[GRASS-SVN] r71613 - grass/trunk/lib/proj
svn_grass at osgeo.org
Mon Oct 30 13:45:14 PDT 2017
Author: mmetz
Date: 2017-10-30 13:45:14 -0700 (Mon, 30 Oct 2017)
New Revision: 71613
grass/trunk/lib/proj/convert.c
projlib: fix segfault
Modified: grass/trunk/lib/proj/convert.c
--- grass/trunk/lib/proj/convert.c 2017-10-30 20:31:26 UTC (rev 71612)
+++ grass/trunk/lib/proj/convert.c 2017-10-30 20:45:14 UTC (rev 71613)
@@ -379,7 +379,7 @@
* been defined
int GPJ_osr_to_grass(struct Cell_head *cellhd, struct Key_Value **projinfo,
- struct Key_Value **projunits, OGRSpatialReferenceH hSRS,
+ struct Key_Value **projunits, OGRSpatialReferenceH hSRS1,
int datumtrans)
struct Key_Value *temp_projinfo;
@@ -389,10 +389,13 @@
char *datum = NULL;
struct gpj_datum dstruct;
const char *ograttr;
+ OGRSpatialReferenceH hSRS;
*projinfo = NULL;
*projunits = NULL;
+ hSRS = hSRS1;
if (hSRS == NULL)
goto default_to_xy;
@@ -453,7 +456,6 @@
G_set_key_value("name", pszProj, *projinfo);
- OSRDestroySpatialReference(hSRS);
hSRS = OSRNewSpatialReference(NULL);
if (OSRImportFromProj4(hSRS, proj4ext) != OGRERR_NONE) {
G_fatal_error(_("Can't parse PROJ.4-style parameter string"));
@@ -830,6 +832,9 @@
+ if (hSRS != hSRS1)
+ OSRDestroySpatialReference(hSRS);
return 2;
@@ -846,6 +851,9 @@
*projinfo = NULL;
*projunits = NULL;
return 1;
#endif
