[GRASS-SVN] r71463 - grass/branches/releasebranch_7_2/tools
svn_grass at osgeo.org
Sat Sep 2 19:14:01 PDT 2017
Author: wenzeslaus
Date: 2017-09-02 19:14:01 -0700 (Sat, 02 Sep 2017)
New Revision: 71463
grass/branches/releasebranch_7_2/tools/thumbnails.py
replace g.ppmtopng and d.colortable by g.region, r.mapcalc and d.rast (see #3200, backport of r70725)
Modified: grass/branches/releasebranch_7_2/tools/thumbnails.py
--- grass/branches/releasebranch_7_2/tools/thumbnails.py 2017-08-31 21:04:14 UTC (rev 71462)
+++ grass/branches/releasebranch_7_2/tools/thumbnails.py 2017-09-03 02:14:01 UTC (rev 71463)
@@ -14,6 +14,7 @@
import sys
import os
+import shutil
import atexit
import string
import array
@@ -23,8 +24,8 @@
tmp_grad_abs = None
tmp_grad_rel = None
-height = 85
-width = 15
+height = 15
+width = 85
def cleanup():
if tmp_img:
@@ -96,6 +97,8 @@
else:
grass.fatal(_("Cannot find g.ppmtopng, pnmtopng or convert"))
+# TODO: this code is not used and can be moved to some lib function or
+# separate module if useful
def convert_and_rotate(src, dst, flip = False):
ppm = read_ppm(src)
if flip:
@@ -135,26 +138,52 @@
maxval = 0.04
else:
minval = float(records[0][0])
+ # shift min up for floating point values so that
+ # first color in color table is visible
+ if '.' in records[0][0]:
+ # assumes that 1% of min does not go to the next value
+ # and is still represented as float and does not make
+ # too much difference in color
+ # works better than 1% of the difference to the next value
+ minval += abs(minval / 100)
maxval = float(records[-1][0])
maxval = min(maxval, 2500000)
grad = tmp_grad_abs
- grass.mapcalc("$grad = if(row()==1, float($min), float($max))",
+ # alternatively, only simpler expression would suffice if frames
+ # are used to render raster and then the borders
+ grass.mapcalc("$grad = if(col() > 2 && col() < ncols() - 1,"
+ " float($min) + (col() - 3) * (float($max) - float($min)) / (ncols() - 2),"
+ " null())",
grad = tmp_grad_abs, min = minval, max = maxval, quiet = True)
else:
grad = tmp_grad_rel
return grad
-def make_image(output_dir, table, grad, discrete = False):
- if discrete:
- lines, cols = height, 1
- else:
- lines, cols = None, None
+def make_image(output_dir, table, grad):
grass.run_command("r.colors", map = grad, color = table, quiet = True)
- grass.run_command("d.colortable", flags = 'n', map = grad,
- lines = lines, columns = cols, quiet = True)
+ grass.run_command("d.rast", map=grad, quiet=True)
+ if 1:
+ grass.write_command("d.graph", quiet=True, flags='m', stdin="""width 1
+ color {outcolor}
+ polyline
+ {x1} {y1}
+ {x2} {y1}
+ {x2} {y2}
+ {x1} {y2}
+ {x1} {y1}
+ color {incolor}
+ polyline
+ {x3} {y3}
+ {x4} {y3}
+ {x4} {y4}
+ {x3} {y4}
+ {x3} {y3}
+ """.format(x1=1, x2=width, y1=0, y2=height - 1,
+ x3=2, x4=width - 1, y3=1, y4=height - 2,
+ outcolor='white', incolor='black'))
outfile = os.path.join(output_dir, "colortables", "%s.png" % table)
- convert_and_rotate(tmp_img, outfile, discrete)
+ shutil.move(tmp_img, outfile)
def main():
global tmp_img, tmp_grad_abs, tmp_grad_rel
@@ -170,36 +199,43 @@
pid = os.getpid()
tmp_grad_abs = "tmp_grad_abs_%d" % pid
tmp_grad_rel = "tmp_grad_rel_%d" % pid
- tmp_img = grass.tempfile() + ".ppm"
+ tmp_img = grass.tempfile() + ".png"
os.environ['GRASS_RENDER_WIDTH'] = '%d' % width
os.environ['GRASS_RENDER_HEIGHT'] = '%d' % height
os.environ['GRASS_RENDER_FRAME'] = '%f,%f,%f,%f' % (0,height,0,width)
os.environ['GRASS_RENDER_FILE'] = tmp_img
os.environ['GRASS_RENDER_TRUECOLOR'] = 'TRUE'
- os.environ['GRASS_RENDER_FILE_READ'] = 'FALSE'
+ # for multiple d commands (requires to delete/move image each time)
+ os.environ['GRASS_RENDER_FILE_READ'] = 'TRUE'
os.environ['GRASS_RENDER_FILE_MAPPED'] = 'FALSE'
os.environ['GRASS_RENDER_TRANSPARENT'] = 'FALSE'
os.environ['GRASS_RENDER_BACKGROUNDCOLOR'] = 'ffffff'
os.environ['GRASS_RENDER_IMMEDIATE'] = 'cairo'
+ # for one pixel wide lines
+ os.environ['GRASS_RENDER_ANTIALIAS'] = 'none'
- for var in ['GRASS_RENDER_LINE_WIDTH', 'GRASS_RENDER_ANTIALIAS']:
+ for var in ['GRASS_RENDER_LINE_WIDTH']:
if var in os.environ:
del os.environ[var]
grass.use_temp_region()
- grass.run_command('g.region', rows = 100, cols = 100)
+ grass.run_command('g.region', s=0, w=0, n=height, e=width,
+ rows=height, cols=width, res=1, flags='a')
- grass.mapcalc("$grad = row()/1.0", grad = tmp_grad_rel, quiet = True)
+ " float(col()), null())", grad=tmp_grad_rel, quiet=True)
for table in os.listdir(color_dir):
path = os.path.join(color_dir, table)
grad = make_gradient(path)
- grass.mapcalc("$grad = row()", grad = tmp_grad_abs, quiet = True)
+ " col(), null())", grad=tmp_grad_abs, quiet=True)
for table in ['grey.eq', 'grey.log', 'random']:
- make_image(output_dir, table, tmp_grad_abs, True)
+ make_image(output_dir, table, tmp_grad_abs)
if __name__ == "__main__":
atexit.register(cleanup)
