[GRASS-SVN] r72643 - in grass-addons/grass7/vector: . v.stream.profiler
Sun Apr 22 09:22:52 PDT 2018
Author: awickert
Date: 2018-04-22 09:22:52 -0700 (Sun, 22 Apr 2018)
New Revision: 72643
Added:
   grass-addons/grass7/vector/v.stream.profiler/
   grass-addons/grass7/vector/v.stream.profiler/Makefile
   grass-addons/grass7/vector/v.stream.profiler/v.stream.profiler.html
   grass-addons/grass7/vector/v.stream.profiler/v.stream.profiler.py
v.stream.profiler:
Build long profiles and slope--accumulation diagrams of a river network
Currently just works in a single-channel downstream-directed way
Added: grass-addons/grass7/vector/v.stream.profiler/Makefile
--- grass-addons/grass7/vector/v.stream.profiler/Makefile	                        (rev 0)
+++ grass-addons/grass7/vector/v.stream.profiler/Makefile	2018-04-22 16:22:52 UTC (rev 72643)
@@ -0,0 +1,8 @@
+MODULE_TOPDIR = /usr/local/grass-7.3.svn
+PGM = v.stream.profiler
+include $(MODULE_TOPDIR)/include/Make/Script.make
+default: script
Added: grass-addons/grass7/vector/v.stream.profiler/v.stream.profiler.html
--- grass-addons/grass7/vector/v.stream.profiler/v.stream.profiler.html	                        (rev 0)
+++ grass-addons/grass7/vector/v.stream.profiler/v.stream.profiler.html	2018-04-22 16:22:52 UTC (rev 72643)
@@ -0,0 +1,21 @@
+<h2>DESCRIPTION</h2>
+<em>v.stream.profiler</em> builds and exports plots and data sets of river long profiles, slope-accumulation (e.g., slope-area), and more for topographic analysis. It currently works only in a downstream-directed walk, for a single channel, from the chosen segment until the downstream-most point in the network.
+It takes in the adjacency structure supplied by <a href="v.stream.network">v.stream.network</a>.
+<h2>SEE ALSO</h2>
+<em>
+<a href="v.stream.network">v.stream.network</a>
+</em>
+<h2>REFERENCES</h2>
+None (yet)
+<h2>AUTHORS</h2>
+Andrew D. Wickert<br>
+<p><i>Last changed: $Date 2018-04-22$</i>
Added: grass-addons/grass7/vector/v.stream.profiler/v.stream.profiler.py
--- grass-addons/grass7/vector/v.stream.profiler/v.stream.profiler.py	                        (rev 0)
+++ grass-addons/grass7/vector/v.stream.profiler/v.stream.profiler.py	2018-04-22 16:22:52 UTC (rev 72643)
@@ -0,0 +1,376 @@
+#!/usr/bin/env python
+# MODULE:       v.stream.profiler
+# AUTHOR(S):    Andrew Wickert
+# PURPOSE:      Build long profiles and slope--area diagrams of a river network
+# COPYRIGHT:    (c) 2016-2018 Andrew Wickert
+#               This program is free software under the GNU General Public
+#               License (>=v2). Read the file COPYING that comes with GRASS
+#               for details.
+# REQUIREMENTS:
+#      -  uses inputs from r.stream.extract
+# More information
+# Started 14 October 2016
+#%module
+#% description: Build a linked stream network: each link knows its downstream link
+#% keyword: vector
+#% keyword: stream network
+#% keyword: hydrology
+#% keyword: geomorphology
+#%end
+#%option
+#%  key: cat
+#%  label: Starting line segment category
+#%  required: yes
+#%  guidependency: layer,column
+#%end
+#%option G_OPT_V_INPUT
+#%  key: streams
+#%  label: Vector input of stream network created by r.stream.extract
+#%  required: yes
+#%end
+#%option G_OPT_V_OUTPUT
+#%  key: outstream
+#%  label: Vector output stream
+#%  required: no
+#%end
+#%option
+#%  key: direction
+#%  type: string
+#%  label: Which directon to march: up or down
+#%  options: upstream,downstream
+#%  answer: downstream
+#%  required: no
+#%end
+#%option G_OPT_R_INPUT
+#%  key: elevation
+#%  label: Topography (DEM)
+#%  required: no
+#%end
+#%  key: accumulation
+#%  label: Flow accumulation raster
+#%  required: no
+#%end
+#%  key: slope
+#%  label: Map of slope created by r.slope.area
+#%  required: no
+#%end
+#%option
+#%  key: units
+#%  type: string
+#%  label: Flow accumulation units
+#%  options: m2, km2, cumecs, cfs
+#%  required: no
+#%end
+#%option
+#%  key: accum_mult
+#%  type: double
+#%  label: Multiplier to convert flow accumulation to your chosen unit
+#%  answer: 1
+#%  required: no
+#%end
+#%  key: window
+#%  label: Averaging distance [map units]
+#%  required: no
+#%end
+#%option
+#%  key: plots
+#%  type: string
+#%  label: Plots to generate
+#%  options: LongProfile,SlopeAccum,SlopeDistance,AccumDistance
+#%  required: no
+#%  multiple: yes
+#%end
+#%option
+#%  key: outfile_original
+#%  type: string
+#%  label: output file for data on original grid
+#%  required: no
+#%end
+#%option
+#%  key: outfile_smoothed
+#%  type: string
+#%  label: output file for data on smoothed grid
+#%  required: no
+#%end
+# IMPORT MODULES #
+# PYTHON
+import numpy as np
+from matplotlib import pyplot as plt
+import sys
+# GRASS
+from grass.pygrass.modules.shortcuts import general as g
+from grass.pygrass.modules.shortcuts import raster as r
+from grass.pygrass.modules.shortcuts import vector as v
+from grass.pygrass.gis import region
+from grass.pygrass import vector # Change to "v"?
+from grass.script import vector_db_select
+from grass.pygrass.vector import Vector, VectorTopo
+from grass.pygrass.raster import RasterRow
+from grass.pygrass import utils
+from grass import script as gscript
+from grass.pygrass.vector.geometry import Point
+# UTILITY MODULES #
+def moving_average(x, y, window):
+    Create a moving average every <window/2> points with an averaging
+    distance of <window>, but including the the first point + window/2
+    and the last point - window/2
+    (so distance to last point could be irregular)
+    x = np.array(x)
+    y = np.array(y)
+    out_x = np.arange(x[0]+window/2., x[-1]-window/2., window)
+    out_x = np.hstack((out_x, x[-1]-window/2.))
+    out_y = []
+    for _x in out_x:
+        out_y.append( np.mean(y[ (x < _x + window/2.) *
+                                 (x > _x - window/2.) ]))
+    return out_x, out_y
+# MAIN MODULE #
+def main():
+    Links each river segment to the next downstream segment in a tributary
+    network by referencing its category (cat) number in a new column. "0"
+    means that the river exits the map.
+    options, flags = gscript.parser()
+    # Parsing
+    window = float(options['window'])
+    accum_mult = float(options['accum_mult'])
+    if options['units'] == 'm2':
+        accum_label = 'Drainage area [m$^2$]'
+    elif options['units'] == 'km2':
+        accum_label = 'Drainage area [km$^2$]'
+    elif options['units'] == 'cumecs':
+        accum_label = 'Water discharge [m$^3$ s$^{-1}$]'
+    elif options['units'] == 'cfs':
+        accum_label = 'Water discharge [cfs]'
+    else:
+        accum_label = 'Flow accumulation [$-$]'
+    plots = options['plots'].split(',')
+    # Attributes of streams
+    colNames = np.array(vector_db_select(options['streams'])['columns'])
+    colValues = np.array(vector_db_select(options['streams'])['values'].values())
+    tostream = colValues[:,colNames == 'tostream'].astype(int).squeeze()
+    cats = colValues[:,colNames == 'cat'].astype(int).squeeze() # = "fromstream"
+    # We can loop over this list to get the shape of the full river network.
+    selected_cats = []
+    segment = int(options['cat'])
+    selected_cats.append(segment)
+    x = []
+    z = []
+    if options['direction'] == 'downstream':
+        # Get network
+        gscript.message("Network")
+        while selected_cats[-1] != 0:
+            selected_cats.append(int(tostream[cats == selected_cats[-1]]))
+        x.append(selected_cats[-1])
+        selected_cats = selected_cats[:-1] # remove 0 at end
+        # Extract x points in network
+        data = vector.VectorTopo(options['streams']) # Create a VectorTopo object
+        data.open('r') # Open this object for reading
+        coords = []
+        _i = 0
+        for i in range(len(data)):
+            if type(data.read(i+1)) is vector.geometry.Line:
+                if data.read(i+1).cat in selected_cats:
+                    coords.append(data.read(i+1).to_array())
+                    gscript.core.percent(_i, len(selected_cats), 100./len(selected_cats))
+                    _i += 1
+        gscript.core.percent(1, 1, 1)
+        coords = np.vstack(np.array(coords))
+        _dx = np.diff(coords[:,0])
+        _dy = np.diff(coords[:,1])
+        x_downstream_0 = np.hstack((0, np.cumsum((_dx**2 + _dy**2)**.5)))
+        x_downstream = x_downstream_0.copy()
+    elif options['direction'] == 'upstream':
+        #terminalCATS = list(options['cat'])
+        #while terminalCATS:
+        print "Upstream direction not yet active!"
+        return
+        # Add new lists for each successive upstream river
+        river_is_upstream =
+        while
+        full_river_cats
+    # Network extraction
+    if options['outstream'] is not '':
+        selected_cats_str = list(np.array(selected_cats).astype(str))
+        selected_cats_csv = ','.join(selected_cats_str)
+        v.extract( input=options['streams'], output=options['outstream'], \
+                   cats=selected_cats_csv, overwrite=gscript.overwrite() )
+    # Analysis
+    gscript.message("Elevation")
+    if options['elevation']:
+        _include_z = True
+        DEM = RasterRow(options['elevation'])
+        DEM.open('r')
+        z = []
+        _i = 0
+        _lasti = 0
+        for row in coords:
+            z.append(DEM.get_value(Point(row[0], row[1])))
+            if float(_i)/len(coords) > float(_lasti)/len(coords):
+                gscript.core.percent(_i, len(coords), np.floor(_i - _lasti))
+            _lasti = _i
+            _i += 1
+        DEM.close()
+        z = np.array(z)
+        if options['window'] is not '':
+            x_downstream, z = moving_average(x_downstream_0, z, window)
+    else:
+        _include_z = False
+    gscript.message("Slope")
+    if options['slope']:
+        _include_S = True
+        slope = RasterRow(options['slope'])
+        slope.open('r')
+        S = []
+        _i = 0
+        _lasti = 0
+            S.append(slope.get_value(Point(row[0], row[1])))
+            _lasti = _i
+            _i += 1
+        slope.close()
+        S = np.array(S)
+        S_0 = S.copy()
+            x_downstream, S = moving_average(x_downstream_0, S, window)
+    else:
+        _include_S = False
+    gscript.message("Accumulation")
+    if options['accumulation']:
+        _include_A = True
+        accumulation = RasterRow(options['accumulation'])
+        accumulation.open('r')
+        A = []
+        _i = 0
+        _lasti = 0
+            A.append(accumulation.get_value(Point(row[0], row[1])) * accum_mult)
+            _lasti = _i
+            _i += 1
+        accumulation.close()
+        A = np.array(A)
+        A_0 = A.copy()
+            x_downstream, A = moving_average(x_downstream_0, A, window)
+    else:
+        _include_A = False
+    # Plotting
+    if 'LongProfile' in plots:
+        plt.figure()
+        plt.plot(x_downstream/1000., z, 'k-', linewidth=2)
+        plt.xlabel('Distance downstream [km]', fontsize=16)
+        plt.ylabel('Elevation [m]', fontsize=20)
+        plt.tight_layout()
+    if 'SlopeAccum' in plots:
+        plt.figure()
+        plt.loglog(A, S, 'ko', linewidth=2)
+        plt.xlabel(accum_label, fontsize=20)
+        plt.ylabel('Slope [$-$]', fontsize=20)
+    if 'SlopeDistance' in plots:
+        plt.figure()
+        plt.plot(x_downstream/1000., S, 'k-', linewidth=2)
+    if 'AccumDistance' in plots:
+        plt.figure()
+        plt.plot(x_downstream/1000., A, 'k-', linewidth=2)
+        plt.ylabel(accum_label, fontsize=20)
+    plt.show()
+    # Saving data
+    if options['outfile_original'] is not '':
+        header = ['x_downstream', 'E', 'N']
+        outfile = np.hstack((np.expand_dims(x_downstream_0, axis=1), coords))
+        if _include_S:
+            header.append('slope')
+            outfile = np.hstack((outfile, np.expand_dims(S_0, axis=1)))
+        if _include_A:
+            if (options['units'] == 'm2') or (options['units'] == 'km2'):
+                header.append('drainage_area_'+options['units'])
+            elif (options['units'] == 'cumecs') or (options['units'] == 'cfs'):
+                header.append('water_discharge_'+options['units'])
+            else:
+                header.append('flow_accumulation_arbitrary_units')
+            outfile = np.hstack((outfile, np.expand_dims(A_0, axis=1)))
+        header = np.array(header)
+        outfile = np.vstack((header, outfile))
+        np.savetxt(options['outfile_original'], outfile, '%s')
+    if options['outfile_smoothed'] is not '':
+        # E, N on smoothed grid
+        x_downstream, E = moving_average(x_downstream_0, coords[:,0], window)
+        x_downstream, N = moving_average(x_downstream_0, coords[:,1], window)
+        # Back to output
+        outfile = np.hstack((np.expand_dims(x_downstream, axis=1),
+                             np.expand_dims(E, axis=1),
+                             np.expand_dims(N, axis=1)))
+        if _include_S:
+            outfile = np.hstack((outfile, np.expand_dims(S, axis=1)))
+        if _include_A:
+            else:
+            outfile = np.hstack((outfile, np.expand_dims(A, axis=1)))
+        np.savetxt(options['outfile_smoothed'], outfile, '%s')
+if __name__ == "__main__":
+    main()
