[GRASS-SVN] r72626 - in grass/trunk/gui/wxpython: core dbmgr gui_core iclass
svn_grass at osgeo.org
Tue Apr 17 08:00:24 PDT 2018
Author: annakrat
Date: 2018-04-17 08:00:24 -0700 (Tue, 17 Apr 2018)
New Revision: 72626
grass/trunk/gui/wxpython/core/gthread.py
grass/trunk/gui/wxpython/dbmgr/base.py
grass/trunk/gui/wxpython/gui_core/gselect.py
grass/trunk/gui/wxpython/gui_core/widgets.py
grass/trunk/gui/wxpython/iclass/digit.py
grass/trunk/gui/wxpython/iclass/frame.py
wxGUI: fix d.vect dialog when loading layer without db connection, caused by r72547
Modified: grass/trunk/gui/wxpython/core/gthread.py
--- grass/trunk/gui/wxpython/core/gthread.py 2018-04-17 14:30:38 UTC (rev 72625)
+++ grass/trunk/gui/wxpython/core/gthread.py 2018-04-17 15:00:24 UTC (rev 72626)
@@ -22,6 +22,7 @@
import Queue
from core.gconsole import EVT_CMD_DONE, wxCmdDone
+from core.gcmd import DecodeString
class gThread(threading.Thread, wx.EvtHandler):
Modified: grass/trunk/gui/wxpython/dbmgr/base.py
--- grass/trunk/gui/wxpython/dbmgr/base.py 2018-04-17 14:30:38 UTC (rev 72625)
+++ grass/trunk/gui/wxpython/dbmgr/base.py 2018-04-17 15:00:24 UTC (rev 72626)
@@ -251,6 +251,7 @@
for column in columns:
if globalvar.wxPythonPhoenix:
info.Text = column
+ info.SetAlign(wx.LIST_FORMAT_LEFT)
self.InsertColumn(i, info)
else:
info.m_text = column
Modified: grass/trunk/gui/wxpython/gui_core/gselect.py
--- grass/trunk/gui/wxpython/gui_core/gselect.py 2018-04-17 14:30:38 UTC (rev 72625)
+++ grass/trunk/gui/wxpython/gui_core/gselect.py 2018-04-17 15:00:24 UTC (rev 72626)
@@ -1139,7 +1139,7 @@
self.columns.remove(key)
except ValueError:
pass
- except (KeyError, ValueError):
+ except (KeyError, ValueError, GException):
self.columns[:] = []
# update list
Modified: grass/trunk/gui/wxpython/gui_core/widgets.py
--- grass/trunk/gui/wxpython/gui_core/widgets.py 2018-04-17 14:30:38 UTC (rev 72625)
+++ grass/trunk/gui/wxpython/gui_core/widgets.py 2018-04-17 15:00:24 UTC (rev 72626)
@@ -1087,7 +1087,7 @@
self._search.Bind(wx.EVT_TEXT_ENTER, self.OnEnter)
if self._showTip:
- self._searchTip = StaticWrapText(parent=self, id=wx.ID_ANY,
+ self._searchTip = wx.StaticText(parent=self, id=wx.ID_ANY,
label="Choose a module", size=(-1, 35))
if self._showChoice:
@@ -1160,6 +1160,7 @@
label = _("%d modules match") % len(commands)
if self._showTip:
self._searchTip.SetLabel(label)
+ self._searchTip.Wrap(self.GetSize()[0])
self.showNotification.emit(message=label)
@@ -1193,6 +1194,7 @@
for module in self._results:
if cmd == module.data['command']:
self._searchTip.SetLabel(module.data['description'])
break
def Reset(self):
Modified: grass/trunk/gui/wxpython/iclass/digit.py
--- grass/trunk/gui/wxpython/iclass/digit.py 2018-04-17 14:30:38 UTC (rev 72625)
+++ grass/trunk/gui/wxpython/iclass/digit.py 2018-04-17 15:00:24 UTC (rev 72626)
@@ -167,7 +167,9 @@
G_set_verbose(verbose)
ret = Vect_get_num_lines(poMapInfoNew)
+ print os.listdir('/home/anna/grassdata/nc_spm_08_grass7/user1/.tmp/anna-laptop/vector')
Vect_close(poMapInfoNew)
return ret
Modified: grass/trunk/gui/wxpython/iclass/frame.py
--- grass/trunk/gui/wxpython/iclass/frame.py 2018-04-17 14:30:38 UTC (rev 72625)
+++ grass/trunk/gui/wxpython/iclass/frame.py 2018-04-17 15:00:24 UTC (rev 72626)
@@ -624,7 +624,8 @@
return
# copy features to the temporary map
- vname = self._getTempVectorName()
+ #vname = self._getTempVectorName()
+ vname = self.trainingAreaVector
# avoid deleting temporary map
os.environ['GRASS_VECTOR_TEMPORARY'] = '1'
if digitClass.CopyMap(vname, tmp=True) == -1:
