[GRASS-SVN] r71487 - in grass-addons/grass7/raster: . r.cell.area
svn_grass at osgeo.org
Tue Sep 12 20:53:04 PDT 2017
Author: awickert
Date: 2017-09-12 20:53:04 -0700 (Tue, 12 Sep 2017)
New Revision: 71487
Added:
grass-addons/grass7/raster/r.cell.area/
grass-addons/grass7/raster/r.cell.area/Makefile
grass-addons/grass7/raster/r.cell.area/r.cell.area.html
grass-addons/grass7/raster/r.cell.area/r.cell.area.py
Tool to compute area in each raster cell
Added: grass-addons/grass7/raster/r.cell.area/Makefile
--- grass-addons/grass7/raster/r.cell.area/Makefile (rev 0)
+++ grass-addons/grass7/raster/r.cell.area/Makefile 2017-09-13 03:53:04 UTC (rev 71487)
@@ -0,0 +1,7 @@
+MODULE_TOPDIR = ../..
+PGM = r.cell.area
+include $(MODULE_TOPDIR)/include/Make/Script.make
+default: script
Property changes on: grass-addons/grass7/raster/r.cell.area/Makefile
___________________________________________________________________
Added: svn:executable
Added: grass-addons/grass7/raster/r.cell.area/r.cell.area.html
--- grass-addons/grass7/raster/r.cell.area/r.cell.area.html (rev 0)
+++ grass-addons/grass7/raster/r.cell.area/r.cell.area.html 2017-09-13 03:53:04 UTC (rev 71487)
@@ -0,0 +1,21 @@
+<h2>DESCRIPTION</h2>
+<em>r.cell.area</em> uses the current computational region to compute the area of each raster cell. It can do so on a projected coordinate system or on a geographic coordinate system; the latter is accomplished via the latitude of the cell's midpoint.
+<h2>NOTES</h2>
+Output units can be either square meters or square kilometers.
+This module is useful for determining the flow accumulation area to weight flow accumulation algorithms by rainfall and/or on lat/lon grids.
+<h2>SEE ALSO</h2>
+<em>
+<a href="r.mapcalc">r.mapcalc</a>
+</em>
+<h2>AUTHOR</h2>
+Andrew D. Wickert<br>
+<p><i>Last changed: $Date 2017-10-12$</i>
Added: grass-addons/grass7/raster/r.cell.area/r.cell.area.py
--- grass-addons/grass7/raster/r.cell.area/r.cell.area.py (rev 0)
+++ grass-addons/grass7/raster/r.cell.area/r.cell.area.py 2017-09-13 03:53:04 UTC (rev 71487)
@@ -0,0 +1,90 @@
+#! /usr/bin/env python
+#!/usr/bin/env python
+# MODULE: r.cell.area
+# AUTHOR(S): Andrew Wickert
+# PURPOSE: Compute raster cell areas
+# COPYRIGHT: (c) 2017 Andrew Wickert
+# This program is free software under the GNU General Public
+# License (>=v2). Read the file COPYING that comes with GRASS
+# for details.
+#%module
+#% description: Calculate cell sizes within the computational region
+#% keyword: raster
+#%end
+#%option G_OPT_R_OUTPUT
+#% key: output
+#% type: string
+#% description: Output grid of cell sizes
+#% required: yes
+#%end
+#%option
+#% key: units
+#% type: string
+#% description: Units for output areas
+#% options: m2, km2
+#% required: yes
+#%end
+# IMPORT MODULES #
+# PYTHON
+import os
+import glob
+import numpy as np
+# GRASS
+import grass.script as grass
+from grass.script import array as garray
+from grass.pygrass.vector import VectorTopo
+def main():
+ Compute cell areas
+ projinfo = grass.parse_command('g.proj', flags='g')
+ options, flags = grass.parser()
+ output = options['output']
+ units = options['units']
+ # First check if output exists
+ if len(grass.parse_command('g.list', type='rast',
+ pattern=options['output'])):
+ if not grass.overwrite():
+ grass.fatal("Raster map '" + options['output'] +
+ "' already exists. Use '--o' to overwrite.")
+ # Then compute
+ if projinfo['units'] == 'meters':
+ if units == 'm2':
+ grass.mapcalc(output+' = nsres() * ewres()')
+ elif units == 'km2':
+ grass.mapcalc(output+' = nsres() * ewres() / 10.^6')
+ elif projinfo['units'] == 'degrees':
+ if units == 'm2':
+ grass.mapcalc(output+' = ( 111195. * nsres() ) * \
+ ( ewres() * (3.14159/180.) * 6371000. * cos(y()) )')
+ grass.mapcalc(output+' = ( 111.195 * nsres() ) * \
+ ( ewres() * (3.14159/180.) * 6371. * cos(y()) )')
+ else:
+ print 'Units: ', + projinfo['units'] + ' not currently supported'
+if __name__ == "__main__":
+ main()
