[GRASS-SVN] r72598 - grass/trunk/raster/r.proj
svn_grass at osgeo.org
Sun Apr 8 06:47:32 PDT 2018
Author: mmetz
Date: 2018-04-08 06:47:32 -0700 (Sun, 08 Apr 2018)
New Revision: 72598
grass/trunk/raster/r.proj/main.c
r.proj: +option for user-defined PROJ pipeline
Modified: grass/trunk/raster/r.proj/main.c
--- grass/trunk/raster/r.proj/main.c 2018-04-08 13:45:58 UTC (rev 72597)
+++ grass/trunk/raster/r.proj/main.c 2018-04-08 13:47:32 UTC (rev 72598)
@@ -131,10 +131,12 @@
*inlocation, /* name of input location */
*outmap, /* name of output layer */
*indbase, /* name of input database */
- *interpol, /* interpolation method:
- nearest neighbor, bilinear, cubic */
+ *interpol, /* interpolation method */
*memory, /* amount of memory for cache */
*res; /* resolution of target map */
+#ifdef HAVE_PROJ_H
+ struct Option *pipeline; /* name of custom PROJ pipeline */
+#endif
struct Cell_head incellhd, /* cell header of input map */
outcellhd; /* and output map */
@@ -199,6 +201,14 @@
res->description = _("Resolution of output raster map");
res->guisection = _("Target");
+#ifdef HAVE_PROJ_H
+ pipeline = G_define_option();
+ pipeline->key = "pipeline";
+ pipeline->type = TYPE_STRING;
+ pipeline->required = NO;
+ pipeline->description = _("PROJ pipeline for coordinate transformation");
+#endif
list = G_define_flag();
list->key = 'l';
list->description = _("List raster maps in input mapset and exit");
@@ -285,13 +295,13 @@
/* if requested, list the raster maps in source location - MN 5/2001 */
if (list->answer) {
int i;
- char **list;
+ char **srclist;
G_verbose_message(_("Checking location <%s> mapset <%s>"),
inlocation->answer, setname);
- list = G_list(G_ELEMENT_RASTER, G_getenv_nofatal("GISDBASE"),
+ srclist = G_list(G_ELEMENT_RASTER, G_getenv_nofatal("GISDBASE"),
G_getenv_nofatal("LOCATION_NAME"), setname);
- for (i = 0; list[i]; i++) {
- fprintf(stdout, "%s\n", list[i]);
+ for (i = 0; srclist[i]; i++) {
+ fprintf(stdout, "%s\n", srclist [i]);
fflush(stdout);
exit(EXIT_SUCCESS); /* leave r.proj after listing */
@@ -317,6 +327,12 @@
if (pj_get_kv(&iproj, in_proj_info, in_unit_info) < 0)
G_fatal_error(_("Unable to get projection key values of input map"));
+ tproj.def = NULL;
+#ifdef HAVE_PROJ_H
+ if (pipeline->answer) {
+ tproj.def = G_store(pipeline->answer);
+#endif
if (GPJ_init_transform(&iproj, &oproj, &tproj) < 0)
G_fatal_error(_("Unable to initialize coordinate transformation"));
