[GRASS-SVN] r71596 - in grass/trunk/raster: r.external r.in.gdal
svn_grass at osgeo.org
Wed Oct 25 12:03:46 PDT 2017
Author: mmetz
Date: 2017-10-25 12:03:46 -0700 (Wed, 25 Oct 2017)
New Revision: 71596
grass/trunk/raster/r.external/proj.c
grass/trunk/raster/r.in.gdal/proj.c
r.in.gdal/r.external: fix error reporting (sync to v.in.ogr)
Modified: grass/trunk/raster/r.external/proj.c
--- grass/trunk/raster/r.external/proj.c 2017-10-25 18:56:51 UTC (rev 71595)
+++ grass/trunk/raster/r.external/proj.c 2017-10-25 19:03:46 UTC (rev 71596)
@@ -149,6 +149,30 @@
sprintf(error_msg + strlen(error_msg), "%s: %s\n",
proj_info->key[i_value],
proj_info->value[i_value]);
+ else {
+ strcat(error_msg, _("Dataset PROJ_INFO is:\n"));
+ if (cellhd->proj == PROJECTION_XY)
+ sprintf(error_msg + strlen(error_msg),
+ "Dataset proj = %d (unreferenced/unknown)\n",
+ cellhd->proj);
+ else if (cellhd->proj == PROJECTION_LL)
+ "Dataset proj = %d (lat/long)\n",
+ cellhd->proj);
+ else if (cellhd->proj == PROJECTION_UTM)
+ "Dataset proj = %d (UTM), zone = %d\n",
+ cellhd->proj, cellhd->zone);
+ else
+ "Dataset proj = %d (unknown), zone = %d\n",
+ if (loc_wind.proj != cellhd->proj) {
+ strcat(error_msg, "\nERROR: proj\n");
+ else {
strcat(error_msg, "\nERROR: ");
switch (err) {
case -1:
@@ -186,25 +210,6 @@
break;
- else {
- strcat(error_msg, _("Dataset PROJ_INFO is:\n"));
- if (cellhd->proj == PROJECTION_XY)
- sprintf(error_msg + strlen(error_msg),
- "Dataset proj = %d (unreferenced/unknown)\n",
- cellhd->proj);
- else if (cellhd->proj == PROJECTION_LL)
- "Dataset proj = %d (lat/long)\n",
- cellhd->proj);
- else if (cellhd->proj == PROJECTION_UTM)
- "Dataset proj = %d (UTM), zone = %d\n",
- cellhd->proj, cellhd->zone);
- else
- "Dataset proj = %d (unknown), zone = %d\n",
else {
/* error in proj_units */
@@ -235,11 +240,12 @@
"the 'location' parameter.\n"));
if (check_only)
- msg_fn = G_message;
+ msg_fn = G_warning;
else
msg_fn = G_fatal_error;
msg_fn(error_msg);
if (check_only) {
+ GDALClose(hDS);
exit(EXIT_FAILURE);
Modified: grass/trunk/raster/r.in.gdal/proj.c
--- grass/trunk/raster/r.in.gdal/proj.c 2017-10-25 18:56:51 UTC (rev 71595)
+++ grass/trunk/raster/r.in.gdal/proj.c 2017-10-25 19:03:46 UTC (rev 71596)
+ else {
+ cellhd->proj);
+ cellhd->proj);
+ else
+ else {
switch (err) {
case -1:
break;
- else {
- cellhd->proj);
- cellhd->proj);
- else
else {
@@ -235,7 +240,7 @@
if (check_only)
else
msg_fn(error_msg);
