[GRASS-SVN] r72594 - grass/trunk/vector/v.random
svn_grass at osgeo.org
Fri Apr 6 10:49:51 PDT 2018
Author: martinl
Date: 2018-04-06 10:49:51 -0700 (Fri, 06 Apr 2018)
New Revision: 72594
grass/trunk/vector/v.random/v.random.html
v.random: fix syntax issues in manual
Modified: grass/trunk/vector/v.random/v.random.html
--- grass/trunk/vector/v.random/v.random.html 2018-04-06 12:38:39 UTC (rev 72593)
+++ grass/trunk/vector/v.random/v.random.html 2018-04-06 17:49:51 UTC (rev 72594)
@@ -3,26 +3,26 @@
<em>v.random</em> randomly generates vector points within the
current region using the selected random number generator.
-<p><em>v.random</em> can generate also 3D vector points or
-write random value to attribute table. Point height range or
-attribute value range is controlled by specifying zmin and zmax values.
-Both z values are included in range (<em>zmin <= z <= zmax</em>).
-Generated random attribute value type can be controlled by column
-data type. Use <b>INTEGER</b> column type for integers and
-<b>DOUBLE PRECISION</b> for floating point numbers. Integer values are
+<p><em>v.random</em> can generate also 3D vector points or write
+random value to attribute table. Point height range or attribute value
+range is controlled by specifying <b>zmin</b> and <b>zmax</b> options.
+Both z values are included in range (<em>zmin <= z <=
+zmax</em>). Generated random attribute value type can be controlled
+by <b>column_type</b>. Use <i>integer</i> column type for integers and
+<i>double precision</i> for floating point numbers. Integer values are
calculated by rounding random floating point number.
<p>To produce repeatable results a random seed can be set using the
-option <em>seed</em>.
+option <b>seed</b>.
<h3>Restriction to vector areas</h3>
<p>
-If an <em>input</em> vector map with areas is specified, the location of
-random points is restricted to the selected areas. By default, the
+If an <b>restrict</b> vector map with areas is specified, the location
+of random points is restricted to the selected areas. By default, the
requested number of points are distributed across all areas.
<p>
-If the <em>-a</em> flag is given, the requested number of points is
+If the <b>-a</b> flag is given, the requested number of points is
generated for each individual area. For example, if 20 points should be
generated and the input map has 100 individual areas, 2000 points will
be generated in total.
@@ -57,8 +57,7 @@
Generate 20 random points with binary attributes (only 0 or 1):
<div class="code"><pre>
-v.random output=binary_random npoints=20 zmin=0 zmax=1 \
- column='binary' column_type=integer
+v.random output=binary_random npoints=20 zmin=0 zmax=1 column='binary' column_type=integer
v.db.select binary_random
cat|binary
1|0
@@ -108,8 +107,7 @@
Generate 3 random points only in selected polygons ("RALEIGH" related ZIP
code areas):
-v.random restrict=zipcodes_wake output=zipcodes_local_random_n3 npoints=3 \
- where="ZIPNAME = 'RALEIGH'" -a
+v.random restrict=zipcodes_wake output=zipcodes_local_random_n3 npoints=3 where="ZIPNAME = 'RALEIGH'" -a
# visualization
d.mon wx0
@@ -122,7 +120,7 @@
<a href="v_random_points_in_polygon.png">
<img src="v_random_points_in_polygon.png" width="400" height="368" alt="v.random example" border="0">
</a><br>
-<i>Fixd number of random points generated in selected polygons</i>
+<i>Fixed number of random points generated in selected polygons</i>
</div>
<h3>Generating random adjacent polygons</h3>
@@ -149,7 +147,7 @@
<p>
To eventually obtain isolated polygons, selected polygons can be extracted with
-<em>v.extract</em>.
+<em><a href="v.extract.html">v.extract</a></em>.
<p>
These vector polygons can also be rasterized:
@@ -186,8 +184,7 @@
g.region -p vector=geology
v.random output=random_samples npoints=20
v.db.addtable map=random_samples columns='cat integer, geology varchar(100)'
-v.what.vect map=random_samples column=geology \
- query_map=geology query_layer=1 query_column=GEO_NAME
+v.what.vect map=random_samples column=geology query_map=geology query_layer=1 query_column=GEO_NAME
v.db.select random_samples
cat|geology
1|PzZm
@@ -202,8 +199,7 @@
g.region -p raster=landclass96
r.to.vect -v input=landclass96 output=landclass96 type=area
-v.random restrict=landclass96 output=random_samples npoints=20 \
- where="label = 'forest'" layer=1
+v.random restrict=landclass96 output=random_samples npoints=20 where="label = 'forest'" layer=1
</pre></div>
@@ -227,8 +223,7 @@
-v.random restrict=landclass96 output=random_samples npoints=2 \
- where="label = 'water'" layer=1 -a
+v.random restrict=landclass96 output=random_samples npoints=2 where="label = 'water'" layer=1 -a
</pre></div>
