[GRASS-SVN] r72630 - grass-addons/grass7/imagery/i.segment.uspo
svn_grass at osgeo.org
Wed Apr 18 00:10:59 PDT 2018
Author: mlennert
Date: 2018-04-18 00:10:58 -0700 (Wed, 18 Apr 2018)
New Revision: 72630
grass-addons/grass7/imagery/i.segment.uspo/i.segment.uspo.py
i.segment.uspo: allow use of seeds and ignore segmentations which lead to only one single segment
Modified: grass-addons/grass7/imagery/i.segment.uspo/i.segment.uspo.py
--- grass-addons/grass7/imagery/i.segment.uspo/i.segment.uspo.py 2018-04-17 15:11:31 UTC (rev 72629)
+++ grass-addons/grass7/imagery/i.segment.uspo/i.segment.uspo.py 2018-04-18 07:10:58 UTC (rev 72630)
@@ -48,6 +48,12 @@
#% required : no
#%end
+#%option G_OPT_R_MAP
+#% key: seeds
+#% description: Seeds for segmentation
+#% required : no
+#%end
#%option G_OPT_F_OUTPUT
#% description: Name for output file (- for standard output)
#% required : no
@@ -364,22 +370,25 @@
try:
for threshold, minsize in iter(parameter_queue.get, 'STOP'):
mapname = rg_non_hierarchical_seg(parms, threshold, minsize)
- variance_per_raster = []
- autocor_per_raster = []
- neighbordict = get_nb_matrix(mapname)
- for raster in parms['rasters']:
- # there seems to be some trouble in ms windows with qualified
- # map names
- raster = raster.split('@')[0]
- var = get_variance(mapname, raster)
- variance_per_raster.append(var)
- autocor = get_autocorrelation(mapname, raster,
- neighbordict, parms['indicator'])
- autocor_per_raster.append(autocor)
+ numsegments = len(gscript.read_command('r.category',
+ map_=mapname).splitlines())
+ if numsegments > 1:
+ variance_per_raster = []
+ autocor_per_raster = []
+ neighbordict = get_nb_matrix(mapname)
+ for raster in parms['rasters']:
+ # there seems to be some trouble in ms windows with qualified
+ # map names
+ raster = raster.split('@')[0]
+ var = get_variance(mapname, raster)
+ variance_per_raster.append(var)
+ autocor = get_autocorrelation(mapname, raster,
+ neighbordict, parms['indicator'])
+ autocor_per_raster.append(autocor)
- mean_lv = sum(variance_per_raster) / len(variance_per_raster)
- mean_autocor = sum(autocor_per_raster) / len(autocor_per_raster)
- result_queue.put([mapname, mean_lv, mean_autocor, threshold, minsize])
+ mean_lv = sum(variance_per_raster) / len(variance_per_raster)
+ mean_autocor = sum(autocor_per_raster) / len(autocor_per_raster)
+ result_queue.put([mapname, mean_lv, mean_autocor, threshold, minsize])
except:
result_queue.put(["%s: %s_%f_%d failed" % (current_process().name,
@@ -429,14 +438,25 @@
temp_segment_map_thresh = parms['temp_segment_map'] + "__%s" % parms['region']
temp_segment_map_thresh += "__%.4f" % threshold
temp_segment_map_thresh += "__%d" % minsize
- gscript.run_command('i.segment',
- group=parms['group'],
- threshold=threshold,
- minsize=minsize,
- output=temp_segment_map_thresh,
- memory=parms['memory'],
- quiet=True,
- overwrite=True)
+ if parms['seeds']:
+ gscript.run_command('i.segment',
+ group=parms['group'],
+ threshold=threshold,
+ minsize=minsize,
+ seeds=parms['seeds'],
+ output=temp_segment_map_thresh,
+ memory=parms['memory'],
+ quiet=True,
+ overwrite=True)
+ else:
+ minsize=minsize,
+ quiet=True,
+ overwrite=True)
return temp_segment_map_thresh
@@ -674,6 +694,9 @@
rg = False
if method == 'region_growing':
rg = True
+ parms['seeds'] = False
+ if options['seeds']:
+ parms['seeds'] = options['seeds']
output = False
if options['output']:
output = options['output']
