[GRASS-SVN] r72653 - grass/trunk/raster/r.slope.aspect
svn_grass at osgeo.org
Sun Apr 29 07:19:55 PDT 2018
Author: mmetz
Date: 2018-04-29 07:19:55 -0700 (Sun, 29 Apr 2018)
New Revision: 72653
grass/trunk/raster/r.slope.aspect/main.c
grass/trunk/raster/r.slope.aspect/r.slope.aspect.html
r.slope.aspect: new -e flag to compute values at edges (like gdaldem -compute_edges), fix for #2526
Modified: grass/trunk/raster/r.slope.aspect/main.c
--- grass/trunk/raster/r.slope.aspect/main.c 2018-04-27 10:20:55 UTC (rev 72652)
+++ grass/trunk/raster/r.slope.aspect/main.c 2018-04-29 14:19:55 UTC (rev 72653)
@@ -87,7 +87,8 @@
int dyy_fd;
int dxy_fd;
DCELL *elev_cell[3], *temp;
- DCELL *c1, *c2, *c3, *c4, *c5, *c6, *c7, *c8, *c9;
+ DCELL *pc1, *pc2, *pc3;
+ DCELL c1, c2, c3, c4, c5, c6, c7, c8, c9;
DCELL tmp1, tmp2;
FCELL dat1, dat2;
CELL cat;
@@ -158,8 +159,9 @@
} parm;
struct
- struct Flag *a, *n;
+ struct Flag *a, *n, *e;
} flag;
+ int compute_at_edges;
G_gisinit(argv[0]);
@@ -277,6 +279,12 @@
_("Do not align the current region to the raster elevation map");
flag.a->guisection = _("Settings");
+ flag.e = G_define_flag();
+ flag.e->key = 'e';
+ flag.e->description =
+ _("Compute output at edges and near NULL values");
+ flag.e->guisection = _("Settings");
flag.n = G_define_flag();
flag.n->key = 'n';
flag.n->label =
@@ -292,6 +300,8 @@
radians_to_degrees = 180.0 / M_PI;
degrees_to_radians = M_PI / 180.0;
+ compute_at_edges = flag.e->answer;
/* INC BY ONE
answer[0] = 0.0;
answer[91] = 15000.0;
@@ -609,15 +619,9 @@
else
Rast_get_d_row_nomask(elevation_fd, elev_cell[2], row);
- c1 = elev_cell[0];
- c2 = c1 + 1;
- c3 = c1 + 2;
- c4 = elev_cell[1];
- c5 = c4 + 1;
- c6 = c4 + 2;
- c7 = elev_cell[2];
- c8 = c7 + 1;
- c9 = c7 + 2;
+ pc1 = elev_cell[0];
+ pc2 = elev_cell[1];
+ pc3 = elev_cell[2];
if (aspect_fd >= 0) {
if (Wrap)
@@ -691,18 +695,26 @@
/*skip first cell of the row */
- for (col = ncols - 2; col-- > 0;
- c1++, c2++, c3++, c4++, c5++, c6++, c7++, c8++, c9++) {
+ for (col = ncols - 2; col-- > 0; pc1++, pc2++, pc3++) {
+ c1 = *pc1;
+ c2 = *(pc1 + 1);
+ c3 = *(pc1 + 2);
+ c4 = *pc2;
+ c5 = *(pc2 + 1);
+ c6 = *(pc2 + 2);
+ c7 = *pc3;
+ c8 = *(pc3 + 1);
+ c9 = *(pc3 + 2);
/* DEBUG:
fprintf(stdout, "\n%.0f %.0f %.0f\n%.0f %.0f %.0f\n%.0f %.0f %.0f\n",
- *c1, *c2, *c3, *c4, *c5, *c6, *c7, *c8, *c9);
+ c1, c2, c3, c4, c5, c6, c7, c8, c9);
- if (Rast_is_d_null_value(c1) || Rast_is_d_null_value(c2) ||
- Rast_is_d_null_value(c3) || Rast_is_d_null_value(c4) ||
- Rast_is_d_null_value(c5) || Rast_is_d_null_value(c6) ||
- Rast_is_d_null_value(c7) || Rast_is_d_null_value(c8) ||
- Rast_is_d_null_value(c9)) {
+ if (Rast_is_d_null_value(&c5) || (!compute_at_edges &&
+ (Rast_is_d_null_value(&c1) || Rast_is_d_null_value(&c2) ||
+ Rast_is_d_null_value(&c3) || Rast_is_d_null_value(&c4) ||
+ Rast_is_d_null_value(&c6) || Rast_is_d_null_value(&c7) ||
+ Rast_is_d_null_value(&c8) || Rast_is_d_null_value(&c9)))) {
if (slope_fd > 0) {
Rast_set_null_value(slp_ptr, 1, data_type);
slp_ptr =
@@ -751,9 +763,29 @@
continue;
} /* no data */
- dx = ((*c1 + *c4 + *c4 + *c7) - (*c3 + *c6 + *c6 + *c9)) / H;
- dy = ((*c7 + *c8 + *c8 + *c9) - (*c1 + *c2 + *c2 + *c3)) / V;
+ if (compute_at_edges) {
+ /* same method like ComputeVal in gdaldem_lib.cpp */
+ if (Rast_is_d_null_value(&c1))
+ c1 = c5;
+ if (Rast_is_d_null_value(&c2))
+ c2 = c5;
+ if (Rast_is_d_null_value(&c3))
+ c3 = c5;
+ if (Rast_is_d_null_value(&c4))
+ c4 = c5;
+ if (Rast_is_d_null_value(&c6))
+ c6 = c5;
+ if (Rast_is_d_null_value(&c7))
+ c7 = c5;
+ if (Rast_is_d_null_value(&c8))
+ c8 = c5;
+ if (Rast_is_d_null_value(&c9))
+ c9 = c5;
+ dx = ((c1 + c4 + c4 + c7) - (c3 + c6 + c6 + c9)) / H;
+ dy = ((c7 + c8 + c8 + c9) - (c1 + c2 + c2 + c3)) / V;
/* compute topographic parameters */
key = dx * dx + dy * dy;
slp_in_perc = 100 * sqrt(key);
@@ -875,10 +907,10 @@
continue;
/* compute second order derivatives */
- s4 = *c1 + *c3 + *c7 + *c9 - *c5 * 8.;
- s5 = *c4 * 4. + *c6 * 4. - *c8 * 2. - *c2 * 2.;
- s6 = *c8 * 4. + *c2 * 4. - *c4 * 2. - *c6 * 2.;
- s3 = *c7 - *c9 + *c3 - *c1;
+ s4 = c1 + c3 + c7 + c9 - c5 * 8.;
+ s5 = c4 * 4. + c6 * 4. - c8 * 2. - c2 * 2.;
+ s6 = c8 * 4. + c2 * 4. - c4 * 2. - c6 * 2.;
+ s3 = c7 - c9 + c3 - c1;
dxx = -(s4 + s5) / ((3. / 32.) * H * H);
dyy = -(s4 + s6) / ((3. / 32.) * V * V);
Modified: grass/trunk/raster/r.slope.aspect/r.slope.aspect.html
--- grass/trunk/raster/r.slope.aspect/r.slope.aspect.html 2018-04-27 10:20:55 UTC (rev 72652)
+++ grass/trunk/raster/r.slope.aspect/r.slope.aspect.html 2018-04-29 14:19:55 UTC (rev 72653)
@@ -160,10 +160,12 @@
<p>
The algorithm used to determine slope and aspect uses a 3x3
-neighborhood around each cell in the raster elevation map. Thus, it is
-not possible to determine slope and aspect for the cells adjacent to
+neighborhood around each cell in the raster elevation map. Thus,
+slope and aspect are not determineed for cells adjacent to
the edges and NULL cells in the elevation map layer. These cells are
-set to nodata in both the slope and aspect raster maps.
+by default set to nodata in output raster maps. With the <b>-e</b> flag,
+output values are estimated for these cells, avoiding cropping along
+the edges.
<p>
Horn's formula is used to find the first order derivatives in x and y directions.
