[GRASS-SVN] r71605 - in grass-addons/grass7/vector/v.profile: . testsuite
svn_grass at osgeo.org
Sun Oct 29 03:18:41 PDT 2017
Author: marisn
Date: 2017-10-29 03:18:41 -0700 (Sun, 29 Oct 2017)
New Revision: 71605
Added:
grass-addons/grass7/vector/v.profile/testsuite/
grass-addons/grass7/vector/v.profile/testsuite/test_v_profile.py
v.profile: add simple tests
Added: grass-addons/grass7/vector/v.profile/testsuite/test_v_profile.py
--- grass-addons/grass7/vector/v.profile/testsuite/test_v_profile.py (rev 0)
+++ grass-addons/grass7/vector/v.profile/testsuite/test_v_profile.py 2017-10-29 10:18:41 UTC (rev 71605)
@@ -0,0 +1,105 @@
+Name: v.profile test
+Purpose: Tests v.profile input parsing and simle output generation.
+ Uses NC Basic data set.
+Author: Maris Nartiss
+Copyright: (C) 2017 by Maris Nartiss and the GRASS Development Team
+Licence: This program is free software under the GNU General Public
+ License (>=v2). Read the file COPYING that comes with GRASS
+ for details.
+TODO: Convert to synthetic dataset. It would allow to shorten output sample length.
+ Cover more input/output combinations.
+import os
+from grass.gunittest.case import TestCase
+from grass.gunittest.main import test
+from grass.gunittest.gmodules import SimpleModule
+output_full = """Number|Distance|cat|feature_id|featurenam|class|st_alpha|st_num|county|county_num|primlat_dm|primlon_dm|primlatdec|primlondec|srclat_dms|srclon_dms|srclatdec|srclondec|elev_m|map_name
+1|19537.97|572|986138|"Greshams Lake"|"Reservoir"|"NC"|37|"Wake"|183|"078:34:31W"|"35:52:43N"|35.878484|-78.57528|""|""|""|""|77|"Wake Forest"
+2|19537.97|1029|999647|"Greshams Lake Dam"|"Dam"|"NC"|37|"Wake"|183|"078:34:31W"|"35:52:43N"|35.878484|-78.57528|""|""|""|""|77|"Wake Forest"
+output_nocols = """1|19537.97|572|986138|"Greshams Lake"|"Reservoir"|"NC"|37|"Wake"|183|"078:34:31W"|"35:52:43N"|35.878484|-78.57528|""|""|""|""|77|"Wake Forest"
+output_filtered = """Number|Distance|cat|feature_id|featurenam|class|st_alpha|st_num|county|county_num|primlat_dm|primlon_dm|primlatdec|primlondec|srclat_dms|srclon_dms|srclatdec|srclondec|elev_m|map_name
+1|19537.97|1029|999647|"Greshams Lake Dam"|"Dam"|"NC"|37|"Wake"|183|"078:34:31W"|"35:52:43N"|35.878484|-78.57528|""|""|""|""|77|"Wake Forest"
+output_coords = """Number|Distance|cat|feature_id|featurenam|class|st_alpha|st_num|county|county_num|primlat_dm|primlon_dm|primlatdec|primlondec|srclat_dms|srclon_dms|srclatdec|srclondec|elev_m|map_name
+1|24.34|572|986138|"Greshams Lake"|"Reservoir"|"NC"|37|"Wake"|183|"078:34:31W"|"35:52:43N"|35.878484|-78.57528|""|""|""|""|77|"Wake Forest"
+2|24.34|1029|999647|"Greshams Lake Dam"|"Dam"|"NC"|37|"Wake"|183|"078:34:31W"|"35:52:43N"|35.878484|-78.57528|""|""|""|""|77|"Wake Forest"
+class TestProfiling(TestCase):
+ in_points = 'points_of_interest'
+ in_map = 'roadsmajor'
+ where = "cat='354'"
+ prof_ponts = (647952, 236176, 647950, 236217)
+ outfile = 'test_out.csv'
+ def testParsing(self):
+ """Test input parameter parsing"""
+ # Positive buffer size
+ self.assertModuleFail('v.profile', input=self.in_points, coordinates=self.prof_ponts, buffer=0)
+ # Where without input map
+ self.assertModuleFail('v.profile', input=self.in_points, coordinates=self.prof_ponts, buffer=10,
+ profile_where=self.where)
+ # Both coords and input vector is not supported
+ profile_map=self.in_map)
+ # Neither of coords or input line are provided
+ self.assertModuleFail('v.profile', input=self.in_points, buffer=10)
+ # Two coordinate parirs are reqiured
+ self.assertModuleFail('v.profile', input=self.in_points, coordinates=(647952, 236176), buffer=10)
+ # Wrong object match count
+ self.assertModuleFail('v.profile', input=self.in_points, profile_map=self.in_map, buffer=10,
+ profile_where="ROAD_NAME='wrong'")
+ profile_where="ROAD_NAME='US-1'")
+ self.assertModuleFail('v.profile', input=self.in_points, profile_map=self.in_map, buffer=10)
+ where="class='wrong'")
+ # Wrong output name
+ map_output='5cats')
+ def testFileExists(self):
+ """This function checks if the output file is written correctly"""
+ self.runModule('v.profile', input=self.in_points, coordinates=self.prof_ponts, buffer=10,
+ output=self.outfile)
+ self.assertFileExists(self.outfile)
+ if os.path.isfile(self.outfile):
+ os.remove(self.outfile)
+ def testOutput(self):
+ """Test correctness of output"""
+ # Normal output
+ vpro = SimpleModule('v.profile', input=self.in_points, profile_map=self.in_map, buffer=200,
+ vpro.run()
+ self.assertLooksLike(reference=output_full, actual=vpro.outputs.stdout)
+ # Without column names
+ profile_where=self.where, c=True)
+ vpro.run()
+ self.assertLooksLike(reference=output_nocols, actual=vpro.outputs.stdout)
+ # Filtering input points
+ where="class='Dam'", profile_where=self.where)
+ vpro.run()
+ self.assertLooksLike(reference=output_filtered, actual=vpro.outputs.stdout)
+ # Providing profiling line from coordinates
+ vpro = SimpleModule('v.profile', input=self.in_points, coordinates=self.prof_ponts, buffer=200)
+ vpro.run()
+ self.assertLooksLike(reference=output_coords, actual=vpro.outputs.stdout)
+if __name__ == '__main__':
+ test()
