[GRASS-SVN] r71518 - grass-addons/grass7/vector/v.gsflow.reaches
svn_grass at osgeo.org
Sat Sep 30 18:04:48 PDT 2017
Author: awickert
Date: 2017-09-30 18:04:48 -0700 (Sat, 30 Sep 2017)
New Revision: 71518
grass-addons/grass7/vector/v.gsflow.reaches/v.gsflow.reaches.py
hydrogeologic properties options
Modified: grass-addons/grass7/vector/v.gsflow.reaches/v.gsflow.reaches.py
--- grass-addons/grass7/vector/v.gsflow.reaches/v.gsflow.reaches.py 2017-10-01 01:04:03 UTC (rev 71517)
+++ grass-addons/grass7/vector/v.gsflow.reaches/v.gsflow.reaches.py 2017-10-01 01:04:48 UTC (rev 71518)
@@ -114,7 +114,56 @@
#% required : no
#%end
+#%option
+#% key: strthick
+#% type: double
+#% description: Streambed sediment thickness [m]
+#% answer: 1
+#% required : no
+#%end
+#%option
+#% key: strhc1
+#% type: double
+#% description: Streambed hydraulic conductivity [m/day]
+#% answer: 5
+#% required : no
+#%end
+#%option
+#% key: thts
+#% type: double
+#% description: theta_sat: Streambed saturated water content (i.e. porosity) [unitless]
+#% answer: 0.35
+#% required : no
+#%end
+#%option
+#% key: thti
+#% type: double
+#% description: Streambed initial water content [unitless]
+#% answer: 0.3
+#% required : no
+#%end
+#%option
+#% key: eps
+#% type: double
+#% description: Epsilon: streambed Brooks-Corey exponent [unitless]
+#% answer: 3.5
+#% required : no
+#%end
+#%option
+#% key: uhc
+#% type: double
+#% description: Streambed unsaturated zone saturated hydraulic conductivity [m/day]
+#% answer: 0.3
+#% required : no
+#%end
+# Default values strthick onwards from sagehen example
# IMPORT MODULES #
@@ -146,6 +195,10 @@
These reaches link the PRMS stream segments to the MODFLOW grid cells.
+ # OPTION PARSING #
options, flags = gscript.parser()
segments = options['segment_input']
grid = options['grid_input']
@@ -158,7 +211,13 @@
x2 = options['downstream_easting_column_seg']
y2 = options['downstream_northing_column_seg']
tostream = options['tostream_cat_column_seg']
+ # Hydraulic paramters
+ STRTHICK = options['strthick']
+ STRHC1 = options['strhc1']
+ THTS = options['thts']
+ THTI = options['thti']
+ EPS = options['eps']
+ UHC = options['uhc']
# Build reach maps by overlaying segments on grid
if len(gscript.find_file(segments, element='vector')['name']) > 0:
v.extract(input=segments, output='GSFLOW_TEMP__', type='line', quiet=True, overwrite=True)
@@ -203,6 +262,11 @@
reachesTopo.table.columns.add('STRTOP', 'double precision')
reachesTopo.table.columns.add('SLOPE', 'double precision')
reachesTopo.table.columns.add('STRTHICK', 'double precision')
+ reachesTopo.table.columns.add('STRHC1', 'double precision')
+ reachesTopo.table.columns.add('THTS', 'double precision')
+ reachesTopo.table.columns.add('THTI', 'double precision')
+ reachesTopo.table.columns.add('EPS', 'double precision')
+ reachesTopo.table.columns.add('UHC', 'double precision')
reachesTopo.table.columns.add('xr1', 'double precision')
reachesTopo.table.columns.add('xr2', 'double precision')
reachesTopo.table.columns.add('yr1', 'double precision')
@@ -222,8 +286,15 @@
for i in range(len(cats)):
nseg_cats.append( (nseg[i], cats[i]) )
cur = reachesTopo.table.conn.cursor()
- cur.execute("update "+reaches+" set KRCH=1") # MAKE A VARIABLE LATER???
- cur.execute("update "+reaches+" set STRTHICK=0.1") # 10 cm, prescribed -- MAKE A VARIABLE LATER!!!!!
+ # Hydrogeologic properties
+ cur.execute("update "+reaches+" set STRTHICK="+str(STRTHICK))
+ cur.execute("update "+reaches+" set STRHC1="+str(STRHC1))
+ cur.execute("update "+reaches+" set THTS="+str(THTS))
+ cur.execute("update "+reaches+" set THTI="+str(THTI))
+ cur.execute("update "+reaches+" set EPS="+str(EPS))
+ cur.execute("update "+reaches+" set UHC="+str(UHC))
+ # Grid properties
+ cur.execute("update "+reaches+" set KRCH=1") # Top layer: unchangable
cur.executemany("update "+reaches+" set IRCH=? where row=?", nseg_cats)
cur.executemany("update "+reaches+" set JRCH=? where col=?", nseg_cats)
reachesTopo.table.conn.commit()
@@ -342,12 +413,13 @@
v.db_update(map=reaches, column='SLOPE', value='(zr1 - zr2)/RCHLEN')
v.db_update(map=reaches, column='SLOPE', value=Smin, where='SLOPE <= '+str(Smin))
- ## srtm_local_filled_grid = srtm_local_filled @ 200m (i.e. current grid)
- ## resolution
- ## r.to.vect in=srtm_local_filled_grid out=srtm_local_filled_grid col=z type=area --o#
- #v.db_addcolumn(map=reaches, columns='z_topo_mean double precision')
- #v.what_vect(map=reaches, query_map='srtm_local_filled_grid', column='z_topo_mean', query_column='z')
- #v.db_update(map=reaches, column='STRTOP', value='z_topo_mean -'+str(h_stream))
+ # srtm_local_filled_grid = srtm_local_filled @ 200m (i.e. current grid)
+ # resolution
+ # r.to.vect in=srtm_local_filled_grid out=srtm_local_filled_grid col=z type=area --o#
+ # NOT SURE IF IT IS BEST TO USE MEAN ELEVATION OR TOP ELEVATION!!!!!!!!!!!!!!!!!!!!!!!
+ v.db_addcolumn(map=reaches, columns='z_topo_mean double precision')
+ v.what_vect(map=reaches, query_map=elevation, column='z_topo_mean', query_column='z')
+ v.db_update(map=reaches, column='STRTOP', value='z_topo_mean -'+str(h_stream), quiet=True)
if __name__ == "__main__":
