[GRASS-SVN] r71607 - grass/trunk/raster/r.stream.extract
svn_grass at osgeo.org
Sun Oct 29 08:38:41 PDT 2017
Author: mmetz
Date: 2017-10-29 08:38:41 -0700 (Sun, 29 Oct 2017)
New Revision: 71607
grass/trunk/raster/r.stream.extract/main.c
r.stream.extract: remove problematic infinity as default answer for input TYPE_DOUBLE option
Modified: grass/trunk/raster/r.stream.extract/main.c
--- grass/trunk/raster/r.stream.extract/main.c 2017-10-29 10:21:34 UTC (rev 71606)
+++ grass/trunk/raster/r.stream.extract/main.c 2017-10-29 15:38:41 UTC (rev 71607)
@@ -110,7 +110,6 @@
_("If accumulation is larger than d8cut, SFD is used instead of MFD."
" Applies only if no accumulation map is given.");
input.d8cut->required = NO;
- input.d8cut->answer = "infinity";
input.d8cut->type = TYPE_DOUBLE;
input.mont_exp = G_define_option();
@@ -192,7 +191,7 @@
G_fatal_error(_("Threshold must be > 0 but is %f"), threshold);
/* d8cut */
- if (strcmp(input.d8cut->answer, "infinity") == 0) {
+ if (!input.d8cut->answer) {
d8cut = DBL_MAX;
else {
