int create_spatial_filter(ds_t Ogr_ds, OGRGeometryH *,
+ int , int *, char **,
+ double *, double *,
+ int , struct Option *);
struct OGR_iterator
-#if GDAL_VERSION_NUM >= 2020000
- GDALDatasetH *Ogr_ds;
-#else
- OGRDataSourceH *Ogr_ds;
-#endif
+ ds_t *Ogr_ds;
char *dsn;
int nlayers;
int has_nonempty_layers;
@@ -69,12 +89,7 @@
void OGR_iterator_init(struct OGR_iterator *OGR_iter,
- GDALDatasetH *Ogr_ds,
-#else
- OGRDataSourceH *Ogr_ds,
-#endif
- char *dsn, int nlayers,
+ ds_t *Ogr_ds, char *dsn, int nlayers,
int ogr_interleaved_reading);
void OGR_iterator_reset(struct OGR_iterator *OGR_iter);
@@ -119,15 +134,11 @@
dbDriver *driver = NULL;
dbString sql, strval;
int with_z, input3d;
- const char *key_column;
- int key_idx = -2; /* -1 for fid column */
+ const char **key_column;
+ int *key_idx;
/* OGR */
- GDALDatasetH Ogr_ds;
-#else
- OGRDataSourceH Ogr_ds;
-#endif
+ ds_t Ogr_ds;
const char *ogr_driver_name;
int ogr_interleaved_reading;
OGRLayerH Ogr_layer;
@@ -136,13 +147,10 @@
OGRFieldType Ogr_ftype;
OGRFeatureH Ogr_feature;
OGRFeatureDefnH Ogr_featuredefn;
- OGRGeometryH Ogr_geometry, Ogr_oRing, *poSpatialFilter;
- OGRSpatialReferenceH Ogr_projection;
- OGREnvelope oExt;
- double *xminl, *yminl, *xmaxl, *ymaxl;
- int *have_ogr_extent;
+ OGRGeometryH Ogr_geometry, *poSpatialFilter;
const char *attr_filter;
struct OGR_iterator OGR_iter;
+ int proj_trouble;
int OFTIntegerListlength;
@@ -168,11 +176,10 @@
xmax = ymax = 0.0;
loc_proj_info = loc_proj_units = NULL;
Ogr_ds = NULL;
- Ogr_oRing = poSpatialFilter = NULL;
+ poSpatialFilter = NULL;
OFTIntegerListlength = 255; /* hack due to limitation in OGR */
area_size = 0.0;
use_tmp_vect = FALSE;
- key_column = GV_KEY_COLUMN;
G_gisinit(argv[0]);
@@ -488,14 +495,14 @@
/* driver name */
ogr_driver_name = GDALGetDriverShortName(GDALGetDatasetDriver(Ogr_ds));
- G_verbose_message(_("Using OGR driver '%s': %s"), ogr_driver_name,
+ G_verbose_message(_("Using OGR driver '%s/%s'"), ogr_driver_name,
GDALGetDriverLongName(GDALGetDatasetDriver(Ogr_ds)));
#else
ogr_driver_name = OGR_Dr_GetName(OGR_DS_GetDriver(Ogr_ds));
G_verbose_message(_("Using OGR driver '%s'"), ogr_driver_name);
#endif
- /* OSM interleaved reading */
+ /* OGR interleaved reading */
ogr_interleaved_reading = 0;
if (strcmp(ogr_driver_name, "OSM") == 0) {
@@ -512,14 +519,6 @@
if (ogr_interleaved_reading)
G_verbose_message(_("Using interleaved reading mode"));
- navailable_layers = GDALDatasetGetLayerCount(Ogr_ds);
-#else
- navailable_layers = OGR_DS_GetLayerCount(Ogr_ds);
-#endif
- OGR_iterator_init(&OGR_iter, &Ogr_ds, dsn, navailable_layers,
- ogr_interleaved_reading);
if (param.geom->answer) {
#if GDAL_VERSION_NUM >= 1110000
@@ -547,6 +546,15 @@
G_warning(_("Encoding value not supported by OGR driver <%s>"), ogr_driver_name);
+ navailable_layers = GDALDatasetGetLayerCount(Ogr_ds);
+#else
+ navailable_layers = OGR_DS_GetLayerCount(Ogr_ds);
+#endif
+ if (navailable_layers < 1)
+ G_fatal_error(_("No OGR layers available"));
/* make a list of available layers */
available_layer_names =
(char **)G_malloc(navailable_layers * sizeof(char *));
@@ -556,11 +564,7 @@
dsn, ogr_driver_name, navailable_layers);
for (i = 0; i < navailable_layers; i++) {
- Ogr_layer = GDALDatasetGetLayer(Ogr_ds, i);
-#else
- Ogr_layer = OGR_DS_GetLayer(Ogr_ds, i);
-#endif
+ Ogr_layer = ds_getlayerbyindex(Ogr_ds, i);
Ogr_featuredefn = OGR_L_GetLayerDefn(Ogr_layer);
available_layer_names[i] =
@@ -571,11 +575,7 @@
if (flag.list->answer) {
fflush(stdout);
- GDALClose(Ogr_ds);
-#else
- OGR_DS_Destroy(Ogr_ds);
-#endif
+ ds_close(Ogr_ds);
exit(EXIT_SUCCESS);
@@ -609,93 +609,25 @@
for (i = 0; i < nlayers; i++)
layers[i] = i;
- n_features = (GIntBig *)G_malloc(nlayers * sizeof(GIntBig));
- for (i = 0; i < nlayers; i++) {
- n_features[i] = 0;
- if (param.out->answer) {
- output = G_store(param.out->answer);
+ /* compare SRS of the different layers to be imported */
+ if (cmp_layer_srs(Ogr_ds, nlayers, layers, layer_names, param.geom->answer)) {
+ ds_close(Ogr_ds);
+ G_fatal_error(_("Detected different projections of input layers. "
+ "Input layers must be imported separately."));
- else {
- if (nlayers < 1)
- G_fatal_error(_("No OGR layers available"));
- output = G_store(layer_names[0]);
- if (param.layer->answer == NULL)
- G_warning(_("All available OGR layers will be imported into vector map <%s>"), output);
- if (!param.outloc->answer && !flag.proj->answer) { /* Check if the map exists */
- if (G_find_vector2(output, G_mapset()) && !overwrite)
- G_fatal_error(_("Vector map <%s> already exists"),
- output);
/* Get first imported layer to use for projection check */
- Ogr_layer = GDALDatasetGetLayer(Ogr_ds, layers[0]);
-#else
- Ogr_layer = OGR_DS_GetLayer(Ogr_ds, layers[0]);
-#endif
- /* projection check must come before extents check */
- /* Fetch input map projection in GRASS form. */
+ Ogr_layer = ds_getlayerbyindex(Ogr_ds, layers[0]);
+ /* Fetch input projection in GRASS form. */
proj_info = NULL;
proj_units = NULL;
-#if GDAL_VERSION_NUM >= 1110000
- if (param.geom->answer) {
- OGRGeomFieldDefnH Ogr_geomdefn;
- Ogr_featuredefn = OGR_L_GetLayerDefn(Ogr_layer);
- igeom = OGR_FD_GetGeomFieldIndex(Ogr_featuredefn, param.geom->answer);
- if (igeom < 0)
- G_fatal_error(_("Geometry column <%s> not found in OGR layer <%s>"),
- param.geom->answer, OGR_L_GetName(Ogr_layer));
- Ogr_geomdefn = OGR_FD_GetGeomFieldDefn(Ogr_featuredefn, igeom);
- Ogr_projection = OGR_GFld_GetSpatialRef(Ogr_geomdefn);
- else {
- Ogr_projection = OGR_L_GetSpatialRef(Ogr_layer);
-#else
- Ogr_projection = OGR_L_GetSpatialRef(Ogr_layer); /* should not be freed later */
-#endif
+ G_get_window(&cellhd);
- /* fetch boundaries */
- have_ogr_extent = (int *)G_malloc(nlayers * sizeof(int));
- xminl = (double *)G_malloc(nlayers * sizeof(double));
- xmaxl = (double *)G_malloc(nlayers * sizeof(double));
- yminl = (double *)G_malloc(nlayers * sizeof(double));
- ymaxl = (double *)G_malloc(nlayers * sizeof(double));
- for (layer = 0; layer < nlayers; layer++) {
+ proj_trouble = get_layer_proj(Ogr_layer, &cellhd, &proj_info, &proj_units,
+ param.geom->answer, 1);
- Ogr_layer = GDALDatasetGetLayer(Ogr_ds, layers[layer]);
-#else
- Ogr_layer = OGR_DS_GetLayer(Ogr_ds, layers[layer]);
-#endif
- have_ogr_extent[layer] = 0;
- if ((OGR_L_GetExtent(Ogr_layer, &oExt, 1)) == OGRERR_NONE) {
- xminl[layer] = oExt.MinX;
- xmaxl[layer] = oExt.MaxX;
- yminl[layer] = oExt.MinY;
- ymaxl[layer] = oExt.MaxY;
- /* use OGR extents if possible, needed to skip corrupted data
- * in OGR dsn/layer */
- have_ogr_extent[layer] = 1;
- /* OGR_L_GetExtent():
- * Note that some implementations of this method may alter
- * the read cursor of the layer. */
- GDALDatasetResetReading(Ogr_ds);
-#else
- OGR_L_ResetReading(Ogr_layer);
-#endif
- G_get_window(&cellhd);
cellhd.north = 1.;
cellhd.south = 0.;
cellhd.west = 0.;
@@ -717,8 +649,10 @@
if (param.outloc->answer != NULL) {
/* Convert projection information non-interactively as we can't
* assume the user has a terminal open */
- if (GPJ_osr_to_grass(&cellhd, &proj_info,
- &proj_units, Ogr_projection, 0) < 0) {
+ /* do not create a xy location because this can mean that the
+ * real SRS has not been recognized */
+ if (proj_trouble) {
G_fatal_error(_("Unable to convert input map projection to GRASS "
"format; cannot create new location."));
@@ -736,11 +670,7 @@
/* If the i flag is set, clean up and exit here */
if (flag.no_import->answer) {
-#else
-#endif
+ ds_close(Ogr_ds);
exit(EXIT_SUCCESS);
@@ -749,10 +679,21 @@
void (*msg_fn)(const char *, ...);
/* Projection only required for checking so convert non-interactively */
- G_warning(_("Unable to convert input map projection information to "
- "GRASS format for checking"));
+ strcpy(error_msg, _("Unable to convert input map projection information "
+ "to GRASS format."));
+ if (flag.over->answer) {
+ msg_fn = G_warning;
+ else {
+ msg_fn = G_fatal_error;
+ ds_close(Ogr_ds);
+ msg_fn(error_msg);
+ if (!flag.over->answer) {
+ exit(EXIT_FAILURE);
/* Does the projection of the current location match the dataset? */
/* G_get_window seems to be unreliable if the location has been changed */
@@ -773,7 +714,7 @@
G_compare_projections(loc_proj_info, loc_proj_units,
proj_info, proj_units)) != TRUE) {
int i_value;
strcpy(error_msg,
_("Projection of dataset does not"
" appear to match current location.\n\n"));
@@ -845,8 +786,10 @@
" from input data set.\n"));
if (flag.proj->answer)
msg_fn = G_message;
- else
+ else {
+ ds_close(Ogr_ds);
msg_fn(error_msg);
exit(EXIT_FAILURE);
@@ -858,144 +801,77 @@
msg_fn = G_verbose_message;
msg_fn(_("Projection of input dataset and current location "
"appear to match"));
- if (flag.proj->answer)
+ if (flag.proj->answer) {
+ ds_close(Ogr_ds);
exit(EXIT_SUCCESS);
- G_begin_polygon_area_calculations(); /* Used in geom() and centroid() */
+ /* get output name */
+ if (param.out->answer) {
+ output = G_store(param.out->answer);
+ else {
+ output = G_store(layer_names[0]);
- /* set spatial filter */
- if (flag.region->answer && param.spat->answer)
- G_fatal_error(_("Select either the current region flag or the spatial option, not both"));
- if (!param.outloc->answer && flag.region->answer) {
- G_get_window(&cur_wind);
- xmin = cur_wind.west;
- xmax = cur_wind.east;
- ymin = cur_wind.south;
- ymax = cur_wind.north;
+ /* check output name */
+ if (Vect_legal_filename(output) != 1) {
+ ds_close(Ogr_ds);
+ G_fatal_error(_("Illegal output name <%s>"), output);
- if (param.spat->answer) {
- /* See as reference: gdal/ogr/ogr_capi_test.c */
- /* cut out a piece of the map */
- /* order: xmin,ymin,xmax,ymax */
- i = 0;
- while (param.spat->answers[i]) {
- if (i == 0)
- xmin = atof(param.spat->answers[i]);
- if (i == 1)
- ymin = atof(param.spat->answers[i]);
- if (i == 2)
- xmax = atof(param.spat->answers[i]);
- if (i == 3)
- ymax = atof(param.spat->answers[i]);
- i++;
- if (i != 4)
- G_fatal_error(_("4 parameters required for 'spatial' parameter"));
- if (xmin > xmax)
- G_fatal_error(_("xmin is larger than xmax in 'spatial' parameters"));
- if (ymin > ymax)
- G_fatal_error(_("ymin is larger than ymax in 'spatial' parameters"));
+ /* Check if the output map exists */
+ if (G_find_vector2(output, G_mapset()) && !overwrite) {
+ ds_close(Ogr_ds);
+ G_fatal_error(_("Vector map <%s> already exists"),
+ output);
- if ((!param.outloc->answer && flag.region->answer) ||
- param.spat->answer) {
- G_debug(2, "cut out with boundaries: xmin:%f ymin:%f xmax:%f ymax:%f",
- xmin, ymin, xmax, ymax);
- /* spatial filter, set by ogr_getnextfeature */
- poSpatialFilter = G_malloc(nlayers * sizeof(OGRGeometryH));
- int have_filter = 0;
+ /* report back if several layers will be imported because
+ * none has been selected */
+ if (nlayers > 1 && param.layer->answer == NULL) {
+ void (*msg_fn)(const char *, ...);
-#else
-#endif
+ /* make it a warning if output name has not been specified */
+ msg_fn = G_important_message;
+ else
- if (have_ogr_extent[layer]) {
- if (xmin <= xmax && ymin <= ymax) {
- /* check for any overlap */
- if (xminl[layer] > xmax || xmaxl[layer] < xmin ||
- yminl[layer] > ymax || ymaxl[layer] < ymin) {
- G_warning(_("The spatial filter does not overlap with OGR layer <%s>. Nothing to import."),
- layer_names[layer]);
+ msg_fn(_("All available OGR layers will be imported into vector map <%s>"),
+ output);
- xminl[layer] = xmin;
- xmaxl[layer] = xmax;
- yminl[layer] = ymin;
- ymaxl[layer] = ymax;
- else {
- /* shrink with user options */
- xminl[layer] = MAX(xminl[layer], xmin);
- xmaxl[layer] = MIN(xmaxl[layer], xmax);
- yminl[layer] = MAX(yminl[layer], ymin);
- ymaxl[layer] = MIN(ymaxl[layer], ymax);
- have_filter = 1;
- else if (xmin <= xmax && ymin <= ymax) {
+ /* attribute filter */
+ attr_filter = param.where->answer;
- have_filter = 1;
+ /* create spatial filters */
+ if (param.outloc->answer && flag.region->answer) {
+ G_warning(_("When creating a new location, the current region "
+ "can not be used as spatial filter, disabling"));
+ flag.region->answer = 0;
+ if (flag.region->answer && param.spat->answer)
+ G_fatal_error(_("Select either the current region flag or the spatial option, not both"));
- if (have_filter) {
- /* some invalid features can be filtered out by using
- * the layer's extents as spatial filter
- * hopefully these filtered features are all invalid */
- /* TODO/BUG:
- * for OSM, a spatial filter applied on the 'points' layer
- * will also affect other layers */
+ poSpatialFilter = G_malloc(nlayers * sizeof(OGRGeometryH));
+ if (create_spatial_filter(Ogr_ds, poSpatialFilter,
+ nlayers, layers, layer_names,
+ &xmin, &ymin, &xmax, &ymax,
+ flag.region->answer, param.spat)
+ || attr_filter) {
- /* in theory this could be an irregular polygon */
- G_debug(2, "spatial filter for layer <%s>: xmin:%f ymin:%f xmax:%f ymax:%f",
- layer_names[layer],
- xminl[layer], yminl[layer],
- xmaxl[layer], ymaxl[layer]);
- poSpatialFilter[layer] = OGR_G_CreateGeometry(wkbPolygon);
- Ogr_oRing = OGR_G_CreateGeometry(wkbLinearRing);
- OGR_G_AddPoint_2D(Ogr_oRing, xminl[layer], yminl[layer]);
- OGR_G_AddPoint_2D(Ogr_oRing, xminl[layer], ymaxl[layer]);
- OGR_G_AddPoint_2D(Ogr_oRing, xmaxl[layer], ymaxl[layer]);
- OGR_G_AddPoint_2D(Ogr_oRing, xmaxl[layer], yminl[layer]);
- OGR_G_AddGeometryDirectly(poSpatialFilter[layer], Ogr_oRing);
+ for (layer = 0; layer < nlayers; layer++) {
+ Ogr_layer = ds_getlayerbyindex(Ogr_ds, layers[layer]);
+ OGR_L_SetSpatialFilter(Ogr_layer, poSpatialFilter[layer]);
+ if (OGR_L_SetAttributeFilter(Ogr_layer, attr_filter) != OGRERR_NONE)
+ G_fatal_error(_("Error setting attribute filter '%s'"),
+ attr_filter);
- else
- poSpatialFilter[layer] = NULL;
- /* update xmin, xmax, ymin, ymax if possible */
- if (xmin > xmax) {
- xmin = xminl[layer];
- xmax = xmaxl[layer];
- ymin = yminl[layer];
- ymax = ymaxl[layer];
- else {
- /* expand */
- xmin = MIN(xminl[layer], xmin);
- xmax = MAX(xmaxl[layer], xmax);
- ymin = MIN(yminl[layer], ymin);
- ymax = MAX(ymaxl[layer], ymax);
- /* attribute filter, set by ogr_getnextfeature */
- attr_filter = param.where->answer;
/* suppress boundary splitting ? */
if (flag.no_clean->answer || xmin >= xmax || ymin >= ymax) {
split_distance = -1.;
@@ -1009,22 +885,22 @@
db_init_string(&sql);
db_init_string(&strval);
+ n_features = (GIntBig *)G_malloc(nlayers * sizeof(GIntBig));
+ OGR_iterator_init(&OGR_iter, &Ogr_ds, dsn, navailable_layers,
+ ogr_interleaved_reading);
+ /* check if input id 3D and if we need a tmp vector */
+ /* estimate distance for boundary splitting --> */
n_polygon_boundaries = 0;
input3d = 0;
- /* check if input id 3D and if we need a tmp vector */
- /* estimate distance for boundary splitting --> */
- OGR_iterator_reset(&OGR_iter);
GIntBig ogr_feature_count;
+ n_features[layer] = 0;
layer_id = layers[layer];
- Ogr_layer = GDALDatasetGetLayer(Ogr_ds, layer_id);
-#else
- Ogr_layer = OGR_DS_GetLayer(Ogr_ds, layer_id);
-#endif
+ Ogr_layer = ds_getlayerbyindex(Ogr_ds, layer_id);
igeom = -1;
@@ -1141,58 +1017,63 @@
ncentr = n_overlaps = n_polygons = 0;
+ G_begin_polygon_area_calculations(); /* Used in geom() and centroid() */
/* Points and lines are written immediately with categories. Boundaries of polygons are
* written to the vector then cleaned and centroids are calculated for all areas in clean vector.
* Then second pass through finds all centroids in each polygon feature and adds its category
- * to the centroid. The result is that one centroids may have 0, 1 ore more categories
+ * to the centroid. The result is that one centroid may have 0, 1 ore more categories
* of one ore more (more input layers) fields. */
+ /* get input column to use for categoy values, create tables */
+ key_column = G_malloc(nlayers * sizeof(char *));
+ key_idx = G_malloc(nlayers * sizeof(int));
+ key_column[layer] = GV_KEY_COLUMN;
+ key_idx[layer] = -2; /* -1 for fid column */
-#else
-#endif
- igeom = -1;
-#endif
if (param.key->answer) {
+ /* use existing column for category values */
const char *fid_column;
fid_column = OGR_L_GetFIDColumn(Ogr_layer);
if (fid_column) {
- key_column = G_store(fid_column);
- key_idx = -1;
+ key_column[layer] = G_store(fid_column);
+ key_idx[layer] = -1;
if (!fid_column || strcmp(fid_column, param.key->answer) != 0) {
- key_idx = OGR_FD_GetFieldIndex(Ogr_featuredefn, param.key->answer);
- if (key_idx == -1)
- G_fatal_error(_("Key column '%s' not found"), param.key->answer);
+ key_idx[layer] = OGR_FD_GetFieldIndex(Ogr_featuredefn, param.key->answer);
+ if (key_idx[layer] == -1)
+ G_fatal_error(_("Key column '%s' not found in input layer <%s>"),
+ param.key->answer, layer_names[layer]);
- if (key_idx > -1) {
+ if (key_idx[layer] > -1) {
/* check if the field is integer */
- Ogr_field = OGR_FD_GetFieldDefn(Ogr_featuredefn, key_idx);
+ Ogr_field = OGR_FD_GetFieldDefn(Ogr_featuredefn, key_idx[layer]);
Ogr_ftype = OGR_Fld_GetType(Ogr_field);
if (!(Ogr_ftype == OFTInteger
#if GDAL_VERSION_NUM >= 2000000
|| Ogr_ftype == OFTInteger64
#endif
- G_fatal_error(_("Key column '%s' is not integer"), param.key->answer);
+ G_fatal_error(_("Key column '%s' in input layer <%s> is not integer"),
- key_column = G_store(OGR_Fld_GetNameRef(Ogr_field));
+ key_column[layer] = G_store(OGR_Fld_GetNameRef(Ogr_field));
- /* Add DB link */
+ /* Add DB link and create table */
if (!flag.notab->answer) {
+ G_important_message(_("Creating attribute table for layer <%s>..."),
+ layer_names[layer]);
if (nlayers == 1) { /* one layer only */
Fi = Vect_default_field_info(&Map, layer + 1, NULL,
GV_1TABLE);
@@ -1203,21 +1084,21 @@
if (ncnames > 0) {
- key_column = param.cnames->answers[0];
+ key_column[layer] = param.cnames->answers[0];
Vect_map_add_dblink(&Map, layer + 1, layer_names[layer], Fi->table,
- key_column, Fi->database, Fi->driver);
+ key_column[layer], Fi->database, Fi->driver);
ncols = OGR_FD_GetFieldCount(Ogr_featuredefn);
G_debug(2, "%d columns", ncols);
/* Create table */
sprintf(buf, "create table %s (%s integer", Fi->table,
- key_column);
+ key_column[layer]);
db_set_string(&sql, buf);
for (i = 0; i < ncols; i++) {
- if (key_idx > -1 && key_idx == i)
+ if (key_idx[layer] > -1 && key_idx[layer] == i)
continue; /* skip defined key (FID column) */
Ogr_field = OGR_FD_GetFieldDefn(Ogr_featuredefn, i);
@@ -1364,9 +1245,14 @@
G_fatal_error(_("Unable to grant privileges on table <%s>"),
Fi->table);
- db_begin_transaction(driver);
+ db_close_database_shutdown_driver(driver);
+ /* import features */
+ OGR_iterator_reset(&OGR_iter);
+ layer_id = layers[layer];
/* Import features */
cat = 1;
nogeom = 0;
@@ -1375,6 +1261,32 @@
G_important_message(_("Importing %lld features (OGR layer <%s>)..."),
n_features[layer], layer_names[layer]);
+ driver = NULL;
+ if (!flag.notab->answer) {
+ /* one transaction per layer/table
+ * or better one transaction for all layers/tables together ?
+ Fi = Vect_get_field(&Map, layer + 1);
+ driver =
+ db_start_driver_open_database(Fi->driver,
+ Vect_subst_var(Fi->database,
+ &Map));
+ if (driver == NULL) {
+ G_fatal_error(_("Unable to open database <%s> by driver <%s>"),
+ Vect_subst_var(Fi->database, &Map), Fi->driver);
+ db_begin_transaction(driver);
+ Ogr_featuredefn = OGR_L_GetLayerDefn(Ogr_layer);
+ igeom = -1;
+#if GDAL_VERSION_NUM >= 1110000
+ if (param.geom->answer)
+ igeom = OGR_FD_GetGeomFieldIndex(Ogr_featuredefn, param.geom->answer);
+#endif
while ((Ogr_feature = ogr_getnextfeature(&OGR_iter, layer_id,
layer_names[layer],
@@ -1382,8 +1294,8 @@
G_percent(feature_count++, n_features[layer], 1); /* show something happens */
/* Geometry */
+ Ogr_featuredefn = OGR_iter.Ogr_featuredefn;
- Ogr_featuredefn = OGR_iter.Ogr_featuredefn;
for (i = 0; i < OGR_FD_GetGeomFieldCount(Ogr_featuredefn); i++) {
if (igeom > -1 && i != igeom)
continue; /* use only geometry defined via param.geom */
@@ -1395,7 +1307,7 @@
if (Ogr_geometry != NULL) {
if (OGR_G_HasCurveGeometry(Ogr_geometry, 1)) {
- G_debug(1, "Approximating curves in a '%s'",
+ G_debug(2, "Approximating curves in a '%s'",
OGR_G_GetGeometryName(Ogr_geometry));
Ogr_geometry = OGR_G_GetLinearGeometry(Ogr_geometry, 0, NULL);
@@ -1405,9 +1317,9 @@
nogeom++;
else {
- if (key_idx > -1)
- cat = OGR_F_GetFieldAsInteger(Ogr_feature, key_idx);
- else if (key_idx == -1)
+ cat = OGR_F_GetFieldAsInteger(Ogr_feature, key_idx[layer]);
+ else if (key_idx[layer] == -1)
cat = OGR_F_GetFID(Ogr_feature);
geom(Ogr_geometry, Out, layer + 1, cat, min_area, type,
@@ -1420,13 +1332,14 @@
#endif
/* Attributes */
+ ncols = OGR_FD_GetFieldCount(Ogr_featuredefn);
sprintf(buf, "insert into %s values ( %d", Fi->table, cat);
const char *Ogr_fstring = NULL;
@@ -1508,8 +1421,8 @@
if (db_execute_immediate(driver, &sql) != DB_OK) {
db_close_database(driver);
db_shutdown_driver(driver);
- G_fatal_error(_("Cannot insert new row: %s"),
- db_get_string(&sql));
+ G_fatal_error(_("Cannot insert new row for input layer <%s>: %s"),
+ layer_names[layer], db_get_string(&sql));
@@ -1524,10 +1437,40 @@
if (nogeom > 0)
- G_warning(_("%d %s without geometry skipped"), nogeom,
- nogeom == 1 ? "feature" : "features");
+ G_warning(_("%d %s without geometry in input layer <%s> skipped"),
+ nogeom, nogeom == 1 ? _("feature") : _("features"),
+ delete_table = Vect_maptype(&Map) != GV_FORMAT_NATIVE;
+ /* create index - must fail on non-unique categories */
+ driver =
+ &Map));
+ if (!delete_table) {
+ if (db_create_index2(driver, Fi->table, Fi->key) != DB_OK)
+ G_fatal_error(_("Unable to create index for table <%s>, key <%s>"),
+ Fi->table, Fi->key);
+ else {
+ sprintf(buf, "drop table %s", Fi->table);
+ db_set_string(&sql, buf);
+ if (db_execute_immediate(driver, &sql) != DB_OK) {
+ G_fatal_error(_("Unable to drop table: '%s'"),
+ db_get_string(&sql));
+ /* attribute tables are now done */
separator = "-----------------------------------------------------";
G_message("%s", separator);
@@ -1537,6 +1480,8 @@
Vect_build_partial(&Tmp, GV_BUILD_BASE);
+ /* make this a separate function ?
+ * no, too many arguments */
if (use_tmp_vect && !flag.no_clean->answer &&
Vect_get_num_primitives(Out, GV_BOUNDARY) > 0) {
int ret, centr, otype, n_nocat;
@@ -1550,6 +1495,8 @@
+ /* the principal purpose is to convert non-topological polygons to
+ * topological areas */
G_message(_("Cleaning polygons"));
if (snap >= 0) {
@@ -1560,7 +1507,9 @@
/* It is not to clean to snap centroids, but I have seen data with 2 duplicate polygons
* (as far as decimal places were printed) and centroids were not identical */
- /* Disabled, because overlapping polygons result in many duplicate centroids anyway */
+ /* Disabled, because the mechanism has changed:
+ * at this stage, there are no centroids yet, centroids are caluclated
+ * later for output areas, not fo input polygons */
fprintf ( stderr, separator );
fprintf ( stderr, "Snap centroids (threshold 0.000001):\n" );
@@ -1663,61 +1612,57 @@
G_message(_("Finding centroids for OGR layer <%s>..."), layer_names[layer]);
-#else
-#endif
- igeom = -1;
+ igeom = -1;
#endif
cat = 0; /* field = layer + 1 */
attr_filter)) != NULL) {
G_percent(cat, n_features[layer], 2);
- /* Category */
- if (key_idx > -1)
- else
- cat++;
+ /* Category */
+ else
+ cat++;
/* Geometry */
- for (i = 0; i < OGR_FD_GetGeomFieldCount(Ogr_featuredefn); i++) {
- if (igeom > -1 && i != igeom)
- continue; /* use only geometry defined via param.geom */
- Ogr_geometry = OGR_F_GetGeomFieldRef(Ogr_feature, i);
+ for (i = 0; i < OGR_FD_GetGeomFieldCount(Ogr_featuredefn); i++) {
+ if (igeom > -1 && i != igeom)
+ continue; /* use only geometry defined via param.geom */
+ Ogr_geometry = OGR_F_GetGeomFieldRef(Ogr_feature, i);
#else
- Ogr_geometry = OGR_F_GetGeometryRef(Ogr_feature);
+ Ogr_geometry = OGR_F_GetGeometryRef(Ogr_feature);
#endif
- if (Ogr_geometry != NULL) {
+ if (Ogr_geometry != NULL) {
#endif
- centroid(Ogr_geometry, Centr, &si, layer + 1, cat,
- min_area, type);
+ centroid(Ogr_geometry, Centr, &si, layer + 1, cat,
+ min_area, type);
OGR_G_DestroyGeometry(Ogr_geometry);
#endif
#endif
OGR_F_Destroy(Ogr_feature);
- G_percent(1, 1, 1);
+ G_percent(1, 1, 1);
/* Write centroids */
@@ -1801,11 +1746,7 @@
-#else
-#endif
+ ds_close(Ogr_ds);
if (use_tmp_vect) {
/* Copy temporary vector to output vector */
@@ -1816,8 +1757,11 @@
Vect_build(&Map);
- if (0 && flag.no_clean->answer)
+#if 0
+ /* disabled, Vect_topo_check() is quite slow */
+ if (flag.no_clean->answer)
Vect_topo_check(&Map, NULL);
+#endif
if (n_polygons && nlayers == 1) {
/* test for topological errors */
@@ -1910,34 +1854,6 @@
- delete_table = Vect_maptype(&Map) != GV_FORMAT_NATIVE;
- /* create index - may fail on non-unique categories */
- if (!flag.notab->answer) {
- Fi = Vect_get_field(&Map, layer + 1);
- driver =
- db_start_driver_open_database(Fi->driver,
- Vect_subst_var(Fi->database,
- &Map));
- if (!delete_table) {
- if (db_create_index2(driver, Fi->table, Fi->key) != DB_OK)
- G_warning(_("Unable to create index for table <%s>, key <%s>"),
- Fi->table, Fi->key);
- else {
- sprintf(buf, "drop table %s", Fi->table);
- db_set_string(&sql, buf);
- if (db_execute_immediate(driver, &sql) != DB_OK) {
- G_fatal_error(_("Unable to drop table: '%s'"),
- db_close_database_shutdown_driver(driver);
Vect_get_map_box(&Map, &box);
if (0 != Vect_close(&Map))
G_fatal_error(_("Import failed"));
@@ -1981,12 +1897,7 @@
exit(EXIT_SUCCESS);
-void OGR_iterator_init(struct OGR_iterator *OGR_iter,
-#else
-#endif
+void OGR_iterator_init(struct OGR_iterator *OGR_iter, ds_t *Ogr_ds,
@@ -2029,40 +1940,26 @@
const char *attr_filter)
if (OGR_iter->requested_layer != layer) {
- int i;
- /* clear filters */
- for (i = 0; i < OGR_iter->nlayers; i++) {
- OGR_iter->Ogr_layer = GDALDatasetGetLayer(*(OGR_iter->Ogr_ds), i);
-#else
- OGR_iter->Ogr_layer = OGR_DS_GetLayer(*(OGR_iter->Ogr_ds), i);
-#endif
- OGR_L_SetSpatialFilter(OGR_iter->Ogr_layer, NULL);
- OGR_L_SetAttributeFilter(OGR_iter->Ogr_layer, NULL);
/* reset OGR reading */
if (!OGR_iter->ogr_interleaved_reading) {
OGR_iter->curr_layer = layer;
- OGR_iter->Ogr_layer = GDALDatasetGetLayer(*(OGR_iter->Ogr_ds), OGR_iter->curr_layer);
-#else
- OGR_iter->Ogr_layer = OGR_DS_GetLayer(*(OGR_iter->Ogr_ds), OGR_iter->curr_layer);
-#endif
+ OGR_iter->Ogr_layer = ds_getlayerbyindex(*(OGR_iter->Ogr_ds), OGR_iter->curr_layer);
OGR_iter->Ogr_featuredefn = OGR_L_GetLayerDefn(OGR_iter->Ogr_layer);
OGR_L_ResetReading(OGR_iter->Ogr_layer);
- OGR_L_SetSpatialFilter(OGR_iter->Ogr_layer, poSpatialFilter);
- OGR_L_SetAttributeFilter(OGR_iter->Ogr_layer, attr_filter);
else {
+ int i;
+ /* clear filters */
+ for (i = 0; i < OGR_iter->nlayers; i++) {
+ OGR_iter->Ogr_layer = ds_getlayerbyindex(*(OGR_iter->Ogr_ds), i);
+ OGR_L_SetSpatialFilter(OGR_iter->Ogr_layer, NULL);
+ OGR_L_SetAttributeFilter(OGR_iter->Ogr_layer, NULL);
GDALDatasetResetReading(*(OGR_iter->Ogr_ds));
- OGR_iter->curr_layer = 0;
- OGR_iter->Ogr_layer = GDALDatasetGetLayer(*(OGR_iter->Ogr_ds), layer);
- OGR_iter->Ogr_featuredefn = OGR_L_GetLayerDefn(OGR_iter->Ogr_layer);
#else
/* need to re-open OGR DSN in order to start reading from the beginning
* NOTE: any constraints are lost */
@@ -2071,13 +1968,18 @@
if (*(OGR_iter->Ogr_ds) == NULL)
G_fatal_error(_("Unable to re-open data source <%s>"), OGR_iter->dsn);
OGR_iter->Ogr_layer = OGR_DS_GetLayer(*(OGR_iter->Ogr_ds), layer);
OGR_iter->has_nonempty_layers = 0;
#endif
+ OGR_iter->Ogr_layer = ds_getlayerbyindex(*(OGR_iter->Ogr_ds), layer);
+ OGR_iter->Ogr_featuredefn = OGR_L_GetLayerDefn(OGR_iter->Ogr_layer);
+ OGR_L_SetSpatialFilter(OGR_iter->Ogr_layer, poSpatialFilter);
+ if (OGR_L_SetAttributeFilter(OGR_iter->Ogr_layer, attr_filter) != OGRERR_NONE)
+ attr_filter);
+#if GDAL_VERSION_NUM < 2020000
+ OGR_iter->Ogr_layer = OGR_DS_GetLayer(*(OGR_iter->Ogr_ds), OGR_iter->curr_layer);
+#endif
OGR_iter->requested_layer = layer;
OGR_iter->done = 0;
@@ -2159,3 +2061,386 @@
return NULL;
+/* get projection info of OGR layer in GRASS format
+ * return 0 on success (some non-xy SRS)
+ * return 1 if no SRS available
+ * return 2 if SRS available but unreadable */
+int get_layer_proj(OGRLayerH Ogr_layer, struct Cell_head *cellhd,
+ struct Key_Value **proj_info, struct Key_Value **proj_units,
+ char *geom_col, int verbose)
+ OGRSpatialReferenceH Ogr_projection;
+ Ogr_projection = NULL;
+ *proj_info = NULL;
+ *proj_units = NULL;
+ G_get_window(cellhd);
+ /* Fetch input layer projection in GRASS form. */
+ if (geom_col) {
+ int igeom;
+ OGRGeomFieldDefnH Ogr_geomdefn;
+ OGRFeatureDefnH Ogr_featuredefn;
+ igeom = OGR_FD_GetGeomFieldIndex(Ogr_featuredefn, geom_col);
+ if (igeom < 0)
+ G_fatal_error(_("Geometry column <%s> not found in input layer <%s>"),
+ geom_col, OGR_L_GetName(Ogr_layer));
+ Ogr_geomdefn = OGR_FD_GetGeomFieldDefn(Ogr_featuredefn, igeom);
+ Ogr_projection = OGR_GFld_GetSpatialRef(Ogr_geomdefn);
+ else {
+ Ogr_projection = OGR_L_GetSpatialRef(Ogr_layer);
+#else
+ Ogr_projection = OGR_L_GetSpatialRef(Ogr_layer); /* should not be freed later */
+#endif
+ /* verbose is used only when comparing input SRS to GRASS projection,
+ * not when comparing SRS's of several input layers */
+ if (GPJ_osr_to_grass(cellhd, proj_info,
+ proj_units, Ogr_projection, 0) < 0) {
+ /* TODO: GPJ_osr_to_grass() does not return anything < 0
+ * check with GRASS 6 and GRASS 5 */
+ G_warning(_("Unable to convert input layer projection information to "
+ "GRASS format for checking"));
+ if (verbose && Ogr_projection != NULL) {
+ char *wkt = NULL;
+ if (OSRExportToPrettyWkt(Ogr_projection, &wkt, FALSE) != OGRERR_NONE) {
+ G_warning(_("Can't get WKT-style parameter string"));
+ else if (wkt) {
+ G_important_message(_("WKT-style definition:\n%s"), wkt);
+ return 2;
+ /* custom checks because if in doubt GPJ_osr_to_grass() returns a
+ * xy CRS */
+ if (Ogr_projection == NULL) {
+ if (verbose) {
+ G_important_message(_("No OGR projection available for layer <%s>"),
+ OGR_L_GetName(Ogr_layer));
+ return 1;
+ if (!OSRIsProjected(Ogr_projection) && !OSRIsGeographic(Ogr_projection)) {
+ G_important_message(_("OGR projection for layer <%s> does not contain a valid SRS"),
+ if (verbose) {
+ char *wkt = NULL;
+ G_important_message(_("Can't get WKT-style parameter string"));
+ else if (wkt) {
+ return 2;
+ char *pszProj4 = NULL;
+ if (OSRExportToProj4(Ogr_projection, &pszProj4) != OGRERR_NONE) {
+ G_important_message(_("OGR projection for layer <%s> can not be converted to proj4"),
+ if (verbose) {
+ char *wkt = NULL;
+ else if (wkt) {
+ return 2;
+ return 0;
+/* compare projections of all OGR layers
+ * return 0 if all layers have the same projection
+ * return 1 if layer projections differ */
+int cmp_layer_srs(ds_t Ogr_ds, int nlayers, int *layers,
+ char **layer_names, char *geom_col)
+ int layer;
+ struct Key_Value *proj_info1, *proj_units1;
+ struct Key_Value *proj_info2, *proj_units2;
+ struct Cell_head cellhd1, cellhd2;
+ OGRLayerH Ogr_layer;
+ if (nlayers == 1)
+ return 0;
+ proj_info1 = proj_units1 = NULL;
+ proj_info2 = proj_units2 = NULL;
+ layer = 0;
+ do {
+ /* Get first SRS */
+ if (get_layer_proj(Ogr_layer, &cellhd1, &proj_info1, &proj_units1,
+ geom_col, 0) == 0) {
+ break;
+ layer++;
+ } while (layer < nlayers);
+ if (layer == nlayers) {
+ /* could not get layer proj in GRASS format for any of the layers
+ * -> projections of all layers are the same, i.e. unreadable by GRASS */
+ G_warning(_("Layer projections are unreadable"));
+ if (proj_info1)
+ G_free_key_value(proj_info1);
+ if (proj_units1)
+ G_free_key_value(proj_units1);
+ return 0;
+ if (layer > 0) {
+ /* could not get layer proj in GRASS format for at least one of the layers
+ * -> mix of unreadable and readable projections */
+ G_warning(_("Projection for layer <%s> is unreadable"),
+ if (proj_info1)
+ if (proj_units1)
+ return 1;
+ for (layer = 1; layer < nlayers; layer++) {
+ /* Get SRS of other layer(s) */
+ if (get_layer_proj(Ogr_layer, &cellhd2, &proj_info2, &proj_units2,
+ geom_col, 0) != 0) {
+ return 1;
+ if (cellhd1.proj != cellhd2.proj
+ || G_compare_projections(proj_info1, proj_units1,
+ proj_info2, proj_units2) != TRUE) {
+ if (proj_info1)
+ if (proj_units1)
+ if (proj_info2)
+ G_free_key_value(proj_info2);
+ if (proj_units2)
+ G_free_key_value(proj_units2);
+ G_warning(_("Projection of layer <%s> is different from "
+ "projection of layer <%s>"),
+ layer_names[layer], layer_names[layer - 1]);
+ return 1;
+ if (proj_info2)
+ if (proj_units2)
+ if (proj_info1)
+ if (proj_units1)
+ return 0;
+int create_spatial_filter(ds_t Ogr_ds, OGRGeometryH *poSpatialFilter,
+ int nlayers, int *layers, char **layer_names,
+ double *xmin, double *ymin,
+ double *xmax, double *ymax,
+ int use_region, struct Option *spat)
+ int layer;
+ int have_spatial_filter;
+ int *have_ogr_extent;
+ double *xminl, *yminl, *xmaxl, *ymaxl;
+ OGREnvelope oExt;
+ OGRGeometryH Ogr_oRing;
+ struct Cell_head cur_wind;
+ /* fetch extents */
+ have_ogr_extent = (int *)G_malloc(nlayers * sizeof(int));
+ xminl = (double *)G_malloc(nlayers * sizeof(double));
+ xmaxl = (double *)G_malloc(nlayers * sizeof(double));
+ yminl = (double *)G_malloc(nlayers * sizeof(double));
+ ymaxl = (double *)G_malloc(nlayers * sizeof(double));
+ have_ogr_extent[layer] = 0;
+ if ((OGR_L_GetExtent(Ogr_layer, &oExt, 1)) == OGRERR_NONE) {
+ xminl[layer] = oExt.MinX;
+ xmaxl[layer] = oExt.MaxX;
+ yminl[layer] = oExt.MinY;
+ ymaxl[layer] = oExt.MaxY;
+ /* use OGR extents if possible, needed to skip corrupted data
+ * in OGR dsn/layer */
+ have_ogr_extent[layer] = 1;
+ /* OGR_L_GetExtent():
+ * Note that some implementations of this method may alter
+ * the read cursor of the layer. */
+ GDALDatasetResetReading(Ogr_ds);
+#else
+ OGR_L_ResetReading(Ogr_layer);
+#endif
+ /* set spatial filter */
+ if (use_region && spat->answer)
+ if (use_region) {
+ G_get_window(&cur_wind);
+ *xmin = cur_wind.west;
+ *xmax = cur_wind.east;
+ *ymin = cur_wind.south;
+ *ymax = cur_wind.north;
+ if (spat->answer) {
+ int i;
+ /* See as reference: gdal/ogr/ogr_capi_test.c */
+ /* cut out a piece of the map */
+ /* order: xmin,ymin,xmax,ymax */
+ i = 0;
+ while (spat->answers[i]) {
+ if (i == 0)
+ *xmin = atof(spat->answers[i]);
+ if (i == 1)
+ *ymin = atof(spat->answers[i]);
+ if (i == 2)
+ *xmax = atof(spat->answers[i]);
+ if (i == 3)
+ *ymax = atof(spat->answers[i]);
+ i++;
+ if (i != 4)
+ G_fatal_error(_("4 parameters required for 'spatial' parameter"));
+ if (*xmin > *xmax)
+ G_fatal_error(_("xmin is larger than xmax in 'spatial' parameters"));
+ if (*ymin > *ymax)
+ G_fatal_error(_("ymin is larger than ymax in 'spatial' parameters"));
+ if (use_region || spat->answer) {
+ G_debug(2, "cut out with boundaries: xmin:%f ymin:%f xmax:%f ymax:%f",
+ *xmin, *ymin, *xmax, *ymax);
+ /* create spatial filter for each layer */
+ have_spatial_filter = 0;
+ int have_filter = 0;
+ if (have_ogr_extent[layer]) {
+ if (*xmin <= *xmax && *ymin <= *ymax) {
+ /* check for any overlap */
+ if (xminl[layer] > *xmax || xmaxl[layer] < *xmin ||
+ yminl[layer] > *ymax || ymaxl[layer] < *ymin) {
+ G_warning(_("The spatial filter does not overlap with OGR layer <%s>. Nothing to import."),
+ xminl[layer] = *xmin;
+ xmaxl[layer] = *xmax;
+ yminl[layer] = *ymin;
+ ymaxl[layer] = *ymax;
+ else {
+ /* shrink with user options */
+ xminl[layer] = MAX(xminl[layer], *xmin);
+ xmaxl[layer] = MIN(xmaxl[layer], *xmax);
+ yminl[layer] = MAX(yminl[layer], *ymin);
+ ymaxl[layer] = MIN(ymaxl[layer], *ymax);
+ have_filter = 1;
+ else if (*xmin <= *xmax && *ymin <= *ymax) {
+ have_filter = 1;
+ if (have_filter) {
+ /* some invalid features can be filtered out by using
+ * the layer's extents as spatial filter
+ * hopefully these filtered features are all invalid */
+ /* TODO/BUG:
+ * for OSM, a spatial filter applied on the 'points' layer
+ * will also affect other layers */
+ /* in theory this could be an irregular polygon */
+ G_debug(2, "spatial filter for layer <%s>: xmin:%f ymin:%f xmax:%f ymax:%f",
+ xminl[layer], yminl[layer],
+ xmaxl[layer], ymaxl[layer]);
+ poSpatialFilter[layer] = OGR_G_CreateGeometry(wkbPolygon);
+ Ogr_oRing = OGR_G_CreateGeometry(wkbLinearRing);
+ OGR_G_AddPoint_2D(Ogr_oRing, xminl[layer], yminl[layer]);
+ OGR_G_AddPoint_2D(Ogr_oRing, xminl[layer], ymaxl[layer]);
+ OGR_G_AddPoint_2D(Ogr_oRing, xmaxl[layer], ymaxl[layer]);
+ OGR_G_AddPoint_2D(Ogr_oRing, xmaxl[layer], yminl[layer]);
+ OGR_G_AddGeometryDirectly(poSpatialFilter[layer], Ogr_oRing);
+ have_spatial_filter = 1;
+ else
+ poSpatialFilter[layer] = NULL;
+ /* update xmin, xmax, ymin, ymax if possible */
+ if (xmin > xmax) {
+ *xmin = xminl[layer];
+ *xmax = xmaxl[layer];
+ *ymin = yminl[layer];
+ *ymax = ymaxl[layer];
+ else {
+ /* expand */
+ *xmin = MIN(xminl[layer], *xmin);
+ *xmax = MAX(xmaxl[layer], *xmax);
+ *ymin = MIN(yminl[layer], *ymin);
+ *ymax = MAX(ymaxl[layer], *ymax);
+ G_free(have_ogr_extent);
+ G_free(xminl);
+ G_free(xmaxl);
+ G_free(yminl);
+ G_free(ymaxl);
+ return have_spatial_filter;
