[GRASS-SVN] r73023 - grass/trunk/imagery/i.atcorr
svn_grass at osgeo.org
Thu Aug 2 00:56:09 PDT 2018
Author: mmetz
Date: 2018-08-02 00:56:09 -0700 (Thu, 02 Aug 2018)
New Revision: 73023
grass/trunk/imagery/i.atcorr/6s.cpp
grass/trunk/imagery/i.atcorr/main.cpp
i.atcorr: add comments and warnings
Modified: grass/trunk/imagery/i.atcorr/6s.cpp
--- grass/trunk/imagery/i.atcorr/6s.cpp 2018-07-31 16:25:24 UTC (rev 73022)
+++ grass/trunk/imagery/i.atcorr/6s.cpp 2018-08-02 07:56:09 UTC (rev 73023)
@@ -106,7 +106,6 @@
return 0;
/* Only update those objects that are affected by a height and vis change */
void pre_compute_hv(const float height, const float vis)
@@ -532,6 +531,10 @@
+ if (seb < accu3)
+ G_warning("compute(): variable seb is too small: %g", seb);
+ if (sb < accu3)
+ G_warning("compute(): variable sb is too small: %g", sb);
/* ---- integrated values of apparent reflectance, radiance ----*/
/* ---- and gaseous transmittances (total,downward,separately gases) ----*/
Modified: grass/trunk/imagery/i.atcorr/main.cpp
--- grass/trunk/imagery/i.atcorr/main.cpp 2018-07-31 16:25:24 UTC (rev 73022)
+++ grass/trunk/imagery/i.atcorr/main.cpp 2018-08-02 07:56:09 UTC (rev 73023)
@@ -54,7 +54,15 @@
* for 10 aerosol optical depths. Here we use finer grain. */
/* TICache: create bins for altitude and visibility */
+/* altitude range: appr. 0 - 9000
+ * bin 10: change between bins is 0.05 - 0.16%
+ * bin 100: change between bins is 0.5 - 1.5%
+ * bin 1000: change between bins is 6 - 13%*/
#define BIN_ALT 10 /* unit is meters */
+/* visibility range: 0 - 50000
+ * bin 10: change between bins is 0.004 - 0.16%
+ * bin 100: change between bins is 0.01 - 1.6%
+ * bin 1000: change between bins is 0.1 - 13%*/
#define BIN_VIS 100 /* unit is meters */
/* uncomment to disable cache usage */
