[GRASS-SVN] r72639 - in grass-addons/grass7/vector: . v.gsflow.mapdata
svn_grass at osgeo.org
Sun Apr 22 08:56:18 PDT 2018
Author: awickert
Date: 2018-04-22 08:56:18 -0700 (Sun, 22 Apr 2018)
New Revision: 72639
Added:
grass-addons/grass7/vector/v.gsflow.mapdata/
grass-addons/grass7/vector/v.gsflow.mapdata/Makefile
grass-addons/grass7/vector/v.gsflow.mapdata/v.gsflow.mapdata.html
grass-addons/grass7/vector/v.gsflow.mapdata/v.gsflow.mapdata.py
v.gsflow.mapdata: Generalized interface to attach raster/vector data sources
to GSFLOW data structures (HRU, gravres, MODFLOW grid, segment, reach)
Added: grass-addons/grass7/vector/v.gsflow.mapdata/Makefile
--- grass-addons/grass7/vector/v.gsflow.mapdata/Makefile (rev 0)
+++ grass-addons/grass7/vector/v.gsflow.mapdata/Makefile 2018-04-22 15:56:18 UTC (rev 72639)
@@ -0,0 +1,8 @@
+MODULE_TOPDIR = ../..
+PGM = v.gsflow.mapdata
+include $(MODULE_TOPDIR)/include/Make/Script.make
+default: script
Added: grass-addons/grass7/vector/v.gsflow.mapdata/v.gsflow.mapdata.html
--- grass-addons/grass7/vector/v.gsflow.mapdata/v.gsflow.mapdata.html (rev 0)
+++ grass-addons/grass7/vector/v.gsflow.mapdata/v.gsflow.mapdata.html 2018-04-22 15:56:18 UTC (rev 72639)
@@ -0,0 +1,29 @@
+<h2>DESCRIPTION</h2>
+<em>v.gsflow.mapdata</em> allows the user to add attributes from any raster or vector (area or point) data set to a GSFLOW set of HRUs, MODFLOW grid cells, gravity reservoirs, stream segments, or stream reaches. It does so by using either an averaging or a nearest-neighbor approach, depending on the type of both the data source geometry (raster, vector area, vector point) and, if it is a vector, the data source in the column (integer, string (varchar), or float (double precision)).<br>
+Nearest-neighbor (<a href="v.distance">v.distance</a>,) is used for:<br>
+Vector point data<br>
+Vector area data in which the data type in the column that is queried is integer or varchar<br>
+An average (<a href="v.rast.stats">v.rast.stats</a>,) is used for:<br>
+Raster data<br>
+Vector area data with data in the column that is queried that is of "double precision" type<br>
+<h2>AUTHORS</h2>
+Andrew D. Wickert<br>
+<h2>SEE ALSO</h2>
+<a href="v.gsflow.export">v.gsflow.export</a>,
+<a href="v.gsflow.gravres">v.gsflow.gravres</a>,
+<a href="v.gsflow.grid">v.gsflow.grid</a>,
+<a href="v.gsflow.hruparams">v.gsflow.hruparams</a>,
+<a href="v.gsflow.reaches">v.gsflow.reaches</a>,
+<a href="v.gsflow.segments">v.gsflow.segments</a>,
+<a href="v.gsflow.mapdata">v.gsflow.mapdata</a>
+<a href="r.gsflow.hydrodem">r.gsflow.hydrodem</a>,
+<a href="v.stream.inbasin">v.stream.inbasin</a>,
+<a href="v.stream.network">v.stream.network</a>,
+<p><i>Last changed: $Date 2018-04-22$</i>
Added: grass-addons/grass7/vector/v.gsflow.mapdata/v.gsflow.mapdata.py
--- grass-addons/grass7/vector/v.gsflow.mapdata/v.gsflow.mapdata.py (rev 0)
+++ grass-addons/grass7/vector/v.gsflow.mapdata/v.gsflow.mapdata.py 2018-04-22 15:56:18 UTC (rev 72639)
@@ -0,0 +1,221 @@
+#!/usr/bin/env python
+# MODULE: v.gsflow.mapdata
+# AUTHOR(S): Andrew Wickert
+# PURPOSE: Generalized interface for data import into GSFLOW data
+# structures: HRUs, MODFLOW grid cells, gravity reservoirs,
+# segments, and reaches.
+# COPYRIGHT: (c) 2018 Andrew Wickert
+# This program is free software under the GNU General Public
+# License (>=v2). Read the file COPYING that comes with GRASS
+# for details.
+# REQUIREMENTS:
+# - uses inputs from r.stream.extract
+# More information
+# Started December 2016
+#%module
+#% description: Upload data to PRMS data
+#% keyword: vector
+#% keyword: import
+#% keyword: hydrology
+#% keyword: GSFLOW
+#%end
+#%option G_OPT_V_INPUT
+#% key: map
+#% label: GSFLOW vect: HRUs, MODFLOW grid, gravres, segments, or reaches
+#% required: yes
+#% guidependency: layer,column
+#%end
+#% key: vector_area
+#% label: Input vector area (polygon) data set (e.g., geologic map)
+#% required: no
+#%end
+#% key: vector_points
+#% label: Input vector points data set (e.g., field surveys at points)
+#% required: no
+#%end
+#%option G_OPT_R_INPUT
+#% key: raster
+#% label: Input raster gridded data set (e.g., gridded soils data)
+#% required: no
+#%end
+#%option
+#% key: dxy
+#% type: string
+#% description: Cell size for rasterization of vector_area, if needed
+#% answer: 100
+#% required: no
+#%end
+#%option
+#% key: column
+#% type: string
+#% description: Column to which to upload data (will create if doesn't exist)
+#% required: no
+#%end
+#%option
+#% key: from_column
+#% type: string
+#% description: Column from which to upload data (for vector input)
+#% required: no
+#%end
+#%option
+#% key: attrtype
+#% type: string
+#% description: Data type in column; user may treat int as float
+#% options: int,float,string
+#% required: no
+#%end
+#%rules
+#% exclusive: vector_area, vector_points, raster
+#% requires: vector_area, column, from_column, attrtype
+#% requires: vector_points, column, from_column, attrtype
+#%end
+# IMPORT MODULES #
+# PYTHON
+import numpy as np
+# GRASS
+from grass.pygrass.modules.shortcuts import general as g
+from grass.pygrass.modules.shortcuts import raster as r
+from grass.pygrass.modules.shortcuts import vector as v
+from grass.pygrass.modules.shortcuts import miscellaneous as m
+from grass.pygrass.gis import region
+from grass.pygrass import vector # Change to "v"?
+from grass.script import vector_db_select
+from grass.pygrass.vector import Vector, VectorTopo
+from grass.pygrass.raster import RasterRow
+from grass.pygrass import utils
+from grass import script as gscript
+# MAIN MODULE #
+def main():
+ Import any raster or vector data set and add its attribute
+ to a GSFLOW data object
+ # OPTION PARSING #
+ options, flags = gscript.parser()
+ # Parsing
+ if options['attrtype'] == 'int':
+ attrtype = 'integer'
+ elif options['attrtype'] == 'float':
+ attrtype = 'double precision'
+ elif options['attrtype'] == 'string':
+ attrtype = 'varchar'
+ else:
+ attrtype = ''
+ # PROCESS AND UPLOAD TO DATABASE TABLE #
+ if options['vector_area'] is not '':
+ gscript.use_temp_region()
+ g.region(vector=options['map'], res=options['dxy'])
+ v.to_rast(input=options['vector_area'], output='tmp___tmp',
+ use='attr', attribute_column=options['from_column'],
+ quiet=True, overwrite=True)
+ try:
+ gscript.message("Checking for existing column to overwrite")
+ v.db_dropcolumn(map=options['map'],
+ columns=options['column'],
+ quiet=True)
+ except:
+ pass
+ if attrtype is 'double precision':
+ try:
+ columns='tmp_average',
+ quiet=True)
+ except:
+ pass
+ v.rast_stats(map=options['map'], raster='tmp___tmp',
+ column_prefix='tmp', method='average', flags='c',
+ quiet=True)
+ g.remove(type='raster', name='tmp___tmp', flags='f', quiet=True)
+ v.db_renamecolumn(map=options['map'],
+ column=['tmp_average',options['column']],
+ quiet=True)
+ else:
+ try:
+ v.db_addcolumn(map=options['map'],
+ columns=options['column']+' '+attrtype,
+ quiet=True)
+ except:
+ pass
+ gscript.run_command('v.distance', from_=options['map'],
+ to=options['vector_area'],
+ upload='to_attr',
+ to_column=options['from_column'],
+ column=options['column'], quiet=True)
+ elif options['vector_points'] is not '':
+ try:
+ columns = options['column'],
+ quiet=True)
+ quiet=True)
+ except:
+ pass
+ to=options['vector_points'],
+ upload='to_attr', to_column=options['from_column'],
+ elif options['raster'] is not '':
+ try:
+ quiet=True)
+ except:
+ pass
+ v.rast_stats(map=options['map'], raster=options['raster'],
+ quiet=True)
+ column=['tmp_average',options['column']], quiet=True)
+ gscript.message("Done.")
+if __name__ == "__main__":
+ main()
