[GRASS-SVN] r71611 - in grass/trunk/raster/r.sun: . testsuite
svn_grass at osgeo.org
Sun Oct 29 20:12:23 PDT 2017
Author: annakrat
Date: 2017-10-29 20:12:23 -0700 (Sun, 29 Oct 2017)
New Revision: 71611
Added:
grass/trunk/raster/r.sun/testsuite/
grass/trunk/raster/r.sun/testsuite/test_rsun.py
grass/trunk/raster/r.sun/Makefile
grass/trunk/raster/r.sun/local_proto.h
grass/trunk/raster/r.sun/main.c
r.sun: port r.sun.mp by Jaro Hofierka et al. from addons to core and add tests
Modified: grass/trunk/raster/r.sun/Makefile
--- grass/trunk/raster/r.sun/Makefile 2017-10-29 17:29:27 UTC (rev 71610)
+++ grass/trunk/raster/r.sun/Makefile 2017-10-30 03:12:23 UTC (rev 71611)
@@ -2,9 +2,10 @@
PGM = r.sun
-LIBES = $(GPROJLIB) $(RASTERLIB) $(GISLIB) $(MATHLIB) $(PROJLIB)
-DEPENDENCIES = $(GPROJDEP) $(RASTERDEP) $(GISDEP)
+LIBES = $(GPROJLIB) $(RASTERLIB) $(GISLIB) $(MATHLIB) $(GMATHLIB) $(PROJLIB) $(OMPLIB)
+DEPENDENCIES = $(GPROJDEP) $(RASTERDEP) $(GISDEP) $(GMATHDEP)
EXTRA_INC = $(PROJINC) $(OCLINCPATH)
+EXTRA_CFLAGS = $(OMPCFLAGS)
EXTRA_LIBS = $(OCLLIB)
#needed? LIBES += $(OCLLIBPATH) or EXTRA_LDFLAGS = $(OCLLIBPATH)
Modified: grass/trunk/raster/r.sun/local_proto.h
--- grass/trunk/raster/r.sun/local_proto.h 2017-10-29 17:29:27 UTC (rev 71610)
+++ grass/trunk/raster/r.sun/local_proto.h 2017-10-30 03:12:23 UTC (rev 71611)
@@ -3,9 +3,32 @@
void where_is_point(double *length, struct SunGeometryVarDay *sunVarGeom,
struct GridGeometry *gridGeom);
+void where_is_point_parallel(double *length, double *sunVarGeom_zp,
+ double *gridGeom_xx0,
+ double *gridGeom_yy0,
+ double *gridGeom_xg0,
+ double *gridGeom_yg0,
+ double *gridGeom_stepx,
+ double *gridGeom_stepy);
int searching(double *length, struct SunGeometryVarDay *sunVarGeom,
+int searching_parallel(double *length,
+ double *sunVarGeom_z_orig,
+ double *sunVarGeom_zmax,
+ double *sunVarGeom_zp,
+ double *sunVarGeom_tanSolarAltitude,
+ double *sunVarGeom_stepsinangle,
+ double *sunVarGeom_stepcosangle,
+ double *gridGeom_stepy,
+ double *gridGeom_deltx,
+ double *gridGeom_delty);
int useCivilTime();
void setUseCivilTime(int val);
int useShadow();
@@ -29,12 +52,32 @@
double brad(double, double *bh, struct SunGeometryVarDay *sunVarGeom,
struct SunGeometryVarSlope *sunSlopeGeom,
struct SolarRadVar *sunRadVar);
+double brad_parallel(double sh, double *bh,
+ double *sunVarGeom_solarAltitude,
+ double *sunVarGeom_sinSolarAltitude,
+ double *sunSlopeGeom_slope,
+ double *sunSlopeGeom_aspect,
+ double *sunRadVar_cbh,
+ double *sunRadVar_linke,
+ double *sunRadVar_G_norm_extra);
double drad(double, double bh, double *rr,
+double drad_parallel(double sh, double bh, double *rr,
+ int *sunVarGeom_isShadow,
+ double *sunVarGeom_solarAzimuth,
+ double *sunRadVar_cdh,
+ double *sunRadVar_G_norm_extra,
+ double *sunRadVar_alb);
double brad_angle_loss(double, double *bh,
@@ -49,13 +92,67 @@
struct GridGeometry *gridGeom,
double latitude, double longitude);
+void com_par_parallel(double *sunGeom_lum_C11,
+ double *sunGeom_lum_C13,
+ double *sunGeom_lum_C22,
+ double *sunGeom_lum_C31,
+ double *sunGeom_lum_C33,
+ double *sunGeom_sunrise_time,
+ double *sunGeom_sunset_time,
+ double *sunGeom_timeAngle,
+ double *sunVarGeom_sunAzimuthAngle,
+ double *gridGeom_stepxy,
+ double latitude);
void com_par_const(double longitTime, struct SunGeometryConstDay *sungeom,
+void com_par_const_parallel(double longitTime,
+ double *sunGeom_lum_C11,
+ double *sunGeom_sindecl,
+ double *sunGeom_cosdecl,
+ double *gridGeom_sinlat,
+ double *gridGeom_coslat);
double lumcline2(struct SunGeometryConstDay *sungeom,
unsigned char *horizonpointer);
+double lumcline2_parallel(double *sunGeom_timeAngle,
+ double *sunSlopeGeom_longit_l,
+ double *sunSlopeGeom_lum_C31_l,
+ double *sunSlopeGeom_lum_C33_l,
+ double *gridGeom_delty,
+ unsigned char *horizonpointer);
typedef double (*BeamRadFunc) (double sh, double *bh,
Modified: grass/trunk/raster/r.sun/main.c
--- grass/trunk/raster/r.sun/main.c 2017-10-29 17:29:27 UTC (rev 71610)
+++ grass/trunk/raster/r.sun/main.c 2017-10-30 03:12:23 UTC (rev 71611)
@@ -29,7 +29,12 @@
/*v. 2.0 July 2002, NULL data handling, JH */
/*v. 2.1 January 2003, code optimization by Thomas Huld, JH */
/*v. 3.0 February 2006, several changes (shadowing algorithm, earth's curvature JH */
+/*v. 4.0 December 2016, OpenMP support Stanislav Zubal, Michal Lacko */
+#if defined(_OPENMP)
+#include <omp.h>
+#endif
#include <stdio.h>
#include <stdlib.h>
#include <math.h>
@@ -43,6 +48,7 @@
#include <grass/gis.h>
#include <grass/raster.h>
+#include <grass/gmath.h>
#include <grass/gprojects.h>
#include <grass/glocale.h>
#include "sunradstruct.h"
@@ -122,7 +128,11 @@
struct SolarRadVar *sunRadVar,
unsigned char *horizonpointer, double latitude,
- double longitude);
+ double longitude,
+ double *Pbeam_e,
+ double *Pdiff_e,
+ double *Prefl_e,
+ double *Pinsol_t);
void calculate(double singleSlope, double singleAspect,
@@ -213,6 +223,8 @@
double singleAlbedo;
double singleLinke;
+ int threads;
struct GModule *module;
struct
@@ -220,7 +232,7 @@
*lin, *albedo, *longin, *alb, *latin, *coefbh, *coefdh,
*incidout, *beam_rad, *insol_time, *diff_rad, *refl_rad,
*glob_rad, *day, *step, *declin, *ltime, *dist, *horizon,
- *horizonstep, *numPartitions, *civilTime;
+ *horizonstep, *numPartitions, *civilTime, *threads;
parm;
@@ -469,6 +481,15 @@
parm.ltime->options = "0-24";
parm.ltime->guisection = _("Time");
+ parm.threads = G_define_option();
+ parm.threads->key = "nprocs";
+ parm.threads->type = TYPE_INTEGER;
+ parm.threads->answer = "1";
+ parm.threads->options = "1-1000";
+ parm.threads->required = NO;
+ parm.threads->description =
+ _("Number of threads which will be used for parallel computing");
* parm.startTime = G_define_option();
* parm.startTime->key = "start_time";
@@ -551,6 +572,20 @@
civiltime = parm.civilTime->answer;
+ sscanf(parm.threads->answer, "%d", &threads);
+ if (threads < 1)
+ G_warning(_("<%d> is not valid number of threads. Number of threads will be set to <%d>"),
+ threads, abs(threads));
+ threads = abs(threads);
+ omp_set_num_threads(threads);
+#else
+ threads = 1;
+#endif
+ G_message(_("Number of threads <%d>"), threads);
if (civiltime != NULL) {
setUseCivilTime(TRUE);
@@ -790,7 +825,6 @@
int finalRow, rowrevoffset;
int numRows;
- int numDigits;
FCELL *cell1 = NULL, *cell2 = NULL;
FCELL *cell3 = NULL, *cell4 = NULL, *cell5 = NULL, *cell6 = NULL, *cell7 =
NULL;
@@ -801,9 +835,8 @@
fd7 = -1, row, row_rev;
static int *fd_shad;
int fr1 = -1, fr2 = -1;
- int l, i, j;
+ int i, j;
char *shad_filename;
- char formatString[10];
double angle_deg = 0.;
finalRow = m - offset - m / numPartitions;
@@ -816,12 +849,10 @@
cell1 = Rast_allocate_f_buf();
if (z == NULL) {
- z = (float **)G_malloc(sizeof(float *) * (numRows));
- for (l = 0; l < numRows; l++) {
- z[l] = (float *)G_malloc(sizeof(float) * (n));
+ if (!(z = G_alloc_fmatrix(numRows, n)))
+ G_fatal_error(_("Out of memory"));
fd1 = Rast_open_old(elevin, "");
@@ -829,11 +860,10 @@
if (slopein != NULL) {
cell3 = Rast_allocate_f_buf();
if (s == NULL) {
- s = (float **)G_malloc(sizeof(float *) * (numRows));
- s[l] = (float *)G_malloc(sizeof(float) * (n));
+ if (!(s = G_alloc_fmatrix(numRows, n)))
fd3 = Rast_open_old(slopein, "");
@@ -843,11 +873,10 @@
cell2 = Rast_allocate_f_buf();
if (o == NULL) {
- o = (float **)G_malloc(sizeof(float *) * (numRows));
- o[l] = (float *)G_malloc(sizeof(float) * (n));
+ if (!(o = G_alloc_fmatrix(numRows, n)))
fd2 = Rast_open_old(aspin, "");
@@ -856,10 +885,10 @@
if (linkein != NULL) {
cell4 = Rast_allocate_f_buf();
if (li == NULL) {
- li = (float **)G_malloc(sizeof(float *) * (numRows));
- li[l] = (float *)G_malloc(sizeof(float) * (n));
+ if (!(li = G_alloc_fmatrix(numRows, n)))
fd4 = Rast_open_old(linkein, "");
@@ -867,9 +896,10 @@
if (albedo != NULL) {
cell5 = Rast_allocate_f_buf();
if (a == NULL) {
- a = (float **)G_malloc(sizeof(float *) * (numRows));
- a[l] = (float *)G_malloc(sizeof(float) * (n));
+ if (!(a = G_alloc_fmatrix(numRows, n)))
fd5 = Rast_open_old(albedo, "");
@@ -877,18 +907,22 @@
if (latin != NULL) {
cell6 = Rast_allocate_f_buf();
if (latitudeArray == NULL) {
- latitudeArray = (float **)G_malloc(sizeof(float *) * (numRows));
- latitudeArray[l] = (float *)G_malloc(sizeof(float) * (n));
+ if (!(latitudeArray = G_alloc_fmatrix(numRows, n)))
fd6 = Rast_open_old(latin, "");
if (longin != NULL) {
cell7 = Rast_allocate_f_buf();
- longitudeArray = (float **)G_malloc(sizeof(float *) * (numRows));
- longitudeArray[l] = (float *)G_malloc(sizeof(float) * (n));
+ if (latitudeArray == NULL) {
+ if (!(longitudeArray = G_alloc_fmatrix(numRows, n)))
fd7 = Rast_open_old(longin, "");
@@ -896,9 +930,10 @@
if (coefbh != NULL) {
rast1 = Rast_allocate_f_buf();
if (cbhr == NULL) {
- cbhr = (float **)G_malloc(sizeof(float *) * (numRows));
- cbhr[l] = (float *)G_malloc(sizeof(float) * (n));
+ if (!(cbhr = G_alloc_fmatrix(numRows, n)))
fr1 = Rast_open_old(coefbh, "");
@@ -906,9 +941,10 @@
if (coefdh != NULL) {
rast2 = Rast_allocate_f_buf();
if (cdhr == NULL) {
- cdhr = (float **)G_malloc(sizeof(float *) * (numRows));
- cdhr[l] = (float *)G_malloc(sizeof(float) * (n));
+ if (!(cdhr = G_alloc_fmatrix(numRows, n)))
fr2 = Rast_open_old(coefdh, "");
@@ -916,11 +952,11 @@
if (useHorizonData()) {
if (horizonarray == NULL) {
horizonarray =
- (unsigned char *)G_malloc(sizeof(char) * arrayNumInt *
- numRows * n);
+ (unsigned char *)G_calloc(arrayNumInt *
+ numRows * n, sizeof(char));
- horizonbuf = (FCELL **) G_malloc(sizeof(FCELL *) * arrayNumInt);
- fd_shad = (int *)G_malloc(sizeof(int) * arrayNumInt);
+ horizonbuf = (FCELL **) G_calloc(arrayNumInt, sizeof(FCELL *) );
+ fd_shad = (int *)G_calloc(arrayNumInt, sizeof(int));
* if(ttime != NULL)
@@ -1298,7 +1334,11 @@
struct GridGeometry *gridGeom, unsigned char *horizonpointer,
- double latitude, double longitude)
+ double latitude, double longitude,
+ double *Pbeam_e,
+ double *Pdiff_e,
+ double *Prefl_e,
+ double *Pinsol_t)
double s0, dfr, dfr_rad;
@@ -1310,10 +1350,6 @@
double bh;
double rr;
- beam_e = 0.;
- diff_e = 0.;
- refl_e = 0.;
- insol_t = 0.;
com_par(sunGeom, sunVarGeom, gridGeom, latitude, longitude);
@@ -1326,21 +1362,21 @@
if (sunVarGeom->solarAltitude > 0.) {
if ((!sunVarGeom->isShadow) && (s0 > 0.)) {
ra = brad(s0, &bh, sunVarGeom, sunSlopeGeom, sunRadVar); /* beam radiation */
- beam_e += ra;
+ *Pbeam_e += ra;
else {
- beam_e = 0.;
+ *Pbeam_e = 0.;
bh = 0.;
if ((diff_rad != NULL) || (glob_rad != NULL)) {
dra = drad(s0, bh, &rr, sunVarGeom, sunSlopeGeom, sunRadVar); /* diffuse rad. */
- diff_e += dra;
+ *Pdiff_e += dra;
if ((refl_rad != NULL) || (glob_rad != NULL)) {
if ((diff_rad == NULL) && (glob_rad == NULL))
- refl_e += rr; /* reflected rad. */
+ *Prefl_e += rr; /* reflected rad. */
} /* solarAltitude */
@@ -1377,9 +1413,9 @@
- insol_t += dfr;
+ *Pinsol_t += dfr;
- beam_e += dfr * ra;
+ *Pbeam_e += dfr * ra;
ra = 0.;
else {
@@ -1389,7 +1425,7 @@
dra =
sunRadVar);
- diff_e += dfr * dra;
+ *Pdiff_e += dfr * dra;
dra = 0.;
@@ -1397,7 +1433,7 @@
sunRadVar);
- refl_e += dfr * rr;
+ *Prefl_e += dfr * rr;
rr = 0.;
} /* illuminated */
@@ -1685,9 +1721,9 @@
if (incidout != NULL) {
- lumcl = (float **)G_malloc(sizeof(float *) * (m));
+ lumcl = (float **)G_calloc((m), sizeof(float *));
for (l = 0; l < m; l++) {
- lumcl[l] = (float *)G_malloc(sizeof(float) * (n));
+ lumcl[l] = (float *)G_calloc((n), sizeof(float *));
for (j = 0; j < m; j++) {
for (i = 0; i < n; i++)
@@ -1696,9 +1732,9 @@
if (beam_rad != NULL) {
- beam = (float **)G_malloc(sizeof(float *) * (m));
+ beam = (float **)G_calloc((m), sizeof(float *));
- beam[l] = (float *)G_malloc(sizeof(float) * (n));
+ beam[l] = (float *)G_calloc((n), sizeof(float *));
@@ -1708,9 +1744,9 @@
if (insol_time != NULL) {
- insol = (float **)G_malloc(sizeof(float *) * (m));
+ insol = (float **)G_calloc((m), sizeof(float *));
- insol[l] = (float *)G_malloc(sizeof(float) * (n));
+ insol[l] = (float *)G_calloc((n), sizeof(float *));
@@ -1720,9 +1756,9 @@
if (diff_rad != NULL) {
- diff = (float **)G_malloc(sizeof(float *) * (m));
+ diff = (float **)G_calloc((m), sizeof(float *));
- diff[l] = (float *)G_malloc(sizeof(float) * (n));
+ diff[l] = (float *)G_calloc((n), sizeof(float *));
@@ -1732,9 +1768,9 @@
if (refl_rad != NULL) {
- refl = (float **)G_malloc(sizeof(float *) * (m));
+ refl = (float **)G_calloc((m), sizeof(float *));
- refl[l] = (float *)G_malloc(sizeof(float) * (n));
+ refl[l] = (float *)G_calloc((n), sizeof(float *));
@@ -1744,9 +1780,9 @@
if (glob_rad != NULL) {
- globrad = (float **)G_malloc(sizeof(float *) * (m));
+ globrad = (float **)G_calloc((m), sizeof(float *));
- globrad[l] = (float *)G_malloc(sizeof(float) * (n));
+ globrad[l] = (float *)G_calloc((n), sizeof(float *));
@@ -1777,7 +1813,7 @@
else {
setTimeOffset(0.);
+ int shadowoffset_base = shadowoffset;
G_percent(j, m - 1, 2);
@@ -1788,10 +1824,12 @@
sunVarGeom.zmax = zmax;
+ shadowoffset_base = (j % (numRows)) * n * arrayNumInt;
+ #pragma omp parallel firstprivate(q1,tan_lam_l,z1,i,shadowoffset,longitTime,coslat,coslatsq,func,latitude,longitude,sin_phi_l,latid_l,sin_u,cos_u,sin_v,cos_v,lum, gridGeom,sunGeom,sunVarGeom,sunSlopeGeom,sunRadVar, elevin,aspin,slopein,civiltime,linkein,albedo,latin,coefbh,coefdh,incidout,longin,horizon,beam_rad,insol_time,diff_rad,refl_rad,glob_rad,mapset,per,decimals,str_step )
+ #pragma omp for schedule(dynamic)
for (i = 0; i < n; i++) {
+ shadowoffset = shadowoffset_base + (arrayNumInt * i);
if (useCivilTime()) {
/* sun travels 15deg per hour, so 1 TZ every 15 deg and 15 TZs * 24hrs = 360deg */
longitTime = -longitudeArray[arrayOffset][i] / 15.;
@@ -1922,27 +1960,31 @@
else lumcl[j][i] = UNDEFZ;
+ double Pbeam_e = 0.;
+ double Pdiff_e = 0.;
+ double Prefl_e = 0.;
+ double Pinsol_t = 0.;
if (someRadiation) {
joules2(&sunGeom, &sunVarGeom, &sunSlopeGeom, &sunRadVar,
&gridGeom, horizonarray + shadowoffset, latitude,
- longitude);
+ longitude, &Pbeam_e, &Pdiff_e, &Prefl_e, &Pinsol_t);
- beam[j][i] = (float)beam_e;
+ beam[j][i] = (float)Pbeam_e;
- insol[j][i] = (float)insol_t;
+ insol[j][i] = (float)Pinsol_t;
/* G_debug(3,"\n %f",insol[j][i]); */
- diff[j][i] = (float)diff_e;
+ diff[j][i] = (float)Pdiff_e;
- refl[j][i] = (float)refl_e;
+ refl[j][i] = (float)Prefl_e;
- globrad[j][i] = (float)(beam_e + diff_e + refl_e);
+ globrad[j][i] = (float)(Pbeam_e + Pdiff_e + Prefl_e);
} /* undefs */
- shadowoffset += arrayNumInt;
arrayOffset++;
Added: grass/trunk/raster/r.sun/testsuite/test_rsun.py
--- grass/trunk/raster/r.sun/testsuite/test_rsun.py (rev 0)
+++ grass/trunk/raster/r.sun/testsuite/test_rsun.py 2017-10-30 03:12:23 UTC (rev 71611)
@@ -0,0 +1,117 @@
+# -*- coding: utf-8 -*-
+from grass.gunittest.case import TestCase
+from grass.gunittest.main import test
+from grass.gunittest.gmodules import SimpleModule
+class TestRSunMode2(TestCase):
+ elevation = 'elevation'
+ elevation_attrib = 'elevation_attrib'
+ elevation_threads = 'elevation_threads'
+ slope = 'rsun_slope'
+ aspect = 'rsun_aspect'
+ beam_rad = 'beam_rad'
+ glob_rad = 'glob_rad'
+ insol_time = 'insol_time'
+ glob_rad_threads = 'glob_rad_threads'
+ @classmethod
+ def setUpClass(cls):
+ cls.use_temp_region()
+ cls.runModule('g.region', n=223500, s=220000, e=640000, w=635000, res=10)
+ cls.runModule('r.slope.aspect', elevation=cls.elevation, slope=cls.slope, aspect=cls.aspect)
+ @classmethod
+ def tearDownClass(cls):
+ cls.del_temp_region()
+ cls.runModule('g.remove', type=['raster'],
+ name=[cls.slope, cls.aspect, cls.insol_time, cls.beam_rad, cls.glob_rad, cls.glob_rad_threads], flags='f')
+ def setUp(self):
+ self.rsun = SimpleModule('r.sun', elevation=self.elevation, slope=self.slope, aspect=self.aspect,
+ day=172, beam_rad=self.beam_rad, glob_rad=self.glob_rad, insol_time=self.insol_time,
+ overwrite=True)
+ def test_more_threads(self):
+ self.assertModule(self.rsun)
+ try:
+ self.rsun.inputs['nprocs'].value = 4
+ self.rsun.outputs.glob_rad = self.glob_rad_threads
+ self.assertRastersNoDifference(self.glob_rad, self.glob_rad_threads, precision=1e-8)
+ except KeyError:
+ # original version of r.sun without parallel processing
+ return
+ def test_run_outputs(self):
+ self.assertRasterExists(name=self.beam_rad)
+ self.assertRasterExists(name=self.glob_rad)
+ self.assertRasterExists(name=self.insol_time)
+ # beam_rad
+ values = 'min=6561.3505859375\nmax=7680.93505859375\nmean=7638.91454059886'
+ self.assertRasterFitsUnivar(raster=self.beam_rad, reference=values, precision=1e-8)
+ # glob_rad
+ values = 'min=7829.4921875\nmax=8889.4765625\nmean=8851.4872842213'
+ self.assertRasterFitsUnivar(raster=self.glob_rad, reference=values, precision=1e-8)
+ # insol_time
+ values = 'min=11.5\nmax=14\nmean=13.8521038175691'
+ self.assertRasterFitsUnivar(raster=self.insol_time, reference=values, precision=1e-8)
+class TestRSunMode1(TestCase):
+ incidout = 'incidout'
+ @classmethod
+ @classmethod
+ name=[cls.slope, cls.aspect, cls.incidout, cls.beam_rad, cls.glob_rad, cls.glob_rad_threads], flags='f')
+ def setUp(self):
+ day=172, time=18, beam_rad=self.beam_rad, glob_rad=self.glob_rad, incidout=self.incidout,
+ overwrite=True)
+ try:
+ except KeyError:
+ return
+ self.assertRasterExists(name=self.incidout)
+ # beam_rad
+ values = 'min=0\nmax=355.780944824219\nmean=124.615522080923'
+ # glob_rad
+ values = 'min=32.1095008850098\nmax=451.527923583984\nmean=178.057346498427'
+ # incidout
+ values = 'min=0.0100772567093372\nmax=40.5435371398926\nmean=13.2855086254291'
+ self.assertRasterFitsUnivar(raster=self.incidout, reference=values, precision=1e-8)
+if __name__ == '__main__':
+ test()
