[GRASS-SVN] r71590 - in grass/trunk/scripts: r.import v.import
svn_grass at osgeo.org
Wed Oct 25 00:22:56 PDT 2017
Author: mmetz
Date: 2017-10-25 00:22:56 -0700 (Wed, 25 Oct 2017)
New Revision: 71590
grass/trunk/scripts/r.import/r.import.py
grass/trunk/scripts/v.import/v.import.py
r.import/v.import: create temporary location only if direct import is not possible
Modified: grass/trunk/scripts/r.import/r.import.py
--- grass/trunk/scripts/r.import/r.import.py 2017-10-25 07:20:26 UTC (rev 71589)
+++ grass/trunk/scripts/r.import/r.import.py 2017-10-25 07:22:56 UTC (rev 71590)
@@ -175,8 +175,37 @@
grass.fatal(
_("Please provide the resolution for the imported dataset or change to 'estimated' resolution"))
+ # try r.in.gdal directly first
+ additional_flags = 'l' if flags['l'] else ''
+ if flags['o']:
+ additional_flags += 'o'
+ region_flag = ''
+ if options['extent'] == 'region':
+ region_flag += 'r'
+ if flags['o'] or grass.run_command('r.in.gdal', input=GDALdatasource, flags='j',
+ errors='status', quiet=True) == 0:
+ parameters = dict(input=GDALdatasource, output=output,
+ memory=memory, flags='k' + additional_flags + region_flag)
+ if bands:
+ parameters['band'] = bands
+ try:
+ grass.run_command('r.in.gdal', **parameters)
+ grass.verbose(
+ _("Input <%s> successfully imported without reprojection") %
+ GDALdatasource)
+ return 0
+ except CalledModuleError as e:
+ grass.fatal(_("Unable to import GDAL dataset <%s>") % GDALdatasource)
grassenv = grass.gisenv()
tgtloc = grassenv['LOCATION_NAME']
+ # make sure target is not xy
+ if grass.parse_command('g.proj', flags='g')['name'] == 'xy_location_unprojected':
+ grass.fatal(
+ _("Coordinate reference system not available for current location <%s>") %
+ tgtloc)
tgtmapset = grassenv['MAPSET']
GISDBASE = grassenv['GISDBASE']
tgtgisrc = os.environ['GISRC']
@@ -208,40 +237,9 @@
# switch to temp location
os.environ['GISRC'] = str(SRCGISRC)
- # switch to target location
- os.environ['GISRC'] = str(tgtgisrc)
+ # print projection at verbose level
+ grass.verbose(grass.read_command('g.proj', flags='p').rstrip(os.linesep))
- # try r.in.gdal directly first
- additional_flags = 'l' if flags['l'] else ''
- if flags['o']:
- additional_flags += 'o'
- region_flag = ''
- if options['extent'] == 'region':
- region_flag += 'r'
- if flags['o'] or grass.run_command('r.in.gdal', input=GDALdatasource, flags='j',
- errors='status', quiet=True) == 0:
- parameters = dict(input=GDALdatasource, output=output,
- memory=memory, flags='k' + additional_flags + region_flag)
- if bands:
- parameters['band'] = bands
- try:
- grass.run_command('r.in.gdal', **parameters)
- grass.verbose(
- _("Input <%s> successfully imported without reprojection") %
- GDALdatasource)
- return 0
- except CalledModuleError as e:
- grass.fatal(_("Unable to import GDAL dataset <%s>") % GDALdatasource)
- # make sure target is not xy
- if grass.parse_command('g.proj', flags='g')['name'] == 'xy_location_unprojected':
- grass.fatal(
- _("Coordinate reference system not available for current location <%s>") %
- tgtloc)
- # switch to temp location
- os.environ['GISRC'] = str(SRCGISRC)
# make sure input is not xy
grass.fatal(_("Coordinate reference system not available for input <%s>") % GDALdatasource)
Modified: grass/trunk/scripts/v.import/v.import.py
--- grass/trunk/scripts/v.import/v.import.py 2017-10-25 07:20:26 UTC (rev 71589)
+++ grass/trunk/scripts/v.import/v.import.py 2017-10-25 07:22:56 UTC (rev 71590)
@@ -161,26 +161,6 @@
return grass.run_command('g.proj', epsg=options['epsg'],
datum_trans=options['datum_trans'])
- grassenv = grass.gisenv()
- tgtloc = grassenv['LOCATION_NAME']
- tgtmapset = grassenv['MAPSET']
- GISDBASE = grassenv['GISDBASE']
- tgtgisrc = os.environ['GISRC']
- SRCGISRC = grass.tempfile()
- TMPLOC = 'temp_import_location_' + str(os.getpid())
- f = open(SRCGISRC, 'w')
- f.write('MAPSET: PERMANENT\n')
- f.write('GISDBASE: %s\n' % GISDBASE)
- f.write('LOCATION_NAME: %s\n' % TMPLOC)
- f.write('GUI: text\n')
- f.close()
- tgtsrs = grass.read_command('g.proj', flags='j', quiet=True)
- # create temp location from input without import
- grass.verbose(_("Creating temporary location for <%s>...") % OGRdatasource)
if layers:
vopts['layer'] = layers
if output:
@@ -201,6 +181,33 @@
except CalledModuleError:
grass.fatal(_("Unable to import <%s>") % OGRdatasource)
+ grassenv = grass.gisenv()
+ tgtloc = grassenv['LOCATION_NAME']
+ grass.fatal(
+ tgtloc)
+ tgtmapset = grassenv['MAPSET']
+ GISDBASE = grassenv['GISDBASE']
+ tgtgisrc = os.environ['GISRC']
+ SRCGISRC = grass.tempfile()
+ TMPLOC = 'temp_import_location_' + str(os.getpid())
+ f = open(SRCGISRC, 'w')
+ f.write('MAPSET: PERMANENT\n')
+ f.write('GISDBASE: %s\n' % GISDBASE)
+ f.write('LOCATION_NAME: %s\n' % TMPLOC)
+ f.write('GUI: text\n')
+ f.close()
+ tgtsrs = grass.read_command('g.proj', flags='j', quiet=True)
+ # create temp location from input without import
+ grass.verbose(_("Creating temporary location for <%s>...") % OGRdatasource)
try:
grass.run_command('v.in.ogr', input=OGRdatasource,
location=TMPLOC, flags='i', quiet=True, overwrite=overwrite, **vopts)
@@ -216,18 +223,6 @@
kwargs['datum_trans'] = options['datum_trans']
grass.run_command('g.proj', flags='c', epsg=options['epsg'], **kwargs)
- grass.fatal(
- tgtloc)
