[GRASS-SVN] r71588 - grass/branches/releasebranch_7_2/raster/r.watershed/front
Tue Oct 24 14:38:38 PDT 2017
Author: neteler
Date: 2017-10-24 14:38:38 -0700 (Tue, 24 Oct 2017)
New Revision: 71588
   grass/branches/releasebranch_7_2/raster/r.watershed/front/r.watershed.html
r.watershed: fix a run-on sentence in the manual
Modified: grass/branches/releasebranch_7_2/raster/r.watershed/front/r.watershed.html
--- grass/branches/releasebranch_7_2/raster/r.watershed/front/r.watershed.html	2017-10-24 20:49:46 UTC (rev 71587)
+++ grass/branches/releasebranch_7_2/raster/r.watershed/front/r.watershed.html	2017-10-24 21:38:38 UTC (rev 71588)
@@ -103,14 +103,14 @@
 parameter.
 <p>
-Output <b>accumulation</b> map contains the absolute value of each
-cell in this output map is the amount of overland flow that traverses
-the cell. This value will be the number of upland cells plus one if no
-overland flow map is given. If the overland flow map is given, the
-value will be in overland flow units. Negative numbers indicate that
-those cells possibly have surface runoff from outside of the current
-geographic region. Thus, any cells with negative values cannot have
-their surface runoff and sedimentation yields calculated accurately.
+Output <b>accumulation</b> map contains the absolute value of the
+amount of overland flow that traverses each cell. This value will be
+the number of upland cells plus one if no overland flow map is given.
+If the overland flow map is given, the value will be in overland flow
+units. Negative numbers indicate that those cells possibly have surface
+runoff from outside of the current geographic region. Thus, any cells
+with negative values cannot have their surface runoff and sedimentation
+yields calculated accurately.
 <p>
 Output <b>tci</b> raster map contains topographic index TCI,
