[GRASS-SVN] r71584 - grass/trunk/raster/r.watershed/front
svn_grass at osgeo.org
Tue Oct 24 04:25:53 PDT 2017
Author: hcho
Date: 2017-10-24 04:25:53 -0700 (Tue, 24 Oct 2017)
New Revision: 71584
grass/trunk/raster/r.watershed/front/r.watershed.html
r.watershed: fix a run-on sentence in the manual
Modified: grass/trunk/raster/r.watershed/front/r.watershed.html
--- grass/trunk/raster/r.watershed/front/r.watershed.html 2017-10-23 22:47:18 UTC (rev 71583)
+++ grass/trunk/raster/r.watershed/front/r.watershed.html 2017-10-24 11:25:53 UTC (rev 71584)
@@ -103,14 +103,14 @@
parameter.
<p>
-Output <b>accumulation</b> map contains the absolute value of each
-cell in this output map is the amount of overland flow that traverses
-the cell. This value will be the number of upland cells plus one if no
-overland flow map is given. If the overland flow map is given, the
-value will be in overland flow units. Negative numbers indicate that
-those cells possibly have surface runoff from outside of the current
-geographic region. Thus, any cells with negative values cannot have
-their surface runoff and sedimentation yields calculated accurately.
+Output <b>accumulation</b> map contains the absolute value of the
+amount of overland flow that traverses each cell. This value will be
+the number of upland cells plus one if no overland flow map is given.
+If the overland flow map is given, the value will be in overland flow
+units. Negative numbers indicate that those cells possibly have surface
+runoff from outside of the current geographic region. Thus, any cells
+with negative values cannot have their surface runoff and sedimentation
+yields calculated accurately.
<p>
Output <b>tci</b> raster map contains topographic index TCI,
