[GRASS-SVN] r71602 - grass-addons/grass7/imagery/i.segment.stats
svn_grass at osgeo.org
Sat Oct 28 06:58:23 PDT 2017
Author: mlennert
Date: 2017-10-28 06:58:23 -0700 (Sat, 28 Oct 2017)
New Revision: 71602
grass-addons/grass7/imagery/i.segment.stats/i.segment.stats.py
i.segment.stats: add flag to suppress calculation of shape statistics (fix for #3426)
Modified: grass-addons/grass7/imagery/i.segment.stats/i.segment.stats.py
--- grass-addons/grass7/imagery/i.segment.stats/i.segment.stats.py 2017-10-28 08:11:26 UTC (rev 71601)
+++ grass-addons/grass7/imagery/i.segment.stats/i.segment.stats.py 2017-10-28 13:58:23 UTC (rev 71602)
@@ -76,6 +76,11 @@
#% key: r
#% description: Adjust region to input map
#%END
+#%flag
+#% key: s
+#% description: Do not calculate any shape statistics
+#% guisection: shape_statistics
+#%end
import os
@@ -111,7 +116,7 @@
csvfile = options['csvfile'] if options['csvfile'] else []
vectormap = options['vectormap'] if options['vectormap'] else []
rasters = options['rasters'].split(',') if options['rasters'] else []
- area_measures = options['area_measures'].split(',') if options['area_measures'] else []
+ area_measures = options['area_measures'].split(',') if (options['area_measures'] and not flags['s']) else []
if area_measures:
if not gscript.find_program('r.object.geometry', '--help'):
message = _("You need to install the addon r.object.geometry to be able")
